PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Silver, Gold, or Black?
  2. couple pics of my car at a small local meet...
  3. Electric Fans -- (2) 94 LS 400
  4. 20's, do they have to be specifically designed for the LS?
  5. Front bumper sidemarker on 98-00.
  6. Radio replacement
  7. Anybody here from Kansas city?
  8. Exhaust gasket replacement
  9. 98 vs 99 vs 2000
  10. 98-00 LS400 Foglight Opening....
  11. hood strut prices
  12. Royal Purple is better?
  13. How many here have replaced their stock wheel locks?
  14. strike two...
  15. Pics of an old LS
  16. My genuine Lexus battery died today.
  17. Aftermarket HID + 98LS400 = Doesn't Turn On? Help ?
  18. New Wheels Revealed!
  19. Insulation lining underneath hood.
  20. I can has new seat?
  21. Need help using cassette adapter with 1990 LS400 - keeps ejecting
  22. My car wont reach the normal operating temperature.
  23. What to do with 211K high mileage LS400
  24. Exhaust that sounds like an m5's exhaust in my ls400, is it a possibility?
  25. Snow?? It's almost April!!
  26. Need urgent help, leaking thermostat housing.
  27. Road Trip
  28. 2nd Gen Leather
  29. Finally Got My Muffs!!!! :)
  30. 1998 LS400 number of airbags standard?
  31. Passenger Side Rear Strut Mount
  32. ol skool shootout
  33. Mystery Brake/Turn signal issue
  34. turning off air suspension on 96 ls400....
  35. 95-97 parking lens replacement
  36. Random Oil Light '91
  37. Yellow vs White fog lights
  38. 95 ls400 parts on a 93 ls400
  39. DIY - Tail Light Removal/Installation - DIY
  40. Not locking car causes dead battery
  41. A tale of a broken starter (my Ex '98).....
  42. New Wheels Teaser...
  43. Dead starter rant, 99 LS400
  44. 93 LS 400, 150k miles, won't start - intermittent
  45. Slight gas pedal vibration on 99 LS
  46. 1994 LS 400 - Cost of maintenance
  47. Check Out My Lambolexus (merged)
  48. Once again i'm reminded god hates me and i cannot have anything nice...
  49. Black smoke on startup
  50. 1993 LS 400 Brakes Squeaking..
  51. EGR Delete for LS400
  52. Want more from you LS? Supercharge it!
  53. Looking to buy
  54. Awww poopy. hood latch help needed ASAP
  55. hey club lexus..checking out a ls400..
  56. 18's or 20's
  57. All in One - Power steering fix(s). Solenoid/ACV plug/Drain-Flush/Bleed system. -DIY
  58. Can't get the radio to work. Need help!!
  59. Ls400 dipstick o-ring replacement?
  60. S.S.Back Panel
  61. Question NOT in my thick set of Owner manuals
  62. 99 LS has lateral vibration
  63. Painting Wheel wells -- Paint Type?
  64. LS400 vs LS430
  65. ACV/Idle Control Valve
  66. One step away from buying a '93 LS400, need some advice
  67. How low are you?
  68. Summer Wheels & Tires
  69. Tranny Flush
  70. Chrome, Hyper Black, or Glossy Black?
  71. Will these speakers work?
  72. Question about 90 and 92 grills
  73. Thouroghly disgusted with intake mod! :(
  74. Chrome Post Pillar
  75. Upper Control Arm question...
  76. Metallic sounds - '90 LS
  77. LS 400 90,000 Mile Timing Belt Costs
  78. SIlverstar busted, need new fogs.
  79. Weird problem LS stalls and then revs freely before going into gear
  80. Height Control LS
  81. Power Steering Pump replaced -- Still a problem?
  82. Light Bulb Question...1st Post
  83. Back into an ls
  84. 1990 LS400 2J swap Need help!
  85. should i change the springs or just the shocks/struts?
  86. Airbag suspesion to coil-over struts
  87. AC Compressor #3 on a 90LS
  88. Help..how to replace a catalytic converter and where to buy
  89. Alternator - LS400 1991
  90. Coolant system failure...and many more rants.
  91. REQUEST: 1992 LS A/C Evaporator Valve Part Number
  92. 1998 LS400 strut bars
  93. WTB 1993 Hub Cover - Gold Insignia
  94. Brake pad opinions wanted
  95. How to pull codes on a 96
  96. Hoping for clarification on unlit needle issue
  97. 92 LS400 no power...
  98. How To: Removing the phone from the center armrest console
  99. Please help..95 LS clicking noise with brakes
  100. need help identifyin a part!
  101. Drain/Fill or Flush...transmission fluid?
  102. Seafoam makes engine smoke when poured in gas tank?
  103. 95 LS400 Radio problem
  104. Will This Offset Work On A 95 LS?
  105. Water Wetter. (Where does your temp gauge max at?)
  106. 29.8 Mpg <--- 95ls
  107. Coding a key for early LS 400.
  108. Where is Fuel hose located?
  109. Have you ever used "Motor Flush" when doing an oil change?
  110. looking for a manual transmission.
  111. shorted my cigarette lighter?? please help!!
  112. REAR taillights wont turn ON!!!(but they work when i brake??)
  113. Windshield wipers swipe water very poorly.
  114. LS400 left me stranded for the first time.
  115. Where to buy a clockspring?
  116. fixed some things today
  117. Bodykit q's UCF 10
  118. Instead of JBrady or Lexkost air intake mod.
  119. ls400 engine mounts
  120. Does it matter whether the replacement subwoofer is Free-Air or not?
  121. 93 LS400 Rear Struts
  122. Programming Master Key, 98 LS
  123. update on clunking noise
  124. Hey 19psi check pm box!!!
  125. New shoes for the 1LS
  126. Much more than a Door Ding
  127. Horn replacement question.
  128. Opinions???
  129. Going for a 'sporty' look on the LS 400 --
  130. New toys..
  131. Do you realize how good youve got it.
  132. Post up Recent pixs of YOUR car (LS400s)
  133. knocking noise in rear ls400?
  134. My own key issue - have a master key but can't open......
  135. Ls 400 Switches
  136. Do we have a temperature sensor light?
  137. Drive Belt Pulley may be going south...
  138. Factory Phone
  139. pics of my car :)
  140. My wheel came off
  141. What is necessary? PS.
  142. Just received my clear bumpers today :)
  143. control arm controling me
  144. where to get these accessories...
  145. neeed pics wireing my amp as i write this
  146. Has anyone replace the factory changer in the same exact location?
  147. More MPG, use Regular; More Power, use Premium
  148. Need your help with your Tint jobs -- (Pics for front strip angle).
  149. 18' rims
  150. Cleaned up LS throttle body - Pics
  151. new.....firewall location
  152. Head bulb size
  153. Instrument Cluster fix for 91' ls400
  154. Lexus Burnout on Speed TV
  155. is this a LS400 oem wheel?
  156. Buying New Lug Nuts
  157. K Sport Coilover ?
  158. Any danger to this?????
  159. 2000 Lexus LS400 Turn off Daytime Running Lights
  160. What are the symptoms of worn transmission and engine mounts?
  161. Taking the LS in for paint in an hour.
  162. Air vents stuck on my 90 LS
  163. IIHS crash test pictures
  164. Too lazy to look in the three inch books!!!
  165. mrr hr3
  166. how do u get the whole ash tray out 90 ls400
  167. Not all LS400 the same everywhere !!
  168. Flushed PS fluid and removed solenoid and cleaned filter.
  169. 99 LS400 Tilt Wheel problem
  170. first post: timing belt (???)
  171. knocking noise in rear end of my 94'ls?
  172. 17" rims
  173. Any air suspension expert here?
  174. Code 45 "trac light" on LS400
  175. Battery replacement trigger security
  176. Hard to start 92 LS400
  177. Which bushings for road feel?
  178. 1992, Goodridge SS Lines fitment
  179. finally a couple pics of the LS
  180. want a quick opinion on grillz
  181. Top Gear: 1990 LS 400 vs. 735i vs. 420 SE vs. 4.0 Sov.
  182. ls400 hood
  183. Newbie got a quick question
  184. Guys, is my waterpump leaking?
  185. Two quick pictures taken around New Orleans
  186. Anyone got the hook up on RCR taillights?
  187. 19" On Ls400 1993?
  188. subwoofer replacement help
  189. Blinking flashing Norm Ride height problem air suspension
  190. antilock light....help...
  191. Clear bumper or leave orange.
  192. Can the LS400 tow a 4' x 8' Trailer???
  193. .............................
  194. Factory Air Ride help
  195. 2000 Lexus LS400 Turn off Automatic Steering Wheel Tilt
  196. Lexus 2000 LS400 how to replace and the bulb number
  197. Mechanics will not do the carrier bushings?
  198. Picture Thread
  199. Headlight electrical issue
  200. Plans for Spring road trip
  201. Does anyone here have a spoiler on their LS?
  202. help help ('93 stalling)
  203. The lexus is totaled!!!!!
  204. From my Sea foam, or running rich?
  205. Tensioner moves while car is on...
  206. DIY - Filthy Leather Cleaning for 1st Gen LS400's
  207. Outer Fog light 98-00
  208. An update on my problems
  209. Rebuilding PS Pump.
  210. 98-00 Fog Light Removal....
  211. UV blocking windshield?
  212. how much is my car worth?
  213. Way into Trunk????
  214. RPM activated exhaust cutouts?
  215. LS400 tubular headers installed?
  216. Paint damage - College parking lots suck.
  217. where can I get a suspension parts diagram?
  218. Please help...
  219. Radio/cd player issues 1995 LS00
  220. subwoofer replacement in 90
  221. mystery knob
  222. "Thunk" sound on out of P on incline/decline
  223. Looky what I finally got.....
  224. windshield trim scrape '98
  225. 10mm wheels adaptor
  226. Hesitating at high revs when cold
  227. Pic Request: Lowering Springs on stock wheels
  228. Is the 1998 VSC able to apply brakes if...
  229. 3 Week Review
  230. UCF21: How does your brake pedal feel?
  231. 2nd Gen LS 400 owners-How much did you pay, How many miles, What condition?
  232. My 2ls shakedown ride....800 plus miles
  233. 1st Gen LS400 Owners - How much did you pay, How many miles, What condition?
  234. Front Brakes By Dealer-price?
  235. Will "93 Wheels fit a 2000 LS400?
  236. Magazine articles on ucf 10,20, or 21.
  237. Correct Light Bulb Sizes
  238. New rims for the LS
  239. Sold my 99 LS400
  240. Looks like am back.....Just got this 93 LS400 for $1100cad.....
  241. Tachometer Reading??
  242. Is This your LS400?
  243. Quick question -- Exhaust tips.
  244. First gen 90-94 Aiming Headlights? help.
  245. Painting stock grill semi-flat black on a 95.
  246. How to install front door bezel?
  247. question on dash light auto dim '97
  248. Please Help...Clicking Noise from Engine
  249. SILVERSTAR ULTRA vs. STOCK.......wow
  250. Steering Tilt Problem
