PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 1998 LS400 spark plug: IFR6T11 or IFR6A11 ??
  2. Won't start: clicking noises, erratic gauges
  3. low windshield washer fluid light...
  4. LS400 Exhaust video clip
  5. 91 ls400 suspension help
  6. just some pics
  7. installing mast ?
  8. I need upper intake piping- have one or part#?
  9. LS400 in its new home
  10. Cost of gas beginning to hurt! At wat point would you give her up?
  11. Kool Blue air filter.
  12. Where is the member who had their subframe bolts tightened?
  13. What is the growling/moaning noise when I'm braking?
  14. Battery light on when engine is running '95
  15. Engine System Warning Light is on and the car drives fine
  16. How to replace low beam headlight bulb?
  17. HELP my 96 LS400 rear shocks are dead!
  18. New owner reporting in...'92 LS400 in CA
  19. What is the limiting factor that defines our engine's rpm redline?
  20. antilock trac off lights are on !
  21. Was in Accident LS is out of Commission. Got an Accord
  22. Exhaust tips
  23. How do you replace the Windshield washer Hose on a 98 LS400?
  24. LS400 Projectors
  25. LS400 updates...
  26. 95 LS400 Front and Rear brakes locking up
  27. What is this?
  28. Anybody take the back two mufflers off?
  29. Muffler Tip and Grille suggestions please!!!
  30. w000000tt!!!111 (Update pics inside)
  31. Car is running really BAD...need help (first gen)
  32. locked out
  33. Just Another 1st Gen....Pics!
  34. radiator replacement
  35. part number confirmation for 98 LS400
  36. Pneumatic Cylinder control location???
  37. Question About Changing Camshaft Seals During 90,000 Mile Service
  38. 96 Parking Brake Adjustment
  39. Cant find owners manual, what are the radio unlock steps?
  40. moonroof problems..
  41. Thanks : reference for a good honest independent Lexus Mechanics in Honolulu, Hawaii
  42. Have anyone upgraded their leather seat interiors?
  43. body kits
  44. Weird brake noise! Any help?!
  45. Avoid Costco for Tires-Headaches 1995 ls400
  46. Timing Belt Replacement
  47. Drivers' side seat. Guess whats in the front of it?
  48. Service in Orlando?
  49. Back from the Body Shop & in the dway with 200K
  50. Octane booster: when to add
  51. had to trade in the LS
  52. What brand O2 sensors?
  53. Car rolling slightly in park?
  54. Tracking maintenance through the VIN#
  55. My car sounds old. Is it worth keeping?
  56. Remove/Install P/S pump
  57. Junction Produce UCF10 Celsior // 56k Beware
  58. Brake fluid brand?
  59. Thinkin of getting a second gen this Weekend!!
  60. Was in a Wreck... Have a Few Questions
  61. LS400 Rotors
  62. Things I have to do when driving my LS400 at night.
  63. Wierd suspension creek
  64. Engine bay flasher fuse?
  65. Weird grinding/moaning but only on freeway?
  66. Test fit: 19x10 -7 AME Shallen LX
  67. Test fit: 19x8.5 19x9.5 Zauber Gettins *56k* beware
  68. I Screwed Myself
  69. OMG Fing top L & R turn signal lights
  70. Ls400 moon roof
  71. Is a back plate really necessary? 95 ls400
  72. UCF10/11 Anybody seen this? Factory in dash TV?
  73. Rear Sunshade Question
  74. new steering wheel (SC430) mounted
  75. ordering parts from Carson
  76. LS compared to newer Toyota Camry.
  77. How much do you owe for the LS?
  78. New Member, Just Bought a LS400
  79. 1994 LS400.....bad ECU????
  80. Still drive with spare tire?
  81. noob lexus owner saying hi, but only lasted 2 months.
  82. 2nd battery install......help
  83. Motor mounts changed
  84. Brake Calipers
  85. Some of you may have noticed my absence... (pics inside)
  86. 1LS brake pad compatability
  87. what to do first...
  88. diy eyelids?
  89. Immobilizer
  90. Since youve owned your LS...
  91. Wheel bearing issue (I think)......
  92. Ls 400 1997 Pre Owned, Those Interior Colors?
  93. Intermitten Horn
  94. Suspension issues?
  95. What to Look For
  96. Just purchased a 1990 Lexus LS 400 and have many Questions!
  97. ls 400 or RSX
  98. Cracked lens! 99 LS400 clear bumper light?
  99. Wheels and tires
  100. Hello everyone....
  101. CSV & check engine light
  102. Question on exhaust hardware
  103. Thinking about selling my LS :(
  104. i cant get it off!!!
  105. Anyone running 0W-40 oil?
  106. Strange 99 LS chirping noise when the AC is on
  107. Got bored so i took pics of the LS with a few homies
  108. Divine Intervention In My Ls400?
  109. Clicking noise under gear selector console
  110. Finally got it moving - Thanks guys
  111. Some wheel help for a new owner?
  112. 93-94 center caps interchangeable with 95-97?
  113. how many o2 sensors are on 1990 ls 400
  114. po135 engine check code
  115. Headgasket + Bars
  116. Question about my 93 Ls400... wierd
  117. Weekend Drive! 500miles. Few pics
  118. 93 wierd idle and studdering
  119. I dont want to get booted off but can we list a car here for sale?
  120. I have two LS400's both are 1 owner cars, need help with one
  121. Retrofitting onto UCF10
  122. Radio swap
  123. car shutdown on motorway
  124. 93 ls sunroof help!!!
  125. Injen Intake
  126. ID this part i broke.
  127. Throttle cut off issue...please help!
  128. What Goes LOW!!?? ('97 spring question)
  129. lightning storm under the hood
  130. Parking brake light comes on under braking
  131. the LS got om nom nom'd the other night
  132. Cost to turn 94 rotors
  133. piston rings issue
  134. High or Low Beam?
  135. Leaking windshield!
  136. Thoughts on wheels
  137. Right side blinker!
  138. What tire size and brand are you rolling on?
  139. Red or Pink coolant?
  140. Engine swap 95 LS to 91 LS?
  141. instrument cluster and stock radio
  142. Warped rotors and lousy seats
  143. How to test the rear defroster in AZ?
  144. need help
  145. Disabling the DRLs...gotta be an easy way
  146. p/s help
  147. Front end Blues.
  148. Is octane booster beneficial for the 1UZFE?
  149. Why did Lexus build such a Dependable car?
  150. PLEASE run those carfax reports folks!
  151. Water Pump bad?
  152. Picking up 93 LS400 today (Pics)
  153. LS400 Angel Eyes
  154. 90-92 vs 93-94 Lights.. question.
  155. Adding a second Lexus to the stable - UCF20
  156. Have you done exhaust or intake mods or both?
  157. Silver, Gold, or Black?
  158. couple pics of my car at a small local meet...
  159. Electric Fans -- (2) 94 LS 400
  160. 20's, do they have to be specifically designed for the LS?
  161. Front bumper sidemarker on 98-00.
  162. Radio replacement
  163. Anybody here from Kansas city?
  164. Exhaust gasket replacement
  165. 98 vs 99 vs 2000
  166. 98-00 LS400 Foglight Opening....
  167. hood strut prices
  168. Royal Purple is better?
  169. How many here have replaced their stock wheel locks?
  170. strike two...
  171. Pics of an old LS
  172. My genuine Lexus battery died today.
  173. Aftermarket HID + 98LS400 = Doesn't Turn On? Help ?
  174. New Wheels Revealed!
  175. Insulation lining underneath hood.
  176. I can has new seat?
  177. Need help using cassette adapter with 1990 LS400 - keeps ejecting
  178. My car wont reach the normal operating temperature.
  179. What to do with 211K high mileage LS400
  180. Exhaust that sounds like an m5's exhaust in my ls400, is it a possibility?
  181. Snow?? It's almost April!!
  182. Need urgent help, leaking thermostat housing.
  183. Road Trip
  184. 2nd Gen Leather
  185. Finally Got My Muffs!!!! :)
  186. 1998 LS400 number of airbags standard?
  187. Passenger Side Rear Strut Mount
  188. ol skool shootout
  189. Mystery Brake/Turn signal issue
  190. turning off air suspension on 96 ls400....
  191. 95-97 parking lens replacement
  192. Random Oil Light '91
  193. Yellow vs White fog lights
  194. 95 ls400 parts on a 93 ls400
  195. DIY - Tail Light Removal/Installation - DIY
  196. Not locking car causes dead battery
  197. A tale of a broken starter (my Ex '98).....
  198. New Wheels Teaser...
  199. Dead starter rant, 99 LS400
  200. 93 LS 400, 150k miles, won't start - intermittent
  201. Slight gas pedal vibration on 99 LS
  202. 1994 LS 400 - Cost of maintenance
  203. Check Out My Lambolexus (merged)
  204. Once again i'm reminded god hates me and i cannot have anything nice...
  205. Black smoke on startup
  206. 1993 LS 400 Brakes Squeaking..
  207. EGR Delete for LS400
  208. Want more from you LS? Supercharge it!
  209. Looking to buy
  210. Awww poopy. hood latch help needed ASAP
  211. hey club lexus..checking out a ls400..
  212. 18's or 20's
  213. All in One - Power steering fix(s). Solenoid/ACV plug/Drain-Flush/Bleed system. -DIY
  214. Can't get the radio to work. Need help!!
  215. Ls400 dipstick o-ring replacement?
  216. S.S.Back Panel
  217. Question NOT in my thick set of Owner manuals
  218. 99 LS has lateral vibration
  219. Painting Wheel wells -- Paint Type?
  220. LS400 vs LS430
  221. ACV/Idle Control Valve
  222. One step away from buying a '93 LS400, need some advice
  223. How low are you?
  224. Summer Wheels & Tires
  225. Tranny Flush
  226. Chrome, Hyper Black, or Glossy Black?
  227. Will these speakers work?
  228. Question about 90 and 92 grills
  229. Thouroghly disgusted with intake mod! :(
  230. Chrome Post Pillar
  231. Upper Control Arm question...
  232. Metallic sounds - '90 LS
  233. LS 400 90,000 Mile Timing Belt Costs
  234. SIlverstar busted, need new fogs.
  235. Weird problem LS stalls and then revs freely before going into gear
  236. Height Control LS
  237. Power Steering Pump replaced -- Still a problem?
  238. Light Bulb Question...1st Post
  239. Back into an ls
  240. 1990 LS400 2J swap Need help!
  241. should i change the springs or just the shocks/struts?
  242. Airbag suspesion to coil-over struts
  243. AC Compressor #3 on a 90LS
  244. Help..how to replace a catalytic converter and where to buy
  245. Alternator - LS400 1991
  246. Coolant system failure...and many more rants.
  247. REQUEST: 1992 LS A/C Evaporator Valve Part Number
  248. 1998 LS400 strut bars
  249. WTB 1993 Hub Cover - Gold Insignia
  250. Brake pad opinions wanted
