PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. '99 LS road noise
  2. spark plugs & fuel injector cleaner
  3. 1995 LS400 w/ 250K miles. Good buy?
  4. Valve, vacuum switch
  5. Oil Viscosity?
  6. 1st Gen LS400 Alternator/Garging System
  7. rear lower control arm bushings
  8. bumper lights not working
  9. Engine mounts/tranny mount question
  10. How come they dont sell Rear brake pads but sell rear rotors?
  11. 90 ls400 a/c not working
  12. MAF sensor
  13. Lower ball joint change for 1999
  14. LS400 Eye lids
  15. Problems with wireless locks, trunk release, steering wheel retraction, ect
  16. Recommend me a replacement subwoofer for my 1991 LS400
  17. OK guys... here's a difficult question... to me, anyways. A/C code 33.
  18. Emergency brake release just broke. EDIT: NM
  19. 1st gen LS400, rims from an '06 GS300
  20. oxygensensors.com tells me I need to remove seats to install sensors?
  21. my LS400 is sick, im sad =(
  22. I am happy for my accomplishments.DIY!
  23. The Ride
  24. Arm rest compatability with other lexus models????
  25. Wiper Blade Brands
  26. Wanna Be LS430
  27. 2JZ in an LS 400
  28. 1991 LS400: How to drain old gas from the fuel tank. Ideas?
  29. Wireless door lock buzzer switch
  30. ran out of gas
  31. Will 1990 LS Air Strut Work In A 1993 LS?
  32. Hit and Run, Think I found the guy, Now insurance is probably going to total it..
  33. The List
  34. check engine light
  35. dome light
  36. Transmission hesitates? Sticks? I dont know
  37. 98 LS400 AC comp short cycle
  38. got a new ride to replace my wrecked 1LS...
  39. Short Ram Intake Mod for 1st Gen LS, $35 bucks!
  40. Tune Up question
  41. need urgent help asap
  42. 98 LS400 Nav. Unit
  43. Exterior lighting issue
  44. Drove a ES350 loaner today
  45. RX330 wheels on a UCF21???
  46. 90-94 Aftermarket Intake Owners in Houston.. help me out?
  47. Advice - never buy aftermarket steering rods and ball joints.
  48. My custom paint job on my headlights
  49. Oxygen Sensor Replacement 96 LS
  50. UCF-10 Headlights
  51. LS400 window wind noise
  52. after market air struts
  53. 98 LS 400 OEM Questions
  54. Cureline Links??
  55. replace engine?
  56. New LS400 Owner with some questions
  57. 98 - 2000 LED taillights
  58. Operation Identity Change: Complete
  59. My RPM's are stuttering
  60. clicking noise from serpentine belt
  61. air assist rear shocks and how to install
  62. Quick answer: Brake pads sold in pairs on lexuspartsonline.com?
  63. 1LS with red clears only using for the outers...
  64. bad ecu?
  65. 94 Ls400 Motor/transmission Mounts ??
  66. 94 LS 400 Wheel Bearing Repair ???
  67. Toyota Celsior parts...
  68. Fender mods vs. rim size/width/offset
  69. LS400 - painting the door handle...
  70. Does anyone know the STEERING WHEEL dimensions???
  71. What type of headunit are you running??
  72. Driver side wiperblade.
  73. i got a question please helpp somone
  74. Sorry guys, another gas question?
  75. LPG retrofit - Liquid Petroleum Gas
  76. 94 LS 400 Starting Problem?
  77. Door locks- Help Diagnose
  78. Gas Tank Pressure
  79. The Next Lexus??
  80. What the... what is up with my tach needle?
  81. Thinking about selling my 00 LS400
  82. UCF20, 170k with no service records - what to look for?
  83. My 96 Lexus LS400 for those who havent seen
  84. My 96 Lexus LS400 for those who havent seen
  85. 94 lexus ls400 amp location (nakamichi)?
  86. does everyone here lower and put bling on their LS?
  87. Brake Asssit.
  88. i just got a 2000 ls 400 ? dvd system and rims
  89. Dome light issue
  90. car struggles to start after running...
  91. Got my 94 cluster repaired
  92. Mystery oil leak...from where?
  93. Just wanna make sure on a strut bar
  94. Advice needed regarding service (Lexus dealer quote)
  95. has anyone taken there LS to a drag strip?
  96. aftermarket RR sway bar links for LS400?
  97. do they make carbon fiber hood for LS400?
  98. 96 lexus Billet Grill
  99. Updated pics of my 96' LS400
  100. Pioneer CD Changer
  101. 89 octane okay?
  102. Will 22 in Tyfuns RIMS fit on my 1992 lexus ls400
  103. Vibration Problem Solved!!
  104. Can you recommend a muffler?
  105. Gas guage broken
  106. Back passenger door lock
  107. Passenger seat belt- help
  108. Amp Wiring Question - Blue Power wire - '99 LS
  109. Newbie, looking to buy 99' LS
  110. Please HELP Difference in air struts UCF21
  111. Need a part name/number..Please!
  112. just flushed my coolent but light is on
  113. How can you tell ?(AC Question)
  114. differences between first and second gen mirrors?
  115. Stock fog light question.
  116. Seat height - 98LS
  117. Front jacking point on a 95-00 LS400?
  118. 1995 on a 1991 front end conversion - possible?
  119. 93' ls400 firing order
  120. watch my 1996 LS400 EXPLODE! W/VIDEO and PICS
  121. What is this piece UNDER my car leaking?
  122. Help! Does anyone know if there are adjustable camber plates for a 99 LS400
  123. It finally happened.. LS left me stranded, in a bad way.
  124. Will the electrochromatic mirrors still work if I get the windows tinted?
  125. got a dilemma!
  126. Need Adviced on wheel
  127. Looking for a 98 ls 400, front passenger side blinker.
  128. exhaust mod
  129. Steering Issues
  130. Looking for a regulated 12v
  131. GS430 wheels on my LS400 - check it out
  132. LS400 Print Brochure Archive
  133. Need advice on my bushings/other suspension on 92 LS400
  134. can anyone... headunit '96
  135. Anyone know...
  136. Rear Diff
  137. suspension question 90 LS
  138. Headers
  139. Considering '97 LS400 purchase
  140. Where to find carpet replacement '90-94
  141. ABS Speed Sensor Question
  142. Spring Cleaning ('95 LS400)
  143. 1st Gen. 10PA20C Compressor Oil capacity??
  144. 1UZFE Spark Plugs
  145. Failed smog.... '93
  146. 1997 LS400 headlight
  147. Engine and Trans Drain Plug Gaskets
  148. Ignition Switch Light and Door Key hole light
  149. green fluid
  150. cleanest LS ive ever seen?
  151. Bad Ignition Coil, clogged catalytic converter, bad cap/rotors? A DIY story..
  152. door "hinge" broke on driver side door 1991 LS400....
  153. Brake light on Dashboard, master cylinder replaced, light still on
  154. Who here has re-dyed their leather?
  155. 99 with 76k, when to change timing belt?
  156. Ls 400 1997 - Gold Exhaust Tips?
  157. Exhaust Pics! Finally! Yesss!!! :)
  158. 1996 Ls400 O2 sensor wiring
  159. Check engine light and Trac off light
  160. Nice size rims for my LS
  161. My LS...Help?
  162. PLS help, questions re: cluster/fuel consumption
  163. My UCF10 on UAS Bags
  164. Getting OEM struts installed on '91 LS400 - What else?
  165. 98 Newb question about corner lights. :)
  166. Rear shock replacement - my observations.
  167. Front suspension again
  168. 95 LS400 with suspension mystery
  169. Gas Tank Questions
  170. LS 400 1993 audio system (Pioneer)
  171. 1995 LS400 Upper Control Arms
  172. 1990 lexus ls400 tach and speedo problem
  173. no power steering
  174. 90 LS rear suspension issue
  175. back seats??
  176. Carbon fiber insert for Lexus L logo.
  177. Is my alternator going bad again?
  178. '93 Lexus wont start. Shifter problem??
  179. 91 Ls400 What Brand Coilovers Should I Get????
  180. 1998 LS400 spark plug: IFR6T11 or IFR6A11 ??
  181. Won't start: clicking noises, erratic gauges
  182. low windshield washer fluid light...
  183. LS400 Exhaust video clip
  184. 91 ls400 suspension help
  185. just some pics
  186. installing mast ?
  187. I need upper intake piping- have one or part#?
  188. LS400 in its new home
  189. Cost of gas beginning to hurt! At wat point would you give her up?
  190. Kool Blue air filter.
  191. Where is the member who had their subframe bolts tightened?
  192. What is the growling/moaning noise when I'm braking?
  193. Battery light on when engine is running '95
  194. Engine System Warning Light is on and the car drives fine
  195. How to replace low beam headlight bulb?
  196. HELP my 96 LS400 rear shocks are dead!
  197. New owner reporting in...'92 LS400 in CA
  198. What is the limiting factor that defines our engine's rpm redline?
  199. antilock trac off lights are on !
  200. Was in Accident LS is out of Commission. Got an Accord
  201. Exhaust tips
  202. How do you replace the Windshield washer Hose on a 98 LS400?
  203. LS400 Projectors
  204. LS400 updates...
  205. 95 LS400 Front and Rear brakes locking up
  206. What is this?
  207. Anybody take the back two mufflers off?
  208. Muffler Tip and Grille suggestions please!!!
  209. w000000tt!!!111 (Update pics inside)
  210. Car is running really BAD...need help (first gen)
  211. locked out
  212. Just Another 1st Gen....Pics!
  213. radiator replacement
  214. part number confirmation for 98 LS400
  215. Pneumatic Cylinder control location???
  216. Question About Changing Camshaft Seals During 90,000 Mile Service
  217. 96 Parking Brake Adjustment
  218. Cant find owners manual, what are the radio unlock steps?
  219. moonroof problems..
  220. Thanks : reference for a good honest independent Lexus Mechanics in Honolulu, Hawaii
  221. Have anyone upgraded their leather seat interiors?
  222. body kits
  223. Weird brake noise! Any help?!
  224. Avoid Costco for Tires-Headaches 1995 ls400
  225. Timing Belt Replacement
  226. Drivers' side seat. Guess whats in the front of it?
  227. Service in Orlando?
  228. Back from the Body Shop & in the dway with 200K
  229. Octane booster: when to add
  230. had to trade in the LS
  231. What brand O2 sensors?
  232. Car rolling slightly in park?
  233. Tracking maintenance through the VIN#
  234. My car sounds old. Is it worth keeping?
  235. Remove/Install P/S pump
  236. Junction Produce UCF10 Celsior // 56k Beware
  237. Brake fluid brand?
  238. Thinkin of getting a second gen this Weekend!!
  239. Was in a Wreck... Have a Few Questions
  240. LS400 Rotors
  241. Things I have to do when driving my LS400 at night.
  242. Wierd suspension creek
  243. Engine bay flasher fuse?
  244. Weird grinding/moaning but only on freeway?
  245. Test fit: 19x10 -7 AME Shallen LX
  246. Test fit: 19x8.5 19x9.5 Zauber Gettins *56k* beware
  247. I Screwed Myself
  248. OMG Fing top L & R turn signal lights
  249. Ls400 moon roof
  250. Is a back plate really necessary? 95 ls400
