PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Front brakes on 1993 LS squeaking!
  2. transmission mount
  3. Help!! Air Suspension on '95 LS400??
  4. Grinding when braking and accelerating?
  5. Full Exhaust, True Dual setup
  6. What is the V bank cover for?
  7. Seat Covers for LS400??
  8. New ignition wires and plugs...
  9. going on a 1500 mile trip soon
  10. 1998 or 2000 LS 400...What price?
  11. Tinttt
  12. Indicator light is on (#16 in manual)
  13. Need front upper control arms/ ball joints
  14. A/C and Radio Issues
  15. buy a 93-94 or pony up for a 95-97???
  16. Noob Question on Exhaust...
  17. 92 LS400 with 93K will not continue running
  18. Headrest Removal ???
  19. hurricane survival
  20. torque converter
  21. Quick fog light question for a 91
  22. need new rotor screws
  23. Getting access to the amplifier (1gen)
  24. Update
  25. Electrical Issue! Help Pls
  26. CEL, Trac off, trac
  27. Steering issue
  28. '90 LS400 - intermittent engine problem
  29. 94' LS400 - Soft Shocks/Struts - Need that soft Lexus Ride Back?
  30. Drivers Side Mirror Replacement?
  31. Trade sports for luxury 1993 LS400 77K miles go for it?
  32. Lexus Club/owners in Houston, TX?
  33. my transmission nooo :(
  34. 1UZFE Plate Swap
  35. 93 LS400 starting problems.
  36. rare ls 400?
  37. 1993 Ls400 Air Suspension
  38. Door Sensor Problem
  39. VSC light came and went
  40. Air Suspension release valve on the 96 ls400??
  41. new member & new to car i have Qs on the air ride susp on a 90 LS 400 help me out?
  42. Crystal Clear red tail lights
  43. UCF20 visors on my UCF10. Painted trim.
  44. Trouble Passing Inspection Test
  45. 1994 Ls 400 Key Shell
  46. How do i lower the headrest? 1994 LS400
  47. Great Info On Wet Trunks
  48. blown lighting igniton and trans.shift indicator
  49. LS400 HID Install Problem (1st gen)
  50. Quick ECU question
  51. Courtesy of fellow member "Suneet"
  52. engine ping noise
  53. No power, glowing red cat, misfire, at my wits end
  54. rear seat removal
  55. weird problem
  56. Wheel fitment on a 2LS
  57. 91 LS Stock Alarm Help
  58. stereo system 91 LS400
  59. noise when i turn the a/c on in my 96 LS
  60. Tail lights LS 400 1 gen.
  61. Is there anyone else out there with cloth interior
  62. Is there a LSD for the first gen
  63. Swapping a 1JZGTE into a first gen LS400
  64. Need Advice On Seatcovers
  65. Transmisson shifting
  66. 94 LS 400 - Is Grinding Noise Water Pump or Fan Bracket?
  67. Location of amp in '96 LS?
  68. Front suspension noise... too soon for struts ?
  69. 94ls searched forums, Still clunking--thoughts?
  70. What Coilovers should I get
  71. fender rolling
  72. Pulstar Pulse Plugs
  73. 2001 IS 300 Stock rims on '90 LS400
  74. Power Steering ECU Question - Kinda Urgent :)
  75. DIY Coolant Temperature Sensor change (PICS)
  76. Power folding Mirrors for the UCF-21
  77. How to check an Air Ride Compressor?
  78. few questions
  79. Err 14
  80. New LS owner
  81. On Hiatus For Hurricanes
  82. 94 LS400 139k Rack and Pinion Question
  83. Zinik wheels and tires
  84. Yep! guess what, power window problem.
  85. Rims on a 91 LS400.
  86. new p/s hose now not working plz help
  87. All LS400 owners with bad gas mileage READ THIS!
  88. Exterior color question on 1990 LS400
  89. 1994 LS400 Sunroof Drain?
  90. Wondering if Ill ever get air susp?
  91. Ls400 98 Hid Headlight, Is there a Missing Ballast
  92. 1990 LS 400 Air Ride Compressor
  93. info needed
  94. Sold my 92LS... yes, I have a story.
  95. Radio displa problem.
  96. For those who love old reviews.
  97. '90 LS Shaking - possibly need new rotors.
  98. Installing clear sidemarkers, 99 LS
  99. Part #
  100. 92 ls400 ignition coil replacement
  101. Need Help Extracting Engine ECU 93 LS400
  102. Starting problem
  103. Loss Of Power
  104. 1994 Spare Key... sewell too expensive, need help
  105. Passenger Side Mirror-Electrochromic Problem?
  106. Wheel Fit Guide
  107. Where's the headlamp level module?
  108. UCF20/21 Inner Tire Wear on Front
  109. newbie with a 91 ls400
  110. PPS ECU (Power Steering)
  111. ignition switch problem?????
  112. Hey guys, and girls, I have a weird instrument cluster question for ya
  113. What is this indicator light?
  114. Sudden Power loss,, ned help.
  115. headlight compatibility for ucf10/11!!!
  116. Online site to buy coilovers
  117. Can't pull codes ????
  118. book values
  119. 1997 ls400 w/Nakamichi replacement help???
  120. Help! possible water in oil
  121. No More Fogged Headlights
  122. LS400 Gas Bomb 1996
  123. Looking at the DF210's but want to see pics
  124. '91 LS400 Waxed
  125. Good price for these?
  126. 2 slight issues on my 96 LS
  127. whoes is this
  128. 18's On My 92
  129. Need help finding Curtains for my 99 LS400
  130. 1st gen LS400
  131. 2DIN Radio
  132. More bumper fun-not
  133. New Member : AsiaHiTopic - '93 UCF11
  134. The orange engine Icon on the speedometer?
  135. blown fuse?
  136. Oh so that's why my Japanese Battleship was overheating...
  137. engine code 52, no 1 knock sensor signal
  138. interference engine or non-interference? 1990 LS400
  139. Finally making progress (new exhaust w/vid)
  140. 1991 LS400 Brake and ABS Help
  141. Needing expert advise on issues for '90 LS400 I just purchased
  142. Help me choose! (buying a newer LS)
  143. Question: Best Catalytic Converter
  144. LS400 timing belt
  145. 93 LS400 vs 99 Acura RL ?????
  146. 96 LS for 5 grand a good buy?
  147. Replacing Screen at PS solenoid?
  148. '90 LS400 fuel pump system problem
  149. oh no, another window problem
  150. Another LS400 LSD Question
  151. Installed aftermarket stereo but antenna is not activating...?
  152. 1991 ls400 engine lopes then cuts off.. help
  153. 1992 Turn Signals and hazards do not work, need help asap thanx
  154. Lexus LS400 cigarette lighter no working
  155. It's a sad day for me..had to sell my car.
  156. Need a Decision on a 90 LS400 Purchase
  157. Front Seats, Leather and padding ...
  158. incredible gas mileage
  159. Stereo
  160. How to remove badges on bootlid
  161. 19" G37 Rims on a LS400?! Teaser Pics
  162. New, looking at '91 LS400
  163. ls400 lsd do they have it?
  164. New LS400 95' owner
  165. need some help with audio!!!
  166. UCF2X brake pad reviews
  167. Looking for photo of 1995-1996 LS400 in Blackberry Pearl
  168. Changing spark plugs on 2000 LS 400
  169. Key Question ... Help, Input Needed
  170. Factory Navigation Questions 98-00
  171. UCF11 sound system horrible?
  172. 1998 LS400 Oil Leaks From Valve Cover (cylinder head cover?)
  173. second gen power steering help
  174. Err 13 Cd Changer Please Help '97
  175. AM radio reception
  176. Teaser thread :D
  177. Why does my car have trouble shifting......
  178. someone please help
  179. Speaker problem when playing CD's.. cannot find w/search
  180. It has been too long...an update...
  181. I inherited my dad's 96' ls 400, so much potential, where to start?
  182. Help
  183. A/C Compressor help please!
  184. 2nd Gen LS Front End Vibration/Shimmy
  185. Smoke from UNDERNEATH the car, drivers side..
  186. Went to the dealers yesterday, need some help so i could save $$$
  187. Newbie and ebay??????
  188. brake caliper bleeder screw size
  189. 94 LS400 Won't Start? Is it my spark plugs?
  190. sensor short
  191. 2500 Mile trip in 3 days=26.8MPG
  192. Running amplifier power
  193. New member who has a few questions about a LS400 I might be buying...
  194. finally! pics of my LS with 25mm rear spacers and right size tires...
  195. Project Update, suspension, wheels and tires
  196. Oil viscosity change
  197. What struts and shocks should I put on my '99 LS 400
  198. 10PA20C Compressor Clip doesn't match
  199. tenabe df210 springs
  200. UCF10 & UCF20 scuff panel comparason.
  201. Car start but engine does not stay running if let go gas, what is wrong?
  202. good place for parts?
  203. roof spoiler/rear windshield visor
  204. tyre flyes: cool or not, probably a little of both...flashing led caps
  205. Muffler delete review on 1st gen '91LS in Texas; legal for state inspection?
  206. Pics of my LS at Import Alliance this weekend
  207. 1UZ-FE valve adjustment and my thoughts on it.
  208. OEM Celsior Badges
  209. Heated switch bulbs
  210. LS400 Timing Belt
  211. Want to by Mass AirFlow Sensor 4 '92 LS400
  212. 1992 LS400 air flow meter
  213. I need your help ls400 guys, what's this worth?
  214. Ebay Control Arms...any good?
  215. Help: 91 LS400 vibrations from the back
  216. rear center head rest, what do do?
  217. changed starter now car leaks
  218. interchangeable parts, possibly a dumb question
  219. Spark plugs / wires
  220. 90-94 Ls 400 Transmission Is There A Difference
  221. New owner of Lexus LS 400 Car is 18yrs old
  222. Trunk filler
  223. help how to sell 1999 lexus ls 400??
  224. You know you are an LS owner when....
  225. Will 225 40 18"s fit my 99 LS 400 came off of IS 300
  226. Need Help: Radio and Alarm
  227. JUST GOT MY FIRST LEXUS!! Couple questions?
  228. VSC Check Engine FIX
  229. Anyone running a 255/35/20 on rear ls 400
  230. SERIOUS COOLANT problem!
  231. Broken Door Handle? My DIY $5 Fix inside with pics
  232. upgrading Shocks/springs
  233. what could it be?
  234. Differential Bushings Diagnostics
  235. Do Kyb strut mounts fit OEM struts?
  236. New 96 LS400 owner. Few questions..
  237. what is going on? after replace PS and altenator
  238. Emblems
  239. General Rant - More Conclusions Needed
  240. 93 LS400 vs 95LS400 driving impressions
  241. New member with a few questions
  242. Arrrrgg.....swiped!
  243. Ls 460 Cruisin'
  244. 96 Seats In A 92 Model
  245. Blew a fuse.. I think.
  246. '94 ls ac condenser fan motor shot?
  247. car stalling
  248. A/C issue with 94 LS working but not
  249. Replacement Electrical Connectors Especialy in engine bay
  250. 3rd brake light question
