PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. light on the dash!
  2. New owner here
  3. Suspension Bushings
  4. St. Louis Snow no work today! Snow Pic
  5. Transmission Shifter Stuck
  6. Fan bracket replaced
  7. How Much for a new paint job
  8. Intermitent brake failure
  9. replace timing belt 96 after break
  10. newbie wheel fitment question
  11. Need a color code...
  12. How to fix powersteering leak on 98-2000 LS400's
  13. 1998 coolant refill after replacing timing belt
  14. ls400. Good Daily?
  15. Is there a diy??
  16. Hey Youz guys! UCF20/21 question \_*;*_/
  17. Calling All Gen 1 Experts
  18. I Need Rear Differential Bushings, anyone know where to get a good set?
  19. First LS...problem. Noob
  20. I love this vid, Tribute To The 1UZ-FE
  21. Water pump installation question
  22. purchased a 98 LS400 - vague maintenance records
  23. How much is it worth?
  24. The Life of my LS400 In pictures...
  25. DIYers what tools have you invested in and what task have you encountered?
  26. New Disc Brake Rotor Question - 94 LS400
  27. Help on replacing P/S seat belt in '96 LS400
  28. ideas to lower cold start high idle speed problem
  29. Requesting picture: Steering Rack
  30. Headlights just went out....?
  31. '98 LS400 Timing Belt Change Costs - Parts and Labor
  32. Junction Produce Heaven! pillows, pads, curtains FUSA!!!!!!!!!!!!!!!!!!
  33. Electrical questions/problems...
  34. Air Suspension question, someone please help
  35. Adus rear bushings comments
  36. TRAC light.
  37. Simple question 92 LS400
  38. Affordable Wheel Refinishing ?
  39. UCF10 (90-92) Fog lights not working...
  40. Audiophiles: LS 98 - 00 Audio System Question
  41. P0100 & P0110 car not starting..clicks only.
  42. exhaust
  43. OMG...My Eyes!
  44. 91 LS400 coolant light problems
  45. Battery is always getting dead...
  46. They see me rollin... they hatin'....
  47. Here goes another "starter woe" thread
  48. GS 300 wheel on a LS 400 will it fit?
  49. Idler pulleys...bearings replaceable?
  50. Crank bolt - did I #@&* up?
  51. 1993 LS400 - Fuel Gauge - VERY weird problem (?!?!)
  52. What kind of wood is this?
  53. PS Fluid fowling ignition components?
  54. Replaced Brake Lights, Still Not Working '91 LS400
  55. car wont start? radio and lights work
  56. exhaust problem?
  57. Will LS430 wheels fit on my LS400?
  58. Air ride computer location
  59. Odometer repair
  60. Steering Wheel- horn sounds off
  61. LS400 exhaust piping.
  62. Can I reuse the IACV gasket when cleaning it?
  63. transmission drain and refill capacity?
  64. First question from a new LS400 owner
  65. lighting problems
  66. Couple Q's, 91 1UZ
  67. what's best way to repai seats?
  68. 1991 LS 400 Alert / Warning Dash Lights
  69. BAGGED ls !!!!
  70. First Gen LS400 Wheel Question
  71. 1993 LS, rattling or pinging?
  72. Help!!! Newbie with problems
  73. At what point do you give up on your LS?
  74. 1993 LS400 Losing power while driving.
  75. Audio screen is crazy!
  76. Condensation in the car... \_;_/
  77. new here! 94 ls400.
  78. brakes
  79. Inspection due in nj.....hids legal?
  80. Hello LS430 =)
  81. Newbie 91 LS400 - Quick Q's
  82. alignment settings with megans?
  83. 94 LS400 JDM headlight bulbs?
  84. 92 LS 400 instrument cluster removal
  85. LS400 starting problem
  86. Camshaft timing marks
  87. LS400 Lower Ball Joint Question
  88. thinking of getting megans?
  89. shock mounts
  90. Strange smell around battery once this evening....
  91. HELP!!! Brake problem w/ my 99 LS400
  92. what are biggest concerns for 1st gen LS?
  93. problem with brakes can you help!!!!!!!!
  94. need black leather skins
  95. where can i buy megan coilovers
  96. new exhaust =)
  97. rear bushings info please
  98. Key Question....
  99. K&N Air filter (1999 LS400)
  100. Persistant whine, very heavy PS cured! Simple fix!
  101. Injectors
  102. bushings seller ph # needed
  103. cluster in repair and disconnected
  104. knob under the d/s dash...
  105. '93 LS 400 Driver Seat Issue
  106. megans ordered today
  107. Pictures of 20's on the LS400
  108. carrier and lateral arm bushings
  109. Gas mileage?
  110. Timing belt service parts list!
  111. Trans flush help with vibration?
  112. parts question!
  113. Bulb Sizes for some interior parts?
  114. Daizen Impressions.... Anyone ?
  115. Need picture of 1st gen ls400 brake master cylinder
  116. Rear door panel removal
  117. My UCF11 vip inspired
  118. 1993 LS400 Owner's Manual
  119. Speaker acting funny.
  120. 93 LS 400 CEL that won't flash
  121. Which Fuel to Use? Newbie to Lexus
  122. What does the ECT Power switch do?
  123. New Wheels :[
  124. LF Shop recommendation LS400 90K Maintenance Tampa FL area.
  125. which springs (not coilovers) drop my 98 ls400 the most? tanabe?
  126. Performace for 1999 Lexus LS400
  127. caps and temperature rating
  128. Do it yourself / Disable DRL in UCF20
  129. Instrument panel
  130. 91 LS400 Question
  131. LS400 and snow
  132. radio no sound
  133. intermittent limp-home mode - WHY?
  134. can someone please help with the lil stuff?
  135. Cat installed after all four O2 sensors?
  136. Supra LSD onto LS400, CONFIRMED!
  137. Front camber adjust
  138. 1996 LS400 Stalls after prolonged use of cruise control
  139. Bushings
  140. Power steering pump replacement notes
  141. Jeremy Clarkson destroys the LS400
  142. Electrical Fire!! Yikes...
  143. Speakers and Door Panel
  144. LX470 Rims on LS400?
  145. Climate Control Unit removal?
  146. DIY of Strut Brace bar
  147. Me and my 91 - A Christmas Story
  148. 2gen 95-97 LS400, blitz ecu (link in here)
  149. Duce Inspection Rear trunk/window wings....
  150. questions: want to replace rear diff
  151. Technical Manual
  152. Will this OBD2 cable work with my LS?
  153. ls400 safety
  154. Uneven suspension
  155. Swap parts? Michigan 1 Gen?
  156. Best shocks and Swaybar bushings for 92 LS400?
  157. PS Fluid Poisoning Sensors?
  158. wiring problems
  159. 93 LS400 Engine Fan Grinding Noise
  160. OEM HID Bulbs are completely shot - recommendations?
  161. New Rims/ Re-chrome original
  162. My LS =P
  163. Weird Brake Bias (2nd gen 95-97)
  164. Starting woes...
  165. new here 93 LS400/UCF11
  166. Coilover Spring Rates..
  167. rear hop and slight vibration
  168. Questions about replacing timing belt on '99 LS400
  169. Looking for ...
  170. LED's in tails.
  171. Fender Roll v Cut
  172. 1st Gen Springy Car Seats
  173. Ls400 front blinker, how to remove.
  174. Hot Air when the heat is not on. HELP
  175. New guy here with 92 LS 400
  176. HID fogs on first gen?
  177. capacitors #'s needed
  178. 1999 Lexus LS400 Signal Side Mirror Cover
  179. Replace Stock Air Suspension with Regular Suspension
  180. 1995 LS400 Hot Air
  181. 93 LS 400 riding rough
  182. Buying a '93-'94 vs. a '95-'96?
  183. Checkout this ls400 on Craigs List w/ pics.....
  184. Check out my new AEM filter from ebay.
  185. 2000 LS400 Radio Problem Please Help
  186. Adjusting Shims for Proper Valve Clearance
  187. 92 LS400 Trunk Leaks
  188. 99 LS400 Shaking Problem
  189. what is this relay used for?
  190. Eagle eyes
  191. LS400 differential
  192. Anyone else seen this eBay turbo kit? Claims to work on Celsior...
  193. 1999 ls400
  194. 1996 Drivers seat?
  195. all dash lights and cluster out
  196. NEWBIE from Ireland
  197. afm/maf
  198. Problem with 93 LS...
  199. Replacing sidemarker lights
  200. brake pedal still pulsating after rotor and brake pad change
  201. What Other OEM LExus wheels fit 2LS?
  202. Code 15-need tech advice
  203. Catalytic converter options
  204. new here
  205. brake conversion
  206. Speaker volume unbalanced
  207. Clear Headlights for the 95-97 LS400
  208. UCF11 one piece headlight prices?
  209. Need chassis plug pinouts for 91 LS400!!
  210. 92 Ls400 - Check Engine and Traction Light (200K)
  211. 1996 Lexus LS400 Stereo Install - Wiring Info + Diagrams
  212. windows open themselves
  213. Let me reintroduce myself
  214. No Fuel, Got Spark, New Relays, Just Turns Over
  215. What value - stock 1996 wheels/tires???
  216. Park(P),engage foot brake or Foot brake then park ?
  217. timing belt skip a tooth?
  218. What offset will fot a 95 LS 400
  219. Looking to buy ls400 norcal
  220. So... Michelin MXM4 or MXV4 tires?
  221. Headlight wiring diagram
  222. What to look for when buying a ls400?
  223. 1991 LS400 Front end suspension question (the car is riding low)
  224. 93 LS400 suspension question
  225. Frozen Windshield Washer Fluid??
  226. what suspensions are good?
  227. My car is finally complete! New pics to help me sell it.
  228. Accelerator pedal hard to push when cold
  229. LS400 Lights mods
  230. Noise after start - Starter Relay?
  231. Six mpg, code 26, suggestions?
  232. engine cooling system problem..please help
  233. what are good air suspension
  234. Anyone else have these problems??
  235. Steering wheel remove?
  236. Newbie from norcal
  237. Cold start-Rattling noise in bottom left of engine
  238. Projectors in the early models?
  239. Frozen Antennae
  240. before buying 2000 LS400, What should I check?
  241. Dealers carelessness caused me to rev my engine to 5000rpms! Engine damage?
  242. 90K Maintenance Ebay kits ok to purchase? 98 LS400
  243. Hey guys a little help with UCA Control Arms!
  244. No Spark, No inj Pulse, no start
  245. Problem with the cluster.
  246. Hello from a noob - New LS!
  247. A/C is killing the motor
  248. car wont start in the morning
  249. RPM drops to zero
  250. suddenly no power steering at all
