PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Smoke from steering column. Source?
  2. 99 LS400 Mirror housing removal
  3. 92 ls400 pioneer 2 ohm sub??
  4. Where are the main and return fuel lines connected to the tank?
  5. How to change headlight bulb for 98 LS400 DIY?
  6. HKB (or other brand) steering boss kit to fit UCF21?
  7. Question on oil and tranny fluids pan....
  8. center mounted backup camera
  9. What this hose for?
  10. 99LS400 brake caliper bolts
  11. 1992 LS400 Parking Brake Light + Check Engine Light on
  12. 18" tires for the high temps of Saudi Arabia?
  13. catalytic converter replacement help
  14. Ucf10 oil consumption?
  15. As Time Goes By.
  16. Celsior Niggles and Surprises
  17. '96 LS400 w/ P0340, P0500, P0770 - Trans?
  18. Please identify wire harness (picture)
  19. 99 LS400 RS Mirror
  20. LS400, Air meter code with a fix?
  21. (1998 LS400) How Do I Replace the Coolant Temp Sensor?
  22. Engine is loud at idle
  23. Original battery terminals?
  24. Picked up a 97 coach for a good price.
  25. Just bought my '94 LS this past Friday
  26. stereo crackling sound
  27. Moonroof cover rattle
  28. Instrment Cluster - between 93 & 94
  29. 92 starting/firing up problems help
  30. Best tires for long distance?
  31. Driver fender well harness relocation gone bad
  32. higher idle in extreme cold (when already warmed up)?
  33. 1991 oil pan leak
  34. Brand new starter motors
  35. Dension iPhone4s audio hook up
  36. What did you do with your LS on Valentine's Day?
  37. Need help with my 96 ls400 transmission and car wont past 2k
  38. Blower motor question
  39. Junkyard scores and an ashtray question
  40. 1990-2000 Color combonations
  41. Double Din Unit
  42. Help identifiying source of fluid leak
  43. Input needed on color choice for new LS400 purchase
  44. Replaced starter - don't know what harness this is
  45. Starter solenoid 'clicking''
  46. Low oil pressure light after bump
  47. '98-"00 wheels on '97 LS 400
  48. door panel removal
  49. Pcv hose
  50. Where does this vaccum hose go to?
  51. Replace belt tensioner
  52. New LS400 owner here
  53. (Pic)F Sport LS400 - (help?)Time for a Complete OEM Suspension Overhaul/Restoration
  54. 96 LS400 key info chip?transponder?best way to get duplicate?
  55. Wiring diagram for instrument cluster for 91 LS400
  56. 98-00 LS400 Best way to remove amber turn signal lens?
  57. its "just an expensive camry"
  58. plastic engine covers
  59. Don't Hold Your Breath for a Bose Suspension on Your Lexus LS
  60. 1997 ls400 Heated mirrors
  61. New member here . glad to join this community
  62. Aftermarket Steering wheel
  63. Key fob internal swap?
  64. 95LS starts to die after a minute of driving
  65. How did you feel when you first got your LS?
  66. Lower steering wheel without power.
  67. Condenser fan issues
  68. Smoking from Right Front Wheel Well
  69. New Guy
  70. 91LS400-Stalls after 15 minutes, Starts, Idles/runs beautifully when running
  71. Help with buying this LS400
  72. Adding technology to your LS to bring it into the 21st century
  73. Identifying Trunk Items
  74. Power steering hose cracked on my 98 Celsior
  75. Corroded Waterpump - Green Anti-Freeze the Culprit??
  76. 96 Ignition Switch Problem
  77. 2000 LS noise
  78. UCF20 Lexus LS400 Electric Kart [Powerwheels?]
  79. Vibration on deceleration
  80. How not to diagnose things...
  81. Replacing TPS on 1991 LS400
  82. Celsior (F10) the Development of History and Chronology
  83. Electrical Issues on a 1999 LS400
  84. 1998 LS400 dual custom exhaust, video clip and pics.
  85. Raybestos brake dampener
  86. 92 Ls400 tune up?
  87. Strut Bar Looks Twisted - Is It Normal
  88. My LS system, sounds nice and on budget
  89. '93 ls400 running bad video HELP!
  90. OE Fogs...going old school yellow
  91. Stuck in pasco washington with my LS/road trip gone bad
  92. Steering noises
  93. are these important?
  94. Best way to change paint color on car?
  95. New member needs your take on "knock".
  96. What tool are you guys using to change the O2 sensor?
  97. Blower Motor Stopped Working 1991 LS400
  98. your LS400 story, why is it special to you?
  99. No WTB in this forum - use the classifieds
  100. Looking to buy megan coilovers
  101. any "barn find" Ls400 restorations yet?
  102. 1990 Celsior issues
  103. Replacement Tanabe Coilover Lower Bushing
  104. Club Lexus Your My Last Hope
  105. GS F Sport wheels on LS. Need spacer help
  106. Tilt/Telescope multiplex, 96 LS
  107. another 1st gen LS goes down
  108. LS400 will not idle after a flat battery
  109. Air bag deploy on Gen 1's
  110. Free online wiring diagrams and TSBs
  111. Is this the death sentence to all 1st gen LS400?
  112. Slow to start, only the first time in the morning
  113. LS400 won't co-operate
  114. Trouble with switching out flexjoints.
  115. Rear Door locks
  116. How many with LS's in the snow?
  117. Knock sensor and starter service info?
  118. Best place to buy parts
  119. '98 LS400: puff of smoke/steam from under car?
  120. Purpose of pump unerneath the brake master?
  121. water pump
  122. 1996 Shop Manual Info?
  123. 1990 Toyota Celsior in Virginia
  124. Need help!! ECU problem
  125. Parts diagrams for 98-00
  126. $9000. 1992 ls
  127. check engine light/VSC off - code P1121
  128. Seat belt light not turning off?
  129. P0325 Knock sensor code?
  130. 1995 power steering compatibility?
  131. As they've aged... Reliability?
  132. Is this repair needed?
  133. fs links not allowed
  134. Looking to Buy a Low Mileage UCF20, Some Questions
  135. 1997 to 1996 engine/tran. swap
  136. Motor buzzing after engine shut off
  137. Need help - cats turning bright red to orange color
  138. LS400 alternator compatibility
  139. Timing Belt Alignment question
  140. Oil leak front cam cap passenger side
  141. Issue or not?
  142. Front passenger seatbelt issue
  143. Window switch swap
  144. Won't Crank After Replacing Fan Clutch Bracket
  145. Wheel Fitment Question
  146. Valet trunk lock button ucf10
  147. Need help please! Tail lights out
  148. NEED HELP - 1996 LS400 Steering Wheel
  149. Radiator grille
  150. Heated front and rear seats?
  151. Looking for low mileage, check this one... 60k
  152. to buy or not to buy, That is the question
  153. Please help, key in ignition problems
  154. Cranks but won't Fire. Air Sensor Replacement?
  155. Considering the purchase of a 95 LS400
  156. Trans Mount Threads?
  157. Please Help battery keeps dying
  158. My first Post...93 ls500 and help needed inside
  159. For all my mechanics here
  160. LED Bulbs for Reverse Lights?
  161. LS400 Dilemma
  162. Replaced Engine with other components Catalytic Converter turned Glowing Red
  163. Defeating high idle.
  164. Weird battery light issue
  165. 1st gen LS400 front seat covers interchangeable?
  166. Just got a 1st gen LS400! Power steerig system HELP!
  167. Toyota body grease and chassis lubricant
  168. HOw much would you offer?
  169. DIY inner tie rod (rack end) help ! 92 LS400
  170. Looking for coilovers VIA Yahoo auctions
  171. Ngk laser iridium or Iridium ix?
  172. Ls400 fuses
  173. Dream Car Found- 1990 LS400, 169K, now mine!
  174. Almost turned my LS into a submarine last night
  175. 1998- 2000 LS400 Transmission Line Cushions
  176. LS400 1995 side headlights purpose?
  177. Brake light problem
  178. 98 LS Power Steering Line - Bolt Size Needed Please
  179. replaced my two idlers and drive belt
  180. 96 shifting problem
  181. 250k see you soon!
  182. 1998-2000 ls400 alternator upgrade
  183. Dead battery
  184. How to replace tail light/brake light bulbs.
  185. My BABY 1995 LS400 got side swiped!!
  186. 94 LS400 Cats off question
  187. Steering wheel lock up
  188. Body shop gave me a door ding.
  189. 98 antenna location ?
  190. Lead foot
  191. 1992 Lexus LS400 - Easy way to get to the kick panel fuse box?
  192. PPG windshield glass
  193. New owner, list of questions...
  194. New owner, list of questions...
  195. 1996 LS400 Ski Trips?
  196. 1991 LS400, Saying Hello!
  197. 1992 Lexus garage find
  198. Spark plug wire problem
  199. I'm back ;)
  200. New 1995 ls400 owner here!
  201. Midnight Indigo UCF10 checking in
  202. New 90' ls400 saying hi
  203. Moon roof air deflector?
  204. LS400 1995 shaking, loss power, smoke
  205. Speedometer Schematic
  206. [How] to check long term and short term fuel trims
  207. New lexus owner
  208. Door lock actuator replacement. 1999 ls400 passenger side
  209. Tail lights
  210. 1998-2000 Lexus LS400 Reliable High Output Alternator
  211. Where to buy just plain coil springs?
  212. Crankshaft Position Sensor look like this?
  213. low speed noise
  214. Fuel injector covers
  215. Will these wheels fit?
  216. Replacement Key programming
  217. Serpentine belt jumping off
  218. P1349, P0300 trouble codes, CEL and VSC
  219. Ls400 1998-2000 celsior 20 aimgain rear mufflers buy or pass
  220. Resetting fuel gauge?
  221. Front suspension recommendation 1999 ls400
  222. That Hum.....
  223. coolant cap
  224. Fuel Leak in Engine Bay
  225. 92 LS400 no cluster backlight
  226. Help Getting Snapped Exhaust Manifold Stud Removed
  227. 98 LS400 P/S Pump Leaking
  228. Time To Let It Go??
  229. $18,000 for a 96??
  230. That LS400 feeling
  231. Looking to purchase an LS400
  232. 1994 LS400: Water pump failing
  233. Wire harness plastic clamps
  234. Is there an instructional guide to replace the AC Vent where you put Phone mounts on?
  235. No heater
  236. ls400 clunk
  237. Scored some M1 AFE 0w30 for cheap!
  238. Need some help on tire size
  239. What in the heck is going on with these rear shocks? (1995 LS400)
  240. keeping track of them, early build cars, statistics
  241. 1995. power windows going. help!
  242. P1350 code and misfiring on cylinder 2,4,6
  243. Out with the old in with the not so old
  244. Leaking oil.... Need help
  245. A Sad Story with My LS 400 A/C
  246. Driver side mpx box
  247. Big wheels. MMR hr3 fitment question
  248. Yet another weird issue1995 ls400 - p0308
  249. Rear brake calipers - 430 or 460 bolt up?
  250. 1995 LS400 rear seat removal w/pictures
