PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. where can i buy megans coilover
  2. Stalls in warm/humid weather and/or low gas
  3. Front Seat Swap, Pics Inside
  4. 90 LS400 Firewall diagrams? Any Available?
  5. Rear UCA Replacement
  6. no start
  7. Hood Dampers Question
  8. [?] Common Problems?
  9. Headlights dont work on 96' Ls400
  10. 10W30 or 5W30 Synthetic?
  11. 1990 ls400 high idle w/ MAF, low idle but no go without MAF...
  12. Rubber Bushings from another make/model
  13. Cheap fix for old bumpers
  14. Bilsteins/stock springs vs. H&R/KYB GR2s
  15. Headunit Installation
  16. Car jerks when shifting from Park
  17. coilover springs for UCF10
  18. have to replace shift lock control ECU?
  19. About to buy 95 Lexus - Good Deal ?
  20. Tail Lamp Failure
  21. oil light comes up when doing 100mph
  22. Newbie here... needs assistance. Dashboard light...
  23. New pair of shoes
  24. motor ticking
  25. 1995 LS400 or 2001/02 GS 300
  26. Caliper stickers for 1995-2000 LS400 FRONT calipers
  27. 92 LS400 will not start. Help please.
  28. 1990 ls400 headlight bulb replacement
  29. stiff steering problem
  30. Cannot Fill tank Gas // 14.8G isnt 21.9 for FULL tank!
  31. HID flickering?
  32. need opinions on these wheels.
  33. How critical is it to use Genuine Lexus stuff ??
  34. Dropin My Car
  35. Brake wear.
  36. Power mirror issues - only works sometimes
  37. Happy easter!
  38. LS400 Noob, Lexus Veteran, HID Hi/Lo Question
  39. How do you find codes when you get check eng light on 1st gen 400
  40. Speedo problem
  41. Extended wheel studs
  42. Dropping your car causing clunking?
  43. newbe 2000 ls400
  44. Win Corp Bar?
  45. Hesitation problem FIX! cheap by a professional.
  46. Radius Arms and Sturt rod -Same thing?
  47. lowering help?
  48. Help from audio genius needed
  49. Made home on 4 cylinders
  50. Where to find a rear stabilizer bar
  51. My garage, trade score... Wtf is this??
  52. Performance parts?
  53. Mobil 1 Synthetic ATF
  54. Ls400 how many fuel gallons left in the tank?
  55. Great repair service climate control and ecu
  56. What are these wheels off of?
  57. which airbag suspension kit?
  58. Busted Rear Air Suspension
  59. Best Rotor/Pad Combination?
  60. 1990 LS400 Diagnosis of Front End Vibration
  61. heater ac digital control
  62. high beam/fog switch mix up
  63. Finally got one!!
  64. Best deal on air suspensions?
  65. Front Rotor & Caliper Question
  66. 2 rubber pieces saved me $800
  67. Headlight Conversions
  68. Brake Fluid Leak
  69. Lexus LS400 1990 123000km sparks???
  70. Seats.... anyone ever put recaros, sparco, corbeau, f1spec, etc?
  71. Cold starts on 1998 LS400
  72. 2000 LS400 w/ 20x8.5 +40 & 20x9.5 +45 require fender work?
  73. New Wheel Choice
  74. Pics inside, where exactly does the trunk wire break on the LS400s
  75. ordered coilovers
  76. set a new key control to my ls400 1990
  77. New here ? about climate control
  78. Im still getting 10 mpg!! What else can i do?
  79. Hello LS forum, 92' LS4 on craiglist and I bought it.
  80. Gas gauge not working, "E" light always on, help.
  81. Missing CD Changer
  82. removal of front of steering wheel 98 LS400
  83. Navigation SYS "URGENT"
  84. replace steering wheel .. please help
  85. airbags remove
  86. Timing belt replacement - mileage or age?
  87. Using SC rims
  88. Read the tutorial but have a question
  89. solution to slight vibration problem
  90. Steering wheel swap on 98 LS400
  91. Noob with price question
  92. Need help please!
  93. New paint questions
  94. 1998 Lexus LS400 temp gauge issue
  95. Quick Question: 1994 JDM Celsior Headlight bulbs
  96. My Celsior/Ls400 in AUSTRALIAN
  97. My newest toy , Halo's
  98. Will G37/G35/350Z rims fit on my 92 ls400?
  99. Infamous "NO POWER" CEL on problem
  100. 91 pionneer radio what is the 2nd
  101. Intro: CL Newbie
  102. Heater Core Issue? 92 ls400
  103. Seat's ????????
  104. New to the club
  105. Wheel fitment opinions needed. :)
  106. 91 SHIFTER REMOVAL (hOW TO CHANGE LEATHER HANDLE
  107. Help on seat wiring 94 model
  108. Removing Shifter Clear Cover Plate
  109. Laminated side windows
  110. New Here, Pricing Help
  111. trac light flashing
  112. How to window switches wood trim
  113. Sunroof Leak or Clogged Up
  114. Suspension & wheel recommendation?
  115. Emergency!!the key is in the trunk!!!!
  116. Good Pictures of my JP Curtains and accessories! :)
  117. 91-94 megans coil or 95-00 megans coil on 1999 LS
  118. first Gen ls problems with ipod adapter. Help the n00b <----
  119. Best place to get RCR Tails for first gen ?
  120. Gas Pedal Mount - Floor or Hanging
  121. Help removing window tint from rear winshield
  122. Lost power, had to limp home
  123. removing headrest on 2000 LS
  124. New Coach
  125. Are you getting 30 MPG on highway driving?
  126. LS 400 will not start
  127. Random LS starting problems (have you changed your distributor cap/rotors?)
  128. 92 LS400 Getting code 12
  129. Persistant steaming (powersteering already plugged)
  130. Teaser pix of work in progress !
  131. new calipers... brakes still sticking. wtf?
  132. LS400 window vent visors
  133. sunroof moonroof leak
  134. Headlights stay on if door/trunk open
  135. where's a good place to get rear upper control arm for a 91
  136. 91 Celsior "F" ground to a halt...
  137. DIY // LS400 Headlight Restoration // Before & After
  138. power steering fluid freshen' up
  139. '98 LS Transmission Fluid
  140. just bought 94 LS400!!
  141. Locks/Windows going crazy
  142. Teasers of work in progress - possibly the mother of interior retrofit on a first gen
  143. Meet the daily.
  144. 91 tailight
  145. 1st ls400 have questions?
  146. opinions on price 00 Platinum LS
  147. Help seat belt retractors
  148. 98-2000 headlight questions
  149. Position of Engine Coolant Temperature Sensor
  150. airbagt light flashing
  151. Body styling question :)
  152. ac recharge
  153. 1st Post! High NOx on emissions test?
  154. teaser.. finally
  155. Slow to shift when cold
  156. How? Removal of center console 91 model
  157. My electric fans in front of the radiator will not turn on!!!!!!!!!!!
  158. wanting to do a build 91ls400 motor where to start HELP
  159. Will 08 LS460 Factory Wheels fit my 91? Thanks
  160. Long cranking!!!
  161. Can i disactivate a 1993 ls400 stock alarm
  162. Dash Array replaced.What is that?
  163. O/D off+ white smoke!!!
  164. Did a tune up recently, not much improvement in MPG!
  165. Oil burning what could be the cause?
  166. Wow!!!! Some feathers and remains found in my ls!!!
  167. stereo problem....
  168. Help in figuring out a warning light for my 1993 400SL?
  169. LS400 Acceleration
  170. How much did your tires, rims, and suspension set you back?
  171. hood shakes, vibrates on my 96 LS
  172. 92 lexus 400
  173. A/C Control
  174. LS400 pros/cons
  175. Help with ls400 91, door lock rocker switch
  176. Progressive Power Steering diagnostic procedure
  177. I want a new look for my 95 ls
  178. How does an LS400 handle/feel?
  179. 94 ls400 radio wire harness question
  180. Got $100 Get Some Performance ,gas And Smoothness Back,The ultimate DIY all in 1 fix
  181. Supra TT rear caliper upgrade
  182. Which is Faster LS or GS
  183. MAFS/AFM Mass Air Flow Interchangability
  184. ABS (trac) Relay
  185. 92 ls tail brake light
  186. 92 ls rack and pinion replacement
  187. Electrical Problem!!!!!!!
  188. The Reveal :)
  189. alarm going in...
  190. 1997 LS 400 - Dome and floor lights won't shut off
  191. Removing windshield coating?
  192. New!!!
  193. HVAC (Climate Control) Wiring Schematics?
  194. 1996 LS 400 Cooling Fan relay
  195. Removing rear exhaust boxes
  196. Gatta Replace Motor mounts
  197. Comprehensive Bushings Overview Needed
  198. stereo installed
  199. Question about replacing rear shocks
  200. 2000 400 w/73k or 2001 430 w/105k
  201. 93 LS400 Rear Suspension tips for install of new air struts
  202. Question about Transmission Gasket?
  203. Looking at 91-94 vs 95-97 any thoughts either way?
  204. 1991 ls400 molded carpet wanted
  205. 2000 Spark Plug Question
  206. Mudflaps question
  207. Relocate wheel well wires?
  208. Help electrical problem!!!! '97
  209. Help what type of wheels for 98 LS400
  210. friends LS got hit, need some help
  211. NoOb (looking to buy my first Lexus)
  212. navigation system ?
  213. 98 LS400 Timing Belt Problem
  214. pre-diy for coolant and IACV cleaning
  215. Ls400 interior swap
  216. can someone post driver side for UC20 engine.
  217. Help needed 91 ls400 switches & lights
  218. meagan coils replace air susp?
  219. alternator question
  220. brake pad spacers
  221. 1994 ls 400 remote key
  222. Help needed LS400 - entry lights and radio lights
  223. Hello once again. New 93 ls400 owner
  224. What does it mean when your gas tank makes a whoosh when you take off the cap?
  225. brake wear light stays on after replacing brake pads:sad:
  226. Gasoline Smell in the Trunk
  227. 94LS400 - 4300K lows, 3000k fogs, Polarg M4 corners
  228. T Belt Am I on borrowed Time ?
  229. tweaking stock suspension '98
  230. How do you remove corner lights on a 94?
  231. 1991 ls 400 transmission problem
  232. Transmission Throttle Cable Adjustment
  233. Please help me ID this part
  234. Difference of 1LS & 2LS
  235. Electric cooling fan
  236. Does 2nd Gen suffer from Trunk harness problems?
  237. 2000 LS suspension
  238. Fogging
  239. So after looking I have found this and brought it home today!
  240. Multi Function Display - Incorrect info
  241. 1999 LS400 Owners
  242. 1st gen LS400 or 96-98 acura Tl?
  243. Reasonable Cost? Transmission Pan Gasket Seal
  244. Transmission: Drain or Flush?
  245. thoughts on aftermarket oem Air struts?
  246. 00' seems to be running rich
  247. Does anyone know how to change "door open" or " seatbelt" Light bulbs?
  248. Radio unit replacement with GPS/radio unit >_<''
  249. 91-92 vs. 93-94 Bottom Panels
  250. '94 LS400 Front Rotors & Pad Retainer Question
