PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Problems after installing new stereo - 1997
  2. Creaking in front brakes resolved
  3. 93 LS w/ is300 or mazda wheels?
  4. Tranny Code
  5. Passenger seat belt problem HELP
  6. 1999 Lexus LS 400 fuel pump
  7. Too high idle with A/C on in gear
  8. New owner. Just bought my LS this past weekend.
  9. Oil leak?
  10. Coilovers, grille, muffler delete etc.. = almost done ;)
  11. NEW 93 LS400 owner w/ NEW IDLE PROBLEM!
  12. Rear axel 91 LS400
  13. UCF20 steering rack mount bushes?
  14. Rear Brake Sliders
  15. LS400 starter challange
  16. New problem
  17. Who has had to replace their EGR valve?
  18. P0340 - Camshaft Position Sensor Problem. Help !, Running out of options
  19. :::Aftermarket hub for 1991 LS400?:::
  20. Heated seats not working
  21. Planning on getting a new exhaust system, need advice
  22. Remote Lock/Unlock - How to increase range?
  23. Popping or clunking sound from rear
  24. antenna alternatives?
  25. safe to drive with knock sensor error 52?
  26. Frankensteining LS400's
  27. trunk leak!
  28. Cracked woodgrain wheel repair
  29. Recent front conversions? I've searched
  30. Theft Deterrent System Problem
  31. Yokohama S. Drive tires
  32. White 92 LS with GOLD Sportmax 962's
  33. LED DRLs need module?
  34. UCF10 OEM add on lip/skirts?
  35. Help LED Strip wiring
  36. Factory Muffler enhancement. Pics inside.
  37. 98 LS400 Check Engine Light
  38. 1996 LS400 Suspension Questions!!
  39. 2000 w/ Nak wiring diagram/pinouts
  40. Rear Drop in Normal Mode
  41. Problem with a 92 LS
  42. installing megans
  43. newbie introduction!
  44. 94 LS overheating, yes i searched.
  45. Changed fuel filter, learn from my mistakes
  46. Electrical Issues on 95 LS400
  47. 98 LS400 break wear light just came on .
  48. Curious....swap no not the 2jz
  49. Car is GREAT on hwy but TERRIBLE in city?
  50. '93 ls for sale with 13,000 miles
  51. Looking for engine for 95 Ls400
  52. Had to put my spare tire on. Glad I don't have to drive like this for a long time
  53. LS400 taillamp failure
  54. give your thoughts
  55. Help ID'ing 92 Dealer Option Wheels
  56. New Owner 1992 Ls400
  57. My A/C Journey - 91 LS400
  58. 98LS400 starter replacement ALMOST went flawlessly
  59. New Lexus Owner. 92. Intro + Power Steering.
  60. About to Check Out a 90 LS Got A Few Questions
  61. check engine light
  62. Ksport Airtech Air Suspension system
  63. Turn on headlights and Reverse light comes on
  64. Replacing 93 LS400 Nakamichi with after market radio
  65. Which NGK plug to use in a 99 LS? 3764 or 4589?
  66. Top Gear Features a Lexus LS 400
  67. Megan Coilover settings
  68. Center Instrument console controls
  69. LS400lifes LS #392 rare!
  70. Springs in seat worn out.. Any suggestions?
  71. Rear Half Shaft DIY
  72. Just picked up my long-awaited LS400!
  73. No radio 99 LS400!!
  74. Ok ,my 98 ls400 starter is finally limping on it's last leg .Quick question
  75. Just bought a new 98 LS400...have some questions.
  76. Anyone tried SDSTOYO AUX Input?
  77. Slow accelaration, 0-100kph (0-62mph) in 10.3 seconds
  78. seat problem...
  79. Popping sound front brakes-maybe??
  80. 12v power behind glovebox?
  81. Do I Need An Alignment?
  82. Brake Caliper Sliders
  83. Need to change catalytic converter for LS400,1996
  84. Charging / AC Problem...Need Help!!!
  85. a lone pic night with 2 slightly modded LS400s. 56k warning.
  86. speedometer troubles
  87. 99 LS400 Headlight HID bulb replace
  88. Received my poly strut rod bushings today for 1LS.
  89. 2000 Tool Kit Question
  90. Need help with OEM part number !
  91. Egged LS400
  92. 93 ls acting crazy!!! help
  93. 93 Steering Rack Boot
  94. Car overheats with air conditioner on
  95. where can i get...?
  96. New tension rods on a 1998 with 80k ?
  97. Two interior noises-GOING CRAZY!!!!!!!!!!!
  98. LS400 started as a gauge cluster problem now it wont start.
  99. cant find the low pressure air conditioning port on my 91 ls400
  100. need some help
  101. blower motor bad?
  102. Suspension Install Tips
  103. Cutting Rear Bumper For Mufflers
  104. "R" light stays on when headlights turned on
  105. For sale items go in classifieds only please, not here
  106. UCF11 (1993-1994) - Door Moulding/Trim
  107. Need to Replace leather console cover. 95 LS
  108. Ignition question for UCF10
  109. AC condensor fan want turn on
  110. Air-con sorted
  111. UCF21 Stock Air Suspension??
  112. Replacement Leather = side airbag problems?
  113. UCF21 Shift Knob thread size.
  114. AC/condenser fans questions!
  115. Considering upgrading to UCF 21...
  116. timing belt question
  117. Replace Fuel Injectors how often?
  118. Help finding Wiring Harness
  119. rear axles out
  120. Suspension question and which year to buy 96 97 or 98
  121. 1992 ls 400 noobie got question can anyone help??
  122. My 1995 Lexus LS400 (56k take a nap)
  123. 98-00 ls steering wheel
  124. Fun with Starter Replacement - 96 LS 400
  125. help power steeing not working
  126. UCF20 teaser pic
  127. Tire problem
  128. ~Info needed on 2JZGTE in an LS400~
  129. Low pressure air conditioning port on 1996 LS?
  130. Rear Differential Problem
  131. Possible transmission problem? ('91 w/187K)
  132. Help needed no power when in gear '94
  133. Coilover install, anyone has it documented?
  134. Progressive Foam Bump Stops
  135. removing shift knob on 98 LS400
  136. Air suspension (UAS) installation on my 97 LS400
  137. My new addition, 99 ls400
  138. Tyre choice
  139. Does Minor Leak in Steering Rack and Pinion Matter
  140. Headlight adjustment
  141. Preparing for a small road trip
  142. Is-f
  143. transmission fluid leak
  144. 96 ls400(*help*)dead shocks(need help)
  145. Retrieving Airbag codes from a 1991 LS 400
  146. Opportunity to buy a 96 1UZFE for cheap...
  147. How to test sending unit and gauge
  148. 2 questions about a 99 LS4
  149. installing side airbags on a 1996
  150. Bilstein Air Suspension
  151. 94 model wiring on sending unit
  152. still feel engine running
  153. Heater problem
  154. Radio Problem
  155. Think it's time to introduce my car, a -94 LS400 (UCF11)
  156. Looking to purchase my first LS
  157. Anyone know what year LS this is?
  158. Renewing 98-00 Headlight At Low $$ // DIY // Photos inside
  159. Bendable Curtain Tracks
  160. How my Ls40092 to Last gen.
  161. Question for the Experts....
  162. strange electrical happenings on my 92ls
  163. Projectors
  164. UCF20 LS400 - Complete bush kit?
  165. Body Parts
  166. Just picked up a 96 LS400
  167. Ecm location on a 1992 ls 400
  168. 90 LS400 Center cap
  169. Transmission Hell :(
  170. Front Dash removal (help meeeeeee) '92
  171. 1993 ls400 poor acceleration
  172. Brake wear sensor.
  173. Looking to buy my first Lexus, is this a fair price? Pictures included
  174. Which springs
  175. Buying my first LS400
  176. 4 piston caliper depth ?
  177. About to significantly modify 1997 LS400. Thoughts/opinions? What am I missing?
  178. Oxygen sensor 95 LS
  179. Another Newbie from North West England
  180. Looking for opinion on coilovers on first gen
  181. 90 LS400 Transmission issue!! :/
  182. Switching to Mobil 1 Synthetic?
  183. Transmission Question 91 LS 400
  184. Please help. What is this light?
  185. Newbie from the West of England!
  186. $1,500 a piece for headlight assemblys???
  187. NO aftermarket sway bars for my car?
  188. Passenger Side Mirror Replacement
  189. 99 LS400 O2 sensor
  190. WANTED: LS460 wheels on 1st gen pics???
  191. Need advise on buying code reader
  192. 00' tilt wheel only extending 50% of time on start-up?
  193. RARE Instrument cluster problem. Stays ON
  194. Anyone have a picture of the timing belt tensionser?
  195. Just bought my long awaited 95 UCF20
  196. clicking when gas is pressed
  197. PIX 4 Colorado Springs member @ CU boulder car show
  198. Should I Replace My Struts While I'm At It?
  199. Strut mounts
  200. Wont Start... =[
  201. chrome trim
  202. 6" Freeplay?!
  203. Help needed on warning lights
  204. Considering 96 LS400 or 98 ES300
  205. Rack and Pinion.. quick question.
  206. 1996 Lexus 400 LS 400
  207. I hate standing water...
  208. I'm so pissed off!!
  209. just bought a 96 ls but smokes when i 1st turn it on
  210. quicky pic from last weekend.
  211. What are You Running on Your LS400?
  212. 94 ls400 radiator fan problem??
  213. Oil changes every 5000 ?? ON REGULAR OIL!!
  214. Tail lamp light out but bulbs and fuses are good?
  215. Steering wheel problem
  216. Ls520
  217. Pic of my LS 400
  218. Vibration at Highway Speeds
  219. Brake making noise after tuneup.
  220. Thumping noise coming from front suspension
  221. 94 LS400 Parts Questions
  222. Temprature Sensor and Spring '99
  223. (looking at a couple of cars) Ls400
  224. Finally, back to where things started, well sort of... (New addition w/pics)
  225. Window tinting
  226. Limp Homer Ain't Limping Now !
  227. Steering Wheel Buzz??
  228. bodywork done '95
  229. CD player
  230. Im swapping steering wheels today !! 98 LS400
  231. Megan Install Trouble.
  232. OMG This Noise Wont Stop!
  233. Spilling gas every time i fill up?
  234. where can i buy megans coilover
  235. Stalls in warm/humid weather and/or low gas
  236. Front Seat Swap, Pics Inside
  237. 90 LS400 Firewall diagrams? Any Available?
  238. Rear UCA Replacement
  239. no start
  240. Hood Dampers Question
  241. [?] Common Problems?
  242. Headlights dont work on 96' Ls400
  243. 10W30 or 5W30 Synthetic?
  244. 1990 ls400 high idle w/ MAF, low idle but no go without MAF...
  245. Rubber Bushings from another make/model
  246. Cheap fix for old bumpers
  247. Bilsteins/stock springs vs. H&R/KYB GR2s
  248. Headunit Installation
  249. Car jerks when shifting from Park
  250. coilover springs for UCF10
