PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. LS400 Camber Arm
  2. AC engaged, idle/engine RPMs dip...
  3. ABS and Trac light on...
  4. 1994 repair manuals
  5. 1999 LS400 front suspension question
  6. Problems with fuel system (I think anyway)
  7. AC relocation and Stereo
  8. removing wax stains from lower panels
  9. lexus key Immoblizer questions?
  10. Engine start problem
  11. Gear not catching when car is cold
  12. Gauge lights went out
  13. My Vibration From Hell '91
  14. help me with some mod choices!
  15. I dont know what its called
  16. Back from the shop!
  17. Rust spot inside door area - Pic included...what should I do?
  18. Flushing PS fluid... while the car is not running?
  19. 91' LS 400 Fuel Guage Issues...Need Info PLS
  20. Car will not crank 1996 security issue?
  21. Electric Fan swap, Hayden temp sender, and wiring question...
  22. Valve Adjustment Shortcut?
  23. Power steering fluid?
  24. Brand new owner of a 1993 ls400. NEED ADVICE! PLEASE!
  25. chips
  26. Help My LS is Overheating WHy??
  27. 98 LS400 wiring question
  28. Excellent LS Shift Knob Replacements...
  29. Battery Shocks Hard!!!! Need Help
  30. Larger Capacity Oil Filter for 1999 LS400?
  31. Remote start tach signal?
  32. First gen seats..replace or not?
  33. Will 2nd gen calipers fit on a 1st gen?
  34. My first lexus 1990 LS400
  35. 1999 LS400 Air filter: OEM vs Purolator
  36. My "New" '92 Lexus LS400
  37. found a 90 LS on craigslist and i bought it!! 56k bad idea
  38. 99 LS: just changed rear brakes, now something is rubbing
  39. Possible stupid thread... pics of 95-97 with OEM fogs?
  40. 1995 LS4 Trac Control issue???
  41. 1991 LS400 engine overheating! NO LEAKS - Help!
  42. new owner of '96 checking in
  43. Can you buy body bolts at pep boys?
  44. 93 LS400 engine miss
  45. Compression test instructions
  46. Any idea how to get this piece off?
  47. O2 sensors...universal or OEM?
  48. Changing hids on hid equiped cars
  49. Clear Lense for the 1LS and 2LS...yes or no?
  50. 91 ls400 trunk wont open
  51. ls400 front caliper differences
  52. Keyless entry not working good
  53. Broken ignition coil plug
  54. 1998 LS400 -- does failed O2 sensor require replacement?
  55. Anyone know the cladding color code for 94 LS400 Alpine Silver Metallic?
  56. broke timing belt= trashed engine?
  57. Power steering flush
  58. Cheap fix question
  59. Trouble finding driver side fog light reflector
  60. Any reputable sites to buy JP stuff from?
  61. *rant* Power Steering/Alternator
  62. Intake Question for 98 ls
  63. clunking when braking
  64. 91 ls400 Shifter problems...please help
  65. '96 LS400 Starting (Very Confused)
  66. DIY Engine and Transmission Bushings Replacement
  67. 99' ls ideas on mods?
  68. How much can i get for my 1996 ls400?
  69. Air Shock Fix? or plain ole Luck
  70. Mags/wheels for 95 LS 400
  71. Basic Maintenance
  72. Adding Aftermarket Sub to car with amp; Wiring quesiton
  73. vvti control with Greddy v-manage?
  74. i need a pic
  75. Need to find one
  76. 94 LS400 Brakes problem
  77. 96 ls400 when I shut it off it makes a noise
  78. Whats the name of these rims?
  79. Power steering ICV fix, and then.....
  80. Another fitment/tire size question..
  81. 94 LS Driver seat DIY FIX
  82. Worth buying?
  83. aftermarket navigation experience
  84. AC compressor clutch
  85. Chinese Puzzle tilt-telescope
  86. Just came on the market in my town, a modded 91 LS400
  87. Where is the location of the Running Light Relay?
  88. Finding / Identifying parts
  89. ls,sc,supra,gs interchange thread
  90. My 93 LS400...
  91. Keeping stock Head Unit vs Aftermarket
  92. are all ECU 1990-1994 interchangeable?
  93. Last visited here on 1-25-04. which side is bank 1?
  94. Should I run Synthetic on next service?
  95. the need for speed!!!
  96. hey im new
  97. Where to get car serviced? Dealership? Private?
  98. Dead tachometer on start, then came back to life
  99. Tire sizes? 19x8.5- 19x10...help =)
  100. new windshield/no wiper fluid
  101. Intake Hose
  102. 98-00 owners need you to bust out the measuring tape
  103. Custom steering rack for 95-97
  104. Better off with a 95-97 w/ low miles, or a 98+ w/ relatively high miles?
  105. New rear lower control arm/trailing arm time?
  106. 92 Lexus LS400, Need wiring diagram for dash trunk control to trunk latch
  107. How long does it take for a timing belt to crack?
  108. Anybody have an 1g oem speaker handy (measurments needed)?
  109. OBD1 Engine code 25 and Trac code 51
  110. Introduction ('99 LS400)
  111. My LS is DONE (well, for now)
  112. brake question
  113. 2000 ls 400 exhaust leak and engine vibration
  114. 94 Lexus LS400 suspension problems
  115. Help with vibration 92 ls400
  116. Shift Indicator Replacement
  117. Bimetallic Valve
  118. Blown A/C??
  119. Another question on CEL Situation
  120. Picking up a 91 LS400 tomorrow morning!
  121. MY HEaddd Lightss
  122. Why is my A/C headpressure sooo high?
  123. Trac off light?
  124. Need some advice on my 1991 LS400
  125. 99 LS Power Steering Fluid or ATF ?
  126. can someone help me!!!
  127. 91 LS4 Dying at stop lights...
  128. washer spray nozzle adjustment
  129. Anyone have pics of any 1st Gen Silver LS400s w/ wheels?
  130. BCR coilovers on ls400
  131. Alot of TRAC trouble codes in my ls400 :-(
  132. Need Help: Tilt Steering
  133. Power steering pump knock?
  134. The economy lamp always lights green
  135. Picked her up! 94 LS400 - Need help with a few problems!
  136. Check engine light on, O2 Sensor code
  137. Fitting 18x10s
  138. LS400 AC fuse blows
  139. Hey guys new member here and yes already a problem.
  140. leak in trunk
  141. Clear headlights on 91?
  142. 1998 LS400 Fan Speed Controller
  143. Ooooooooooo! Ya'll gon' be mad!
  144. Electrical Problem - HELP NEEDED
  145. Hood problem.
  146. Rear control arm/carrier/trailing arm part numbers and sources?
  147. Not sure what happened.
  148. Just test drove a 99 LS400 and a 99 GS400
  149. 1994 ls400 - alarm randomly goes on
  150. Key-off operation function power windows?
  151. 1993 LS Firewall Location
  152. '95 LS 400 Wheel fitting.
  153. New member intro and ??
  154. Replacement sub for UCF11?
  155. Anyone else have their rear axle bolts fall out by themselves?
  156. Wheel Fitting
  157. 99 LS chrome bumper inserts.....where to buy?
  158. 93 LS400 boiled oil.
  159. Beck Arnley Parts
  160. coilover settings
  161. What has to come apart for EVAP replacement?
  162. 93 LS400 Exhaust opinions and advise needed please!!
  163. Oem air ride
  164. Max Camber
  165. Looking for an LS around $4,500 or so...
  166. hey guys and girls i have a question? (coilovers)
  167. Help with 1997 LS 400 audio
  168. Why is my '96 LS shifting so early?
  169. Replacing emblems on '96 LS400
  170. O2 heat sensers gone bad... i think
  171. Need help 96 Ls400 (P0340) hows it look like???
  172. Exhaust Cam change make hp?
  173. Buying an LS400 with 250K miles....
  174. variation of instrument lighting problem
  175. Going to pick up my new 1994 LS400 on Saturday
  176. disconecting traction control on a 92 ls400
  177. Factory security system
  178. Anyone here bought the 98-00 LED Tail lights on Ebay?
  179. HID Question
  180. 1992 ls400 traction conrtols issues?? !!help!!
  181. Worth putting a dual air intake?
  182. upgrading to 145 amp Alternator
  183. fuel pump question
  184. Oil Leaks with Synthetic Oil
  185. Electrical problem
  186. Vent Shades?!
  187. Ignition Tune Up - OE Vs. OEM
  188. "Take To Car Dealer" Warning Light
  189. transmission shifts BUT.... problem?
  190. Possible facelift 91 > 95 hood and grill ?
  191. JIC Coilover Thread (Post Your Pics, Settings, and Discuss Please)
  192. lights stay on? 91ls4
  193. 1993 LS400 driver's window problem
  194. My 98 ls400
  195. Advice: G37 wheels on LS1?
  196. Flushing Brake Fluid
  197. '98 windshield replacement & cleaning or replacing the headlights
  198. 90 LS Weird Noise over 60 MPH
  199. New to the forum. checkout my ride!
  200. 99 ls 400 key battery screw
  201. Window problem fixed!!!
  202. Installing New Free-Air Sub
  203. Helix AER Air Suspension Kit
  204. newbie needs some tips please
  205. in dash navigation HELP!
  206. 93 ls 400
  207. Power Door Lock Problems - 94' LS400
  208. Ball Joint question,, fresh perspective needed
  209. Question on R-spec Data System ASC680 controller.
  210. I Checked The Air Conditioning Diagnostic Codes
  211. Out with the old, in with the new. Look!
  212. Synthetic throughout drivetrain
  213. EGR Pipe DIY
  214. Electrical Problem
  215. Death of a starter
  216. Starter relay...
  217. Warning light
  218. 1LS wheel size question
  219. Lexus badge on Toyota grille
  220. Dropped PCV Valve... Can't get it out... Help
  221. ECM source voltage issues.
  222. a/c cycling on and off anyone?
  223. Shudder, Stumble at Low RPM ?????????
  224. Idle going up and down
  225. I'm back, plus question about dual filament brake light.
  226. Looking to buy '98 LS400, should I be worried about it's high mileage?
  227. European/JDM Lip
  228. Pics of 'uneven' tint on an LS? Cant find any
  229. Question for LS Experts
  230. 2000 ls400 mouse smell when in resirc
  231. coilvoers
  232. Lexus LS400 head gaskets
  233. Timing belt change.
  234. Looking for parts list for 91 ls400
  235. anyone put hydros on a ls? looking for ideas here
  236. a little bit lower! new pix! more mods!
  237. 17" IS rims
  238. Ways to tell if LS400/430 has air suspension by VIN?
  239. wiring!!!?????
  240. My LS won't peel out!
  241. Driver window problem
  242. any one wanna trade grilles? i have the toy logo
  243. help LS400 stereo
  244. Check options using VIN number
  245. ♫ DO™ - Picture Me Rollin' ♫
  246. 92 LS400, Radio (Head Unit) dead after battery replacement...
  247. Problem Removing 96 LS400 Rear Dome Lights
  248. $$$96 Ls 400 Power Steering Leek$$$
  249. HELP!!! car dying, but only on hot days
  250. 93 LS400 serious hesitation/ bukling problem, need HELP!
