PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Battery Powered LS400!!!
  2. Horn stuck on, searched.
  3. Help! Steering rack solenoid needed... where to get one?
  4. 92 vs 93-94 Headlight Question
  5. Tilt & Telescoping Steering Control -Tried Search!!
  6. LS w/ HID Projector retrofit...
  7. Cluster problem. Have done searches
  8. Missing, gassy smelling exhaust, funny starting sound.. what happened?
  9. Front cigarette lighter removal
  10. Experience with 1992 LS400 I purchased
  11. Just picked up my new project ls400
  12. Stock tire decision
  13. 95 Air Suspension Struts
  14. rims - what size for '96?
  15. Leaky Temp Sensor in radiator and resevoir tube..
  16. Bought my LS400 today... '95
  17. Rough Start
  18. Random Misfire Check engine light VSC light
  19. wierd problems
  20. Door Handle Part Numbers
  21. weird noise from passenger side
  22. Looking for 1994 lexus lx speedometer
  23. Drive Belt Tensioner for the LS400
  24. help !!!
  25. Higher output alternators '95
  26. so its said...
  27. Window stuck down 90 LS400
  28. Drivers seat revisited
  29. Broken odometer
  30. Need Help, Broke o/d button
  31. 94 LRear Strut Rod Bushing Problem
  32. Sun Visors - First Gen
  33. Think with your dipstick jimmy!
  34. new owner with questions - clunk?
  35. If normal, where does your temperature gauge needle read?
  36. Aftermarket stereo install retaining factory speakers in 1995 LS400
  37. Inoperable steering rack solenoid? Bad solenoid or ?
  38. Which Vendors Sell Megan Coils for Good price
  39. New First Gen Engine?
  40. 93 LS with oil leak
  41. power steering pump screen? How to clean? Gen 1 LS400
  42. HELP I am looking for a Wizard for My 99 LS
  43. Are JDM mirrors different to US domestic?
  44. factory bbs rim parts
  45. A/C Compressor replacement
  46. Programming alarm beep/lights/etc.? 99 LS400
  47. traffic tickets for hid lights?
  48. 18" wheels on 99 ls
  49. What is 'EGR' in Lexus terminology?
  50. Nakamichi radio - constant low volume?
  51. wire of engine, pls help
  52. 90 LS400 repainted
  53. Considering a '94
  54. first gen ls400 bi-xenon headlight retrofit
  55. Front tag mount cover?
  56. Good place for pre purchase inspection in OC/Socal
  57. LS400 1990 painted already
  58. 1995 LS400 fuel gauge pegged to full
  59. High NOx: What to do?
  60. 5 speed ls400s has it been done before ?!?!?
  61. 91 with surging idle?
  62. Picked up a 97 LS400, some repair questions
  63. trac light on
  64. 97 LS400 Transmission Help
  65. Question about '98 LS400 purchase
  66. Mass air cleaning? Ls 400
  67. Quick question about window visors
  68. Front suspension clunk....
  69. transmissions
  70. Urgent... NEED suggestions
  71. three button remote problem
  72. Re-wire 1993 fog lamps
  73. Panfilo's 90 LS400
  74. ABS light? trac OFF light?
  75. help with programming 95 fob remote please
  76. 1991 Air Suspension Struts
  77. Valve train chatter
  78. 1991 ls 400 transmission slipping when cold
  79. Who offers quality ls 400 engines?
  80. Trac Problem
  81. New 94' LS400 Owner with a few questions
  82. please reply quick! new battery needed
  83. Looking at '93 LS 400 "Problem Child"
  84. "Stiff" steering (AT TIMES) '91 LS400
  85. possible to have lsd rear end on a 99 LS 400
  86. 92 ls 400
  87. High stoplight replacement
  88. Disable Factory Security/Alarm
  89. Noise, Smell, Smoke
  90. Swap 98 LS brakes into First Gen?
  91. Broken Door lock!
  92. air strut prb!!!
  93. air strut prb!!!
  94. 1st Gen Tranny Questions
  95. Broken Front Wheel Stud 98 LS
  96. Buying a 1990 LS400
  97. Need to find speed signal wire on 97 ls400
  98. LS430 18"wheels 5 spoke style on 99 LS400 - Which tires
  99. 99 LS needs supplys Oem if Possible
  100. passenger window switch
  101. 10mm wheel spacers (puredrifter very welcome)
  102. need help with timong belt change and code 13
  103. slow drivers side wiper
  104. Need help on options to replace 91 LS Air Suspension
  105. blue lexus emblem
  106. 92 headlight alignment
  107. 1991 ls 400 high beam on both sides wont come on
  108. Leakage
  109. front break pad change
  110. Billet Grill?
  111. Questions on Possible Purchase of 1996 LS 400
  112. what lip kit is this?
  113. How can I drain bad gas from LS400, hasn't been started in 2 years
  114. 1990 ls400
  115. Shaving the front of calipers on 95+ ls400, Please help me
  116. New 1997 LS400 Coach Edition
  117. Couple problems with my 92 ls 400
  118. Anyone know of a GOOD line filter?
  119. Oi, I think I blew a fuse... but where?
  120. New Owner: 99 LS400
  121. 2004 LS430 faster than a 98 LS400?
  122. help! radio antenna
  123. Clunking noise
  124. Trac off and Check Engine light appeared - Also PW Window issue
  125. What did I blow?
  126. Need help with suspension question
  127. Bottom engine cover screws / bolts
  128. How I remove the domelight lense ( cover ) on a 99 LS
  129. Does anyone have experience with rbwheels.com?
  130. ATE rotors - missing alignment screw holes
  131. Headlight retrofit
  132. Sunroof leak
  133. 1st gen air suspension problems
  134. Would you buy an LS400 with 188k miles?
  135. oil light and power steering
  136. i need help with wheel fitment
  137. Air struts. Are they interchangeable?
  138. 1991 fuel pump ecu
  139. Upgrading Wheels on 1992 LS400
  140. Stock 91 Ls400 stereo wiring color code question?.
  141. Where to buy coilovers for '96 Ls400
  142. Wiring OEM HID in non HID car
  143. HOLY Cow...is this right????
  144. how to update stock navigation system?
  145. 93 LS400 - where can I get a new speedometer needle?
  146. How would these look?
  147. Update: My 97 LS400
  148. 98 LS fuel filter location
  149. guage cluster removal
  150. HID light issue 1998 ls400..........
  151. My fog lights are stuck on!
  152. Alarm wont turn off and battery drains dead
  153. 1993 LS400 Climate and Radio LCD Backlight question
  154. LS audio. undoing a mess
  155. 1992 LS400 - Water sound in dashboard
  156. Newbie help On Purchashing This LS 400
  157. Possible 2nd gen purchase..
  158. Unboxed, pic----->
  159. Factory finish double din head unit bracket
  160. Bad Tie Rods?
  161. Headlight resto/polish kits. Has anyone used one?
  162. TRAC light stays on
  163. 96 Shifting Issue
  164. LS photoshoot
  165. New 99 LS owner Air suspension questions you have all heard before .
  166. Lexus BBQ
  167. 93 ls interior cleanup problem
  168. LS400 power antenna mast replacement
  169. heat and ac not working?
  170. How do I update the factory Nav?
  171. 93 LS 400 relay clicking on cold start
  172. Keyless entry need help!!!
  173. New 1995 OWNER!!
  174. Did all first gen LS400s have air suspension?
  175. LS 400 Envy
  176. Turn signal lens coming loose ('99 LS400)
  177. Help with belt tensionor
  178. buying a 98 ls400 with over 200+ miles
  179. New to Me 91 Lexus Ls400 got some Questions!!!!
  180. Picking up a '94 LS400
  181. Looking at 90 LS400 - couple questions
  182. 225/40/19 & 235/40/19 OR 235/35/19 & 245/35/19 on 19x9/10??
  183. Key stuck in Drivers Door & Cylinder Frozen
  184. Remote locks everything BUT Passenger door
  185. Car being too low...Relocate harness? weird noise
  186. Brakes shudder-98 LS400
  187. HELP PLEASE! Car died while at a stop
  188. Brake pad warning light on after breaking the sensor. Any fixes or how to disable?
  189. Airbag red light came up on dashboard
  190. 99 LS400 + 06 IS350 rims Pics
  191. Rear water bypass gasket part #
  192. 97 LS400 - No clock, outside temp or climate control
  193. delayed action after idle-up valve plugged...
  194. Will a 98 grill fit on a 97?
  195. Thinking about buying a 97 LS400
  196. new lexus 93 ls400 owner
  197. Water Sound in the Dashboard
  198. Front indicators - Question
  199. where can i get ls400 bodykits
  200. future mods...will it look ok?
  201. probably the dumbest question (how to remove dome light cover?)
  202. part number for glovebox bulb on 1st gen?
  203. Quick question!
  204. 18s vs 19s vs 20s
  205. Care to explain this to me? (LCA WTF)
  206. A different type of Air suspension problem
  207. Starter Help
  208. FREE Limited Slip Differential "LSD" mod
  209. New 92 1st Gen owner
  210. Frankly . . . 1st Gen Is Best
  211. 06 gs430 wheels on ls400
  212. Headers on 1998-2000 LS400s
  213. alternator oem or aftermarket
  214. Cold start problem - low idle.
  215. 00 LS400 Fog HID Convo question...
  216. New '95 LS400 Owner!
  217. help asap 1994 ls400
  218. No power to radio, power locks, and interior lights
  219. New, Looking at buying a '97 LS
  220. Urgent help needed! Car jerked,Stalled for a second or less while driving on freeway
  221. Starter Replacement Q's
  222. sc430 stock wheels will clear ls400 brake??
  223. Coolant tank cap / low coolant?
  224. Aftermarket Gauge panel/pod
  225. Car won't start, fuel pump staying on
  226. power steering pressure hose
  227. Sticker on my windsheild
  228. TOYOTA Filter CFM?
  229. Transmission messed up?
  230. New LS400 owner checking in
  231. Ride Quality: 16 vs 17 vs 18s
  232. 1992 LS400 - Air Conditioner problem
  233. 95 LS-400 Parts/Vehicle
  234. Antenna and acc wire to stereo not working
  235. 1st gen pulleys
  236. Driver's Side Speakers not Working '93 LS400
  237. 1994 LS400 Heater not working - Need Help
  238. Just picked me up a 97 LS400...
  239. Battery is dead.
  240. 1995 power steering rack leak
  241. Camber Kit?
  242. Help - Replacing Brake Bulbs
  243. My 92 ls400
  244. code 14
  245. Climate control/Radio indicator blank?
  246. where to get good HID kits for ls400
  247. Just rolled past 200,000 miles...
  248. Experts - HELP
  249. Questions on Factory 95 LS400 stereo
  250. Cabin Filter
