PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Will Lexus SUV wheels fit my 92 ls400?
  2. Some things just quit functioning.
  3. New LS400 owner 1996 blk/blk
  4. Clunk from right rear wheel area
  5. 1993 LS400 Slow Fuel Gauge Fix
  6. Picked up 1992 LS400 with 113k. (maroon, with pictures)
  7. Clicking noise from the rear
  8. the end.
  9. Clicking in steering wheel while turning
  10. Mechanic Says Lifters are Tapping?
  11. Front Crossmember Torque Specification
  12. Anyone have noticeable MPG improvement with new O2 sensors?
  13. Help with Transmission Slippage - 91 ls400
  14. Bad fan clutch?
  15. my ls400/sc400 and uncles
  16. Pot holes broke fan clutch bearing, strange?
  17. Tire Fitment Question
  18. 93-94 ECU part numbers?
  19. 1993 LS400 backfiring thru intake? Help
  20. PS Pump ReSeal Cakewalk
  21. Campfire in Passenger Seat
  22. Trunk won't open
  23. New LS400 Owner here!
  24. Crankshaft sensor
  25. a/c control assembly
  26. tachometer issue
  27. What's Good Pimpin's?!
  28. What about this: (LS seen for sale)
  29. What is Exhaust Pipe Gasket type in UCF20 ?
  30. Just changed timing belt, now coolant temp fluctuates '95
  31. 95 Ls400 Stock Headunit Problems
  32. need help with ls400 (lowering questions)
  33. Engine Oil level light
  34. My brake lights went out on my 93 LS400
  35. 1998-2000 White exterior color
  36. German Castrol 0w-30
  37. Buying a Ls400... What to look for?
  38. Whacked in the head...
  39. help
  40. Smoker - 400 ? How do you clean it up?
  41. still cold can i get some help please
  42. Im freezing and the heat dont work!
  43. to change or not to change ls1996
  44. Stupid Questions from a NOOB here
  45. Do Lexus bushings degrade faster than others?
  46. Bank 2 is it passenger side or driver side ?
  47. Fuel Light
  48. MY LS400 gave its life for me and my son...
  49. Help me diagnose heater issue
  50. cruise control
  51. 2 different Clips on the LS400 Calipers?
  52. What Kind of Cars Have You Owned
  53. Anyone have a stock right rear coil spring?
  54. Junk Yard
  55. Website for OEM parts?
  56. No power ('92)
  57. Slightly flooded interior! Energy being drawn! Help!
  58. 1990 LS400 dies when I turn on heater
  59. ls400 commercial?
  60. Oil Leaks
  61. What's YOUR LS cruising playlist?
  62. window visors?
  63. What's my prospective 98 LS400 worth?
  64. Engine Swap question
  65. 95 LS4OO / DataSystem ?? For the Experts
  66. need a favor from 2LS owners.
  67. Does anyone make performance tunes for the LS?
  68. Like Your Leather Interior?
  69. Suspension Questions
  70. Revere Polarity Jump Starting 92 LS400. Radio & More Wont Work
  71. Interior Light bulbs.
  72. Is this normal (jerky forward lunge after lifting off gas)
  73. Engine splash guard
  74. automatic transmission delay in engagement
  75. Broken door handle....any suggestions?
  76. 92 LS400 Won't Start After WaterPump / Timing Replacement
  77. Over heating
  78. Is my pad wear sensor alright?
  79. 1996 LS400 Transmissions
  80. Any pics of black wheels on a silver ls400? 98-00
  81. Paint Job Estimates
  82. Where 2FIND UCF10/11 EYLIDS???
  83. Just bought 95 LS what services are recommended
  84. Vsc isnt working....
  85. Noob here... with a 99 LS 400. Does it have air suspension?
  86. LS400 > LS430 .... ? am I wrong ?
  87. 96 LS400 Pwr Door Locks
  88. Starter problem?
  89. $110 later, CEL is on again!
  90. Oil leaking into/around one of my spark plugs
  91. LS, VVT sensor malfunction?
  92. Adjusting the headlights
  93. 91 ls 400 oil light still on
  94. 1990 LS400 power window switches
  95. Need help on my ls400!!!
  96. Air Runner
  97. Traction Control Light
  98. Spark Plugs and Wires
  99. Yikes, Overpriced LS400
  100. 1996 LS400 with the ABS Light on when driving
  101. Two questions about closing the door...
  102. Position light stays on!!!
  103. ls 400 electronic steering wheel adjustment broken
  104. 1991 ls 400 sub gone with wireing
  105. Just drove the car and parked and then try to go somewhere and the car wont start :(
  106. leaky sunroof in 93ls400!!
  107. Power steering hose
  108. 2000 LS front end compatible with 93?
  109. sc430 wheels on a ls400
  110. 1990 ls400 coolant bleed question
  111. UCF10/11 1989 - 1994 LS400 FaQ(Frequently asked Questions)
  112. 94 LS400 Electronic Mirror Switch - Broken
  113. Installed LED city lights, pics...
  114. EGR pipe
  115. LS400 Key transponder key receiver question
  116. Differences in '96 & '00 steering racks
  117. New member here - 93 LS400 traction control issues
  118. Spotted on CL: '98 LS400, $5800, 129k, Portland
  119. dreaded P0340 code
  120. 98 LS400 Steering wheel tilt not going in and out. Any idea?
  121. Interior renovation
  122. Vac Line on Power steering pump air valve?
  123. 94 LS400 Rotor Splash Shield Repair/Removal ???
  124. ps fluid question (type)
  125. Still rim shopping.. need opinions
  126. trailing link bushing
  127. skipping gears when car warms up
  128. Speedometer Reads Slow
  129. 95 LS400 Low Beam Problem
  130. Say what, $7,980
  131. a quick question
  132. Anybody install a Remote Start?
  133. Slight vibration at 2-3K RPM
  134. Any pictures of Lumarai wheels??
  135. driver side door jammed!!!
  136. warning light in instrument cluster!!!
  137. Replaced battery... now i hear beeping
  138. Best place to get a new key & keyfob for a '93 LS400?
  139. Would like your feedback on '92 LS400 please
  140. Looking at a 1995 LS400... Opinions
  141. Some experts' help needed
  142. help advice for a (maybe) future LS owner
  143. CNG conversion for 1995 ls400
  144. 22inch on 2.5LS? Yay or nay?
  145. Headlight Question
  146. Leaky Air ride on a '91 LS
  147. Total Noob air filter question
  148. Bubbles in my PS reservoir
  149. I think my tranny is toast after 301k miles 1995LS
  150. alternator plug seems to big
  151. ls 460 rims
  152. 1991 Cat/Muffler Delete
  153. Ram Air/CAI?
  154. GPS vs Speedo
  155. At speed and let off gas car will jerk?
  156. Few Issues With My 91 LS400.. Plz Help
  157. Power Steering ACV plug question
  158. Fun Day at the Yard :)
  159. Semi-Newbie 95 LS400 Intro "Have to Upgrades"
  160. Gauge show low temp
  161. Someone with service manual please help!
  162. 1995 LS400 Cluster light not working
  163. Soft Brake Pedal/Goes to Floor
  164. Radio HVAC controls paint color or code?
  165. Sold my beloved 95 LS-Thanks for all you help
  166. How hard to change rack and pinion
  167. 1gen LS owners, got a question...
  168. Just changed all my interior lights to SMD/LED bulbs!!!
  169. Properly resetting the CEL on a gen 1 LS400?
  170. New owner of 93 LS
  171. DIY for rack and pinion swap?
  172. Can I get aftermarket heated seats?
  173. Which is fuse for brake lights?
  174. Vague steering on my 2000 LS400
  175. Chrome Trunk Bar
  176. Excessive Fuel Consumption/Poor Gas Mileage...
  177. noob question, car not gonna be driven for 1 month
  178. anyone replace doors?
  179. first gen fog light problem?!
  180. Headlight bulb question
  181. New with a headlight worrning
  182. suspension bible
  183. Tires rubbing
  184. Steering Damper
  185. Trunk seal
  186. HANDLING SETUP - 95+ LS400 DF210's are wayy too soft.
  187. Is There A Secret In Removing The Rear Panel To Change A Brake Light?
  188. '99 LS CEL & VSC Light on...
  189. OZ Canyon II's on a 1st gen ls?
  190. 91 LS400 - check engine light is on... code 71
  191. 2.5LS Newbie needs some helps. (I searched)
  192. Snow troubles
  193. adding emblems?
  194. '96 LS400 Misfiring Cylinder #1, Throwing code P0301
  195. seat motor fuse
  196. 97 ls400 front brakes DIY
  197. air suspension leak question- '92
  198. flooded trunk
  199. Sunroof sags
  200. 94 vs 98 interior
  201. Shocks/Struts what???
  202. And the pulleys go squeak, squeak, squeak...
  203. Why won't my 1993 ls400 shift????
  204. Idle-Up Valve Leaking '97
  205. Air Suspension?
  206. What does your LS sound like?
  207. GS300 2006 rims on '95 LS400?
  208. Pulls to left while braking..
  209. New key blade in remote shell?
  210. Help me find headlights..
  211. Recommend a strut..
  212. Dashboard Lights Came On While Driving & Car Wont Start
  213. not so happy holidays!!!
  214. 2.5LS Needing foglights, where to buy?
  215. wheel spacers
  216. New member, Need help no power.
  217. new to the site, my 91 LS
  218. Engine Noise Ls400
  219. What size winter tires should I run?
  220. 1st gen ls alternator
  221. 1991 Headlight confusion..
  222. 1992 LS400 Heater doesn't work!
  223. Anyone using rubber pads in between their top mount &UAS bags?
  224. ls 400 from cali
  225. Brake Pad Selection
  226. Had Throttle Body Cleaned - What A Change! Also, My Power Steering is working again!
  227. power steering leak driving me crazy
  228. LS400 Replacing Turn Signal Bulb - How to?
  229. tires and gas mileage
  230. Cleaned solenoid/pump screens, still heavy steering - who has plugged their ICV?
  231. Snapped bolt head off Drive belt tensioner
  232. Has anyone dealt with rbwheels.com before?
  233. Valve bent
  234. Alarm issue
  235. Fitment help
  236. Ls400 Sound system issue!!!
  237. Trans slipping then OK then not
  238. Something wrong up front!!
  239. It's in for winter :)
  240. The clearer the better!
  241. Power steering leak question
  242. LS400 Catalytic Converter Removal?
  243. code 25 1990 ls400 running lean
  244. snow tire rims for 99 ls
  245. ucf20/21 taillight diff
  246. 97 LS400 Antenna Mast Keeps Breaking
  247. New Guy, 99 LS400 a starting issue
  248. New member Couple questions
  249. Air struts
  250. Body kits
