PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 92' sc400 rims on 92' ls400
  2. what is a good brake upgrade for a ls95
  3. What are you using to add ATF?
  4. Nav system
  5. Catalitic Converter Repair
  6. Please help!
  7. Turn signal relay removal?
  8. Where can you buy amber corners?
  9. Inexpensive 90 LS Brake Upgrade?
  10. Help Family
  11. speedometer calibration
  12. Diagnosis Codes PO170 and P0115
  13. hard shifting or not shifting
  14. looking for some help
  15. 1993 LS400 Passanger side window motor problem
  16. 1990 - 1994 LS400 No Seatbelt Tension Fix (kinda)
  17. 1999 Ls400 Needs Left Catalytic Converter Replacement, but $3600 at the dealer...
  18. Location of NO.1 and NO.2 Height Control Relay
  19. 95-97: crank pulley removal question
  20. will speedo needle from 90 fit a 93 cluster?
  21. bellezza curtians
  22. Creative ways to hide a 2nd key????
  23. 265's
  24. Help~ blowing smoke
  25. High Idle Problem
  26. Anyone have pics of the 18" 350z wheels of there LS400?
  27. lowering spring question. eibach's
  28. 1992 Sunroof issues HELP!
  29. 1996 ls 400 nakaminchi stero Help Please
  30. Differential leaking [90 ls400]
  31. 95 LS: Specific fitment question (I have searched already)
  32. 1998 ls400 lsd
  33. Bumper conversion info!!!
  34. Will these wheels fit my 1990 ls 400
  35. Alternator brushes - old vs new
  36. wheels and coilovers on
  37. Ls400 Forum Rant and Suggestion......
  38. Lexus Enthusiast with Maintenance Question
  39. how big can i go with tires?
  40. sc 430 rims on my ls
  41. Battery drain? Bad alternator? 96 LS4
  42. Odd Question of the Week - Moon Roof Question
  43. Opinion on NANKANG NS-II
  44. new to the forum
  45. Where does this vacuum line go to?
  46. An odd request for you LS guys
  47. i smashed it!!!
  48. A/C valve core replacement
  49. New to this, Need Help!!!
  50. Making my own Bushings.
  51. To Paint or Not To Paint
  52. Power outlet and heated seats question...
  53. Odd transmission problem(i think)
  54. 1992 LS 400 HELP Tail Light Warning stays on R on dash lights up when brakes are hit?
  55. 1998 LS400 power steering oil leak
  56. 1998 ls400 hi-speed run
  57. LS 400 Cloth Seats
  58. Strutmasters Vs. Arnott
  59. 1991 Lexus LS400 Pingind and Jerking Badly
  60. Questions regarding engine replacement in 1990 LS400
  61. 91 ls wont move until its warm..
  62. Help help help
  63. Will Tundra headers fit the LS4?
  64. Stereo Install...
  65. trying to help my grandma out.
  66. My 96 LS4
  67. Replace Steering Wheel
  68. 1998 LS400 Left Turn Signal
  69. Vacuum valve
  70. Bucking on hard acceleration
  71. coil
  72. 91 lexus LS 400 drinking gas & loss of power
  73. rims for a ls 400
  74. 98 LS400 Amplifier
  75. Front turning light only one set works
  76. 1991 LS400 1UZ-FE Timing Belt
  77. New here from Mo.
  78. How to remove Idler Pulley on 92 LS400?
  79. How to Remove 1990-1994 LS400 Steering Wheel-- How??!
  80. LS400 Brakes question...
  81. Steering damper update
  82. rough idle in grear, Check VSC light, CEL, cylinder misfire HELP!
  83. Spark plug preferences and a few ???s (96LS)
  84. Suspension troubleshooting
  85. No Spark
  86. Power steering fluid in my PS pump! Oh No!
  87. Rattling Noise driving over bumps low speed
  88. tie rods and ball joints and tranny mount
  89. Check engine AND TRAC light blinking with bad miss....
  90. Thoughts on Exhaust Tips
  91. Trouble Shooting the Susp/Steering
  92. 1997 'Hi Spec' LS400
  93. Transmission
  94. 91 LS 400 US spec EGR problems, fault code 71
  95. Reintroducing me and my car
  96. '98 LS400 limited slip diff
  97. Climate control backlight / radio etc
  98. 1990 lexus ls 400
  99. Official Lexus Parts Guy?
  100. 1991 LS 400 Won't start after battery died
  101. I'm Baaaackkkkkkkkkkk..... Woot Woot
  102. 94 LS400 side PINSTRIPES: Above or Below the side crease?
  103. 1994 LS400 for $800 - Should I buy it?
  104. Cassette Player No Longer Working
  105. 93 LS power window problem
  106. Running lights turn themselves on
  107. 1991 LS 400 Tweeting Sound
  108. Sticky Caliper
  109. 1994 LS400 Trunk Mat???
  110. 1992 ls 400
  111. 95 Stock Upgrade Exhaust
  112. Seafoamin the Lexus
  113. I searched for wheel fitment 1st: 96 ls
  114. Temp Gauge Issue ?
  115. LS Cigarette Lighter Fix (Tutorial)
  116. MAF to MAP conversion
  117. Windows Tinted
  118. Fuel Gauge Fix Tutorial 93-94
  119. Flip Key Remote
  120. ALLDATA vs Hanes/Lexus Service Manual????
  121. Removing cats 93 LS400
  122. 98 ls400 cuts off when coming to a stop help!
  123. crunching noise
  124. Reverse shifter.HELP!
  125. battery keeps dying
  126. Ls air suspension problem, Please help!
  127. Aftermarket Amp install (with subs)
  128. Electric Fans + Hydrolic Fan???
  129. Cant seem to find this part anywhere....
  130. Brake Issues ?
  131. What to look for when buying a salvage engine?
  132. LS400 Smoke ??
  133. 1991 ls 400 electrical problems
  134. Will 2000 Wheels fit a 90 LS?
  135. Alarm problem
  136. "no bulb" bumper light fitting - what's it for?
  137. 1990 lexus ls 400 ( ignition lock cylinder) how to remove old & replace with new,HELP
  138. Growling/ Moaning Noise when cold.
  139. I now know why the CD changer has been reading "error"
  140. front clunk.. wheel hitting steering?
  141. new member sayin hi
  142. Manual tranny??
  143. 1996 ls400
  144. 1996 ls400 code P0770 (ideas needed for fixing)
  145. 95 LS4 wiper motor not working
  146. Wind Noise at 40mph +
  147. new member needs help.
  148. Front Crank seal
  149. Low Washer Fluid light staying on
  150. 1993 bodywork/paint finished
  151. New brake lines
  152. New member and wanted to say "Hi" (pics)
  153. HORRIBLE pad wear!
  154. Need serious help
  155. 1993 LS400 driver side seat doesnt move at all
  156. is it okie for 90LS400 speed ?
  157. 98 LS400 front end creaking popping followup IT'S FIXED !!
  158. Is this a timing or a starter issue? please help
  159. Replaced LBJ & outter Tie Rod end Still making same noise
  160. Anyone have problems with their hood at high speeds?
  161. Finally got to look under my car!
  162. Linglong tires Yay or Nay
  163. Do your phone still works in your LS 400
  164. Lower ball joint change .At wits end !!!
  165. Front End Swap?
  166. Changed Front Rotors - Question about pads ?
  167. Power steering
  168. '98 LS400 only momentary acceleration in drive
  169. Replacing front shocks on 99 Lexus 400LS
  170. New 91' LS400, news from the mechanic
  171. Help me with 90ls400
  172. Sudden Major Oil Leak
  173. 95-97 egr delete
  174. 1st Gen GS Wheels on 96 ls
  175. What part is this...and #
  176. 91 ls400 air suspension question
  177. New member from Denmark. (Pics of my LS400)
  178. Transmission problem '99 LS400
  179. Looking for a part number
  180. Pics of Exhaust Tips on 95-97?
  181. Tires for 95 LS400 with LS430 18's
  182. How to test LCD screen?
  183. Timing Belt - Dealer Vs. Independant
  184. 90 Ls400 Timing Belt Replacement Question
  185. 95 LS400 suspension question
  186. Help with options! Power steering pump
  187. Electrical/Engine Problem, please help
  188. 99 ls400 cat converter question...
  189. Lexus and vip style?
  190. 2002 LS - What's It Really Worth?
  191. Maintenance Question for 90 ls 400
  192. Anyone know where the fuel pump ECU is on a 98 LS400?
  193. 98 LS400 severe rear vibration
  194. Battery light. Alternator change.
  195. LS400 wood trim, is it real or just "wood looking" plastic?
  196. my new 1999 ls400
  197. New Owner
  198. Is there a install thread for springs? Write up.
  199. 93LS Locks won't stop engaging...
  200. If you need a 98 - 2000 repair manual, here it is
  201. Driver side window stopped working malfunctioned ! Stuck open please help!!
  202. Minor Accident, Need a fender
  203. EGR fault how hard of a fix is this?
  204. modifying air system
  205. A testament to the quietness of the LS' cabin
  206. Troubleshooting help
  207. Lowered with Tanabe Springs... still looks high? Tyre Size??
  208. To Paint or Not to Paint - '93 LS400
  209. Who else hates their ASUS poly LCA bushings?
  210. The squeak and blink
  211. Acc. power outlet question... No extra outlet when CD changer equipped?
  212. The speedometer
  213. two tone removeable???
  214. Excellent Information about toyota systems a must read for DIY
  215. new to the lexus scene.
  216. lowering my 1998 ls400
  217. random plugs and other stuff
  218. load squeaking from front wheel
  219. odometer
  220. Suspenstion
  221. Funny warning light
  222. changing powersteering pump 94 ls 400
  223. ASE 664 Datsystem
  224. Leather Seat Question - '93 LS 400
  225. cigarette lighter fuse blowing
  226. Key will not insert ..
  227. New member checking in.
  228. Replace tailight icon on No bad bulbs
  229. 95 ls 400 bumper
  230. Is LS400 < 2500 asking for trouble?
  231. Im going crazy!!!...just some quick suggestions please
  232. Suspension Woes!!!
  233. G35 wheels? 18x8 on 98-00
  234. LS400 w/ poor MPG, and Crank Pos Sensor code, CE light...?
  235. Will 07 ES350 wheels fit the 99 LS400?
  236. Automatic Headlights...Delay?
  237. DIY: Subwoofer install without drilling anything
  238. Traction control module
  239. antenna mast
  240. timing belt issue
  241. WooHoo I have heat
  242. Advice on a 1997 LS
  243. red toyota antifreeze in first gen?
  244. Knocking sound
  245. suspension ls400
  246. No Kickdown + TRC Errors 19 and 45.
  247. need advice
  248. strut problem? help!
  249. Fan shaking and making noise 95 ls400
  250. Exhaust crackling?
