PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 1997 LS400 Coach Edition Pics. 56k beware
  2. Polyurethane swaybar bushings available?
  3. help
  4. lower control arm strut or just the control arm?
  5. 94 LS400 Spark Plug Wires & Spark Plugs?
  6. Suspension on Late Model LS400
  7. I just get a "CLICK" on starting the car
  8. Found what I think is a good deal.....
  9. Air suspension problem
  10. No power steering at idle
  11. Need help with instrument cluster
  12. Started my 2jzgte swap
  13. Power Steering Problem 1.gen. 93'
  14. My Dad's new LS
  15. New Owner of a 1997 LS400 Coach Edition
  16. Ebay RCR Tail Lights
  17. Brake System Bleeding
  18. Inexpensive Break Rotors
  19. Change Headlights
  20. 1993 LS400 Write-Off (had only 119500 KM/74250 Miles on the clock)
  21. Spark plug Wires?
  22. No horn,airbaglight on, no cruse ???
  23. Rattling from sunroof
  24. Lexus 1990 LS400 front Strut Rod bushing
  25. Air susp controllers?
  26. car wont idle at all
  27. Looking for parts 92 ls400
  28. how do you put on a weather seal ???
  29. 1993 ls400 driver window motor
  30. power steering pump help
  31. Heat affects clockspring - HELP
  32. help rear bumper removal...!
  33. alignment adjuster options... interchangeable parts?!?!
  34. How do I disable the factory alarm on 1990 Lexus ls
  35. New to the forum! And I come with bad news :(
  36. Transmission clunk
  37. Smoke from vents
  38. lexus leather sucks
  39. 1999 LS400 knock sensor bank 1?
  40. show us your exhaust
  41. My LS refuses to leave me (starter and misc. brainstorming). COME ON IN!
  42. tight power steering and 'poppin' from the steering wheel
  43. 245/50/18's on sc430 wheels
  44. I'm finally back in a LS. Question about maintenance.
  45. help with problem computer??
  46. Cruise Control Resume
  47. car leaning to left side in the front and back
  48. Power steering experts
  49. Why does my car ping?
  50. Low air flow
  51. Weird shifting and throttle issues.
  52. ignitor?????
  53. New Brake rotors and ceramic Brake pads, and other mods
  54. LS400 w/Garmin navi
  55. 99 LS trunk leak
  56. '98 LS 400 Right Rear Power Door Lock Problem
  57. what should an LS400 shift at?
  58. fixing head gasket
  59. Rolling front fender help.
  60. exhaust size
  61. My 98 LS with IS300 rims.
  62. Offered 92 with bad engine
  63. My First LS400
  64. Exaust flanges
  65. parts
  66. Hey guys first post/ rough idle 94 ls400... please help
  67. power steering pump and hose
  68. Exhaust Y section
  69. transmission won't shift
  70. 92 LS400 Wont Shift With Headlights On
  71. just wondering what my car is worth?
  72. no fast accelaration
  73. Wheel/suspension/brakes
  74. Lambda sensor
  75. Show me your grill!
  76. Car ran hot untill it stopped
  77. A/C blower doesnt work on my 99 LS
  78. Will 22x9.5 rims fit my LS400?
  79. 95 LS400 lost all power sterring & leaky rack
  80. 1992 Lexus LS400 Original Prices
  81. '90 LS400 Engine shut-off
  82. new guy in town...
  83. DIY: Headlight trim (eyeline garnish)
  84. pioneer cd error 14
  85. 1990 lexus ls400 power stering wheel problem
  86. Valve cover gaskets
  87. Another Electrical Gremlin thread
  88. changed radiator ls400 1990
  89. Bilstein fron shocks, H0 vs H1?
  90. Problem w/car dying/starting on trip right now-Help 94LS400
  91. Transmission & VSS & P0500 & Tire Size problem
  92. Lambda sensor Q MOT failyer :0(
  93. Anti freeze smell
  94. steering wheel goes up and down, but not in and out
  95. Recomendation Needed - Replacement Subwoofer - 90 LS400
  96. car starts then shuts right off
  97. 1998 LS 400 with 900mi
  98. Differences between 95 and 96/97?
  99. The new headunit
  100. Need new rotors, but from which company?
  101. Correct spacers to fit is300 17" rims
  102. Quoted $2500 For Repairs For Suspension Parts.
  103. What to look for when checking out 2000 LS400
  104. celsior motor swap
  105. what is this warning light mean on my '90 ls?
  106. 90 LS400 hood struts or lift supports
  107. Wood Grain Trim Replacement
  108. Brake pad installation mistake. Caliper issue 95 LS
  109. Oh My: Another Starter Question
  110. Air suspension or Coilovers? Ls UCF 10
  111. Gold emblems
  112. Windshield Fluid light won't turn off
  113. Tail light question 1999 LS
  114. engine light came on 1991 lexus ls400
  115. speakers cutting out
  116. LS Aero Kit name?
  117. Power steering -- Low flow/pressure issue
  118. New Introduction
  119. Draining Gas Tank on a 96 LS400?
  120. Squealing from A/C
  121. 92"ls400,need help.
  122. 1997 LS Stuck in park
  123. Door Adjustment Help Needed - 90 LS400
  124. What happened to Sewell
  125. Headlights not working
  126. Basic Maintenance questions
  127. Hissing noise under car
  128. 1998, Rear End Clunk
  129. Help! Decelleration problem when I let off the gas
  130. I can get used to this
  131. this is killing me...car wont stay running!!!!
  132. steering wheel/Air bag swap
  133. 1990 ac compressor wont kick on
  134. one more tire question
  135. New Member! '96 LS400 46K
  136. Be careful: Moog tie rod ends are cheaply made in Korea
  137. TC PO1349 Oil Control Valve 1998 & UP
  138. Going to try the General Altimax HP tires
  139. 1998 LS400 Timing Belt Part Number and General Questions
  140. Timing belt Mistake - cams 180 degrees off
  141. How much do you spend per mile on your LS400?
  142. Headgasket going out?
  143. Attempting to reduce more road noise
  144. Thought I'd share some pics of my LS
  145. coilover question...?
  146. 1990 ls400 seats
  147. When should oxygen sensors be replaced? 1999 LS400,130k miles.
  148. 1999 LS400 VSC light & CEL lights on
  149. 1991 LS400 Air Ride Problem
  150. exterior color
  151. Locations of Autowreckers/Scrap Yards in Buffalo, New York area
  152. New head unit and 5.25" component speakers
  153. Transmission making a ticking noise?!?!? Any inputs from the CL vets...
  154. Replacing PS pump, No Screen in reservoir
  155. car making wierd wizzing noise after changing thermostat and coolant temp. sensor
  156. Stereo Help
  157. The LS400 that died! FML
  158. Help with leaking Fuel Pressure Regulator
  159. reliable ls mechanics in minnesota??
  160. 92 LS400 left corner light?
  161. exhaust problem?? PLEASE HELP!
  162. Colder range spark plug= worse gas mileage?
  163. Looking in a 97' 98' LS
  164. 92 LS400 - hard to start when warm
  165. 95 LS New Coilover Conversion, Having Some Problems
  166. Power Steering Problem?
  167. Need Roof Racks / Cross Bars for 2nd Gen LS400
  168. 1999 Lexus LS400 Lower Control Arm Bushing need help
  169. A/C & heat turns on and off intermittently LS400
  170. Running 87
  171. Help! Battery Died now car won't start after charging it
  172. Question about 95-00 LS400 tail lamps
  173. New rear stabilizer link -- dumb question???
  174. Power Steering Pump Stalling The Car?
  175. 96 LS400 stalls occasionally, quick stop, quick gas
  176. Quick Question, Removing Crankshaft bolt
  177. to my low washer fluid warning...
  178. Anyone have XXR 006's?
  179. Never introduced myself..
  180. 99 LS w/ a slow oil leak?
  181. What should i do to my new ls400
  182. Reveres light comes on when breaking also sometimes the dash light goes on and off
  183. Rough idle
  184. rewrapped readliner, sunroof slider and rear window decklid
  185. Wheel Fitment Question!!! (I think i searched for it)
  186. Cut the springs a bit to get low for 0 $$ ? And adapter question.
  187. my ls400 UCF10 *pics*
  188. '92 LS400 - Electrical Issue
  189. Thinking of buying a '92 ls
  190. Will a 96 A/C compressor work on a 92?
  191. Smells rich at idle?
  192. Hood struts installed!
  193. Cheapest place to buy a tilt motor?
  194. Independent Mechanic Ventura CA?
  195. 1995 LS ecu replacement and damage from throttle shock
  196. 98 Fog lights not working...
  197. 18" TRD SC430 rims on UCF21
  198. Stainless steel brake lines
  199. Time to part with the trusty old LS.
  200. Eagle Eyes headlight retro complete
  201. A different starter question-
  202. Lojack
  203. tire sizes
  204. can i put 275's on the back?
  205. does anyone have stock navigation?
  206. Megan Coilover question 2000 LS400
  207. Has anyone tried the LS460 19" wheels on a 98-00?
  208. 1st gen ls400 on a lift? lift points?
  209. Can anyone Explain?
  210. Wheels advice: Bronze VS-XX on grey UCF10? Yay or Nay?
  211. 98' ls400 problem, please help
  212. Timing Off
  213. '98-00 LS400 original rims
  214. smog test fail?
  215. 2000 LS400 ECU location/removal
  216. 91 LS400 Power steering rack
  217. H3 HID to Fogs (1993 LS400) Help
  218. 98 ls400 low iddle problem
  219. which oxygen sensor from advance auto would you get
  220. AC is not freezing anymore.
  221. 95 LS400: Car shut off on me !!
  222. Getting Horrible Gas Mileage - Any Solutions?
  223. Door locks on '96 LS fire like a machine gun
  224. The year from hell - need help
  225. Should I buy these wheels?!?!
  226. Independent mechanics near St. Louis??
  227. stock navigation swap out
  228. Trouble reading codes and Odd Transmission problem
  229. Disc brake hardware
  230. The Texas Sun is not my friend......
  231. Huge problem, easy fix?
  232. What is the MAX you would pay for this 97 LS
  233. New to the LS400 World
  234. Looking for a 95 ls 400 custom grill
  235. Wheel HELP in NY
  236. Help: Exhaust Leak
  237. Bushing replacement for 1991 LS400
  238. ordered more parts. more problems. grrrr
  239. 1996 LS 400 A/C Light Blinking Green
  240. Engine swap, some photos
  241. Fixing stereo backlight (95), not just bulbs
  242. Bushings for front suspension for 95+
  243. 97 ls400 Idle surge
  244. New 98 LS400 owner here! Need a wheel suggestion. PICS-->
  245. Timing belt inspection
  246. Notes on Timing Belt change -- '95-96
  247. Can i use 93' power rack and pinion on my 91 LS?
  248. 93 lexus ls400 oil leak!! Help!!
  249. 1UZ-FE Longevity
  250. 2cm lean!
