PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. 96 LS400 Ball Joint problem.. help!
  2. is catalytic converter important to 90LS ?
  3. Steering wheel horn cover
  4. Steering wheel turns slightly when braking
  5. EFI Relay starting issue
  6. 99 LS400? what are these going for right now?
  7. Outside temp reading off by 30 degrees!
  8. AC light blinking
  9. Can't get anymore VIP than this.
  10. 94 ls400 a/c deos not blow hard
  11. Help please car wont start.
  12. 1st gen ls400 Billet grill help
  13. 95 LS400: New acquisition !
  14. Hey everyone
  15. A8 monoblocks on UCF10?
  16. Peeling steering wheel? Try Leather Magic
  17. ADDCO Rear Swaybar
  18. 92 LS400. Front lower ball joints?
  19. HELP.. CEL and rough IDLE after Tune-up
  20. red flags to look for in LS400
  21. Protecting mats-machined or chrome
  22. Problem past 25% throttle on LS400
  23. Rear Package Tray Removal
  24. Radio install problem
  25. Anybody have stock struts and want coilovers?
  26. Starter replacement gone bad
  27. The Idle/Dying Problem
  28. 1995 Lexus Rims scraping
  29. cutting strut tower??
  30. 95 LS400: OBD I or OBD II ?
  31. New to the forum! Need help
  32. Anyone bagged a first gen?
  33. 95 LS400: unknown (to me) warning light on dash
  34. 1st gen ls400 tailight bulb socket.
  35. I need help! 98 LS amp diagram....
  36. Timing Cam alignment - need help
  37. 1993 ls400 Engine Shuts off while driving
  38. Power steering and AC woes
  39. problem with power steerin 97 LS400
  40. '92 sc400 alternator, will it work on a '97 LS400?
  41. acceleration jump when in drive
  42. A new addition to the family
  43. New to the forum and lexus
  44. 99 LS400 A/C problem code 42
  45. Have to let her go, wife got a new job :(
  46. Timing belt info
  47. '99 LS400 AC Control Panel problems
  48. Poor gas mileage 1990 ls400 84k miles
  49. 95 LS400 power locks and trunk not working
  50. A/C problems - 92 LS400
  51. Brake shim kit and pad spacers help
  52. 1997 LS400 Coach Edition Pics. 56k beware
  53. Polyurethane swaybar bushings available?
  54. help
  55. lower control arm strut or just the control arm?
  56. 94 LS400 Spark Plug Wires & Spark Plugs?
  57. Suspension on Late Model LS400
  58. I just get a "CLICK" on starting the car
  59. Found what I think is a good deal.....
  60. Air suspension problem
  61. No power steering at idle
  62. Need help with instrument cluster
  63. Started my 2jzgte swap
  64. Power Steering Problem 1.gen. 93'
  65. My Dad's new LS
  66. New Owner of a 1997 LS400 Coach Edition
  67. Ebay RCR Tail Lights
  68. Brake System Bleeding
  69. Inexpensive Break Rotors
  70. Change Headlights
  71. 1993 LS400 Write-Off (had only 119500 KM/74250 Miles on the clock)
  72. Spark plug Wires?
  73. No horn,airbaglight on, no cruse ???
  74. Rattling from sunroof
  75. Lexus 1990 LS400 front Strut Rod bushing
  76. Air susp controllers?
  77. car wont idle at all
  78. Looking for parts 92 ls400
  79. how do you put on a weather seal ???
  80. 1993 ls400 driver window motor
  81. power steering pump help
  82. Heat affects clockspring - HELP
  83. help rear bumper removal...!
  84. alignment adjuster options... interchangeable parts?!?!
  85. How do I disable the factory alarm on 1990 Lexus ls
  86. New to the forum! And I come with bad news :(
  87. Transmission clunk
  88. Smoke from vents
  89. lexus leather sucks
  90. 1999 LS400 knock sensor bank 1?
  91. show us your exhaust
  92. My LS refuses to leave me (starter and misc. brainstorming). COME ON IN!
  93. tight power steering and 'poppin' from the steering wheel
  94. 245/50/18's on sc430 wheels
  95. I'm finally back in a LS. Question about maintenance.
  96. help with problem computer??
  97. Cruise Control Resume
  98. car leaning to left side in the front and back
  99. Power steering experts
  100. Why does my car ping?
  101. Low air flow
  102. Weird shifting and throttle issues.
  103. ignitor?????
  104. New Brake rotors and ceramic Brake pads, and other mods
  105. LS400 w/Garmin navi
  106. 99 LS trunk leak
  107. '98 LS 400 Right Rear Power Door Lock Problem
  108. what should an LS400 shift at?
  109. fixing head gasket
  110. Rolling front fender help.
  111. exhaust size
  112. My 98 LS with IS300 rims.
  113. Offered 92 with bad engine
  114. My First LS400
  115. Exaust flanges
  116. parts
  117. Hey guys first post/ rough idle 94 ls400... please help
  118. power steering pump and hose
  119. Exhaust Y section
  120. transmission won't shift
  121. 92 LS400 Wont Shift With Headlights On
  122. just wondering what my car is worth?
  123. no fast accelaration
  124. Wheel/suspension/brakes
  125. Lambda sensor
  126. Show me your grill!
  127. Car ran hot untill it stopped
  128. A/C blower doesnt work on my 99 LS
  129. Will 22x9.5 rims fit my LS400?
  130. 95 LS400 lost all power sterring & leaky rack
  131. 1992 Lexus LS400 Original Prices
  132. '90 LS400 Engine shut-off
  133. new guy in town...
  134. DIY: Headlight trim (eyeline garnish)
  135. pioneer cd error 14
  136. 1990 lexus ls400 power stering wheel problem
  137. Valve cover gaskets
  138. Another Electrical Gremlin thread
  139. changed radiator ls400 1990
  140. Bilstein fron shocks, H0 vs H1?
  141. Problem w/car dying/starting on trip right now-Help 94LS400
  142. Transmission & VSS & P0500 & Tire Size problem
  143. Lambda sensor Q MOT failyer :0(
  144. Anti freeze smell
  145. steering wheel goes up and down, but not in and out
  146. Recomendation Needed - Replacement Subwoofer - 90 LS400
  147. car starts then shuts right off
  148. 1998 LS 400 with 900mi
  149. Differences between 95 and 96/97?
  150. The new headunit
  151. Need new rotors, but from which company?
  152. Correct spacers to fit is300 17" rims
  153. Quoted $2500 For Repairs For Suspension Parts.
  154. What to look for when checking out 2000 LS400
  155. celsior motor swap
  156. what is this warning light mean on my '90 ls?
  157. 90 LS400 hood struts or lift supports
  158. Wood Grain Trim Replacement
  159. Brake pad installation mistake. Caliper issue 95 LS
  160. Oh My: Another Starter Question
  161. Air suspension or Coilovers? Ls UCF 10
  162. Gold emblems
  163. Windshield Fluid light won't turn off
  164. Tail light question 1999 LS
  165. engine light came on 1991 lexus ls400
  166. speakers cutting out
  167. LS Aero Kit name?
  168. Power steering -- Low flow/pressure issue
  169. New Introduction
  170. Draining Gas Tank on a 96 LS400?
  171. Squealing from A/C
  172. 92"ls400,need help.
  173. 1997 LS Stuck in park
  174. Door Adjustment Help Needed - 90 LS400
  175. What happened to Sewell
  176. Headlights not working
  177. Basic Maintenance questions
  178. Hissing noise under car
  179. 1998, Rear End Clunk
  180. Help! Decelleration problem when I let off the gas
  181. I can get used to this
  182. this is killing me...car wont stay running!!!!
  183. steering wheel/Air bag swap
  184. 1990 ac compressor wont kick on
  185. one more tire question
  186. New Member! '96 LS400 46K
  187. Be careful: Moog tie rod ends are cheaply made in Korea
  188. TC PO1349 Oil Control Valve 1998 & UP
  189. Going to try the General Altimax HP tires
  190. 1998 LS400 Timing Belt Part Number and General Questions
  191. Timing belt Mistake - cams 180 degrees off
  192. How much do you spend per mile on your LS400?
  193. Headgasket going out?
  194. Attempting to reduce more road noise
  195. Thought I'd share some pics of my LS
  196. coilover question...?
  197. 1990 ls400 seats
  198. When should oxygen sensors be replaced? 1999 LS400,130k miles.
  199. 1999 LS400 VSC light & CEL lights on
  200. 1991 LS400 Air Ride Problem
  201. exterior color
  202. Locations of Autowreckers/Scrap Yards in Buffalo, New York area
  203. New head unit and 5.25" component speakers
  204. Transmission making a ticking noise?!?!? Any inputs from the CL vets...
  205. Replacing PS pump, No Screen in reservoir
  206. car making wierd wizzing noise after changing thermostat and coolant temp. sensor
  207. Stereo Help
  208. The LS400 that died! FML
  209. Help with leaking Fuel Pressure Regulator
  210. reliable ls mechanics in minnesota??
  211. 92 LS400 left corner light?
  212. exhaust problem?? PLEASE HELP!
  213. Colder range spark plug= worse gas mileage?
  214. Looking in a 97' 98' LS
  215. 92 LS400 - hard to start when warm
  216. 95 LS New Coilover Conversion, Having Some Problems
  217. Power Steering Problem?
  218. Need Roof Racks / Cross Bars for 2nd Gen LS400
  219. 1999 Lexus LS400 Lower Control Arm Bushing need help
  220. A/C & heat turns on and off intermittently LS400
  221. Running 87
  222. Help! Battery Died now car won't start after charging it
  223. Question about 95-00 LS400 tail lamps
  224. New rear stabilizer link -- dumb question???
  225. Power Steering Pump Stalling The Car?
  226. 96 LS400 stalls occasionally, quick stop, quick gas
  227. Quick Question, Removing Crankshaft bolt
  228. to my low washer fluid warning...
  229. Anyone have XXR 006's?
  230. Never introduced myself..
  231. 99 LS w/ a slow oil leak?
  232. What should i do to my new ls400
  233. Reveres light comes on when breaking also sometimes the dash light goes on and off
  234. Rough idle
  235. rewrapped readliner, sunroof slider and rear window decklid
  236. Wheel Fitment Question!!! (I think i searched for it)
  237. Cut the springs a bit to get low for 0 $$ ? And adapter question.
  238. my ls400 UCF10 *pics*
  239. '92 LS400 - Electrical Issue
  240. Thinking of buying a '92 ls
  241. Will a 96 A/C compressor work on a 92?
  242. Smells rich at idle?
  243. Hood struts installed!
  244. Cheapest place to buy a tilt motor?
  245. Independent Mechanic Ventura CA?
  246. 1995 LS ecu replacement and damage from throttle shock
  247. 98 Fog lights not working...
  248. 18" TRD SC430 rims on UCF21
  249. Stainless steel brake lines
  250. Time to part with the trusty old LS.
