PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 2000 LS400 memory function, door locks and mirrors don't work
  2. 1999 Lexus LS400 key issue
  3. How to replace the coolant tank?
  4. anyone heard of these? Godspeed MonoMAX Coilover
  5. Got my big bad suspension parts!
  6. Opinions on tire selection 1996 LS400. Staying with OEM spec.
  7. new guy looking for parts ls400
  8. 92 LS400 wiring issue?
  9. Starting Issue please help
  10. Rotiform NUE
  11. brake master cylinder w traction part number
  12. new mirror for car but connections wrong ??
  13. Bought Used LS400 ECM (1994)--- Do i need it programmed/flashed?
  14. Vsc on car won't move vsc off car moves?
  15. Black Pkg Not Gold
  16. Heat stays on
  17. 1998 Ls400 sluggish throttle response
  18. 97 ls400 smoking - new ecu, no gas smell
  19. 1997 LS400 Starter and Cooling Fan problem
  20. heated seat switch bulb p/n
  21. Removing center vents and A-pillar trim
  22. New here! The Acceleration nightmare!
  23. Fuel Gauge Problem
  24. Seized strut rod bolt.... help
  25. 1991 key housing
  26. Questions about adjusting the sub TPS
  27. No more P0171 on my 98! Also, change your tranny mounts people.....
  28. Gear Shift Indicator Panel Light
  29. ? my ls400 trans issues
  30. 1994 LS400: Suspension issues
  31. Reliable work vehicle
  32. 91 Ls400 ticking sound
  33. 95 ls
  34. Where to buy 1994 LEXUS Engine Control Module?
  35. seat problem
  36. Delete coolant line to throttle body and IACV
  37. Weird dream about the LS
  38. Considering 2000 LS with probs...
  39. P0715 CEL after fillup
  40. Help Needed, fuel- name part?
  41. Is there a good app for reading 1st gen diagnostic codes?
  42. full power steering delete. thoughts needed?
  43. High NOx - need expert tech help
  44. 91 LS400 Front Wheel Hub
  45. Radio set up 96 lexus ls400
  46. Celsior.. very high at front?
  47. Floor mats
  48. Front Coil S Insulator
  49. Water temperature sensor
  50. '98 LS400 CEL p0763
  51. '98 LS400 CEL p0420 & p0430
  52. life saver well get me home angel
  53. Orphan electric connector 93 400
  54. Need help. Differential dilemma.
  55. Megan LP possibly discontinued for our cars?
  56. sat nav radio not working blank screen
  57. Possibly buying a 1997 LS, car has 1 problem
  58. Brake lights don't work - everything (fuse, switch, wires) checks OK!
  59. 95 false abs every stop
  60. Aftermarket deck with nak 95
  61. Fuse box diagram 94 LS 400
  62. wrong vin on car??? [VIN removed-UK VIN]
  63. how do i fit this ?? or where politely do i stick it
  64. 93 ls400 Seat Belt stuck
  65. Transmission filter
  66. 92 LS400 won't accelerate and is sluggish
  67. Control arm question/issue
  68. Fuel Damper
  69. 2000 LS400 O2 Sensor Question
  70. 1998 LS400: Transmission not engaging in drive?
  71. Central Locking/ Seatbelts not working after LS400 got slightly flooded
  72. 1998 LS400 24F VS 27F battery
  73. Sat for a week and won't start today
  74. tired os slow trunk try this cheeap fix $12
  75. whats happend to my loverly new lexus
  76. Miracle adhesive review or I broke the tail light
  77. LS400 crank but no spark! Help!!!!
  78. SoCal meet up
  79. Lurked for a while, picked up this beauty last week.
  80. 1992 Gauge Cluster Question
  81. 2nd Techron Treatment - Oil Change Needed before Smog Check?
  82. urgent please will these fit 1998 ls400
  83. HELP - Driver Window Controls + PS Leak
  84. can i fit any 5x114 wheel ?
  85. Rear upper control arms?
  86. 91 ls400 computer / ecm
  87. Weight reduction and 1/4 times
  88. noob replacing crank seal 1uz 1994
  89. What is this?!??
  90. A? been asked to show my car creations
  91. LONG TIME lurker, first time poster. Got hit n run on my 90 'LS400 :(
  92. [UPDATE] 1994 LS Fog Light Mod (Solved)
  93. wooden dash kit for 2.5 ls400
  94. 95-97' vs. 98'-00' Catalytic Convertors
  95. alternator shield with cut bottle?
  96. i got one at last !!!
  97. LS400 Manual Swap Which Trans?
  98. Did you mean: difference between lexus ufc 10 and ufc 20 rear door
  99. A650E shift kit
  100. Contemplating purchase of '98 LS400: opinions needed
  101. WellVisors Side Window Deflectors Lexus LS400
  102. 1996 Lexus LS400 Cold Start Hesitation
  103. 99 LS400 smokes under hard acceleration
  104. Newly Acquired '99 LS400
  105. SoCal cruise
  106. Is there an oem part# for these bushings?
  107. The trunk will not open using the underdash release. Fixes?
  108. Trunk Setups
  109. 1997 Tails on a 2000?
  110. Headlight leveling red light on dshbr.d
  111. Some LS400 problems
  112. Exhaust mods, better fuel economy ?
  113. RX350 F type wheel fitment
  114. NEED 1994 US LS400 Wiring Diagram
  115. Aftermarket Radio Harness?
  116. 94 LS400 - New TPS & High Idle @ 2000RPM & Hunting???
  117. Door Actuator
  118. SoCal LS400 meet n greet
  119. Deck Plate Mod
  120. Heated Seats
  121. Can anyone help me with a general direction here?
  122. 95 starting problems and ignition cutouts
  123. Bought a Lexus today. Broke a Lexus today..
  124. My First Lexus, 95 LS400 runs rough fuel smell and lot of smoke out the tailpipe
  125. 1998-2000 ls400 oem radiator options
  126. LS400 cluster needle
  127. 1996 vs 1999 parts compatibilty
  128. Climate control resets to foot setting
  129. Need help- transgo shift kit install
  130. Need a new transmission, will these work?
  131. Nothing electrical works
  132. Megan UCF10 coilovers on a 95
  133. 99 LS 400 200000k miles
  134. Foam injector covers
  135. well look who won the Lexus subreddit monthly sidebar photo contest
  136. '95 LS400 - will not start
  137. New CL posting in DFW. White 95, 117k.
  138. 92 LS400 Hood difficult to open
  139. 96 ls400 speedo and tach problem
  140. My LS400 search
  141. Got an LS400 but the Suspension is being difficult
  142. Battery lights and Steering Issue??
  143. Anyone try the knock off 5 slot rims?
  144. Hello Fellow LS Owners
  145. New to 93 Lexus LS400
  146. Iac- cleaning?
  147. Master Reset for '92 Nakamichi Head
  148. Amplifier help
  149. how to get this alternator out!?
  150. O2 Sensor Help!
  151. ADDCO 2027 fit on 98-00???
  152. Question about factory air suspension?
  153. Suspension question
  154. 98-00 Glove Box & CB Radio Question
  155. Black Box In Trunk - What is it ?
  156. My current issues. Erratic running.
  157. Hi Beam (9005) LED conversion
  158. Fuel Tank Vent
  159. 1992 LS400 lock set
  160. Has anyone ever switch A/C panel and radio positions?
  161. 1UZ-FE valve adjustment - target values?
  162. Fuel Leak PLEASE HELP !!!!!
  163. Car Vibrates at 1800-3000 RPM in park
  164. Smoke from steering column. Source?
  165. 99 LS400 Mirror housing removal
  166. 92 ls400 pioneer 2 ohm sub??
  167. Where are the main and return fuel lines connected to the tank?
  168. How to change headlight bulb for 98 LS400 DIY?
  169. HKB (or other brand) steering boss kit to fit UCF21?
  170. Question on oil and tranny fluids pan....
  171. center mounted backup camera
  172. What this hose for?
  173. 99LS400 brake caliper bolts
  174. 1992 LS400 Parking Brake Light + Check Engine Light on
  175. 18" tires for the high temps of Saudi Arabia?
  176. catalytic converter replacement help
  177. Ucf10 oil consumption?
  178. As Time Goes By.
  179. Celsior Niggles and Surprises
  180. '96 LS400 w/ P0340, P0500, P0770 - Trans?
  181. Please identify wire harness (picture)
  182. 99 LS400 RS Mirror
  183. LS400, Air meter code with a fix?
  184. (1998 LS400) How Do I Replace the Coolant Temp Sensor?
  185. Engine is loud at idle
  186. Original battery terminals?
  187. Picked up a 97 coach for a good price.
  188. Just bought my '94 LS this past Friday
  189. stereo crackling sound
  190. Moonroof cover rattle
  191. Instrment Cluster - between 93 & 94
  192. 92 starting/firing up problems help
  193. Best tires for long distance?
  194. Driver fender well harness relocation gone bad
  195. higher idle in extreme cold (when already warmed up)?
  196. 1991 oil pan leak
  197. Brand new starter motors
  198. Dension iPhone4s audio hook up
  199. What did you do with your LS on Valentine's Day?
  200. Need help with my 96 ls400 transmission and car wont past 2k
  201. Blower motor question
  202. Junkyard scores and an ashtray question
  203. 1990-2000 Color combonations
  204. Double Din Unit
  205. Help identifiying source of fluid leak
  206. Input needed on color choice for new LS400 purchase
  207. Replaced starter - don't know what harness this is
  208. Starter solenoid 'clicking''
  209. Low oil pressure light after bump
  210. '98-"00 wheels on '97 LS 400
  211. door panel removal
  212. Pcv hose
  213. Where does this vaccum hose go to?
  214. Replace belt tensioner
  215. New LS400 owner here
  216. (Pic)F Sport LS400 - (help?)Time for a Complete OEM Suspension Overhaul/Restoration
  217. 96 LS400 key info chip?transponder?best way to get duplicate?
  218. Wiring diagram for instrument cluster for 91 LS400
  219. 98-00 LS400 Best way to remove amber turn signal lens?
  220. its "just an expensive camry"
  221. plastic engine covers
  222. Don't Hold Your Breath for a Bose Suspension on Your Lexus LS
  223. 1997 ls400 Heated mirrors
  224. New member here . glad to join this community
  225. Aftermarket Steering wheel
  226. Key fob internal swap?
  227. 95LS starts to die after a minute of driving
  228. How did you feel when you first got your LS?
  229. Lower steering wheel without power.
  230. Condenser fan issues
  231. Smoking from Right Front Wheel Well
  232. New Guy
  233. 91LS400-Stalls after 15 minutes, Starts, Idles/runs beautifully when running
  234. Help with buying this LS400
  235. Adding technology to your LS to bring it into the 21st century
  236. Identifying Trunk Items
  237. Power steering hose cracked on my 98 Celsior
  238. Corroded Waterpump - Green Anti-Freeze the Culprit??
  239. 96 Ignition Switch Problem
  240. 2000 LS noise
  241. UCF20 Lexus LS400 Electric Kart [Powerwheels?]
  242. Vibration on deceleration
  243. How not to diagnose things...
  244. Replacing TPS on 1991 LS400
  245. Celsior (F10) the Development of History and Chronology
  246. Electrical Issues on a 1999 LS400
  247. 1998 LS400 dual custom exhaust, video clip and pics.
  248. Raybestos brake dampener
  249. 92 Ls400 tune up?
  250. Strut Bar Looks Twisted - Is It Normal
