PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 99 ls 400 help!!!
  2. 1990 ls400 fuel pump cover wires broken
  3. 94 LS400 New Torque Converter for Used Aisin-Warner Tranny ?
  4. Insulation for exhaust system
  5. Removing 1st Gen LS400 Glovebox??
  6. 1991 ls400 headers
  7. What does this warning light mean?
  8. Radio compatibility?
  9. radio help
  10. tools for rear trans seal replacement?
  11. Shorted cam sensor????
  12. steering wheel TILT AYO!
  13. Clock spring replacement
  14. Help !! 1995 Lexus LS400 Steering Problem
  15. Replacing struts with OEM, anything else to get?
  16. PS Pump/Rack replacement, what else do get?
  17. I took the poly strut rod bushings back out
  18. on to the next hurtle
  19. 91 LS 400, No Reverse but I have Drive
  20. Paint Color help (w/pic)
  21. 1998 LS400 spungy brakes
  22. VIN# / Engine Serial number verification?
  23. Fixed Stiff Steering
  24. 1998 LS400 Splash Shield
  25. Should I buy this 1997 LS400?
  26. LS400 ('94) Ball Joint Challenge...
  27. 1994 Lexus LS400 best Reman Transmission ???
  28. 94 LS jerks & Blinking Check Engine Light
  29. Natural Gas conversion - First Gen?
  30. First Gen - Aluminum lower body panels?
  31. Front UCA's Upper Control Arms
  32. Massive Coolant Leak from Behind Crank Pulley
  33. Ready to sell
  34. Wrong radiator cap?
  35. Few Quick Questions (95 LS)
  36. Tail Light Problem
  37. Two Low pressure a/c ports? 1991 LS400
  38. LS400 compatibility with SC400
  39. Hola
  40. my fresh to me ufc10!
  41. ls 400 vip curtains ?
  42. Runs rough on second start-up
  43. what is the indicator for a bad starter?
  44. Ls400 Oil Filter 90915-20004
  45. Discount code for Carson Lexus aka l-tunedparts
  46. Picked up a LS400 for the wife off Craigslist
  47. Scrape Pan anyone?
  48. snow tires
  49. My solution to dead door lock actuator
  50. Throwing codes P0300 & P0307 intermittently
  51. New 98 LS400 owner.
  52. Bumper fastener part number
  53. upper control arm removal??
  54. Grinding when coming to a full stop
  55. Present in the mail!
  56. New LS400 owner here
  57. unknown leak:mad:
  58. Can you change a Nackamichi to a pioneer -98ls400
  59. 1997 LS400 Rear Seat Removal
  60. DIY Heated Seat Repair W/ Pics
  61. ebay CC LCD review
  62. Sort of New, My 00 LS400
  63. Any one have stock exhaust manifolds for 1998-2000 LS400?
  64. 1993 LS400 Doesnt move in Drive
  65. 1994 LS400 Phone Controls
  66. Cigarette Lighter POWER ISSUES?
  67. High Idle (Rpm's) or Not
  68. LS400 unloading fail.
  69. unknown part.. coolant leak
  70. Purchased 95 LS, now some DIY Repair Questions
  71. Brake fluid
  72. Leak?
  73. Serpentine belt Stuck/Squealing
  74. Fan clutch - would like help from US
  75. Ls400 5spd M/T
  76. WOW Check this out!!
  77. "Groan" from steering rack?
  78. trouble
  79. My '93 LS400 not starting/running...
  80. Advice on Lexus LS400 Catalytic Converter
  81. My LS400 has lost power :( Any and all help would be greatly appreciated!
  82. Need 94 LS400 ECM ASAP!
  83. Clear signal opinions?
  84. E15 Gas
  85. Sumitomo brake pads
  86. Suspension questions
  87. Purchased 2001 ls430 windshield washer nozzles
  88. Coolant hose to Throttle Body?
  89. Air Conditioner/Timing Belt question
  90. Rims on 94 ls400 here in New Zealand
  91. Locked Keys in Car w/ Factory Alarm On.
  92. parking light change
  93. 1998 LS400 Seat Covers from Ebay
  94. 96 timing belt parts - what am I missing?
  95. '95 LS dies ONLY when getting off freeway ONLY when below ~55* ambient
  96. Oil Filter recommendations?
  97. LS400 VIP Shirt
  98. Updates on my '92 LS400....
  99. 93 LS400 pics
  100. parts.com promo code
  101. Lost power to driver's side seat
  102. another spacer question
  103. Shift Knobs
  104. Amber side marker lamp Bulb
  105. 96 ls Purchase - advice needed
  106. Help !!! Electrical problems for 96ls
  107. Timing Belt
  108. Post-cat O2 sensor readings!
  109. megan racing motor mounts
  110. speaker problems on '92 LS 400
  111. Fuel Injector Cleaners?
  112. another audio system problem-speakers
  113. LS400 running hot
  114. Strut Boots for KYB GR2?
  115. O2 sensor simulator
  116. Installing new audio head unit problem
  117. Power Steering Fluid
  118. gate Shifter Swap?
  119. Crankshaft pulley puller
  120. Rear Diff fill/drain plug size?
  121. Problem while stuck at redlights
  122. Flasher
  123. Just got LS400
  124. Radio removal & front air vent problem
  125. New member, '94 Anniversary Edition
  126. Headlight Socket Fried
  127. 93 Rear wheel bearing
  128. 93 LS400 Brake light problem
  129. 94 LS400 Power Died After Major Tune Up? :confused:
  130. Need help identifying suspension part
  131. Tilt steering
  132. Persistent Code 13 - Did I Screw it Up?
  133. 95 LS Electric Issues...
  134. Foamy PS fluid
  135. 95 Rear Trailing Arm Bushing
  136. Please Help! Key stuck in ignition!
  137. 98 ls headlight function
  138. 1st gen wont shift into gear whats up?
  139. 95 ls400: Evap cel p0441
  140. Coilover Spring Rates for Slammed LS'
  141. have problem when i lower my car need help
  142. Wheel Opinion OE wheels
  143. '91 Front Suspension Knocking
  144. inner and outer tie rod ends
  145. 97 LS 400 Timing Belt Replaced at 152k
  146. Fuel gauge sending unit in tk '92 LS400
  147. Replaced my Strut Rod Bushings on my 99
  148. intro
  149. 91 shakes at highway speeds
  150. video bypass
  151. need help
  152. head bolt question
  153. 97 LS windshield wiper arm adjusment question
  154. Will '98 LS400 springs and struts fit a '92
  155. RMM Intake Anyone?
  156. dead battery again after a week old????
  157. trans over heating problem
  158. 1993 ls timing belt broke due to idler pulley bad HELP with cam ali
  159. 91 overheating, I'm stumped
  160. Introducing...
  161. 00, ECT question
  162. Steering problems !!!
  163. what part is this?
  164. first rolling shots ufc10
  165. LS400 1993 CD changer problem.
  166. Dead alternator or what?
  167. 96 ls400 climate control doesn't work
  168. 93 LS400 Courtesy Light On Door and Rear Pillar?
  169. Need ur Thoughts on this one
  170. Does anybody have a '98-'00 on H&R or Eibachs?
  171. new ls400
  172. ECU rebuilt--trouble with transmission
  173. blower fan not working
  174. coolant temp sensor purchase ?
  175. 1996 ls400 purchase advice
  176. Need to change the evap.
  177. '98 Stainless steel brake lines?
  178. Stolen Valet Key
  179. 1998 LS400 Hood Struts Parts Ave
  180. climate control
  181. 91 LS400 strut rod bushings - press in?
  182. Front air compressor.
  183. LS didn't pass safety, it's the end of it.
  184. Need Some Advice
  185. procedure for checking a faulty fuel gauge
  186. Need both front window controls
  187. What is this body part called? 94 - LS400
  188. Speaker trouble
  189. Need help Ls 400
  190. Somethings leaking
  191. E-brake cable UCF10
  192. 1995 16" 10-spoke center-cap diameter/part number
  193. new guy and need advice on 97 lexus ls400
  194. my bad weekend changing the starter. new problems
  195. Traction Control Light Error Code 43 -- need assistance
  196. 1997 LS400, question regarding transmission filter & P0770
  197. newbie w/classic ls400
  198. Detailing my 93 LS400.
  199. 20" Venza wheels on LS?
  200. need serious help car not starting 98 ls
  201. Daytime Running Lights! 1998 LS400
  202. Coolant overflow resevoir/coolant level sensor swap
  203. ls400 navi removal
  204. 1993 LS400 3 major questions
  205. Fluid leaking/water or possible ps fluid?
  206. 19 inch tire question
  207. '92 LS 400 dr's door latch issue
  208. 1993 Rear seat removal problem.
  209. Torque Crankshaft Pulley Bolt @ 181ft/lbs
  210. Red Clear Red Tailights for '98-2000 LS400
  211. My new 1997 Lexus LS400 I bought off eBay. Please help me fix it!
  212. Need trunk release lever plastic cover
  213. sub replacement for 97 ls400 nakamichi
  214. Fog light and marker light Fuse
  215. LS400 sub/rear speakers hook up to new toyoya head unit
  216. Real Ghetto LS400's
  217. Sputter after replacing EGR Pipe
  218. Replacing front Struts and Upper Control Arms
  219. Newb...sorta
  220. my dash lights
  221. 1994 LS400 Nak Stereo w/changer Issue
  222. Any difference between Lexus vs Infiniti
  223. To Replace or not to Replace Timing Belt
  224. EGR Pipe Replacement-Drop Tranny or Remove Intake
  225. toyota type IV trans fluid
  226. Japanese Celsior Brochure
  227. Catalytic Converter Bolts ?
  228. Cost to replace Egr Pipe
  229. Took the car out to the twisties :)
  230. motor mounts?
  231. 90 grey ls400 progress 180k
  232. trans stays in 1st when lights are on help
  233. cold starting problems
  234. 1990 LS400 Fuel door
  235. Does Seafoam really work
  236. Code 13 - Distributor Rotor?
  237. Weird grinding or clunking on start
  238. replacing passenger mirror on '92 LS400
  239. excessive noise
  240. Where to get wheels on a budget
  241. Introductions Are In Order
  242. 97 ls strut bars or bushings
  243. Upholstery fabric
  244. High rpms on startups on my 1996 LS400
  245. Starter repair on newest 99 LS
  246. No spark, No fuel, No run
  247. 95ls400, check engine light, code P0441
  248. Low Wiper Fluid? NOT
  249. 1994 LS400 Audio Problem (No sound on right side)
  250. Can't figure out why my waterpump is not pumping
