PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 98 ls400 o2 sensor #
  2. 1996 ls 400 iat sensor
  3. 92 LS - Power Antenna Mast Bolt
  4. Ls460 Wheel fit a 2000 LS400?
  5. No heat
  6. Hello Everyone! Can I still buy parts for a 1991 LS400??
  7. mazda 6 vs LS 400
  8. EGR Delete
  9. 1994 vs 1991 cluster
  10. Pics of the new ride! 98 LS400
  11. What an Improvement Wheels Make!
  12. double checking ucf10 brake upgrade
  13. 1999 LS400, 45k miles, but one question....
  14. factory air from lexus
  15. 92 (i think) SC400 Wheels on a 96 LS400
  16. About to buy a 94 LS400, Advice please!
  17. 1990 lexus ls400 order eagle eyes
  18. LS400 Troubles!
  19. Radiator Cap Question
  20. new on this net
  21. Wanting to traded my track car 92 240sx coupe for a 98+ LS400
  22. 300c stock rims for winter on my 91 LS ?
  23. Back-up camera - First Gen
  24. New Member, Old Car
  25. Idling problems :(
  26. Weird issue with heater...96LS...
  27. Tell me why you joined this Owners Club?
  28. transmission filter
  29. What Mileage are you getting?
  30. where can I buy nice rims and a body kit in so cal 92 ls400
  31. 1992 ls 400, whats the biggest size tire i can use for 20's rims?
  32. To get these rims or not???
  33. Beeping after opening door...
  34. 96 LS400 no start? (no codes, new battery, new starter 1 yr old)
  35. EGR Delete kit, Cost beneficial?
  36. trying to use 98 ls400 nak amp including factory sub in another car and sound quality
  37. 1992 lexus 400 wont change gears maybe? lol
  38. Ants... Ants...
  39. New to Club lexus.
  40. New to Club lexus.
  41. exhaust mod...
  42. Need Help
  43. Question about using LS430 wheels/rims on an LS400
  44. Question on Radiator Cap
  45. For the slammed guys: Max front camber?!
  46. 15" wheels ion 93 ls400??
  47. 1990 LS 400 Longevity
  48. Foggin' windsheild
  49. Rant
  50. 94 ls 400 swapping ecm
  51. Master cylinder replacement?
  52. factory alarm system
  53. Charging problem,,
  54. Junction Produce Eye lids
  55. 1990 LS 400 rims/tires??
  56. 1996 LS400 no matter i put 1,2,3 or D same as neutral transmission needs replaced?
  57. I have no remote central locking key
  58. I opted to skip the Black Friday deals this year and picked these up instead
  59. 1995 LS 400 Feels Like it is Starting in 2nd Gear
  60. Nifty info on "Throttle-Shock Condition" in the 1995 LS 400
  61. Megan Lp Camber Plates?
  62. A VERY sad day for LexLS.....R.I.P.
  63. 94 ls 400 no power eng ine and trac light on can't get ecm into diagnostic mode
  64. Does this ebay car have a rolled back odometer?
  65. 1998 LS400 or 2003 GS430??
  66. 1992 LS400 aftermarket remote start install problem !HELP!
  67. Help - Have I just blown a fuse?????
  68. Suspension questions
  69. Need help!!!
  70. fuel pressure regulator
  71. Im going to get an LS400
  72. Buying a 98 LS400
  73. New here. Assistance with turbo..
  74. Engine fan operation question
  75. just picked up a 95LS400
  76. Transmission Drain Bolt
  77. 1992 LS400 - Sylvania Silverstar Ultra?
  78. Heres brakediscs with grooves and dimples for 91 LS.
  79. heated seats
  80. Transmission Sometimes doesn't accelerate as fast
  81. Antifreeze leaking shortly after starter replacement
  82. Castrol Edge: 8X better than Mobil 1 5W-30?
  83. PO340 cam sensor, help?
  84. 95 LS400 Question
  85. 94 ecu problem get a junkyard one or send it to get it fixed in tn.
  86. Really??
  87. Check it out: UCF20 Vectored Design
  88. Looking at a 1996 LS400
  89. 18 to 20 inch factory Takeoff Rims
  90. What are these wires for?
  91. 92 LS400 rough idle after replacing starter
  92. Power Antenna Problem-Help Appreciated
  93. Please Help! Rim/Wheels are hitting calipers
  94. Low Price Strut Rod Bushings 96 LS, incorrect bushing
  95. can alternator failure cause interior electrical not to work?
  96. Few pics of my ucf21
  97. remanufacture PS pump for 45.79
  98. whining noise when turning?
  99. block heater?
  100. Power un-lock not functioning or security feature?
  101. Front End Bottoming Out Solution
  102. Finding a 96 LS400 PS solenoid
  103. Super Low Mileage 92 LS400
  104. New Ls400 owner... having a few problems
  105. Local Montreal shoot
  106. Acceleration/FootBrake Problem.
  107. Need help low power and oil leak
  108. Check engine light went on and turnd off next day
  109. Wont Start somthing with stock securtiy system
  110. $75
  111. Car Cover
  112. Wheel Fit Question - NEWB!
  113. HomeLink on pre 1998
  114. Restoration OVERHAUL!
  115. Looking at a 98 LS400
  116. Megan LP vs EZ
  117. water leaking
  118. ECT Snow
  119. PS fluid
  120. sensors
  121. steering column not moving
  122. I Pod interface with Nakamichi on Ls400 2000
  123. Need help removing glove box cd player
  124. So I went to go work on the LS this morning, but...
  125. Upper ball joint spec
  126. Adus 505 & 583 Bushings On 1st Gen
  127. Replacing the Tranny mount on my 99
  128. harmonic shudder/vibration at idol
  129. timing belt has cracks and other issues
  130. help me with the problem of transmission
  131. Ghetto rig. jackleg repairs, etc.
  132. 95/96 transmissions - same part number?
  133. NOS kit for 99 LS400 what to buy please, ez install?
  134. Stuck in Park
  135. 1992 LS400 - Aftermarket Grille
  136. which coilover is better
  137. Valve covor gasket removed and replaced
  138. Car lunging forward when letting off the brake
  139. Lights dim for a sec when brakes are applied and then back to normal
  140. Crankcase Ventilation Hoses part #'s?
  141. Fix leaky steering (95)
  142. 1st Gen - No Radio unless in the hot summer.
  143. timing question
  144. 1994 LS 400 overheating problem
  145. Removing the side markers
  146. calling 1uzfe experts for help!
  147. more power
  148. After Market Parts
  149. Cracking Noise When Braking
  150. Power Steering ACV valve
  151. Value of late model LS400's
  152. How in the world do the BBS style mesh wheels come off of the 2nd gen LS?
  153. Has anyone noticed a slight short honking sound when giving gas?
  154. High RPM at idle. 1200 rpm?
  155. A little Lexus love from South Carolina
  156. How do I install the Goodyear wipers bought at Costco?
  157. Cleaned my Throttle body and now I have a Trac Light
  158. no power, no engine codes, wtf?
  159. Another "Should I buy...?" thread
  160. Antifreeze
  161. nails in my gas tank
  162. '92 LS excessive gas use-How to check codes?
  163. 1998 LS400 PO340 and hard start help
  164. Car will not start
  165. remote unlock
  166. Air suspension problem
  167. Portable GPS mount location
  168. 1993 Ls400 Headlight issues. Help.
  169. 99 ls 400 help!!!
  170. 1990 ls400 fuel pump cover wires broken
  171. 94 LS400 New Torque Converter for Used Aisin-Warner Tranny ?
  172. Insulation for exhaust system
  173. Removing 1st Gen LS400 Glovebox??
  174. 1991 ls400 headers
  175. What does this warning light mean?
  176. Radio compatibility?
  177. radio help
  178. tools for rear trans seal replacement?
  179. Shorted cam sensor????
  180. steering wheel TILT AYO!
  181. Clock spring replacement
  182. Help !! 1995 Lexus LS400 Steering Problem
  183. Replacing struts with OEM, anything else to get?
  184. PS Pump/Rack replacement, what else do get?
  185. I took the poly strut rod bushings back out
  186. on to the next hurtle
  187. 91 LS 400, No Reverse but I have Drive
  188. Paint Color help (w/pic)
  189. 1998 LS400 spungy brakes
  190. VIN# / Engine Serial number verification?
  191. Fixed Stiff Steering
  192. 1998 LS400 Splash Shield
  193. Should I buy this 1997 LS400?
  194. LS400 ('94) Ball Joint Challenge...
  195. 1994 Lexus LS400 best Reman Transmission ???
  196. 94 LS jerks & Blinking Check Engine Light
  197. Natural Gas conversion - First Gen?
  198. First Gen - Aluminum lower body panels?
  199. Front UCA's Upper Control Arms
  200. Massive Coolant Leak from Behind Crank Pulley
  201. Ready to sell
  202. Wrong radiator cap?
  203. Few Quick Questions (95 LS)
  204. Tail Light Problem
  205. Two Low pressure a/c ports? 1991 LS400
  206. LS400 compatibility with SC400
  207. Hola
  208. my fresh to me ufc10!
  209. ls 400 vip curtains ?
  210. Runs rough on second start-up
  211. what is the indicator for a bad starter?
  212. Ls400 Oil Filter 90915-20004
  213. Discount code for Carson Lexus aka l-tunedparts
  214. Picked up a LS400 for the wife off Craigslist
  215. Scrape Pan anyone?
  216. snow tires
  217. My solution to dead door lock actuator
  218. Throwing codes P0300 & P0307 intermittently
  219. New 98 LS400 owner.
  220. Bumper fastener part number
  221. upper control arm removal??
  222. Grinding when coming to a full stop
  223. Present in the mail!
  224. New LS400 owner here
  225. unknown leak:mad:
  226. Can you change a Nackamichi to a pioneer -98ls400
  227. 1997 LS400 Rear Seat Removal
  228. DIY Heated Seat Repair W/ Pics
  229. ebay CC LCD review
  230. Sort of New, My 00 LS400
  231. Any one have stock exhaust manifolds for 1998-2000 LS400?
  232. 1993 LS400 Doesnt move in Drive
  233. 1994 LS400 Phone Controls
  234. Cigarette Lighter POWER ISSUES?
  235. High Idle (Rpm's) or Not
  236. LS400 unloading fail.
  237. unknown part.. coolant leak
  238. Purchased 95 LS, now some DIY Repair Questions
  239. Brake fluid
  240. Leak?
  241. Serpentine belt Stuck/Squealing
  242. Fan clutch - would like help from US
  243. Ls400 5spd M/T
  244. WOW Check this out!!
  245. "Groan" from steering rack?
  246. trouble
  247. My '93 LS400 not starting/running...
  248. Advice on Lexus LS400 Catalytic Converter
  249. My LS400 has lost power :( Any and all help would be greatly appreciated!
  250. Need 94 LS400 ECM ASAP!
