PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. ls400 1994 and 1992 problems, need help
  2. 95 engine in a 92?
  3. Rod knock!?
  4. check engine diagnosis
  5. New member intro.....
  6. suspension advice
  7. Securing single subwoofer box
  8. Where does this connect to? (1990 LS400)
  9. Can't find projector headlight's for 96 LS 400
  10. what warning light is this?
  11. 91 Ls400 with a supercharged 350 chevy
  12. runs hot in 20 mins ls400 94
  13. Remedial questions about torque converter failure
  14. Speakers for a '98
  15. 90 LS400 purchase advice, please
  16. best aftermarket rack and pinion
  17. Coolant leak front under intake manifold
  18. Thermostat?? Giving sealant a go
  19. What socket sizes for strut bars and ball joints
  20. Transmission noise sounds like PS pump
  21. Intermittent vibration worsens while braking - sometimes
  22. Tough No-Start Problem
  23. 93 LS400 Getting rid of the traction control
  24. Rear Shocks
  25. 92 LS400 with AIRY BIG FAN BLOWING sound when Rev'd???
  26. Tragic end for LS400
  27. No start, check what first?
  28. Tire Size Help
  29. Cam seal or valve cover leaking?
  30. Where to buy extra keys for LS400
  31. LS400 Caliper assembly
  32. first gen non air to factory air suspension conversion
  33. emblems
  34. Exhaust smell in car
  35. Climate control
  36. Power Steering Question
  37. Stripped trans pan-to-case bolt
  38. Torque Converter "while you're in there" advice
  39. PS, to buy with or without the solenoid
  40. Roof rack
  41. 94 ls400 telescope steering wheel fix
  42. 94 LS400 Fuel Pump?
  43. So my Lexus is now a Gross Polluter...
  44. Throttle body/intake manifold Coolant lines
  45. Lwb!?
  46. post airbag engine start
  47. Premium Stereo Disabled - Reset Needed
  48. First Gen LS - Tonight on TV!
  49. Condensation
  50. Problem
  51. kyb W0133-1792263 vs kyb KY341268
  52. 1993 LS400 throttle cable replacement
  53. Aftermarket head units- post your pics!
  54. Double Din Question
  55. New Megan racing Suspension parts...
  56. Ethanol/Cold Wx & Starting Problems?
  57. torque converter
  58. Older LS To-Do List
  59. Please use classifieds for FS threads (after reading the classified rules at top)
  60. point me in the right direction
  61. HID troubleshooting
  62. power draw... arggggggggg
  63. LS400 retrofitted with Jaguar Vanden Plas picnic tables
  64. lexuspartsnow.com - Any experiences?
  65. lowered 98 ls and is now rubbing when turning
  66. Replacing heater core
  67. Horn don't work
  68. Noob with an audio question
  69. Suspension Question, Spindle assembly?
  70. New power steering pump, fast leak now
  71. Engine Problems... Help please!!
  72. 1990 LS400 Occasional no reverse gear
  73. What is this melted burnt smell???
  74. OEM or aftermarket PS hose ok?
  75. Newbie question re: 99 LS 400
  76. "replacement" brand shocks
  77. Horn isn't working. HALP. D:
  78. Severe oil leak/burning oil
  79. Park and Neutral safety switich seal Leak?
  80. considering a 96 LS
  81. 94 Ls400 Accelaration & Light Problems
  82. HELP OEM Suspension stuck in bottom bracket
  83. Remove middle mufflers, better sound or worse?
  84. 91ls400 engine
  85. Aftermarket vs rebuilt oem steering pumps and acv
  86. Christmas eve bought 1994 SL400 for $1200
  87. car start up and kills at 17000rpm what could be the problem?
  88. replaced alternator,power steering leak ls400
  89. Low rumble under car: Torque Converter or other?
  90. Starter spinning, no start
  91. Window switch and motor removal
  92. Basic question from LS400 newbie: how to jack!
  93. LS400 1996 Key Fob Program DIY
  94. need help broken bolts
  95. New LS400 owner, need OEM tranny mount
  96. Trunk lid interchangeability
  97. Posting pic of my new LS400 96
  98. spring for the throttle
  99. My new ride a lexus ls 400
  100. Inner Tie Rod Size
  101. 2000 LS400 - Some feedback needed
  102. 92 ls 400 loud whinning noise?????
  103. Gear Indicator Flashing
  104. light check eng. & vsc
  105. Radiator light
  106. New UCF10 Owner!
  107. No power steering
  108. New '95 Celsior owner
  109. 97 ls400 power steering pump failure?? Little different than the rest.
  110. 92 lexus ls400- i got a few question see if you can help
  111. How To Unlock Seatbelt?
  112. 98 ls400 V8 missing
  113. air suspension wont go up
  114. refurbished rack and pinion for 91 LS?
  115. Rear Lower Control Arm Bushings HELP!
  116. Uh Oh! Sulfur smell
  117. suggestions for HID
  118. High Pressure Fuel Flush
  119. How to tell if I have Nakamichi?
  120. conversion kit
  121. 91LS Master Cylinder
  122. convertation kit
  123. Seat belts
  124. New ucf20 member: Hello there
  125. ls400+snow=broken wheel+wheel bearing
  126. Door Latch Stuck in Open Position
  127. Rain-X wipers? - 92 LS
  128. Checking out a 92 Lexus things to look out for?
  129. Two Flat Tires but no hole!?
  130. ls rear air suspension
  131. Doors Freezing, is it typical
  132. 95 ls400 wont accelerate just bogs out
  133. where is the cap so I can put t4 transmission oil 92 ls400
  134. Are any steering wheels a direct effect?
  135. Has anybody done the BFI mod?
  136. Crazy Vibration
  137. 99 LS400 losing air pressure
  138. My starter adventure on my '92 LS400
  139. RE: 1992 LS400 wont shift into gears maybe.???
  140. 1993 LEXUS LS400 door locks not working
  141. New car runs bad/rough, 1993 lexus ls400 (shakes & vibrates)
  142. White smoke when i start, ps leaking?
  143. Key Fob - Locks but that's it
  144. insurance
  145. battery charging problem
  146. LS400 not running after changing starter
  147. Blue Plastic Sensor?!
  148. Skip at 40 MPH
  149. Please Help--Starting Problem!
  150. 98 LS Whinning Transmission
  151. 1996 LS 400 running bad please help
  152. Help help help
  153. 98 ls400 o2 sensor #
  154. 1996 ls 400 iat sensor
  155. 92 LS - Power Antenna Mast Bolt
  156. Ls460 Wheel fit a 2000 LS400?
  157. No heat
  158. Hello Everyone! Can I still buy parts for a 1991 LS400??
  159. mazda 6 vs LS 400
  160. EGR Delete
  161. 1994 vs 1991 cluster
  162. Pics of the new ride! 98 LS400
  163. What an Improvement Wheels Make!
  164. double checking ucf10 brake upgrade
  165. 1999 LS400, 45k miles, but one question....
  166. factory air from lexus
  167. 92 (i think) SC400 Wheels on a 96 LS400
  168. About to buy a 94 LS400, Advice please!
  169. 1990 lexus ls400 order eagle eyes
  170. LS400 Troubles!
  171. Radiator Cap Question
  172. new on this net
  173. Wanting to traded my track car 92 240sx coupe for a 98+ LS400
  174. 300c stock rims for winter on my 91 LS ?
  175. Back-up camera - First Gen
  176. New Member, Old Car
  177. Idling problems :(
  178. Weird issue with heater...96LS...
  179. Tell me why you joined this Owners Club?
  180. transmission filter
  181. What Mileage are you getting?
  182. where can I buy nice rims and a body kit in so cal 92 ls400
  183. 1992 ls 400, whats the biggest size tire i can use for 20's rims?
  184. To get these rims or not???
  185. Beeping after opening door...
  186. 96 LS400 no start? (no codes, new battery, new starter 1 yr old)
  187. EGR Delete kit, Cost beneficial?
  188. trying to use 98 ls400 nak amp including factory sub in another car and sound quality
  189. 1992 lexus 400 wont change gears maybe? lol
  190. Ants... Ants...
  191. New to Club lexus.
  192. New to Club lexus.
  193. exhaust mod...
  194. Need Help
  195. Question about using LS430 wheels/rims on an LS400
  196. Question on Radiator Cap
  197. For the slammed guys: Max front camber?!
  198. 15" wheels ion 93 ls400??
  199. 1990 LS 400 Longevity
  200. Foggin' windsheild
  201. Rant
  202. 94 ls 400 swapping ecm
  203. Master cylinder replacement?
  204. factory alarm system
  205. Charging problem,,
  206. Junction Produce Eye lids
  207. 1990 LS 400 rims/tires??
  208. 1996 LS400 no matter i put 1,2,3 or D same as neutral transmission needs replaced?
  209. I have no remote central locking key
  210. I opted to skip the Black Friday deals this year and picked these up instead
  211. 1995 LS 400 Feels Like it is Starting in 2nd Gear
  212. Nifty info on "Throttle-Shock Condition" in the 1995 LS 400
  213. Megan Lp Camber Plates?
  214. A VERY sad day for LexLS.....R.I.P.
  215. 94 ls 400 no power eng ine and trac light on can't get ecm into diagnostic mode
  216. Does this ebay car have a rolled back odometer?
  217. 1998 LS400 or 2003 GS430??
  218. 1992 LS400 aftermarket remote start install problem !HELP!
  219. Help - Have I just blown a fuse?????
  220. Suspension questions
  221. Need help!!!
  222. fuel pressure regulator
  223. Im going to get an LS400
  224. Buying a 98 LS400
  225. New here. Assistance with turbo..
  226. Engine fan operation question
  227. just picked up a 95LS400
  228. Transmission Drain Bolt
  229. 1992 LS400 - Sylvania Silverstar Ultra?
  230. Heres brakediscs with grooves and dimples for 91 LS.
  231. heated seats
  232. Transmission Sometimes doesn't accelerate as fast
  233. Antifreeze leaking shortly after starter replacement
  234. Castrol Edge: 8X better than Mobil 1 5W-30?
  235. PO340 cam sensor, help?
  236. 95 LS400 Question
  237. 94 ecu problem get a junkyard one or send it to get it fixed in tn.
  238. Really??
  239. Check it out: UCF20 Vectored Design
  240. Looking at a 1996 LS400
  241. 18 to 20 inch factory Takeoff Rims
  242. What are these wires for?
  243. 92 LS400 rough idle after replacing starter
  244. Power Antenna Problem-Help Appreciated
  245. Please Help! Rim/Wheels are hitting calipers
  246. Low Price Strut Rod Bushings 96 LS, incorrect bushing
  247. can alternator failure cause interior electrical not to work?
  248. Few pics of my ucf21
  249. remanufacture PS pump for 45.79
  250. whining noise when turning?
