PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Weird problem with Stereo Head Unit Install - Beatsonic Issue 90 LS
  2. 98 LS400 Mud Guards
  3. '94 LS Mirror - How many wires
  4. Power lock switch
  5. Rack n Pinion leaking what are my options ?
  6. "93 front speakers crossover
  7. Transmission Filter, drain plug and Gasket question.
  8. 1990 lexus no start
  9. driver window wont work
  10. Coming back to an LS
  11. new suspension and still sagging!
  12. Anybody tried '04-'06 LS430 5 spoke rims on an LS400?
  13. ?Wild story on better gas mileage!
  14. chassis plugs by ecu
  15. 93 ls400 timing belt replacement, what else should be done
  16. Coil OVERS???
  17. 18" rims
  18. Opinion needed...tail lights and paint - 90 LS400
  19. 1993 Ls400 problem
  20. For Sale and Want to Buy posts go ONLY in the classifieds.
  21. Halo Lights For My 1998 LS400
  22. Passenger Rear Right Power Lock not working
  23. maf adaptor for cone filter?
  24. Lexus LS400 Won't Start Please Help!!
  25. rear window spoiler
  26. ls circuit breaker or fuse problem hellp
  27. Heating & ac control panel not working
  28. Engine Vibrations during morning idle and in first gear
  29. 92 LS400 Electrical Issue
  30. My Corner Light Fell off! on my new 97!
  31. upgraded from an '07 cts to '98 LS! now wheel opinions pls.
  32. 93 LS400 digital odometer stopped working
  33. Anyone know a Real GOOD ECU repair shop, 91 LS
  34. anyone had experience with village toyota parts in florida?
  35. 1990 lexus ls 400 electrical problem
  36. OEM crush washer made where?
  37. Rear wheel thunking noise
  38. !992 Lexus LS400 problem
  39. Ls400 factory amp compatability
  40. the whitest hid kit out for my ls400
  41. are there mirrors with blinkers for a ls400
  42. N to D thump??
  43. Bad mileage after temp sensor swap
  44. ls400 fender liner removal question!
  45. 90' ls before & after wheels
  46. 1990 ls400 ecu pinout
  47. E-Brake Help
  48. Subwoofer grille rattling!
  49. Is anyone interested in a tutorial?
  50. Coolant Flush Help!
  51. Which one should I get? Ls or GS
  52. Long crank before start
  53. Daytime running lights?
  54. well i just purchased a ucf10
  55. Egr delete mod...
  56. brembo front rotors
  57. UFC20 rear strut rod bushings
  58. 97 Nak changer dead..options?
  59. Question about 1999 LS400 ignition coils
  60. O2 sensor
  61. New mods: UCF20 $65 Chrome Trunk Garnish & Woodgrain Beatsonic faceplate with Pioneer
  62. ls 400 cam
  63. I broke my strut rod!!!
  64. Will LS 460 Rims work for 96 LS 400
  65. Smog test goes wrong!
  66. Looking for floor carpet for my 92 LS400
  67. Strut rod bolt seized?
  68. New battery died after about 30 miles
  69. seeks steering damper, struts recommendation
  70. 1991 Airbag Layout
  71. Transmission mount OEM vs other brand
  72. 1991 LS400 Radio Problem...
  73. ABS issue ..
  74. need help with the pvc valve
  75. 92 LS 400 with 29000 miles
  76. DIY: Fan Clutch repair
  77. LS400 gurus ... your wisdom is needed ...
  78. Dealer charge to replace motor mounts?
  79. Weird problems
  80. light vibration feel in motor when accelerating
  81. just got vossen wheels on my 99 LS
  82. Strut bar Bushing or cushion?
  83. A/C temp at vents
  84. Lowering my 91' LS400
  85. trying to define what model lexus ls400...
  86. 1990 LS400 Traction Control Issue
  87. Oxygen Sensor Diagnosing
  88. Wheel Size Question for 1995 LS400... please help
  89. 1996 ls400
  90. Aftermarket Subwoffer and Amp
  91. Replaced Knock Sensors MIL still on
  92. guess where the hoses go!!
  93. 1990 Lexus LS...had it shipped and now it's not running..
  94. Vibration when braking, bushings?
  95. 98 ls Random increase in RPM
  96. New LS400 owner... yes i tryed search... :P
  97. 96 ls400 convert to 03 ls430 steering wheels ?
  98. 95 LS400 HID problem
  99. please help me (CEL, engine shaking)
  100. Camry rotors on LS?
  101. Parts for homemade stainless steel exhaust
  102. Whining sound from front of engine??
  103. Sudden acceleration problem 98/2000 ls
  104. Missing Under load/no power, NEED HELP
  105. Serious problem, need help.
  106. My new ls :-D
  107. proformance parts
  108. door switch
  109. Running Rich
  110. transmission gasket
  111. Transmission fluid leak - 91 ls400
  112. 4th gear problem
  113. 1996 LS400 AFM / MAF Connector
  114. m3 style trunk spoiler
  115. LS 400 security light
  116. Lexus = ripoff artists
  117. sunroof leaking
  118. Delima shimmy and bad vibration while breaking
  119. metal headgaskets for the 1uz
  120. Phew...never seen that before.
  121. HVAC vents and circulation
  122. bumper question
  123. Thinking about buying an LS
  124. Water Pump R&R - 97 LS400
  125. Drive and reverse light indicator on.
  126. Seat Compatiblity
  127. Air Conditioner compressor not engaging in 50 deg weather - normal?
  128. Please use the classifieds for FS and WTB posts.
  129. Acceleration = light flutter feel on 98 LS400
  130. slight Thump/Clunk while backing up
  131. 1998 ls400 new beginnings
  132. transmission jerks in revers
  133. Help choosing rims
  134. Proud new owner of a 99 ls400
  135. Can I update GPS on 1998 LS400??
  136. Upperclassmen LS400
  137. Chrome bumper trim
  138. EGR troubleshooting
  139. 1992 LS - Mystery sounds (problem?)
  140. White smoke in engine compartant and exhaust followed with hissing sound
  141. Running wire through firewall
  142. Japan earthquake
  143. interstate battery warranty
  144. exhaust manifold outlet size
  145. Help!! huge problem.
  146. it this natural? (fan comes on when turn key to the on position and stays on)
  147. Loss of Power Steering
  148. 1996 LS400 Questions
  149. 91 Ls400 LeBra.?
  150. Rear Upper Control Arms
  151. Coilover help
  152. Steering Wheel Vibration
  153. OEM Navigation 98 LS400
  154. 1992 LS400 won't start
  155. Bad shifting
  156. intermitten chirping... how long does idler, bearings last?
  157. will 93's 16" center cap fit 90's 15" center cap?
  158. harmonic ballancer removal
  159. 1991 Subwoofer Amp or Speaker?
  160. Sport ECT
  161. Water Leak. Water Pump?
  162. well, i need to find an ls with a bad motor for cheap
  163. gas adjustable kyy
  164. thread headings specificity
  165. car slightly steers loose on freeway... what could it be?
  166. How to remove rear seat on 2000 Ls400
  167. Newbie With Power Steering Pump Leak
  168. Help. Power steering pump seal kit
  169. Help! Ls 400 Gas Pedal
  170. burning oil and bad mileage
  171. 1998-2000 LS 400 safety features
  172. How to seafoam ?!
  173. Wood Steering wheel swap?????
  174. Control Computer? (no power, dying etc)
  175. Maintenance schedule for 1999 LS 400?
  176. Another Idle problem thread. 1997 LS400 Idles too low when warm and in gear
  177. anyone got 15" chrome wheel cap?
  178. 96 LS400 EGR Tube location
  179. 95 LS400 low beam just quit
  180. gas economi
  181. Gas Gauge or Miles Left... What's Right?
  182. Battery drain Passenger door
  183. Vsc And Check Engine Light 1998 Ls 400
  184. Will the doors off a 91 fit my 95 LS400?
  185. Transmission fluid level check
  186. Why use the BeatSonic adapter....?
  187. Dirty LS400 Engine
  188. 96 LS400 heater/ac not working
  189. why 2 ohm in front and 4 ohm in rear?
  190. transmission ecu question
  191. '98 Nakamichi headunit replacement
  192. Interchangable Transmission Mounts?
  193. Advice on Buying 98 LS400
  194. just checking in
  195. speedometer not working
  196. 1992 LS400 - Oil Level Sending Unit
  197. Brake job -- Rotors/pads 94-LS400
  198. which sensor is this?
  199. Vibration after 19" aftermarket rims & tires
  200. 97' LS4 - Changing the front blinker
  201. bad catalytic converter advice please?
  202. Tweeters cracked
  203. Engine problem!
  204. 96 LS400 loud engine
  205. Need a Fuse Box Diagram...
  206. Crankshaft seal replacement
  207. 95 SC seats in a 95 LS (I have searched)
  208. water pump replacement
  209. Tune up gone bad!! HELP REALLY NEEDED BAD!
  210. plug wires specification(please help)
  211. newbie looking for parts
  212. here is why you dont send your ecu to ATE to be repaired.
  213. Lighting issues (sort of) please help anyone.
  214. the best price for parts
  215. dealer = good deal on timing belt job
  216. wind noise
  217. 1995 ls 400
  218. First Lexus
  219. 1996 ls400 PLEASE HELP
  220. 92 ls400 seats
  221. motor mounts
  222. 1991 LS 400 Subwoffer
  223. Power Window Auto Down
  224. Bumper color code 96 ls400
  225. 93 LS400 Check Engine Light
  226. 98-00 LS400 w/out Navi: which wiring harness do I need for audio?
  227. first gen rain handling improvement
  228. 1st gen vs 2nd gen LCA bushings
  229. spark plug wire
  230. Price Check 2000 LS 400
  231. I have fixed my no heat in the car for a 8 hour ride to Buffalo, thanks to this forum
  232. Help have this hesitation on the gas pedal
  233. Wheels and offsets
  234. Looking for headers for 95 celsior
  235. how to get cup holders in front to come out of the armrest.
  236. Leaking Coolant
  237. 1999 LS400 rear suspension
  238. slight engine miss,shaking and rpm drop
  239. what can make a ecm go bad?
  240. Something loose in steering
  241. Sooo tired of stock steering wheel
  242. 2000 LS 400 Rims
  243. LS400 won't start - dinosaur bite??
  244. LS400 wheels
  245. 93 LS400 acceleration problems?!? help!!
  246. 96 LS400 fuel filter location
  247. Door Glass Replacement - Need Help
  248. Trouble code 28 and trac code 47
  249. 96 Ls400 Will Not Start
  250. Heating inside the car.
