PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. No Blinkers, No Dash Lights, No break lights, Cant shift out of park!! Help Me Please
  2. 93 LS400 Depot Lvl MX accomplished (TB/WP 130k mi)
  3. real low mileage ucf10 f/s by me.
  4. 96 LS400 question...
  5. Need any helpful advice before I attempt to replace an injector...
  6. Traction control in dry weather
  7. 99 LS400 Valve Cover Gaskets
  8. engine problem
  9. Transmission Issue??
  10. Sad seatbelts
  11. Flappy blowy engine noise
  12. MK3 Supra Coilovers on UCF20??
  13. Idle Problem With My 1990 Lexus Ls400 Please Watch Video
  14. 99 First change from 1st to 2nd in morning is slow
  15. Engine Cleaning?
  16. Hesitation shifting from 1st to 2nd
  17. V8 Growl- Post TB Service
  18. car molding mosturizer?
  19. valvoline fuel injector cleaner is it safe?
  20. are megan coilovers lighter than stock setup?
  21. Charcoal canister question / power door lock actuator motor.
  22. quick fog light install. :)
  23. 1995-1997 vs 1998-2000 LS 400 Interior
  24. saw the neatest looking ls400 today
  25. Cam seal leaking bad
  26. Battery, alternator fuse questions
  27. Bleeder Valve
  28. 94 LS400 AC Issue
  29. Window Reset/Reprogram?
  30. Newb to the world of Lexus
  31. A new Radio issue
  32. UFC20 interior electronics questions.
  33. Trans Pan
  34. cusco strut bar wont fit. :(
  35. Anyone have any ideas on a car killing when given gas
  36. LS400 Alternator Problems (searched)
  37. 1991 LS400 with only 110,000 miles
  38. Help!! Steering wheel problems!!
  39. Scion TC Mirrors On UCF10??
  40. A/C Question
  41. Renew door clunk
  42. UCF20 engine cover on UCF10?
  43. AC fans not coming on
  44. 1998 ls can't install shocks back on! WTH?
  45. anyone replaced all the hoses?
  46. 98 to 2000 ls400 ride quality question
  47. 1992 Nakamichi 81620-50080 - Very Low Audio
  48. 1992 LS400 1UZFE wont start, wont even crank :(
  49. will removing the rear mufflers increase performance?
  50. 1990 LS400 A/C Electrical problem
  51. back ache
  52. What does UFC mean????
  53. LS400 Fuel Lines /Gas Smell /Stuttering during acceleration
  54. whinning from engine / dimming interior lights when closing windows
  55. please help how to change coolant on an 98 ls400
  56. apx struts on ebay any good only $135.00 for all 4
  57. LS400 antenna
  58. Radiator Hose 91 LS400
  59. Cinnamon interior in my UCF20
  60. Car won't start, electronics don't work!
  61. Code p0420 96 ls400
  62. Signal/Parking light problems
  63. 1991 1jz ls400 swap
  64. Code 0340
  65. 99 Headlight vertical alignment notes
  66. 93 LS 400 cuts out at 2000 rpm
  67. 90 ls400 (newbie)
  68. My touch screen is still white light
  69. 97 fob questions
  70. LS400 Power steering pump
  71. UCF 10 to UCF 21
  72. 91 LS400 Interior
  73. Confused about fluid levels/please help
  74. Reasonable alternator and fan clutch replacement cost
  75. Showing Codes 13, 14, 24, and 71. I need help
  76. 94 ls 400 wont start when warm need help !!
  77. New Paint Job Coming Soon!! (Need Opinions!)
  78. Update on my 93 Lexus LS400
  79. LS400 NRCAs
  80. LS400 Question
  81. My "new" summer work car...
  82. Any service differences from 96 to 99?
  83. 93 ls400 dash problem
  84. look at what i got!
  85. Show me your HID beam pattern
  86. 96 LS400 weird sound
  87. Need help with gas gauge 1993 LS400
  88. Thump thump thump from front right wheel
  89. 1993 lexus ls400 gas question
  90. rear bulb got damaged
  91. EGR Solenoid help
  92. So how do i reset the tail lamp failure message?
  93. proof; admin davegs4 is a douche
  94. Upper Control Arm = Vibration?
  95. Got some new wheels for the ls400!
  96. dash lights
  97. Coolant from Toyota?
  98. A/C code 33
  99. 1st Gen LS400 ipod/mp3 cable routing
  100. What year ls400 to get?
  101. UFC20 factory air ride install problem font bags wont air up
  102. Check Engine Light!
  103. 1993 California LS400 ECU ECM internal pics
  104. blower fan slows down when brake is pressed
  105. i could carry the front end of my ls400
  106. Polished or Chromed Door Handles?
  107. check out my new home made lip... not home depot or garden liner.
  108. Im stumped!!!! Car wont start
  109. 95 LS400 with 135k - What is a good price?
  110. starters on 92 ls 400
  111. New owner here; car has rough idle and hesitation going up hills
  112. Car does something odd when cranking
  113. Multiple Issues I Need Help Diagnosing (AC & Vibration)
  114. Post for sale items in the classifieds, not here.
  115. where to find celsior parts
  116. Pale green ls
  117. My ls got 594 miles on one tank to Florida
  118. ' 92 LS Cranks, turns over and then dies?
  119. changing to leds, but footlight spec,, ?
  120. I dont know whats going on with my windows!
  121. Fitment question - 18x7.5 +35 on '00 LS400?
  122. Tokico Stuts - Any Reviews?
  123. 91 LS400 Wont go past 4,000RPM
  124. 95 LS400 Not Getting Spark. Help!
  125. 94 ls 400 intermittent check engine light
  126. New LS400 member here
  127. 92 LS400 - "Buzzing" sound when cold
  128. Telescopic Steering Column Question
  129. call me crazy, but anyone try iroc rims on ls?
  130. worst day ever 96 LS400 problem
  131. 91L400 Lights
  132. Stereo LCD Light
  133. 98 ls400 buzzing sound from steering column/instrument cluster
  134. JP Vizage UCF10
  135. 92 LS w/ Nak audio problem??
  136. DIY Brake Job question and SS lines?
  137. Parking Lights(rear) and Fog Lights(mod) don't come on?
  138. selt belt trouble
  139. Timing belt possibly dumb question
  140. best way to change the torque curve?
  141. 98 ls400, what should be the proper idle rpm?
  142. how does everyone on here SHIFT their cars?
  143. 1998 ls400 with 73k, when should I expect the alternator to fail?
  144. 91 LS400 Seat stuck
  145. Car bucks
  146. Cold Trans
  147. LED Signals Front&Rear question
  148. need to identify this part of the suspension
  149. Starting issues, some troubleshooting... but not much!
  150. 98 ls400 engine whine! idler pully? alternator?
  151. driver's door lock not locking
  152. What wheels ?
  153. Water coming behind the driver seat
  154. installing an CD player in the ash tray
  155. April Adventures in the Lex - Sucks to Roll Hard!
  156. upper oil pan or engine mid case.?
  157. Does anyone still sell daizen bushings
  158. Are 1998-2000 Ls400 affected by the leaky steering pump
  159. Question about lowering the steering wheel in a 96 LS400
  160. so how hard to convert to air suspension
  161. Beeping Noise From Left Rear Panel
  162. Should I Buy This Used LS?
  163. 1998 ls400 Power Steering question / Problem
  164. Antenna Difficulty
  165. Noise at start, pulls to right
  166. New car, pretty happy
  167. CEL VSC OFF 1999 LS400 after throttle body cleaning
  168. Squeaking sound when revving up
  169. Temperature Gauge Drops
  170. First Gen - oil drain bolt
  171. Proud new LS400 owner and member
  172. need opinions/suggestions on repair UCF20
  173. DIY: 90-94 LS400 Front Air Suspension Removal (Air Struts)
  174. Right Front Seat Removal 96 LS400
  175. New to forum/leaking sunroof...please help
  176. UCF11 vs UCF20 Tails
  177. driver door outside will not open
  178. New (I just got a LS400 UCF20!)
  179. Modding the newer style license plate lights
  180. another new guy here
  181. New Member To Clublexus!
  182. ls400 running badly, rough, feels like 4 cylinder, no ability to rev
  183. What other stock rims are enterchangable??
  184. What wire is this?
  185. Dtc codes 14, 71
  186. LS400 Wheel Fitment Q's - Will These Fit?
  187. ABS Light, Hard to steer, wont shift out of park
  188. Diagnosis
  189. A sad, sad day for me :(
  190. Tail light rattle fix?
  191. ucf1o full clear taillights?
  192. Question about 90 LS400 front Air Strut Removal
  193. 98 Lexus ls 400 suspension torque specs
  194. Trans Pan
  195. 95 LS400: Low in Montreal; a tale of scraping, knocking and breaking
  196. 91 ls400 transmission issue
  197. Turn Signals Not Working
  198. 92 ls400 trouble starting.
  199. My baby is throwing codes!
  200. air bag light and car horn not working
  201. Keyless entry help
  202. steering rack (best place to buy)
  203. Broken connectors
  204. Fog lights won't turn on not the bulbs or fuse, help?
  205. Cheap strut rod cushions for GEN 1??
  206. Need new cupholder assembly for LS 400
  207. 1jz Swap into an LS400 (1996)
  208. Exhaust Leak soung.. no exaust... Help
  209. What hub/wheels recommened for ls 400
  210. Driver side turnsignal bulb replacement
  211. ABS and VSC light
  212. Interchanges from other cars
  213. Looking at this 91 - Need advice
  214. 90-94 ls400 suspension
  215. Help removing rear axle carrier
  216. P/S Problem '94 LS400
  217. I'm uncertain if its worth it to buy this car. Maybe it is, maybe it isn't. I can't
  218. 98 front bumper fitting a 93?
  219. 2000 ls 400
  220. Cruise Control Unresponsive and Acting on its Own
  221. What's brass fitting on rear of air intake chamber for?
  222. just bought '93 lexus LS400 key works but plastic remote was broke off
  223. Headlight bulb replacement for 1990 ls400
  224. First Gen - power steering pump failure ok?
  225. electrical problem, will not turn on my LS400
  226. Just put in a new JDM motor. Only dash has power, no crank. Help?
  227. 94 ls400 and 95 ls400 air ride
  228. Will this Work?
  229. no codes/no start
  230. is rear seatbelt interchangeable with driver's?
  231. Alternative to coilover?
  232. Can i fit a 98 ls steering wheel on my 96
  233. New rims?
  234. Help. Coilover install - Megan EZ
  235. Weird problem with Stereo Head Unit Install - Beatsonic Issue 90 LS
  236. 98 LS400 Mud Guards
  237. '94 LS Mirror - How many wires
  238. Power lock switch
  239. Rack n Pinion leaking what are my options ?
  240. "93 front speakers crossover
  241. Transmission Filter, drain plug and Gasket question.
  242. 1990 lexus no start
  243. driver window wont work
  244. Coming back to an LS
  245. new suspension and still sagging!
  246. Anybody tried '04-'06 LS430 5 spoke rims on an LS400?
  247. ?Wild story on better gas mileage!
  248. chassis plugs by ecu
  249. 93 ls400 timing belt replacement, what else should be done
  250. Coil OVERS???
