PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. (94 LS400 ECU issues/Running Rough)
  2. lights pulsing after cool start up.
  3. 98 ls 400 votage regulator
  4. 95 front caliper
  5. 27F or 24F battery
  6. idle good only when a/c is on
  7. Vibration at 80 mph....2000 LS 400 without air ride...
  8. Strut Rod Bushing replacement (Front Cushion UCF20 1995 1996 1997 Front knock noise)
  9. Newb 1995 ls 400 (AC Issues)
  10. 2000 VVT-I fuel pump flow?
  11. Oxygen Sensor ???
  12. beat-sonic sla-22
  13. My 92 LS still has problems =\
  14. First Toyota/Lexus... 94 Celsior
  15. Navigation system - updating the disc
  16. Wolo "big boy" horn AKA Nautilus Compact install
  17. Scangauge Install
  18. 92 LS400 Wiper Switch Wiring Diagram
  19. Crank Position Sensor
  20. 1st road trip in my LS!!
  21. IS to LS
  22. interior fuses
  23. Removing Gear Shifter Knob
  24. fats new 99 ls400
  25. BBS LM or like on 98-00 ls400
  26. Roof wing (ucf10/11)
  27. no tickets
  28. Best Air Filter for 2000 LS400?
  29. Looking to buy an LS400
  30. Vehicle Service Contract...yes/no?
  31. Upgrading brakes on 90 LS400
  32. Clucking,clicking sounds driver side?
  33. What's it worth?
  34. Sway Bar End Link Removal 90 LS400
  35. gas octane on Ls400
  36. Hello LS world! New member - The $1750 Lexus + Pics
  37. Quick seafoam question...
  38. 2000 LS 400 Valve Cover Gasket Bolts ?
  39. Exhaust tips for 90 LS?
  40. Newb looking to pick up a LS400.
  41. 92 ls400 timing or tps problems?!! :/ help! im lost :/
  42. 99 UCF21 dead speedo?
  43. AUTO LOCK DELAY on 1st gen, normal?
  44. Engine / Idle Issue
  45. power steering
  46. Rack and Pinion Rebuild Tutorial?
  47. No Power LS400 1993
  48. 2000 LS 400 Power Steering Question
  49. wood steering wheel
  50. 1996 LS400 Radio/AC Controls
  51. Need directions on replacing timing belt. Any links?
  52. Exhaust/Muffler Advice
  53. Nakamichi sub upgrade
  54. Front brake rotor and caliper questions '99 LS400
  55. Timing chain or starter 98 LS400
  56. Headlight bulbs
  57. how to remove both front seats?
  58. Haveing a really wierd prod (4 cylinders running)
  59. Looking for a 1990-92 LS 400 UCF10 Mint Condition for Feature Article
  60. My Dubbed out 1st gen LS400
  61. LED VIP Tail Install Instructions
  62. going to fix rust spots and repaint car with $300 MAACO service..uh oh..
  63. Rear brake question
  64. Rough idling
  65. Which rack and Pinion to go with???
  66. Re 97 lS400 new battery drain causes?
  67. Kickdown switch doesn't always work
  68. 1999 Lexus Ls400 Security Problem
  69. 1997 lexus ls 400 coach
  70. I got a question for you audio guys out there?
  71. New Owner of a 2000 LS 400 Platinum Edition: Few maintenance questions...
  72. perfect fitting 91 rubber floor mats? how to adjust headlight level? Blower motor?
  73. trans shift solenoids
  74. Please help me? 93 pull ECU
  75. Most aggressive wheel size? need help 10-10.5 +20 offset?
  76. Chrome triM
  77. 1UZ to W58 Flywheel
  78. my ls400 died :( help
  79. Some restoration products that have worked well for me
  80. old top gear with ls400 and gs300
  81. charging system issues ...
  82. strut bar
  83. Lights out in Audio center
  84. Start "lockout" switch?
  85. 1996 LS400 Dies on long trips.
  86. Heater blowing cold air at idle
  87. SC400 vs LS400 alternator??
  88. Bad ECU
  89. Reverse problems...
  90. 1993 ls400-nightmare (codes- 15,22,41)
  91. TRAC CHECK ENGINE TRAC-OFF light problem
  92. Problem w/ Tach & Speedo Needles!
  93. Beatsonic 98 LS400 with factory navigation
  94. First Car - Electric/Brake troubles
  95. Anyone know this LS?
  96. '98 LS400 acceleration jumps
  97. '98 LS400 drive by wire???????????
  98. Rear Differential Leak at shaft
  99. Question & Ansewer
  100. Obd2
  101. couple quick questions guys!
  102. alarm
  103. Replacement Wheel
  104. Trying to corect the ride height
  105. My soon to be LS400 1999 107k
  106. Got rear-ended!
  107. ls400 or es250?
  108. Greetings from Australia! - I'm looking for USDM ADVICE!!!
  109. Xxr 962s
  110. 92 LS400 - power steering question
  111. cleaning the ecu
  112. 1995 LS400 with 153,000 miles Transmission Shift Lag
  113. Rear Window Noise
  114. Newb with another 93 thread
  115. Braking vibration after new rotors
  116. 98 LS400 steering pump - what is this plastic part?
  117. 20x10 wheels
  118. reverse indicator light
  119. 98 front fit a 95 ls400?
  120. Electrical chaos - press brake motor dies, panel lights quit
  121. ucf 10 wald trunk light garnish?
  122. 96 LS 400 windshield wiper problem
  123. wtf... (fuel pump problem, possible angry enemies and intrigue!)
  124. The LS400 Parts For Free Thread!
  125. I'm New here and I need some help.
  126. ls400 interchangable parts
  127. 93 ls400 jerks
  128. Picture of my 98
  129. 96 ls400
  130. Why I love my '95 LS400
  131. My baby broke her ankle...
  132. big o "euro tour" tires
  133. warning lights flicker at WOT
  134. warning lights flicker at WOT
  135. cluster 95-97
  136. My brake lights won't turn off Help!!!!!
  137. Transmission sheading clutch material
  138. looking and looking with no luck
  139. Finally got around to installing the Megan's on my 90 LS. Few Questions
  140. Replacing Battery
  141. Avg MPG vs MPG Since Refill?
  142. When I turn on AC or defrost it shuts car off.
  143. 1997 LS400 "out of control" incident?
  144. Is the rear bumper from the 95-97 LS the same as the 98-00?
  145. not another oil thread!
  146. just bought a 1995 lexus ls400 thinkin of mods
  147. Post pics of your ls 95-97 dropped only
  148. Oil change!
  149. LS400 Air Suspension
  150. port and polish throttle body and intake?
  151. Chrome Engine Parts
  152. 98 ls400 problem on startup
  153. LS400 Steering Wheel
  154. ls400 driver seat not working..
  155. Bilstein HDs on '94 LS400?
  156. anyone got close up a pic of a broken t-belt? I think mine has 131K
  157. My old 98 ls400 vs my w140 99 s420 lwb
  158. lug pattern question.
  159. Buying a 1997 Lexus LS400 Coach Edition *help*
  160. Slight miss then went to running VERY rough
  161. heat
  162. Installed PS Pump, now issues
  163. Rear end sagging?
  164. New to Forums Still Learning. Question?
  165. Burnt out Radio and AC LED lights
  166. Serpentine belt keeps coming off
  167. windows wont roll down
  168. Cleaning the engine compartment
  169. Ok so im new here
  170. My horny 2000 LS400
  171. Wtb posts go in the classifieds only
  172. Trying to set timing
  173. Update on my "new" Lexus Good news and bad news
  174. Intermittent issue with automatic turn off headlights; '91 LS400.
  175. Going 2 buy 96 ls400 need help!
  176. Had dealer reprogram C-best settings, couldn't do a/c controls.
  177. Overheating at Idle
  178. ac light used to blink...now stays on????
  179. Looking to buy...96 LS400 160K Hello LS World!
  180. Am I Crazy to Consider a 99 LS with 163k on it?
  181. Anyone have access to FSM, WIRING HELP PLEASE!
  182. 1995 LS400 Transmission Electrical Ground
  183. Check engine light 94 LS400
  184. Gas gauge not working reads E, Caps replaced, still E
  185. HELP everything is going haywire!!! Codes p0171, p0300, p0301, p0303, p0305, p0307...
  186. Using Existing NAV for back up camera?!
  187. 1995 LS400...air suspension Q..thanks!
  188. Naki stereo-what goes: Speakers or amp/head unit?
  189. Where to find 1st gen side mirrors w/ signals?!?!?
  190. 91' Ls400 w/ 40,000mi
  191. Thinking about selling my UCF10
  192. Timing Belt 1998 LS400
  193. ALL for sale and WTB posts go in the classifieds only
  194. 91 LS timing belt
  195. 95 ls 400
  196. Replacement Speakers
  197. HELP ECU interchangeability JDM and USDM
  198. adjustable control arms?
  199. High Pitch Squeal HELP..
  200. Looking for a 1995 Lexus Right Fender
  201. Click when you try to start it. 2000 LS400
  202. Pics from a 2200 miles trip
  203. Door to gas cap inop
  204. weird color combo on my 95 ls400
  205. How much should I expect to pay for 90-93?
  206. New member introduction.
  207. Clear coat coming off my 98 on rear driver door
  208. pulling rear quarter panels
  209. Bought New Leather Seat Covers 195 LS
  210. What would you do first?
  211. UFC20/21 Trunk Accessories, Whats included in the spare tire well ?
  212. 1993 Lexus LS 400 Hard to start and dies when you give it gas
  213. Air conditioning issues, need advice
  214. car wont crank but not fuel pump
  215. Sorry, I'm sure this has been posted many times(buying '91 LS 400)
  216. 96 vs 99? What's so bad about a 96 LS?
  217. 1993 ls400
  218. This is not the classifieds
  219. LS400 1995 problems
  220. Lexus dealership says
  221. 96 Temperature Gauge not working
  222. Restore Leather Seats
  223. Possible Engine Flood
  224. outdoor temp sensor says -30 celcius!
  225. 94 LS fuel pump brand/model recommendations?
  226. Your Opinions on Buying a 1994 LS 400
  227. Engine Rot?????
  228. HELP!!! Sun roof wont close!! 98 LS.
  229. List of maintanence to do to a 98 ls400?
  230. How to fish out dropped bolt in bottom timing belt cover
  231. LS430 17" Wheels on my 400
  232. idles low!!
  233. What do i need to get neg camber?
  234. whining noise when i turn and crank up
  235. My 99 LS tried to commit suicide by drowning!
  236. 1991-1999 possible buy + engine swap
  237. Little video of my '99 LS400
  238. lexus misfire blues.. HELP!!!
  239. excessive body flex over speed bumps...
  240. bird chirping sound?
  241. need help wheel bearing replacement.
  242. Smoke tail lights?
  243. Does someone from CL repair climate control lights?
  244. 02 sensor, how many, how hard?
  245. Variable intake runners on 95 ls400
  246. 1998 LS 400 VSC issue
  247. Speaker Replacements for 1990 LS?
  248. Passenger Side Electrical Question
  249. 1998 shift knob compatibility with other lexus/toyota models?
  250. Pothole clunk??
