PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Rear Dome/Map/Reading Lights Not Working ('98 LS400)
  2. Will 19x10 Wheels fit an ls400?
  3. 1st Gen LS400 SRS information
  4. My 1999 LS400- upper & lower control arm
  5. $800 '96 LS400 project
  6. New to the Japanese car scene, my 94 LS intro thread
  7. Can anyone help me? R134 A/C conversion issues
  8. Too much camber not enough axle! Ucf1x content
  9. 1995 LS400CD Changer error codes?
  10. bellezza seat covers
  11. What is 2000 LS400 Platinum with 847 miles worth?
  12. 91 celsior flasher replacement
  13. Problem with my lexus ls 400 98' no run
  14. 97' LS400 Immobiliser help!
  15. Toyota Celsior import
  16. Door latch 1990
  17. Throttle Cable Bracket Sub-Assembly
  18. 97....99..00
  19. 90-94 Depo Clear/Red Taillights Availability???
  20. Shifter knob swap..ES / LS
  21. Ecu?
  22. overheating issues
  23. Possible Bad Gauge??
  24. 95 LS400 Antenna Replacement.
  25. Lets play a game...would you buy?!
  26. 1994 LS.......Wheel issue.....help!?
  27. New here need help with my 93, Rough idling, Stalls coming to stops, no power
  28. 1996 LS400 Fuel Door & Trunk Solenoid Issues
  29. Help full pictures
  30. 96 ls400 door locks and other probmems
  31. front wheel bearing replacement procedure?
  32. Clean 99 in No Cal
  33. Was rust an option?
  34. Side mirror issues
  35. 1996 LS400 was not starting off in first gear
  36. LS400 Information (unconfirmed)
  37. need help... 96 LS400 died while driving. Cranks fine but just won't quite turn over.
  38. 98 Ls slow cranking and non start.
  39. Professionally Replacing 98 LS Navigation - Possible?
  40. P0325, I hate chipmunks.
  41. 99 ls400 headliner removal
  42. 1998 LS 400 AC temp not cool
  43. Can I put a '94 radio in a '90?
  44. It's hot, but is my car SUPPOSE to be doing this??
  45. ECU help
  46. Intermittent horn
  47. Drivers seat storage compartment
  48. LS400 1994 stereo wiring
  49. Lets talk about Brakes
  50. Need help - engine stalling
  51. 1998 -2006 telescopic steering solution
  52. Exhaust work done to ls400
  53. Headlamp restoration
  54. Delayed Engagement
  55. 1997 to 1998-2000 body parts
  56. New Key programming 98 LS400
  57. RTH question about rotors
  58. 1995 LS400..... starting to get picked on lol
  59. What would you pay for this project?
  60. Broke driver door handle
  61. Negative grounding issues
  62. Loss of power and acceleration after timing belt
  63. Motor driven fan noise
  64. Upgrading Daughters LS?
  65. Decent deal on clean 2000 LS
  66. 1998-2000 LS400 Oxygen Sensor Part #'s, OEM & OE
  67. Lexus 1995 rear passenger window
  68. 1uzfe SC spark plugs ?
  69. LS400 UCF20 jerking back and forth
  70. LF: Steering End Boot Rubbers
  71. Battery charging issues
  72. LS400 test
  73. Weird question about alarm...
  74. Update on the '92
  75. Question about battery drain
  76. LS400 brake pedal intermittent firmness
  77. Cheap and Dirty Infotainment upgrade
  78. Mass Air Flow Sensor - Toyota equivalent?
  79. What's this connector for?
  80. Slight pulsing while driving down the highway.
  81. Ls400 [Salvaged-Broken-Running Cars on Craigslist The Mother thread]
  82. Adding an Aux port to radio
  83. 1990-1992 Rocker Panels Paint
  84. Wayback Wednesday: A '90s Review of the Lexus LS 400
  85. Disabling Telescoping steering wheel also disabled my mirrors
  86. exhuast manifold compatability
  87. 1997 LS400 without keyfob
  88. EGR Pipe Replacement strategy help
  89. Rear quarter body damage. Need skeleton diagrams.
  90. It's official, V**veoline Minlife will kill our transmissions
  91. Thoughts on this excellent appearing '99 for sale...
  92. 1997 Ls400 has got some got dang issues...
  93. expansion tank question..
  94. 200,000 mile service for 1997 Lexus LS400
  95. Will an LS400 work for me?
  96. loose window pins.. problem.
  97. 93 LS400 No Start with Code 14
  98. First Gen Ls400 Drivers Power Switch Problem
  99. LS400's with paint pealing off
  100. wife got hit
  101. Ucf10/11 Custom ABS plastic Grille Project
  102. Looses the ability to accelerate
  103. Shock replacement turns into troubleshooting
  104. Has anyone removed only the center resonator?
  105. Programming new key fob?
  106. 98-2000 LS400: Correct brake fluid, DOT 3 VS 4?
  107. looking for S400 Lemons car advice
  108. Bolt won't go all the way in. Ideas why?
  109. UCF21 Transmission Rebuild Kit needed urgent!!
  110. Wacky Fuel Gauge
  111. 94 LS400 20-90mph vid. Supposed to be this slow?
  112. Update on the ls400 (first gen)
  113. LS400 and parts
  114. missfire only when idle at operating temp??
  115. 1996 timing belt change
  116. Crankshaft and cam seals
  117. 95 - Slammed on brakes now car running awful! Help!
  118. Please help crank won't start security light on
  119. Ls400 95 ucf20- red substance , fluid leak down , onto the cat...
  120. Where do you draw the line on maintenance? Just how many parts do I change?
  121. 98+ wheel fitment question
  122. 98 Trans Slip ONLY after decelerating?!
  123. Followed the $3 dash fix sticky, now temp gauge is at 5 o clock
  124. Very Strange Issue: Headlight Washer
  125. help!!! not ur typical overheating problem
  126. 1995 LS400 - love it, but has a few issues....
  127. brake lights don't work need advice asap
  128. 98 LS Wheel Problems
  129. New LS owner have a mysterious leak, Pics!
  130. OBD2 scan tool for iphone5c
  131. Shift Lever stuck due to interlock
  132. Oil for the LS400
  133. ls400 erratic idle intermittent missfire very rich
  134. Looking to Wrap my 2000 LS
  135. Failed california smog
  136. Coolant loss issue
  137. A Long Overdue Goodbye
  138. Removing cheap paint
  139. 94 LS400 Error Codes 24 & 31
  140. Which diesel engine to put in my LS400 1999.
  141. Chirping-squeal when in gear
  142. Looking at the profile of my 90
  143. High $$ but a creampuff low mileage '91
  144. Oxygen Sensors
  145. Any trans experts out there for the A340E?
  146. 96 LS400 - Transmission Part Number
  147. Sound dampening ls400 door panels
  148. need a part number mirror head
  149. 1999 Lexus LS400 Sunroof & Diagnostic Tool
  150. 1996 Lexus LS 400 Looking for new tire recommendations
  151. 2000-driveshaft vibrations?
  152. Looking for Parts
  153. Sagging Headliner
  154. new Lexus shop.. really all cars, but trustworthy
  155. Knock sensors
  156. Can this wood trim be glued back on the radio?
  157. 1996 LS400 died while driving, now starts for a second then dies
  158. Need Help locating relays.
  159. 98 LS400 headlight beam adjustment
  160. 1995 LS400 ignition coil issue - multimeter question
  161. Junction produce Curtain size?
  162. Should I buy high mileage Lexus Ls400
  163. Window regulator motor replaced
  164. Help Rack and Pinion replacement !!!
  165. ton of money in my 1998 ls 400
  166. Trouble removing lower manifold to replace starter
  167. 96 LS 400 with transmission issues
  168. ECT, ecu test question (Yamae)
  169. HELP- mirrors, seats not working, FOB doesn't unlock doors
  170. 2nd Gen Bodykit ideas
  171. Engine coolant temperature is rising while vehicle is idling
  172. 93 LS400 Help! Locked keys in trunk.
  173. Need Help - Sun Roof Will Not Work Properly
  174. New Antenna Non-motorized / Shorty
  175. water accumulating in passenger footwell
  176. Air fuel tuning
  177. How to access inner tail lights
  178. 96 model upper control arm rattle
  179. Iso: Coilovers for 92 ls400
  180. 1998 ls400 oem seat leather
  181. 97 LS 400 Blower Fan Issues
  182. Wild Maserati Biturbo With the Beating Heart of a Lexus V8
  183. First lexus 1990 celsior
  184. 1999 Lexus LS400 ready for the Future
  185. Homemade RUCA Bushings for UCF20
  186. 99 LS 1 Plug Oil fouled after ignition coil failure?
  187. 27mpg, am I doing it right?
  188. Help!!!! 92 Ls400 - flashing red light after sun roof left open
  189. Code P0125 but acts like a vacuum leak?? - Solved
  190. hard shifting and thump when gas depressed
  191. Crazy issues 1997 ls400- misfire, shudder
  192. 90 LS400 - Odometer broke, any way to get real mileage?
  193. Is the LS really this soft?
  194. Cell phone antenna removal/ use spot for sirrus antenna?
  195. Wont start
  196. Code 47 92 LS400 subthrottle TPS.
  197. Power steering tank
  198. Slight whine when accelerating from stop?
  199. Trunk Hinge Wiring Harness PN?
  200. Does my 2000 even have a IAC Valve or motor?
  201. Brake question
  202. First post and first Lexus today! 95 LS400
  203. Ideas to make my celsior look better?
  204. Look Up Past Service History with Your VIN
  205. '97 MAF Cleaning
  206. my first 1998 ls400
  207. 1996 LS400 Remove Radio
  208. Woofer or Head Unit?
  209. 1992 ls400 oil
  210. Disabling Airbag System
  211. UCF20 Rear Upper Control Arms install question
  212. Decoding the Inspection sticker
  213. Code 41
  214. 1998 LS400 127k for $2600 deal?
  215. Halogen to OEM HID+ other wiring questions
  216. 2000 LS400 turn signals not working
  217. 1994 LS400: Rack & Pinion replacement :'(
  218. Help, lot of problems with this LS
  219. Window switch question
  220. Need help, 91 LS400, code 71 using excessive gas
  221. 1996 ls400 XM FM Direct Adapter?
  222. 1UZ swap ignition circuit help
  223. need help with interior carpet
  224. 96 LS400 Click sound at ignition, starts randomly
  225. 98 LS 400 Audio Upgrade to Hi-Res system
  226. '98 ls400 - No power steering after brake job...
  227. driver side front wheel click click click
  228. Seeking advice on Reman ac compressors
  229. Help!- Horn, wipers, sunroof
  230. Idle problem
  231. Need help coolant
  232. 1998 LS400 with whistling noise from brake booster area
  233. '95 LS400 vibration at 2000rpm - what should I test?
  234. #TBT: Relive the LS 400, Before Lexus Discovered Creases
  235. So this happened yesterday
  236. Noob LS owner here
  237. Parting ways with my 97 LS400, Advice?
  238. 98-00: Document to help with vents and a/c modules in dash
  239. parting out 1995 due to hail -TX
  240. Looking for center caps, help!
  241. Moonroof not closing all the way
  242. for sale goes only in the classified forums
  243. ignition keys
  244. Need help- finding engine bay covers
  245. Df210 lowering/settling issues
  246. Just bought a '12 LS460, help me price my Cream Puff '97 LS400!
  247. Rear Monroe struts for 2nd Gen LS
  248. Project LS600
  249. New member and first time buyer.
  250. Godspeed ucf20 Rear camber and toe kit
