PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. DTC 13 on 90 LS
  2. P/S removal help!!!
  3. "93 nak replacement 4" speakers
  4. Front crank seal
  5. Check Engine Light
  6. Rear Seat belt buckle need little help
  7. Steering wheel change out help!!!!
  8. 1LS PS Problem (Went through bible) Bad rack?
  9. Front Suspension Clunk
  10. Odd electrical headache
  11. K Sports v. Megan coilovers
  12. Brake pads & rotors
  13. Stretched tires
  14. 2000 LS 400 Timing Belt Job...Need info!
  15. Help! Battery problem!
  16. Need help with coilover fitment on 90' LS400
  17. Paddle Shift Conversion- Is it possible?
  18. Battery wiring on 2LS???
  19. Help hid harness 95-97 Ls400
  20. Mpg
  21. ls 400 air suspension questions
  22. Trunk Leak Fix 99 LS
  23. LS400 heater question
  24. '92 LS400 slow acceleration, running rough
  25. I almost did it...
  26. Reverse light on when braking????
  27. Alternator Killer
  28. 1990 heater valve part number
  29. Help with exhaust system needed.
  30. Strange VSC and service engine light coming on and RPMs sticking
  31. shift knob options
  32. Try to start and every thing dies
  33. Undersize tires
  34. Have some problem.Please Check in.
  35. 1991 LS400 engine bay noise ( with video/soundclip )
  36. Wheel Sizing 101
  37. Bigger rotors for LS400 Calipers?
  38. Did a spirited run and pulled into driveway and car sounded like a truck....
  39. Fix 91' dash needles.... in Canada?
  40. TRAC light on and Check Engine light on, please help
  41. 98LS400 slow/half nonfunctional rear defrost
  42. Wheels upgrade
  43. LS400 caliper rebuild (4 piston)...retaining ring or no ring?
  44. transmission question
  45. How to fix a drooping center sun visor
  46. Rear crankshaft oil seal leak
  47. Master keys locked in trunk, how do you trip the remote switch?
  48. To you guys that installed sub using stock HU.
  49. AUDIO PPL Please Help!!!! pioneer double-din wont power up
  50. 1995 LS400 Power ECT button
  51. Need radio help?
  52. 95-97 Ls400 wierd Radiator fluid leak? Help???
  53. Will other OEM Lexus wheels fit?
  54. Fluid flush order?
  55. Timing belt 00, ls400 need help
  56. Replacing struts, KYB or Strutmasters or?
  57. need help asap plz car wont start
  58. 96 ls400 whole front vibrates
  59. 93 lexus no power anywhere
  60. rear fog light?
  61. 94 5 speed swap in progress
  62. Windows (not working, 1LS)
  63. New here and new to these cars help wanted..
  64. New to Ls400 and the forum
  65. A series of possibly daft questions
  66. EbayTiming Belt Kit
  67. Good deal on '90 LS400?
  68. ucf10 & ucf21 brake booster & master pump compatibility
  69. Power steering pump
  70. Brake Job Question--Where does this washer go?
  71. Battery or alternator?
  72. new on forum
  73. Question about "Check VSC" causing CEL to come on
  74. 1998 LS 400 - Replacement Shocks Advice
  75. Anti-lock brake question...
  76. '96's temp guage jumping around
  77. Thinking of purchasing this '98 LS 400
  78. Installation of Rear Sway Bar Links
  79. Help, Air Bag light keep on even key is taken off.
  80. DIY 91' LS 400 Recovering front seats
  81. I didn't search but.. 18x8.5/9.5 +6?? (ucf20)
  82. ls400 steering wheel
  83. Front brake strut
  84. Rigged UCF20/21 Pics
  85. Thanksgiving story (Tire related)
  86. Buying used advice: 1996/97 vs 1998
  87. Chasing a Code 14
  88. exhaust mod.... free!! (damage)
  89. Happy ls400 owner
  90. Intermittent hesitation, no acceleration, no codes, but everything checks out...
  91. Heater issues
  92. Help (Temp. gauge, tach gauge and gas gauges)
  93. Bad ECU confirmation
  94. new to forum and the celsior.
  95. Pulled EFI1 and EFI2 fuses to reset computer, now got check engine light and VSC off
  96. Leaky Oil, Dirty Bottom
  97. '94 Rear windows
  98. wrong temp reading
  99. [1999] ls400 car wont stay on
  100. TRAC/Brake Fluid flush with DOT 4 ?
  101. 92 LS 400 car starts, but then shuts off immediately
  102. Considering a 1st or 2nd gen LS 400 - What do I need to know?
  103. '96 LS400 transmission behavior?
  104. 1992 Ls400 a/c expansion valve
  105. 1993 ls 400 driver seat
  106. 1992 Ls400 radiator fan
  107. Question about some ghetto headlight wiring
  108. LS acting up!
  109. Napolex.com out of business or what?
  110. Rear Trailing Arm Bushings 99 LS
  111. Thinking to buy 98+ LS400....
  112. Newbie Here, need help with my 1996 LS
  113. Wipers worked yesterday, now they don't...
  114. LS400 climate LCD dead. What temp am I at?
  115. "VSC Off" and "PWR ECT/SNOW" Switch Light
  116. Our 98 LS400
  117. 91 ls ecu
  118. ls400 acceleration issue
  119. Front seat feels like it is shifting.
  120. Got some work done now my power seems down!
  121. LS400 1991: Disconnected the battery and activated the engine kill switch... help!!
  122. green tint on a 1stgen?
  123. 91' LS 400 Recovering front seats
  124. lexus emblem came off
  125. LS400 used parts source?
  126. My '97 LS400 woes from last night:
  127. Wire next to Oil Filter and AC Compressor
  128. Flashing ECT/PWR light on 95LS
  129. Has anyone ever replaced a steering shaft u-joint here?
  130. A cracked ventilation hose on my 98 Celsior
  131. I have a problem with the dashboard
  132. 93 LS stalls when warm.
  133. noob from east tn
  134. Gas smell
  135. a heat quetion
  136. heater,radio not working
  137. Just bought my '93 today, have a couple questions.
  138. Dreaded - ABS and Traction Control Light
  139. Double Din Install Help Needed
  140. LS 400 - Smoke from ATF an now Power Loss
  141. Spring Rates
  142. Offset?
  143. '92 Gearbox clicking!
  144. New Member Here Got the LS Fever
  145. Help-car won't start due to stock alarm
  146. Rust treatment for 1992 LS400?
  147. sunvisor and headliner removal question
  148. Gas mileage issues, help!!
  149. 90-94 ls400 repair manual
  150. How do you get the "trac-off" light to quit blinking
  151. Just a shared cost on getting new spark plugs / wires
  152. Wheel FITMENT HELP
  153. What's this engine cover? (92 LS400)
  154. Tie rod replacement costs?
  155. Trip a / b
  156. Power steering idle up valve
  157. passenger window problems
  158. '94 LS400 - Head Unit replacement w/ stock amp.
  159. fixed fuel smell in cab at fill up but found corrosion on fuel tank.
  160. TRAC and No TRAC Clusters, Interchangable??
  161. idle problem
  162. 1991 LS400 Starter pics and more
  163. Anyone ever put projector headlights in a UFC10?
  164. LS 460 Wheels on 91 LS 400
  165. 95-97 ls400 conversion to a 98-00 ls400
  166. Gauge cluster problems 95 ls400
  167. 1993 lexus ls400 issues
  168. someone hit my ucf10
  169. Another Gen I suspension ?
  170. Transmission Slipping
  171. recently lowered 97 ls400 making weird noise
  172. Will the SC400 pioneer sub fit in my LS400? Also a car audio question
  173. motor/trans mounts
  174. New guy here! ^.^
  175. It is time
  176. 1992 LS400 Power windows and moonroof don't work
  177. 96 LS400 power door locks wont work...
  178. Sunroof seems to be leaking
  179. Megan EZ's on UCF20/UCF21
  180. seems to me (1LS electrical issues)
  181. Wierd Weird WEIRD!!! Tilt Stering
  182. Steering Wheel Tilt Motor Inoperative
  183. Ordering new fanclutch, Lexus part or Rockauto part?
  184. 1995 LS400, New Member w/ Pics
  185. Identify my old radar detector??
  186. i shaved.... kinda
  187. Normal Idle?
  188. Brakes went out
  189. Front/Rear Personal Lights
  190. I Need Help With My Unfixable '90 LS.
  191. How much is my car worth today? 94 LS400
  192. Rear air suspension stuck
  193. supercharger anyone?
  194. Cam Sensor
  195. Lowering a Strutmaster's Spring/Strut Conversion with Tanabe Springs
  196. Battery For A Ls400 1994
  197. vibration on my 99
  198. Which of these fees are legitimate!?
  199. Help No Tail Lights
  200. 98 ls400 valve cover gasket replacement tips
  201. I have ABS but it does not work..though no error light or fault is shown...
  202. Tie rod package
  203. 1305 code
  204. Oil on my ac compressor
  205. Hello! Door Handle Question
  206. Key FOB Question???
  207. strange coolant leak!! please read
  208. Need Help - '91 Strut rod bushing
  209. A couple key replacement questions!
  210. Hi there!
  211. How do you tighten to torque specs??
  212. 1995 Lexus ls400 fuse box diagram picture?
  213. 94 LS400 Coldstart need to warmup 5 min or it will die
  214. Wood/Leather Steering Wheel
  215. 95-97 Sideskirts/Rear bumpers compatible with a 98+ LS400 ???
  216. 91 ls400 replacing both inner and outter tie rods
  217. new and have a clean one here
  218. Super weird radiator problem *PIC*
  219. 1996 star sapphire pearl ls
  220. Air Suspension Controller
  221. How to fit 22s on my 95?
  222. nob under drivers side kick panel?
  223. need new ball joint nut
  224. 1993 MotorWeek V8 sedan comparison test vid
  225. New in the Club!
  226. 20" Wheels on UCF10
  227. 93 LS400 weird starter "clacking" sound..please help
  228. Did lexus and others stop selling the front strut rod bushing?
  229. Rack and Pinion problem 1995 LS400
  230. Finally got 17" 6-spoke LS430 wheels on my '99 LS400
  231. 91 LS400 Front end shakes violently at random
  232. Newb in the House! Greetings everyone!!
  233. Uf10/uf11?
  234. Water Methanol Injection?
  235. 91 LS400 powersteering pump pulley
  236. Help! upgraded to nav now no antenna raise
  237. New member with 93 pearl white/black leather
  238. engine vibration @ 1200 & 2000
  239. UCF21 Annoying Flickering Foglights
  240. Ucf21 beatsonic double din install kit - woodtrim?
  241. Who can make a key to my LS400 95
  242. Aiming Depo Headlights (UCF20)
  243. Headlights getting foggy
  244. LS400 lack of tension on retracting seatbelts (front)
  245. Timing Belt
  246. How much does a cluster cost?
  247. Timing belt @ 118k
  248. Newbie with a 95
  249. power steering fluid, need simple confirmation (read the bible)
  250. (WTBs go in the classifieds...)
