PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Just did my own alignment, 1990 LS400
  2. 98 LS400 no start
  3. headache.Valve cover gasket
  4. key problems !!
  5. EBC Red Pads install question
  6. LS400 : SSR Agle Strusse x Clifford Sutrisno
  7. Console bezel
  8. Would 96 LS400 OEM 16 inch rims fit a 92 LS400?
  9. ucf10 body kit
  10. 2jz swap
  11. More help needed with 1st and 2nd gen repair instructions compatability
  12. What are these lights?
  13. ZR1 corvete wheels.
  14. ls400 1989 airbag suspension problems. please help
  15. 99 ls-400 instrument cluster removel
  16. trac light fix
  17. 96 LS ecu gone bad
  18. High Speed Shimmy and Bushings
  19. 1997 transmission question
  20. rear brake pad replacement
  21. Soon to be owner of an 1993 LS400?
  22. Paint help
  23. Things to look at while buying an LS
  24. New 1-LS Owner
  25. Selling my 1994 LS400
  26. 95 LS400 rear wheel bearing
  27. Throwing in the towel...
  28. LCD clock weird problem....needs advice
  29. Will 98 seats fit a 95
  30. Engine did not turn over after recharging dead battery
  31. Engine undercover
  32. Converting Power Antenna to Hidden Antenna
  33. 1ls spark plug gap
  34. New- How goes it?
  35. performance chip?
  36. 95 spring and shock replacement question
  37. Sideskirt + lip options for 89-92 UCF10s
  38. Ls400 on Varrstoen Es 1.1.2 picture request!
  39. Air ride advice?
  40. stiff gas pedal.
  41. 5.3 lexus ls400
  42. My wrecked 99 LS400 :(
  43. Part number needed!
  44. Hoping to find a fix for "bubbles" under shifter bezel
  45. Proud new 90' ls owner!! Advice welcome!
  46. engine misfire
  47. Need Advice on Car Purchase
  48. Magnefine 1/2" Inline Magnetic Trans Or Power Steering Filter
  49. New here.
  50. Will 2k LS400 fit wheels on 92 LS?
  51. 1994 Lexus LS400 Radiator Replacement ?
  52. tie rods question
  53. aftermarket steering wheel in 93?
  54. Car will not shift into certain gears (the gearshift wont)
  55. air suspension conversion
  56. 1998 LS400 steering rack leaking
  57. specific misfiring problem
  58. hid help 95 ls 400
  59. my 1996 LS400 is SLOW like a Yugo, why?
  60. Missing exterior trim piece 1992 LS400
  61. 1996 LS400 wheel spacer: advantages n dis-advantages
  62. power steering maintenance schedule
  63. ucf20 strut rod bushing where to buy?
  64. Dealer quoted me $703 for p/s pump reseal
  65. Thumping sound when turning left
  66. Harbor Freight tool for lower ball joints
  67. Studio 2.1 Camber Adapters Installed
  68. Help with coilovers??
  69. horn not working
  70. Drivers door seal broke?
  71. New member intro?
  72. my new 95 ls400
  73. O.G(ee),,,,,it has finally happened!! Sold my 92
  74. Just purchased a 1999 LS400 lolfp Car
  75. TRAC light on; Transmission won't kick down.
  76. Wheel Hub Question
  77. Anybody know where Lextreme gets their upper control arm bushings?
  78. good website for oem parts???
  79. [92 LS fitment question]
  80. LEXUS vanity plates
  81. having problem with tension pulley....
  82. Can you suggest an ideal rim size?
  83. Video tutorials, anyone?
  84. LS400 caliper clearance vs Supra TT ??
  85. Which water outlet (coolant bypass) gasket and knock sensor?
  86. vibration
  87. Good buy or what???
  88. UFC10 coilovers for performance and comfort
  89. P0325 Knock Circuit malfunction, loss of coolant. Best deal on a knock sensor?
  90. LS400 1997 Suspension Diagram
  91. Driver door rattle & Armrest renewd (with photos)
  92. First lexus please comment
  93. 99 Camshaft timing tube leak
  94. 90 LS400 Cooling System Upgrade
  95. Power window master switch simple repair DIY
  96. Purchase Advice???
  97. lack of power
  98. Electrical issue
  99. Should I buy a high mileage 1995 or low mileage 1990?
  100. Rotor Question
  101. '93 LS400 Lack of power and negative rpm gauge under load
  102. New to this..
  103. Head light assembly
  104. Replacing side mirror glass
  105. 1995 ls400.Will sometimes start and then shutt off
  106. Changing out tensioner pulley
  107. Water pump/timing belt
  108. Sticky Gear Selector
  109. Transmission Help
  110. UCF1X camshaft pulley removal
  111. 1998 LS400 won´t start - immobilizer problem?
  112. Is it hard to find a mint LS400?
  113. 1996 LS400 keyless remote
  114. Stupid Question about Cooling Fan (Noise)
  115. Will these Rims Clear the Front Caliper??
  116. Question about tire size... LS430 rims on 1998 LS400 *with pics*
  117. transmission buzz
  118. 1993 LS 400 Coolant Issue
  119. Driver door gets stuck when its cold
  120. Curious on what my 1994 LS400, with 250k, is worth to people like us?
  121. recent problems
  122. acceleration issues with my 1990 ls400
  123. infant seat anchors
  124. cost of maintenance and common repairs
  125. help code 63 car wont star
  126. help its cold and raining! lcd fine, cig lighter fine, unit still off?
  127. needing help to find key fobs
  128. we have classifieds
  129. removing the auto level motor?
  130. Parking Lights
  131. 98 LS400 w/ 140K miles
  132. Update on my 96 LS
  133. Need Valve cover gasket..anything else?
  134. Looking at an LS400 need help
  135. Megan EZ cut coil over body
  136. fog light problem
  137. Picking up a 98 ls400 with 178k (used to own a 91!)
  138. 1997 Vacuum/Coolant line diagrams/pics?
  139. Whirring noise??
  140. Clunk in steering column
  141. ECM Eater
  142. 95 LS 400 - Power Windows Issue Just Developed
  143. Loud squealing and battery light on...
  144. Value of LS Seats??
  145. oil light
  146. Advice needed decoding the Lexus dealer service recommendations
  147. Raising Re Sell Price Of LS's
  148. Leak!!!! Please help!
  149. 1995 LS400 with a 1999 LS400 Frontend
  150. Rising cost of insurance in the UK
  151. (may consider selling?)
  152. My 97'
  153. CD-Rs don't play in CD Changer 2k LS400 HELP!!
  154. Need help removing license plate lamp covers
  155. What do y'all think about this item?
  156. 1997 LS400 Rear Window Question
  157. Has anyone experienced this before(pic inside)
  158. Please help-hi rev sound in 1st??
  159. Climate Control - Clock Lights up Blank, No Climate Control
  160. Looking for 99 Billet Grille
  161. RPM Sensor
  162. Why My LS400 Is A Keeper...?
  163. Remove and replace instrument panel, 1998-2000 LS
  164. hey fellas found a 95 ls400 for a steal what should i look for?
  165. Extended wheel studs?
  166. Watch LIVE: Starter Replacement on a 97.
  167. Fuel pump getting weak, how hard to change?
  168. WTF!!! Brand new pads and rotors CAUGHT ON FIRE!!!
  169. Engine Check Light not working - How to pull codes?
  170. Picked up my UCF21 Grey/Grey
  171. Dreaming of the ultimate mod....
  172. Euro front lip
  173. LS400 owners help please (Bracket ID/location)
  174. Where is the ECU fuse located?
  175. I have the baddest plugs made for the LS400, but will Seafoam hurt em?
  176. New Lexus owner....hope I got fair deal
  177. 92 ls400 cel
  178. UCF1x Brakes on UCF2x
  179. Urgent - how to remove UCF20 rear rotors?
  180. Hope to be picking up my first UCF20 Tomorrow!
  181. Radiator Temperature Sensor
  182. 97 rear coilover installation
  183. Exhaust leak 1995 LS 400
  184. Bad O2 sensor
  185. New to the forum
  186. Noise within engine area,
  187. My new UCF20 and an intro.
  188. Car Randomly Took a Crap on Me Today
  189. Lexus ls 400 help ('93)
  190. Climate Control LCD replacement question
  191. Lots of noise and vibration
  192. suspension help for noob!!! popping from rear
  193. Backlight for '97's Pioneer head unit
  194. should I replace my tie rods?
  195. a/c or heater doesnt blow hard
  196. Wekfest 2012 sf
  197. Battery cable corrosion
  198. Last Minute Timing Belt Questions
  199. cam and crank seals for 1LS
  200. Speedometer works intermttently
  201. Mitsubishi TB190M timing belt, BANDO drive belt, AISIN TKT-010
  202. LS400 won't shift out of first. Reverse light stays on.
  203. How well does your a/c recirculate perform?
  204. marker lights ???????
  205. should i be running this tire size?
  206. Need help ASAP to pass smog :(
  207. 1993 ls400 EGR pipe cracked ;(
  208. going from a 91 to a 98 ls! What differences will I notice?
  209. Source of engine oil leaks
  210. Passenger side view mirror question
  211. Steering Problem
  212. Where can I get brake disc centering screws.
  213. Antenna for '94 LS400
  214. Yet another power steering question.
  215. voltage problem. could there be a short or bad grounding?
  216. 1994 lexus ls400 dashboard
  217. Will 16" '05 GS Wheels Fit a '99 LS400?
  218. 1996 front door speaker grill removal
  219. Climate control LED size?
  220. Key won't unlock/lock door
  221. Fuel Injectors
  222. Has anyone bought their kit from duraflex?
  223. help...bought a set of 19x10.5 +5/19x11.5 +10
  224. suspension dilemma
  225. Wheel Stud Replacement
  226. choise of 19s
  227. Overnight, my car won't start, turns over fine, just will not start
  228. Lowering Driver side front seat in 99 LS?
  229. Idler problem
  230. Can you recommend a pair of mufflers?
  231. Is this the master Key?
  232. Broke a spring...stock spring replacement vendor options?
  233. Thinking of selling.....
  234. 1996 LS400 Preventive Maintenance Questions
  235. LS400 power steering
  236. What's this in my trunk?
  237. should i get these wheels??
  238. Valvoline MaxLife ATF?
  239. LS400 grille
  240. 1993 ls400
  241. common causes for high idle 92 LS400
  242. APX/Sensen Struts
  243. My First Lexus.....(Pics)
  244. Suspension problems 96 LS400
  245. 1995-2000 LS400 Starter info
  246. OmG! - WTF?
  247. Freeing up stock exhaust flow?
  248. LS400 Drift Missile
  249. 93 Ls odometer and outside temp dont work
  250. Looking at 3 LS's - Can't decide which to buy
