PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Starting Woe's
  2. Steering
  3. how to add stop leak directly to radiator
  4. 94 LS400 new-to-me problems
  5. 99 LS-speedometer dead
  6. help with ball joint measurements
  7. Help with Setup Picture 17x?
  8. Need Help pls! 1991 Lexus ls400*
  9. 1997 ecu in 1996?
  10. New to Lexus LS400/VIP
  11. Help finding a 1993 dash kit for single din deck
  12. ***Jin & Juice***
  13. My front crosmember split in two
  14. Need HELP diagnosing transmission problem
  15. Tires with g35 rims
  16. Suspension clud after new lower ball joints
  17. options options options-help
  18. nothing to see here
  19. Silly Question: Engine Light + Brake Wear
  20. 1995 LS400 XM radio
  21. Rear Differential Fluid Change - What is Reasonable?
  22. LS400 wont start-need spark plug chg how to
  23. Thinking of buying a '90 LS400 for $1,500... Please read
  24. What is this part called and where can I get another?
  25. Is the a Warning Light for Low ATF Fluid?
  26. Door lock actuator help
  27. FYI on modifications
  28. Buying a 1991 LS400
  29. TAP Recycling?
  30. front supra tt brakes to ucf10
  31. ignore
  32. problems after replacing air struts, brake rotors and pads
  33. Midwest Mechanics
  34. Do Wires from Wiring Harness Control Trunk Latch Closing?
  35. LS400 Code 12 and wont crank
  36. help with turn signal and brake light issues.
  37. Front-Lower Control Arm
  38. engine miss 94 ls400
  39. 91 LS400 Radiator Oem Vs Aftermarket
  40. Whats yall favorite Vossen wheels?
  41. 93 LS with Nak system, where to get O.E.M. speakers
  42. HI ALL NEWBIE with question!
  43. 90-94 LS400 HID Fog Lights DIY
  44. help my 94 ls400
  45. Need help fast!!...problem after alternator and battery replacement
  46. New LS Owner Here
  47. Silly Stock Suspension question
  48. '90 LS400 - Tach Needle idling @ 2,000rpm
  49. Need help with a/c removal
  50. Lookin for used OEM seat covers??
  51. Transmission or Sensor
  52. 1992 LS400 Smog failed. Please help.
  53. shift knob questions
  54. 91 LS400 Bucks
  55. Rear Seat Arm Rest Question
  56. diy vip table?
  57. Shop lost center cap for '94, what years will fit?
  58. 94 ls400 will not start
  59. sunroof leak
  60. 94 ls400 mods
  61. Celsior Badges are a crime! (apparently)
  62. 1LS Whirring Noise
  63. Keys for 1993
  64. 295/25/22!! is it possible?
  65. will my rear air struts work without the fronts?
  66. lowering, effects on handling
  67. 1991 ls400: 5 lights on dash. CC doesnt work
  68. Help with a power steering leak.......please!
  69. ABS Relay - where and how to test?
  70. 99 ls400 headlight question.
  71. Can someone please get me the Lexus LS400 manual that covers every littie thing?
  72. Frustrating Issue With Sound From Rear Strut Towers (New Suspension Components) 90 LS
  73. Passenger side brake problem on 98
  74. LS400 HIDs (not your average question)
  75. injector differences??
  76. Bushings part number question
  77. Thinking of making a come back
  78. casette player acting weird
  79. Replacing just the shock insulator?
  80. please help me-EGR delete
  81. winddeflectors
  82. 93 ls400 wont start
  83. 94 LS 400 Woes...need your help.
  84. Clicking sound with shifter in park and emergency brake on?
  85. my 98 LS with TSW vortex wheels
  86. Low temperature reading gauge
  87. Battle Version Adjustable Arms
  88. help on pricing for 98 ls 400
  89. About my 99 LX400.. What are the two switches under..
  90. bumper fitment question
  91. Hello from Taiwan :)
  92. coil replacement
  93. sport seats.
  94. Anyone know where to buy a new long block?
  95. Help no turn signals or tail ligts . hazards and brake lights do work tho ??
  96. ATF t-iv
  97. Trac codes 43 and 51
  98. Cluster question
  99. New with question....
  100. Need Help with Brakes
  101. Rebuilt
  102. Chirpping on New Power Steering
  103. 1992 LS400 pps ecu questions
  104. Will I notice more power?
  105. 98-00, how to tell if it has Xenon Headlights
  106. new ls400 owner
  107. hard to start then High idle 1100rpm
  108. ID of part
  109. Temp and fuel level gauge possible (faulty) ?
  110. Need help with throttle body vacuum hose
  111. Quick Fitment Question on UCF10
  112. New Member need your opinion
  113. stock radio with aftermarket amp and sub
  114. Where to get first gen window visor?
  115. 98 rack and pinion advice
  116. pulley part numbers?
  117. faux wood trim removal
  118. Radio will not light up .
  119. wanna put some 20" wheels on
  120. bushings 93 lexus ls400
  121. Should I buy these rims?
  122. Anyone know of any brand that makes floating rotors for 95-00??
  123. Airbag replacement
  124. looking for proper offset for that flush fitment
  125. alarm keeps shutting down my engine!
  126. Potential 93 LS400 owner.
  127. Would you buy it?
  128. How to remove glove box
  129. Where is the location of the Fog Light relay 98 ls
  130. 1993 lexus ls400 failed emissions
  131. 91 ls400 tempurature gauge runs hot
  132. Wheel speed sensor replacement
  133. May Have Front Struts on wrong side
  134. need inputs from fender experts
  135. paint code
  136. New post on an old topic (ECM)
  137. 1996 LS 400 Nakamichi Radio problem
  138. Ls400 low exhaust pipes; major scrape!
  139. Chrome mirror caps?
  140. another brake related issue
  141. Ls400 chrome door molding trim
  142. new saying hello
  143. help with black out climate control?
  144. Door lock actuator or...?
  145. Gt styling window visor
  146. Need help!!! Possible ignition?
  147. Never going back to the dealer.
  148. Which year transmissions will fit my 96 LS400?
  149. Code Reader / Scanner
  150. Tach needle
  151. heater doesnt work
  152. Steering wheel is cocked to the left
  153. Ugggghh! Just messed up my own car
  154. Knock Sensor Replacement
  155. Will be coming back to an LS after my 2002 ES300 fiasco
  156. Oil Leaks: Is the Dealer Screwing Me?
  157. Wheel spacers and ramblings
  158. Need advice on struts
  159. 99 LS400 ECT and Hight level boton problem
  160. Fairly new to the ls vip scene...
  161. third center cat/resonator
  162. Driver Door window tricky
  163. Swapping faceplates on a nakamichi head, 95-97?
  164. Just did my own alignment, 1990 LS400
  165. 98 LS400 no start
  166. headache.Valve cover gasket
  167. key problems !!
  168. EBC Red Pads install question
  169. LS400 : SSR Agle Strusse x Clifford Sutrisno
  170. Console bezel
  171. Would 96 LS400 OEM 16 inch rims fit a 92 LS400?
  172. ucf10 body kit
  173. 2jz swap
  174. More help needed with 1st and 2nd gen repair instructions compatability
  175. What are these lights?
  176. ZR1 corvete wheels.
  177. ls400 1989 airbag suspension problems. please help
  178. 99 ls-400 instrument cluster removel
  179. trac light fix
  180. 96 LS ecu gone bad
  181. High Speed Shimmy and Bushings
  182. 1997 transmission question
  183. rear brake pad replacement
  184. Soon to be owner of an 1993 LS400?
  185. Paint help
  186. Things to look at while buying an LS
  187. New 1-LS Owner
  188. Selling my 1994 LS400
  189. 95 LS400 rear wheel bearing
  190. Throwing in the towel...
  191. LCD clock weird problem....needs advice
  192. Will 98 seats fit a 95
  193. Engine did not turn over after recharging dead battery
  194. Engine undercover
  195. Converting Power Antenna to Hidden Antenna
  196. 1ls spark plug gap
  197. New- How goes it?
  198. performance chip?
  199. 95 spring and shock replacement question
  200. Sideskirt + lip options for 89-92 UCF10s
  201. Ls400 on Varrstoen Es 1.1.2 picture request!
  202. Air ride advice?
  203. stiff gas pedal.
  204. 5.3 lexus ls400
  205. My wrecked 99 LS400 :(
  206. Part number needed!
  207. Hoping to find a fix for "bubbles" under shifter bezel
  208. Proud new 90' ls owner!! Advice welcome!
  209. engine misfire
  210. Need Advice on Car Purchase
  211. Magnefine 1/2" Inline Magnetic Trans Or Power Steering Filter
  212. New here.
  213. Will 2k LS400 fit wheels on 92 LS?
  214. 1994 Lexus LS400 Radiator Replacement ?
  215. tie rods question
  216. aftermarket steering wheel in 93?
  217. Car will not shift into certain gears (the gearshift wont)
  218. air suspension conversion
  219. 1998 LS400 steering rack leaking
  220. specific misfiring problem
  221. hid help 95 ls 400
  222. my 1996 LS400 is SLOW like a Yugo, why?
  223. Missing exterior trim piece 1992 LS400
  224. 1996 LS400 wheel spacer: advantages n dis-advantages
  225. power steering maintenance schedule
  226. ucf20 strut rod bushing where to buy?
  227. Dealer quoted me $703 for p/s pump reseal
  228. Thumping sound when turning left
  229. Harbor Freight tool for lower ball joints
  230. Studio 2.1 Camber Adapters Installed
  231. Help with coilovers??
  232. horn not working
  233. Drivers door seal broke?
  234. New member intro?
  235. my new 95 ls400
  236. O.G(ee),,,,,it has finally happened!! Sold my 92
  237. Just purchased a 1999 LS400 lolfp Car
  238. TRAC light on; Transmission won't kick down.
  239. Wheel Hub Question
  240. Anybody know where Lextreme gets their upper control arm bushings?
  241. good website for oem parts???
  242. [92 LS fitment question]
  243. LEXUS vanity plates
  244. having problem with tension pulley....
  245. Can you suggest an ideal rim size?
  246. Video tutorials, anyone?
  247. LS400 caliper clearance vs Supra TT ??
  248. Which water outlet (coolant bypass) gasket and knock sensor?
  249. vibration
  250. Good buy or what???
