PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Emissions Monitors "Not Ready"
  2. Is a TPS install/replacement on 00 LS as easy as the replacement on the older models?
  3. Suspension height control faulty 1992 LS400
  4. TRAC system diagnostic code in 1992 LS400
  5. 1991 Celsior, my new baby.
  6. Engine turns over, no combustion, now works (fuel pump?)
  7. WHat error code would I get for a loose gas cap?
  8. trying to remove rear differential ucf2x 95 LS400 need some help
  9. LS400 and now 430 too
  10. 99 LS Pinstripe
  11. Ignition click, 2nd time starts
  12. Instrument Panel
  13. 1994 LS400 Stock air suspension
  14. 95 ls400 tps help
  15. Engine Stalls in High Ambient Temperature
  16. Battery
  17. Font end noise
  18. LS Y Pipe Swap
  19. Tune up Info
  20. Looking at buying a high mile 98 LS400, thoughts?
  21. UFC10 driver side door removal
  22. Low idle at times
  23. Fender
  24. what "just for the hell of it mods" have you done
  25. Question on UCF10 Euro Bumper Part #
  26. These two rubber hoses are leaking
  27. Projector Retrofit Autolevel Function
  28. Rear bumper removal.
  29. oil lines
  30. proud new owner
  31. 1990 LS400 CPU location?
  32. A/C relay block
  33. 93 LS400 air suspension
  34. 93 Hesitation with trac light appearing
  35. frog/burping noise
  36. Steel Drum???
  37. 97 LS400 Pioneer Wiring Harness
  38. 1995 LS400 PO135 code bank 1 sensor 1...help
  39. seafoam 95 ls400
  40. Sunroof help
  41. How much better is the Nakamichi audio?
  42. Fan clutch recommendation
  43. 1996 LS400 Ac fan won't cut off when AC is off..HELP!!!!
  44. Rear light indicators
  45. AFTERMARKET STEREO questions HELP!
  46. key stuck in ignition
  47. post up your ebay / junkyard / internet parts find for your LS
  48. 1999 LS400 Subwoofer
  49. Fender Mirrors on UCF2x
  50. Am I a bad candidate for LS 400 ownership?
  51. Just Joined From Vegas
  52. Wheel size and offset for 2000 LS
  53. finally found Stainless Steel Brake Line for UFC20 95-00
  54. 1995 Lexus LS400 205k. Worth looking at closely?
  55. Need Advice - suspension "swaying"
  56. 1993 LS400 Rapid Gear Hunting - TPS?
  57. Re zeroing Speedometer
  58. Dented oil filter
  59. EGR Delete
  60. Where to buy OEM struts for '99 LS400?
  61. Celsior/LS400 mirror glass
  62. just joined the club 91 Ls 400
  63. Replacing the EGR Tube/pipe
  64. EGR tube/pipe
  65. 1998 LS400 temperature sensor not working properly
  66. 99 LS400: Timing belt Change or wait?
  67. 1995 ls 400 instrument cluster
  68. 1995 LS400 for our motorscape prauge rally
  69. Help! name of part?
  70. stock radio issue help please
  71. 1990 possible fuel pump symptoms.
  72. Scanner tool vs programmer?
  73. Recently picked up 98 LS400
  74. 95 ls400
  75. Help overheating '95
  76. Car Hesitating When I try to Accelerate
  77. Battery light and headlight leveling
  78. ls400 a/c diagnostic codes-need help understanding
  79. Real wood
  80. Driver Side Wheel Well Wire Tuck
  81. LS400 fuse box
  82. Car in Safe mode. Kill switch will not disengage '91
  83. my sick LS400
  84. SoCal Dippin'
  85. another wheel fitment question
  86. ucf10 1993 LS400 Rear toe link tie rod end taper ?
  87. i have a exhaust question
  88. Rear diff problem possibly need new one
  89. '99 LS400 with Solar Guard HP Charcoal 43%
  90. I love first gen ls400 front ends (post pics)
  91. 9x18 Porsche wheels
  92. Headlight Problem
  93. '97 LS400 - serious issue, possibly brakes
  94. 1993 Lexus Ls400 . Volume issues help !
  95. Instrument cluster
  96. A/c problem
  97. HELP! loose hose by right front axel??
  98. 1995 ls400 headlight help
  99. stock air suspension problems
  100. Rear Differential Subframe ALLEN BOLT SIZE?
  101. rear fog lights ?????
  102. Registration/Inspection stickers
  103. 96 LS400 Aux. fan
  104. Emissions
  105. Dont know how to do what I want interior lights?
  106. Muffler Setup
  107. Fender rolling dimples
  108. Ucf10 (1st gen) and Ucf20 (2nd gen) straight swap?
  109. 92 LS: Disgusting rear end clunk, getting exceedingly annoyed
  110. Looking at buying '95 LS400 - what would you do?
  111. Noobie from SoCal
  112. Starting engine after sitting 3 years
  113. am i the only one with a low mileage 96 LS400?
  114. 1996 LS: Plug the Windshield Sensor hole with rubber stopper
  115. New Front Upper Arms
  116. Need Help 1994 LS400 Problems! Please!!
  117. Post up your Rear muffler set-up!!! In need of inspiration!!
  118. antenna help
  119. 93 ls400 code 13 and 24
  120. Gauge cluster removal - 1998 LS400
  121. 4" front door replacement speakers ctx-4
  122. Power steering acv hoses
  123. Aggressive Fitment
  124. UCF20 99LS400 As anyone had this problem before?
  125. 91 ls 400
  126. New member intro & questions
  127. test drove today should I buy???
  128. Compatible Aristo/Supra Parts
  129. Pulled The Trigger!!!
  130. Suspension from another lexus question.
  131. Opinion needed on a LS400 purchase
  132. getting a LS 400!
  133. Fair game... Wheel stuff
  134. loud knocking noise (interior)
  135. noob with a/c trouble.
  136. GS430 owner getting ready to dabble in LS400-land
  137. UCF20/21 amplifier connections
  138. Weird Pinging/knocking unde slight acceleration
  139. Tires with the most wett grip for stock rims?
  140. Why is it so Hard!!!!
  141. LS400 California smog test worries
  142. Should I Buy..
  143. Questions on my new/used/LS400
  144. Great fm modulator for ls400
  145. New LS owner
  146. Exhaust questions; Need some Input
  147. Whining Noise at Idle
  148. Is it worth it??
  149. Just Bought LS400, 1991, looking for parts
  150. Air compressors not coming on
  151. Bought LS400
  152. I hope I didn't mess up the electrical!
  153. 97 ls harmonic balancer
  154. 1995 Ls400 overheating
  155. No sound with aftermarket Headunit
  156. Ls400 Coilover mounting location
  157. Rear wheel is loose/wiggles??
  158. LS400 hickup problem
  159. need this tranny seal part number
  160. LS 400 Issues
  161. Hey yall, new LS400 owner here!
  162. 1995 Trailer Wiring
  163. I think my transmission is dieing please advise
  164. gas pedal vibration from 1200-1600 rpm
  165. New from Japan, Toyota Celsior
  166. 02 sensor codes. Again...
  167. 1990 LS 400 Rack and Pinion PS High Pressure Hose
  168. UCF20 (95-97) front lip options
  169. 1996 ls400 motor swap or rebuild?
  170. DVOM suggestions?
  171. Tough Decision... coilovers
  172. Car only starts with gas pedal pressed
  173. Radio doesn't work, door ajar light on
  174. New to CL......and my first LS400
  175. New Ls400 owner, a thank you note
  176. LS400 limo?
  177. Battery/No Instrumentation
  178. Bi-metallic vacuum switching valve BVSV
  179. Planning on going badgeless....
  180. Mystery Bulbs
  181. Tire Recommendation for 18x8
  182. Uhm AC and Heat help???
  183. master keys wont work in trunk.
  184. Lexus phone adapter question
  185. Found a 96 with 84k!!!
  186. 94 LS idles but wont rev/dies/sputters/ARGH!
  187. sun roof motor location
  188. 2jz swap engine mounts
  189. Is it just me? (megan coilovers)
  190. 92 rear brake help??
  191. 99 LS rear brake pulsing..
  192. Telescoping steering wheel isnt going to set position.
  193. LS400 1996 error P0306 & white smoke
  194. Brake rotor recommendations for a 1990 LS400?
  195. Remote starter question
  196. 2000 Lexus LS400 'sighing' while driving problem.
  197. LS400 AC compressor problem
  198. Shot JDMsw20's 98 LS400 ~ Work Wheels Content Inside
  199. All Fans Dead on motor 90 LS400
  200. 93 LS: what is this bracket?
  201. P0401 EGR Flow - sensor delete
  202. HELP !! Head gasket replacement .
  203. Drivers Seat Search and Suspension Question
  204. Smashed my mirror
  205. My next "maybe"
  206. 91 ls400 on fire!
  207. Remote Key
  208. My first Lexus!
  209. I'm back
  210. anyone know wiring?! 1990 ls400 HELP!!
  211. Sewell
  212. Throttle Body Cleaning
  213. 98. The rear view mirror folding forward every time engine starts
  214. Throttle Body E-Port Vacuum Readings
  215. Best tire to get for 1st gen LS
  216. Mayrun tires?
  217. Needle lights - How difficult is it to fix??????
  218. timing belt help (cam marks)
  219. transmission
  220. Diagnosing vibration
  221. best year motor to put into my 93
  222. leaking water into car
  223. How to override the factory air suspension settings
  224. The dealership is not always wrong
  225. How to Turn a Lexus LS 400 into a Convertible on the Spot
  226. timing issues on 93 LS 400
  227. crank shaft pulley
  228. Stock air bag modifications
  229. speedo and tac problem!
  230. Climate control unit wiring diagram
  231. UAS bag over on BC coils
  232. Excessive condensation from exhaust
  233. Under carriage shield
  234. Wrong black FIPG for transmission pan
  235. 1998 w/ 98k whats it worth?
  236. climate control l and clock issue
  237. Look at the lights!
  238. Steering Wheel isnt smooth!
  239. New Lexus Owner
  240. 98, temp gauge high
  241. 99 air help
  242. I had to work on a Dodge today...
  243. too much rim make the ride too hard
  244. Code 71
  245. Consumption
  246. 98 LS Brake Sensor issue
  247. 1994 ls 400 stereo help
  248. Selling my 97 LS400. Not sure how?
  249. Why I hate this car! (not really)
  250. Random Cut off/No Start
