PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. 1995 ls400 models
  2. LS400 Foglight question
  3. 1990 ls400 rear seat installation
  4. LS400 Side Molding/Chrome Trim questions...
  5. please help, my ls is going nuts!!!
  6. 91 LS400 AC question
  7. just got my 1992 ls400
  8. Radio problem
  9. 2000 Lexus LS 400 - Elements Of Luxury
  10. New with a 1990 ls400
  11. castor arm bushes ucf20 anyone
  12. need help:98 Ls400 replacement srs airbags
  13. Coilovers comparison
  14. My newly obtain LS400
  15. **URGENT**98 a/c unit issue
  16. Best bushings for your money?
  17. Speed sensor out? Wrong mph?
  18. front brake judder
  19. Radiator Core Support Removal DIY????
  20. I am about to go change my rear shocks/struts.1995
  21. I have this light on.1995
  22. Clud/thunk sound when coming to a stop on crappy roads
  23. redoing the suspension
  24. Broken A/C center vent..
  25. It has FINALLY happened! I just became a Lexus owner - 99 LS400
  26. LS400 Door lock does not work
  27. 98-00 Brake lines routing.In/out from abs pump.
  28. Electrical problem 95 ls400
  29. Issues after driving through BIG PUDDLES?
  30. My new '92 LS400!!!
  31. Driver side AC Condenser not turning on...
  32. 1992 ls400 engine fan help
  33. '92 LS400 Rear fitment help!
  34. Rough idle when AC is on
  35. 94 LS400 Performance chip
  36. LS 400 0 - 60 & 1/4 miles times
  37. 98 ls400 key not properly function
  38. 92 ucf11 datasystem
  39. nothing to see here.
  40. 1994 ls 400
  41. Anyone running 22's?
  42. electric LS400
  43. 1997 LS400 Loud after catalytic converter replaced
  44. power steering vacuum pressure switch and a smoking exhaust
  45. Swapping springs on coilovers
  46. '98 LS400 Low Beams
  47. Dash issues.... Gurus chime in
  48. tried to get car aligned, came out kind of wrong :(
  49. 90 coilovers swap to 95
  50. LS400 Air Conditioning Regulator not working
  51. Tune-Up
  52. Help: A/C wiring hookup
  53. strong fuel smell/high vapor pressure
  54. Update on my '92 LS...
  55. Introduction and memory seat question
  56. Key wont open/turn any door, 1996 LS400
  57. so i bought my first lexus ls 400
  58. help! rear bumper removal 98-00
  59. A/c light blinking on climate control
  60. Lexus LS 400 Starting/Running Problems!!!!!
  61. My 93' LS update(lot's of pics)
  62. Bought my first Lexus...
  63. Custom Waterjetted Emblem
  64. electrical problems??
  65. Driver side Headlight housing ona 93LS400
  66. first timer need help
  67. Oil drain refill w/ filter = 4.7liters?
  68. Engine Shield for 99' LS 400
  69. Is this running too hot?
  70. Lexus Gearbox identification
  71. What type of Leather was used in the UCF20?
  72. Stancenation Feature: Vincent123's Lexus LS400
  73. Lexus ls400 instument cluster light off
  74. Cylinder head gasket leak - Draining coolant/oil from system
  75. Finally getting around to the introduction
  76. starter seems slow at times starting car
  77. Anyone with a 98+ LS can you measure your a/c vent temp?
  78. front cupholder
  79. Exterior window trim "Touch Up" paint
  80. 99' Lexus LS 400 with 07' GS 350 rims
  81. Multiple 1LS Transmission rebuild questions
  82. Car will not start!! Please Help!!
  83. Front parking light question
  84. misfiring problem on 95 LS400
  85. 2nd gen LS 400 front upper control arm (bushing)
  86. remanufatured ECU
  87. Will these fit?
  88. Jump Started my LS400 and now my gauges don't work at all
  89. Has anyone else seen this?
  90. Rrear Rotor Retaining Screws help
  91. On my 1992 Lexus LS 400 all the lights on the dash came on, then no power, now wont s
  92. discbrakes: whats interchangeable?
  93. locating pistons and other parts
  94. PS vacuum to intake fitting
  95. Speaker size question
  96. 1990 LS400 Will Not Start...
  97. EGR Assembly seems to be missing?
  98. Brake rotor question w/ YouTube vid
  99. '92- Tach and Speedo are wrong
  100. O2 sensor replacement - Location?
  101. Adapters to fit BMW wheels
  102. ls400 plug wires
  103. 1998 LS400 OBD2 Compatibility
  104. Update on my UCF10
  105. I love this car
  106. 98LS coolant leak, possibly water pump about to fail?
  107. Confirmation on this part please?
  108. No holes to mount front license plate
  109. So I have w58 bolted to a 1uz...
  110. What's your favorite interior modification?
  111. Key left in ignition = dead battery?
  112. 1-LS JDM headlight mounting question
  113. New ls400 owner
  114. 98LS has noise issue with a/c on or PS pump use or heavy electrical load. Help?
  115. reverse but no forward
  116. Bad night for the LS
  117. Passed smog in ca
  118. Thinking About Buying - Non-Lexus Owner
  119. thoughts on vinyl wraps?
  120. Tranny flush-drain- is this recommended??
  121. HELP!!! Sway Bar Bushings
  122. My 98 ls400 recently bought
  123. My 1992 Lexus LS400 I got today :)
  124. air suspension lay frame question
  125. Engine Choke for AC (1998 LS400)
  126. Just bought 1998 LS400 w/nav@122K ! Love it!
  127. 98 ls400 (audio headunit question)
  128. 94 LS400 steering column wont got down HELP!!
  129. Yay or Nay? (Exhaust)
  130. why is this exhuast $10,000???. GOLd plated ??
  131. Swaying bad
  132. spherical end link for LS400
  133. which components could cause this weird behavior?
  134. Quick Megan EZ coilovers question
  135. Swapping TO air suspension???
  136. Any LS400 with Lsx swap
  137. 2000 ls400 air conditioning problem
  138. Factory air suspension problem!
  139. Custom LED tail lights UCF10 LS400
  140. Low coolant temp, stalls
  141. OEM/OEM replacement
  142. Going for 400k miles!!!
  143. Potential LS(95) buyer, anti-theft quest, searched
  144. 92 ls400 rear wheel bearing replacement help
  145. Recommend So Cal ls400 Mechanic?
  146. crazy coincidence.
  147. 1999 LS400 Tilt function not working, Please Help
  148. Odd Check engine issue
  149. Blacked out / Smoked bumper lenses
  150. ??? for those that have done their own valve adjustment
  151. freeway speed issue
  152. Rear trunk spoiler options for UCF2X need ideas
  153. 1997 Lighted Door Sills
  154. '97 LS400 Stalling, now will not start. Possible fuel pump failure?
  155. backup camera?
  156. Looking at a 2000 LS400 with 164k. What should have been done/will need done?
  157. Air bag light comes and goes.. why? what to check.
  158. lexus ls400 going to france headlight adjusting
  159. performance issue
  160. Need help picking out my next lexus
  161. Fitment issues?
  162. Broken cam sprocket
  163. Emissions Monitors "Not Ready"
  164. Is a TPS install/replacement on 00 LS as easy as the replacement on the older models?
  165. Suspension height control faulty 1992 LS400
  166. TRAC system diagnostic code in 1992 LS400
  167. 1991 Celsior, my new baby.
  168. Engine turns over, no combustion, now works (fuel pump?)
  169. WHat error code would I get for a loose gas cap?
  170. trying to remove rear differential ucf2x 95 LS400 need some help
  171. LS400 and now 430 too
  172. 99 LS Pinstripe
  173. Ignition click, 2nd time starts
  174. Instrument Panel
  175. 1994 LS400 Stock air suspension
  176. 95 ls400 tps help
  177. Engine Stalls in High Ambient Temperature
  178. Battery
  179. Font end noise
  180. LS Y Pipe Swap
  181. Tune up Info
  182. Looking at buying a high mile 98 LS400, thoughts?
  183. UFC10 driver side door removal
  184. Low idle at times
  185. Fender
  186. what "just for the hell of it mods" have you done
  187. Question on UCF10 Euro Bumper Part #
  188. These two rubber hoses are leaking
  189. Projector Retrofit Autolevel Function
  190. Rear bumper removal.
  191. oil lines
  192. proud new owner
  193. 1990 LS400 CPU location?
  194. A/C relay block
  195. 93 LS400 air suspension
  196. 93 Hesitation with trac light appearing
  197. frog/burping noise
  198. Steel Drum???
  199. 97 LS400 Pioneer Wiring Harness
  200. 1995 LS400 PO135 code bank 1 sensor 1...help
  201. seafoam 95 ls400
  202. Sunroof help
  203. How much better is the Nakamichi audio?
  204. Fan clutch recommendation
  205. 1996 LS400 Ac fan won't cut off when AC is off..HELP!!!!
  206. Rear light indicators
  207. AFTERMARKET STEREO questions HELP!
  208. key stuck in ignition
  209. post up your ebay / junkyard / internet parts find for your LS
  210. 1999 LS400 Subwoofer
  211. Fender Mirrors on UCF2x
  212. Am I a bad candidate for LS 400 ownership?
  213. Just Joined From Vegas
  214. Wheel size and offset for 2000 LS
  215. finally found Stainless Steel Brake Line for UFC20 95-00
  216. 1995 Lexus LS400 205k. Worth looking at closely?
  217. Need Advice - suspension "swaying"
  218. 1993 LS400 Rapid Gear Hunting - TPS?
  219. Re zeroing Speedometer
  220. Dented oil filter
  221. EGR Delete
  222. Where to buy OEM struts for '99 LS400?
  223. Celsior/LS400 mirror glass
  224. just joined the club 91 Ls 400
  225. Replacing the EGR Tube/pipe
  226. EGR tube/pipe
  227. 1998 LS400 temperature sensor not working properly
  228. 99 LS400: Timing belt Change or wait?
  229. 1995 ls 400 instrument cluster
  230. 1995 LS400 for our motorscape prauge rally
  231. Help! name of part?
  232. stock radio issue help please
  233. 1990 possible fuel pump symptoms.
  234. Scanner tool vs programmer?
  235. Recently picked up 98 LS400
  236. 95 ls400
  237. Help overheating '95
  238. Car Hesitating When I try to Accelerate
  239. Battery light and headlight leveling
  240. ls400 a/c diagnostic codes-need help understanding
  241. Real wood
  242. Driver Side Wheel Well Wire Tuck
  243. LS400 fuse box
  244. Car in Safe mode. Kill switch will not disengage '91
  245. my sick LS400
  246. SoCal Dippin'
  247. another wheel fitment question
  248. ucf10 1993 LS400 Rear toe link tie rod end taper ?
  249. i have a exhaust question
  250. Rear diff problem possibly need new one
