PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. [i neglected to read the rules]
  2. Offset GURUs.....need advice and wisdom
  3. Front suspension clunk 96 ls400 144K quick reply please!
  4. Upper Control Arm Ball Joints
  5. Very interesting........
  6. LED bulb replacements 95+
  7. just bought car and it died
  8. Rebuilding Transmission, Need Diagram >.<
  9. Function Button on steering wheel
  10. Ls400 ashtray removal
  11. Bad coil to thrown rod? New here-hope I do this right..
  12. 1998-2000 Wheel Jack
  13. LS400 should I?
  14. New guy looking at this 1998 LS400
  15. 90 ls400 diff question
  16. Tune up question?
  17. dome light
  18. 93 ls400 injectors cleaned / report included
  19. Its alive after 7 years
  20. Weird 1LS engine sounds and more
  21. 1999 LS400 Shift Knob Replacement (How To?)
  22. OBD 1 or OBD 2
  23. Alternator wiring problem
  24. Where can I find this bushing?
  25. custom air intake?
  26. Seeping oil pan.
  27. Doors and sidewalks.... for the lowered people
  28. Rear strut access
  29. Lexus LS 400 Honored in Car Magazine’s 50 Greatest Cars of the Past Fifty Years
  30. Stutter like vibration in gas pedal
  31. paint question
  32. Hoping to get an ls400, advice.
  33. New Owner 96LS400, Transmission Drain Plug
  34. 97 ls400 egr delet please help
  35. LS400 to manual help ?
  36. My parking lights don't work.....HELP!
  37. PBR brake rotors
  38. Engine Rattle/knock/noise
  39. 92 LS400 starting issue
  40. UCF10 Paint Code Clarification (2 Tone Confusion)
  41. 94 ls400 interchangeable parts?
  42. front bumper
  43. impressed w 95 LS
  44. Down shifting? Dump valve?
  45. How to make a LS400 "awesome"
  46. Broken spark plug boot in cylinders 3,6,&7
  47. ? about led lights
  48. Dead transmission.......!!!! Out of words.... Help please!!
  49. Should I pick up a 96 LS400 for 750 bucks?
  50. Is This Normal (Idle)
  51. How hard is it to replace the cooling fan clutch bearing bracket and water pump?
  52. DIY: Integrated Garage Door Opener
  53. 7.5k for a 2000 LS400 - good buy or not
  54. Keep the LS or [sell] it?
  55. MPH Off
  56. Nakamichi Amp - pinout/wiring diagram?
  57. Check Engine Light Code PO420 PO430
  58. O2 sensors, post cat/down stream R&R. 98 LS400
  59. Steering wheel question...
  60. 1991 ls400 suspension nightmares!
  61. Rough idle/CEL after cap & rotor change
  62. Lexus Meter Light display issue
  63. Does this look like a damaged master control switch to you? (LS400)
  64. Exhaust Query
  65. Stut rod bushing repalcement
  66. what brand are these after market wheels ??
  67. Misfiring problem
  68. How's it going?
  69. Radio removal instructions needed
  70. 1992 ls400 with nakamichi -Sound Issues-
  71. Fuse change
  72. Is there room?
  73. lexus high mileage issues
  74. Front end conversion for a 1997?
  75. Has anyone used ksport air suspension?
  76. brakes
  77. 1994 Celsior Radio Wiring....help please!
  78. charging issue
  79. Clunk going from reverse to drive... Driveshaft?
  80. Safety door lock problem
  81. Some questions
  82. Heart broken
  83. 95-97 and 98-00 Inner door panel Question
  84. Random Knocking at cold start
  85. 89 Celsior - program remote key
  86. Airbag Suspension not level
  87. Replacement Key
  88. Would this cause CEL 25? (Pics included)
  89. Hazards work......turn signals don't!!
  90. LS 400 it's '99...
  91. air to coil questions
  92. nope
  93. 1995 Lexus LS400
  94. No code reader no start read codes starts
  95. JDM replacement for tired early 97 UCF20?
  96. New Member: Gebyz.
  97. issue with a 95 ls400
  98. Mobile 1 oil question
  99. help with shocks
  100. P0770 - Urgent Help Needed!!!
  101. My cars worth
  102. Coilover install
  103. 98 ls400 won't start
  104. cruise control ?
  105. need to replace several bulbs in dash
  106. Why i dont got these options on my ls?
  107. MRR HR3 Question
  108. poor power window operation
  109. 91 ls400 no start condition
  110. 95 LS400: Do I need to replace the catalytic converter, or is it something else?
  111. 95 LS400 power problems
  112. Possible Electrical Issue
  113. Best $12 I ever spent in my life... [BT OBDII Scanner]
  114. I need a EXPERT (ECU wiring harness ports)
  115. Different gauge options?
  116. my car run for 30 minutes stalls and wont start for 30 minutes
  117. 99 Onyx black
  118. LS400 UCF 20/21 Electric Rear Curtain
  119. 91 Ls400 Solenoid
  120. 92 ls400 sunroof won't close
  121. item above thermostat leaking?
  122. Battery Light Help!
  123. Ahhhh!!! Finally bought found it and bought it
  124. nothing, nothing at all.
  125. I have a confession to make....
  126. Radio issue
  127. What does this light mean?!
  128. wiper motor problem
  129. Need help with 91 LS AC part Identification
  130. Timing belt + additional services Estimate
  131. differences in repair manuals for 1991 LS400
  132. 1994 LS400 - Grinding/Whirring noise when braking to a stop.
  133. Evaporator Core Cost with installation
  134. [deleted]
  135. Oil leak? P-S leak? Help!!!
  136. need help
  137. 96 LS400 - New owner
  138. UCF10 turn signal/city lights ???
  139. Sound System LCD Display
  140. 1993 UL Ls400 efi system problem.
  141. Idler pulley for drive belt, saved some $$$$
  142. 1991 LS400 Check Engine Light Troubleshooting
  143. tire size
  144. Thinking of swapping my front seats
  145. Retired
  146. Guess who's back on the CL boards!?!?
  147. audio issue-93 pioneer deh 4400 hd...oem amp
  148. engine issues again
  149. LED tails compatible with 90-94?
  150. california car
  151. Lowering Springs
  152. Bad instrument cluster
  153. Heading to the shipping yard in a few days
  154. How to clean Hvac system of artificial smell
  155. Low tire noise (what brand?)
  156. Polished Windshield Trim
  157. Flashing ECT light
  158. Oil pan gasket
  159. 93 ls400 eagle eyes price tag?
  160. 95-97 front end on 90-94?
  161. Turning right stops the air.
  162. What did you do to your LS400 today?
  163. Starting Problem, New fuel pump and mod
  164. 2-piece Front Rotors
  165. 94 LS400 tach
  166. Climate Control Unit problem 1992 LS400
  167. 98 lexus Ls 400 electric problems
  168. Antenna issue
  169. 1996 lexus ls400 rattling Help!!!
  170. when did black leather interior start?
  171. coilovers from another
  172. 2 Tone paint code help
  173. 93 Ls400 - CEL # 25 Trac # 51
  174. Is this Normal (Suspension Height)?
  175. 97 LS 400 runs rough at 2000RPM
  176. speaker help needed
  177. 1998 UCF20 HVAC specialist help needed
  178. Does anyone have a 97???
  179. Custom exhaust routing for 98-00 LS400's?
  180. will these 20s clear the calipers?
  181. Catalytic Converter Question
  182. Replacing ash tray with???
  183. What is your take on this????
  184. Has anyone used Chiltons online repair site?
  185. No Heat in my 94 LS400....
  186. Hotdawwg's 1995 LS400
  187. 98 Brakes and Rotors. Front Screws Missing!
  188. moving forward....
  189. UCA Slaps = Airbags pop
  190. Cold Cranking problem
  191. Another vibration threat...
  192. 1998 lexus ls 400 stalling sometimes while stopped in traffic
  193. Transmission gear jerk
  194. Considering buying these wheels
  195. 96 ls400 problems help :(
  196. What is the best choice for new spark plugs?
  197. Are all UCF20 seat belts interchangeable?
  198. What's wrong with my stereo volume control?
  199. Bad Vibration at 65 mph
  200. Hey what's up newbie over here just bought my first 91 ls400
  201. Code 63 and Code 67
  202. I'm sure we all remember this.............
  203. tanabe springs?????
  204. Cooling Issues
  205. All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
  206. Front drivers side seat belt 94 same as 97
  207. Service interval for coil on wire
  208. 95 ignition switch on 91??
  209. removing ECM 94 ls400
  210. 95-97 head rest removal...help!!!!
  211. Nakamichi '98 LS400 speaker boxes
  212. 1993 ls400 engine jumping at normal speed
  213. Expolsive Battery
  214. Wheels and tire specs for slammed/tucked look.
  215. Where are you guys buying your performance parts from?
  216. Amazing UK price for Door mirror glass
  217. Hi
  218. Ignition coil pin connector
  219. New (to me) 99' LS 400 new to site as well
  220. Selling 93 LS 400 parts
  221. Replacing electrochromic side mirrors
  222. Inoperable tilt wheel mechanism repair
  223. Has anyone replaced the turn signal/headlamp combo switch?
  224. How to turn on heated mirrors
  225. moonroof/sunroof switch bad?
  226. 95-97 LS400 Nak stereo LCD replacement tutorial
  227. 1995 LS400 Super Rediculous Light Steering
  228. Rust killing of LS400's?
  229. Coolant leaks after flush
  230. Fuel release lever
  231. No Power!
  232. My first Lexus. 1991 LS400!
  233. 1995 LS400 Alternator, Please help:(
  234. 93 ls400 Starts and shuts down after two seconds
  235. 91 Ls400 Loud Whining Noise
  236. Cold Air Intake on a 93 LS 400
  237. Closed
  238. '98 LS400 audio upgrade. .. ... ...
  239. New 94 LS400 Owner that cant keep the car
  240. 1991 LS400 Issue OD blink
  241. Display not illuminated......need help
  242. 1992 LS400 has got me stumped !
  243. 98 display startup screen
  244. Stock springs front and back placement
  245. Steering Wheel Tilt Issue
  246. 94 LS400 tacho needle illumination problem
  247. Introduction
  248. RX wheel spacer and tire size help
  249. Megan Racing EZ Street Coilovers Shocks Springs for 1990 LS400
  250. Radio Antenna
