PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Bouncy Idle after IACV swap
  2. 91 LS400 wont start
  3. Custom skid plate
  4. Fuel tank location
  5. 1993 ls 400
  6. 99' LS400 bad starter ... Help Plz..
  7. LS400-Major Electrical problems! lights, charge etc...
  8. sulliman ['98 LS400 slightly low idle]
  9. Help asap-guide pin broke
  10. Owners age - Gen LS
  11. 94 LS400 owner needing selling/parting advice
  12. Ls 400
  13. Exhaust designs
  14. Strong Catalytic Converter Smell
  15. UCF10 exhaust!
  16. HID's installed!
  17. Is 1994 antitheft ECU interchangeable
  18. Question concerning '95 LS400 Amplifier specs (Nakamichi)
  19. Fuel Pump Relay Stuck Closed - Car won't start
  20. Gen 1 Steering rack replacement
  21. 1999 LS400 wiring-security issue
  22. Rare 1990 Infinifi Q45 51K
  23. 93 LS400 tail light moisture problem
  24. 91 LS, Alarm is triggered using manual keylock
  25. Replaced my battery cable ends
  26. air intake tube repair?
  27. engine will not turn over after replacing bulb in shifter
  28. Oil Filter Relocation kit
  29. 90 ls 400 HID CONVERSION Help
  30. Anniversary LS with a few issues
  31. Question about coolant
  32. 1990 Lexus LS 400 Serpentine belt problems
  33. Wheel Spacer Help for GS430 wheels
  34. 1992 ls 400
  35. Theres a LS400 behind a Honda.
  36. Emissions test and what can it tell me about my engine?
  37. newbie with stalling issues
  38. What type and size battery is best?
  39. power window issues
  40. My LS400
  41. '91 LS400 Hums under NO load
  42. Can't open trunk
  43. accelerator seems to not work?
  44. 94 ls400 hit a tree
  45. Don't buy an aftermarket thermostat
  46. Driver Seat only Reclines on the left hand side
  47. Need advice
  48. Radio light... fading way
  49. Liking my $275 bluetooth phone upgrade
  50. Which gen looks the best when modded?
  51. Help on my 94 LS400 purchase
  52. 1996 ls 400 yoroshiku~
  53. Trade LS for LS?
  54. Anybody running Ksports?
  55. ClimberD's 1990 LS400 Upgrade Thread
  56. Hello from Florida!
  57. ecu rebuild--1993 LS 400
  58. Negative pictures?
  59. Strange whirling noise...?
  60. old Lsportline advertisment
  61. Front LBJ nut hitting rotor?!
  62. Does anyone know what wheels......?
  63. Starting issue with 98LS400
  64. 1994 Ls400 starting /stallling issues
  65. Major loss of braking power... brakes feel hard
  66. 92 LS400 - rear dash strut
  67. Weird braking problem please help!
  68. UCF10 New California Customs Exhausts on Craigslists
  69. 1999 Silverjade Paint Code 6P7
  70. Clear headlight lenses 98-00
  71. Too aggressive for a UCF20?
  72. Discussion: FIPG vs. other gasket materials for a perfect tranny pan seal
  73. '99 for $11,999
  74. change ignition lock cylinder
  75. Car Phone wire to antenna wire?
  76. 1990 LS400 worn out bushing
  77. Need 98 LS400 Master Remote Key
  78. deer hit 1994 ls400
  79. No power to cluster fuse 93ls
  80. Factory Radio Service aux-in on 2000 LS400
  81. Head gasket issues
  82. Radio question
  83. Anyone have the polyurethane strut rod bushings?
  84. Any body used these new Transmission solenoids?
  85. poor man's Idle Air Control Valve *by MacGyver
  86. Replace/Clean Transmission Pan Oil Strainer?
  87. ls 400 air suspension woes
  88. Where to get a datasystem suspension controller?
  89. Exhaust part cross over?
  90. Could it be true?? [Tie Rod Manufacturer Discussion]
  91. Ecu question!!!!!!!95-96 ls
  92. how do megan ez streets ride
  93. CAI on a budget?
  94. Cigarette lighter
  95. 95 LS400 DRL Staying on all the time
  96. 92 LS400 Battery Problems
  97. 92 LS400 antenna question
  98. Bad Luck! Power Steering
  99. Websites/Dealers where I can buy aftermarket parts for my 1996 Toyota Celsior/LS400
  100. Just bout my first Ls
  101. How to mix Toyota Red Coolant with Distilled H20
  102. new tail lights !! . i like them .
  103. Main oxygen sensor signal code(1990 LS400)
  104. Plasti Dip FTW
  105. Aftermarket Air Intake Hose (Flex) - Return it?
  106. 93 running cold
  107. 91' LS400 won't get out of first gear HELP!!!
  108. misfires on 1998 LS
  109. Front Cigarette Lighter not working...HELP
  110. Bad heater core?
  111. help! - loud clanging rattle under car at speed
  112. So I was detailing the car today.
  113. Started to mock up my exhaust (pics)
  114. (New Member) JPanther's LS 400 Pics
  115. Best price for motor mounts?
  116. 1LS ABS/TRAC delete
  117. CD player recommendation needed
  118. wooden steering wheels.??
  119. I'm in a Tough Situation (power steering and alternator woes)
  120. Wheel spacer questions..
  121. retractable cupholder removal
  122. Ls400 not burning all the gas
  123. What's a lateral arm bushing - front suspension
  124. Leaking Sunroof, have read all posts on this but cannot find rear holes on 94 LS 400
  125. Does oil pressure increase with rpms?
  126. 4.0 v8
  127. Wheel Thoughts and opinions requested.
  128. Anyone have a rought estimate on how much the steering pump will cost?
  129. 1994 ls400 with huge power loss...sometimes
  130. Random Misfire
  131. Will it fit?
  132. My 'new' 1998 LS400
  133. 1/2jz swap, anyone done it?
  134. 98 LS400 Bar Hopping
  135. junkyard score!
  136. My first time owning a lexus and haven problems can u help with ideas
  137. difficulty replacing lower oil pan 97'
  138. Anyone on these SC430 wheels? (Not pie dishes)
  139. 180,000 Mile Service Quote
  140. Help with value - '94 LS, 73k
  141. Drivers side mirror
  142. Who's car is this? Sick LS400
  143. Fault codes
  144. Brake Fluid Flush for 1st Gen LS400 (with ABS) - Who to Call?
  145. Strut arm or radius arm?
  146. Wheel size
  147. Worn rear knuckle bushings?
  148. how to check 98 LS timing belt condition?
  149. HUB Adapter LS400
  150. First Gen Lexus LS400 - Fluids, Where to Buy
  151. 1990 ls 400 dash freaking out
  152. Tb hellllpp!
  153. Indie Mechanic - Reasonable?
  154. roof baskets?
  155. Seatback Removal
  156. Rear-end Muffler delete project.
  157. Choking, Struggling, Rough Like Diesel
  158. Dumb question about hose clamp
  159. 1998 LS400 check VSC light
  160. Blower motor control relay
  161. Most comprehensive good/bad Capacitor forum
  162. Bad Starter?
  163. Navigation?
  164. Factory Theft System won't activate HELP!
  165. FS and WTB posts go in the classified forums only
  166. Before replacing the starter please check this!Park/Neutral safety switch adjustment
  167. Purchased my first ls
  168. Picture request: '98-'00 LS400 with chrome LS430 wheels
  169. Picked up 1st Gen project, Need help with accel issue
  170. 92 LS: I heard that...
  171. Help Help!! Emergency
  172. To Slam or not to Slam that is the question!
  173. Just got original new Lexus cloth interior
  174. Battery keeps dying
  175. Ls 400 poor aceleration and tailshaft
  176. 1989-1994 and interchangable parts with the 95+?
  177. Leatherique Project: 1993 LS400
  178. Where to get aftermarket celsior/LS400 parts?
  179. Help 90 factory alarm
  180. how to install new ls400 headlights?
  181. Help! With fan bracket
  182. whine in radio
  183. Help Power Steering issues
  184. Celsior/LS400 Questions and help please!
  185. Will 1990 OEM ES wheels fit my 1990 LS?
  186. Gallardo rims
  187. LS400 Climate control LCD display Right Hand Drive
  188. 1998 ls 400 uoa
  189. 92 LS: ECU tuning options?
  190. Wires/harness driver side inner fender
  191. Snow tires Midwest
  192. Part outs?
  193. 1999 lexus ls400 w/P0430 no leaks no Sensor breakage/check engine on/off ... help plz
  194. Help identify leak (pics)
  195. Need duplicate key for 99 LS 400
  196. Just got my LS400 !! pics + mods inside
  197. SC430 Wheels. Opinions?
  198. After months I no longer have the braking shimmy! Also wheel question w/ pic
  199. 1994 LS400 will not start
  200. Has Anyone had problems with water in the Headlights?
  201. Which key is the master key?
  202. It's a gusher! Oil that is!
  203. Newer 1uz in UCF11?
  204. Finally back on a LS now w/ Gallardo wheels(pics)
  205. Introduction - My '94 LS400
  206. Stalling question for the board!
  207. Low car ceiling
  208. wheels
  209. Factory Air Sus delete
  210. New member
  211. replaced Loose/bad gas cap, CEL and VSC misfires.. now sulfur smell.. HELP!
  212. $7500 VIP Celsior - opinions?
  213. The New Guy: 1999 Lexus LS400
  214. "wow...dead tranny" part 2 post
  215. Custom Billet Grill...
  216. Changed out capacitors; how do I reset ECU
  217. My adventure to Function/Form!
  218. Where are you guys buying your Transmission Solenoids?
  219. HOW-TO: 95-00 Coilover install
  220. SC430 Wheels w/ the Center Pie Caps Removed - Let's See It
  221. Is there a scanner that the dealer only has?
  222. Water temp gauge gone bad?
  223. 1996 LS400 engine cutting out
  224. whats mine worth
  225. will 98+ gs300 coilovers fit 94 ls400
  226. LS 400 Power Steering - Noise when cold
  227. Looking to buy LS400
  228. Random No Start Issue 93
  229. Timing belt post replacement question....HELP !
  230. Any interest in a Coilover and brake change how-to?
  231. New 1993 UCF11 owner - story and questions
  232. Front clunking noise
  233. Rear Axle problems
  234. 1999 Lexus Code P0430
  235. Need 91 ls400 driver seat, or motor for reclining
  236. Having a weird vibration issue. Any ideas?
  237. 95 ls400 antenna motor keeps snapping cable
  238. Transmission Woes
  239. So looks like I got struck by the coil/ECU bug too...
  240. 92 LS400 Speedometer Gauge Needles Turning Black
  241. 92 LS400 Stalls and Staves for Gas HELP PLEASE!!!!
  242. I'm too tall
  243. P0336 code
  244. My horror story-forum member in need
  245. Sluggish 96 LS400
  246. LS400 difficulty starting after adding Lucas Fuel Treatmant
  247. There used to be an audio thread/title on this site.
  248. Floor the gas pedal; dies at 2000RPM
  249. Electronic flasher
  250. please help!
