PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Calif New Member
  2. What is this leak?
  3. Can't Read Code
  4. After Market Stereo
  5. Opinions
  6. Introducing myself and my LS
  7. BG Power Steering Flush Kit & 98 LS400 Question
  8. changed battery now headlights won't come on
  9. Cluncking noise gone, Do this before replacing parts!!
  10. Lost power steering while driving
  11. size difference between 93 and 95 front brakes?
  12. Fuel Tank Pressure
  13. How can I upgrade my stock 99LS 400 Navi w/o buying one from the dealer?
  14. New guy! data system issue. AS165X
  15. Idle RPM increases when turning steering wheel
  16. Brake Pedal Low (1998 LS400)
  17. SC430 Wheels finally on my 96 LS400
  18. What do you think of this 2000 LS400?
  19. 96 LS400 - Low Idle
  20. need help identifying this for ls400
  21. 1998 LS400 -- CLICK CLICK CLICK Behind Glove Box ..
  22. so long lexus club
  23. Help! LS Navi screen white
  24. Separation of Upper and Lower Intake Manifold
  25. 1990 LS400 plug wires
  26. 1990 ls 400 Window problem
  27. 1990 ucf10 ls400
  28. 1992 ls400 power steering leak
  29. cam sprocket 1999 LS 400
  30. Shredded the insulation off of the wiring harness in the driver side wheel well
  31. ucf20 coilovers
  32. Daytime Running Lights for 1998 LS400?
  33. Extreme Dimensions Front Bumper Foglamps
  34. Which Brand of DOT 3 Brake Fluid Do You Use?
  35. Bilstein HD on '97 LS400
  36. I want to upgrade my 99 LS 400 wheels/rims, any suggestions?
  37. Seatbelt Question - 90-92 in a 93-94?
  38. noob here, don't understand most of the terminology yet so bare with me
  39. Need front Shocks 00 LS
  40. R12 A/C problems
  41. 1992 LS 400 Shifts from 1st to 3rd
  42. 93 LS400 - Aftermarket Wheel / Tire ???
  43. LS 400 2000, Electrical and Starting Problems
  44. 1998 LS400 Transmission Mount Replacement
  45. Wheel Lug Nuts Under Torqued - Dangerous?
  46. noise drivers side by cams
  47. Help! [Electrical Problems]
  48. 98 LS400 floor mats
  49. How to adjust headlight on 94 LS400
  50. Greetings - my first post and a question or two
  51. 98 LS400 Navigation/Climate and Stereo control module location
  52. Seat covers
  53. front brakes/90 Lexus ls400
  54. 1994 LS400 starting issue
  55. Exhaust pipe
  56. 97 LS400 emblem removal
  57. Where are you guys getting your K&N kit from
  58. Wire Hanging from Dash on my 1998 LS400
  59. Rear end sinks on my '97 w/ 215k miles
  60. 98LS multiple front end noises
  61. 1998 LS400 Thermostat Jiggle Valve
  62. 1992 LS 400 unusual engine blips
  63. LS400 vs. Toyota Springs
  64. Replacing suspension parts when lowering a 98 LS400?Stretch tire install Bay Area CA?
  65. in search for the low,
  66. Is this '92 LS400 a good buy?
  67. '91 LS400 RPM hunts up and down at 1000
  68. Power steering pump pulley removal help please
  69. Stuck Nuts on Megan Coilovers (Can't Adjust Height)
  70. Help on a Rim Decision
  71. 96 timing belt mark help
  72. 91 LS400 Brake repair upgrade on rotors
  73. Waterless cooling
  74. Engine Mounts Cracked/Split - Cost? OEM Mounts?
  75. New(ish) Member Intro
  76. Question about removing carpet.
  77. In a conundrum repair or part out a '97
  78. Need help...
  79. [Where to buy LS400 parts?]
  80. '92 ls400 front strut rod bushings and rear carrier bushings replacement?
  81. speedo needle went out...
  82. Help on audio equipment
  83. Is this LS400 worth picking up??
  84. rear toe link question
  85. No start, has fuel and spark
  86. LS400 brake upgrade questions
  87. Help 1992 ls400
  88. 215 or 225 tires
  89. Been awhile... Need some help?
  90. Trailer brake controller
  91. Power windows
  92. 1991 ls400 skipping idle and missing when cold/wet outside.
  93. Power steering leak and blue smoke at startup
  94. Finally got heater working, kinda...more ?'s
  95. fuel in ehaust
  96. Options for a new master key?
  97. nothing to see here.
  98. A couple things in regards to MAF/TB Cleaning...
  99. Small questions
  100. 1996 Lexus gearbox issue?
  101. Smoke at WOT kickdown -
  102. Parking brake not doing its job.
  103. Color of Brake Fluid in Reservoir
  104. Opportunity to buy a UCF20 or UCF21! Which one should I choose
  105. Steering wheel tilt gear same for 1LS-2LS?
  106. 1998 personalization
  107. Do 95 and up LS400s have the goofy P/S filter screens?
  108. Help!!.. Head lights dash and rear lights wont turn off
  109. 98 power steering solenoid
  110. looking for opinions, my first build
  111. Ls400 start up, Running rough help
  112. 93-94 tail light removal?
  113. Blocked drain holes now sunroof wont open
  114. Electrical problem
  115. Brake Fluid Bleed Pattern - First Gen
  116. Suggestions. .. Two tear oil pan bolts don't tighten.
  117. Introduction - SquiddyB6S4 aka The Squid
  118. Immobilizer? LS400 Won't start after battery disconnected
  119. Whine When Starting the Car 98 LS400
  120. Gear Oil -- Where to Buy? (Need Today)
  121. What is the "A" bolt (First gen trans pan)?
  122. please post up any LS400 OEM's if you know them
  123. SC430 Wheels on a 2nd Gen LS400
  124. New member intro.
  125. head torque specs
  126. 1991 LS400 5 month review
  127. I am looking for some pics of the exhust tips
  128. 98LS400 CD changer Question
  129. Who do you trust for suspension work?
  130. 98 LS400 cigarette lighter not working
  131. HELP!! 91 ls400 running bad, missing out!
  132. New here, introducing myself and my UCF10
  133. 92 LS400 pulles to right when braking
  134. Finally an update to my LS400 - First official Shoot
  135. Eagle Eye's and HID's installed
  136. how do you remove the boot lining on 1995 LS400?
  137. What is the average cost to have Valve cover gasket fixed?
  138. 93 pulls when cold out - normally cuts out open throttle
  139. Sun Roof Wont Open
  140. Differential Bushing Change
  141. How to sort out damage from reverse terminals jump start
  142. first ls and these are my issues
  143. 98 LS Replaced Starter, Didn't Fix Problem
  144. Difficulty in swapping Alternator/PS leak at home?
  145. Bouncy Idle after IACV swap
  146. 91 LS400 wont start
  147. Custom skid plate
  148. Fuel tank location
  149. 1993 ls 400
  150. 99' LS400 bad starter ... Help Plz..
  151. LS400-Major Electrical problems! lights, charge etc...
  152. sulliman ['98 LS400 slightly low idle]
  153. Help asap-guide pin broke
  154. Owners age - Gen LS
  155. 94 LS400 owner needing selling/parting advice
  156. Ls 400
  157. Exhaust designs
  158. Strong Catalytic Converter Smell
  159. UCF10 exhaust!
  160. HID's installed!
  161. Is 1994 antitheft ECU interchangeable
  162. Question concerning '95 LS400 Amplifier specs (Nakamichi)
  163. Fuel Pump Relay Stuck Closed - Car won't start
  164. Gen 1 Steering rack replacement
  165. 1999 LS400 wiring-security issue
  166. Rare 1990 Infinifi Q45 51K
  167. 93 LS400 tail light moisture problem
  168. 91 LS, Alarm is triggered using manual keylock
  169. Replaced my battery cable ends
  170. air intake tube repair?
  171. engine will not turn over after replacing bulb in shifter
  172. Oil Filter Relocation kit
  173. 90 ls 400 HID CONVERSION Help
  174. Anniversary LS with a few issues
  175. Question about coolant
  176. 1990 Lexus LS 400 Serpentine belt problems
  177. Wheel Spacer Help for GS430 wheels
  178. 1992 ls 400
  179. Theres a LS400 behind a Honda.
  180. Emissions test and what can it tell me about my engine?
  181. newbie with stalling issues
  182. What type and size battery is best?
  183. power window issues
  184. My LS400
  185. '91 LS400 Hums under NO load
  186. Can't open trunk
  187. accelerator seems to not work?
  188. 94 ls400 hit a tree
  189. Don't buy an aftermarket thermostat
  190. Driver Seat only Reclines on the left hand side
  191. Need advice
  192. Radio light... fading way
  193. Liking my $275 bluetooth phone upgrade
  194. Which gen looks the best when modded?
  195. Help on my 94 LS400 purchase
  196. 1996 ls 400 yoroshiku~
  197. Trade LS for LS?
  198. Anybody running Ksports?
  199. ClimberD's 1990 LS400 Upgrade Thread
  200. Hello from Florida!
  201. ecu rebuild--1993 LS 400
  202. Negative pictures?
  203. Strange whirling noise...?
  204. old Lsportline advertisment
  205. Front LBJ nut hitting rotor?!
  206. Does anyone know what wheels......?
  207. Starting issue with 98LS400
  208. 1994 Ls400 starting /stallling issues
  209. Major loss of braking power... brakes feel hard
  210. 92 LS400 - rear dash strut
  211. Weird braking problem please help!
  212. UCF10 New California Customs Exhausts on Craigslists
  213. 1999 Silverjade Paint Code 6P7
  214. Clear headlight lenses 98-00
  215. Too aggressive for a UCF20?
  216. Discussion: FIPG vs. other gasket materials for a perfect tranny pan seal
  217. '99 for $11,999
  218. change ignition lock cylinder
  219. Car Phone wire to antenna wire?
  220. 1990 LS400 worn out bushing
  221. Need 98 LS400 Master Remote Key
  222. deer hit 1994 ls400
  223. No power to cluster fuse 93ls
  224. Factory Radio Service aux-in on 2000 LS400
  225. Head gasket issues
  226. Radio question
  227. Anyone have the polyurethane strut rod bushings?
  228. Any body used these new Transmission solenoids?
  229. poor man's Idle Air Control Valve *by MacGyver
  230. Replace/Clean Transmission Pan Oil Strainer?
  231. ls 400 air suspension woes
  232. Where to get a datasystem suspension controller?
  233. Exhaust part cross over?
  234. Could it be true?? [Tie Rod Manufacturer Discussion]
  235. Ecu question!!!!!!!95-96 ls
  236. how do megan ez streets ride
  237. CAI on a budget?
  238. Cigarette lighter
  239. 95 LS400 DRL Staying on all the time
  240. 92 LS400 Battery Problems
  241. 92 LS400 antenna question
  242. Bad Luck! Power Steering
  243. Websites/Dealers where I can buy aftermarket parts for my 1996 Toyota Celsior/LS400
  244. Just bout my first Ls
  245. How to mix Toyota Red Coolant with Distilled H20
  246. new tail lights !! . i like them .
  247. Main oxygen sensor signal code(1990 LS400)
  248. Plasti Dip FTW
  249. Aftermarket Air Intake Hose (Flex) - Return it?
  250. 93 running cold
