PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. New to forum and Lexus
  2. 1995 ls400 jerks,clunks when easing off gas
  3. How NOT to change your idler bearing
  4. transmissikn fluid leak butt from where..
  5. need repair manuel 93 ls 400
  6. Will Lexus ES 300 wheels fit on my 92 LS400?
  7. Newbie down under... any Aussies here?
  8. Tilt works but limited range, already did washer fix
  9. knock sensor pigtails
  10. 90 LS 400 Junction Box 2 Fuse Sparks on insert
  11. Another transmission thread...
  12. Post your aftermarket seats.
  13. power steering very hard on my 1992 LS 400 after these repairs
  14. Trunk Lid Latch Actuator
  15. Valve stem seals
  16. Buying New Rims. Need Help With Specs
  17. Cross threaded nut on wheel stud
  18. Factory Radio problems 1990 LS400
  19. need your HELP please - engine surging
  20. When I grow up I want to be an LS
  21. New Member
  22. Hissing sound from headlamp
  23. 1YUZFE's 1994 LS400 Restoration thread
  24. Is there a Current Lip for the 95 ls400 ??
  25. Late introduction to myself and my LS400
  26. Anyone tried dropping the steering rack to do the engine mounts?
  27. no wtb here please
  28. o2 sensors replacements
  29. first gen strut rod bushings....
  30. '96 LS400 - shock replacement
  31. '96 LS400 - What are those electronics in the right wheel well under the carpet?
  32. My Ride ..
  33. oil in the bellow boots
  34. 1-LS: need help with wheel & tire fitment
  35. will 2006 oem ls430 wheels fit an 2000 ls400?
  36. Fuel System Treatment Question
  37. SSR SP1 or WORK Meister
  38. caliper question
  39. engine stays on with key removed,please help!!!
  40. RCR Taillight Problems...
  41. New Member/Long Time Stalker- 93 LS 400 - Newb Questions
  42. replacing rear bumper cover 1990 ls400
  43. Quick Question Megan EZ
  44. I Cut the front bumper!
  45. Occasional low oil pressure and vsc off + check engine light. Please help
  46. ls400/celsior airbag suspension question
  47. I dare you to buy this LS400!!!
  48. 93- Runs rough until warms up, CEL 13.
  49. 92 Lexus Power Steering Rack
  50. Locked Keys in Trunk
  51. Need some help
  52. Removing the rear seats
  53. 1997 LS400 pixels going slowly but surely?
  54. Looking into getting a high mileage LS400, Advice?
  55. 1993 ls400
  56. will this wheel fit a 2000 ls 400?
  57. Odd electrical issue. Please help with ideas..
  58. 98 ls400 shifter problem/ possible shift issue
  59. Neglected 1998 LS, Shifting Issues Please Help!
  60. Water pump replacement, preferred brand?
  61. Nagisa Front Camber Adapters for UCF21
  62. Brake light on hard braking ?
  63. Anyone ever pull the motor w/ trans out?
  64. shift solenoid
  65. Brake rotors/pads *best bang for its buck*
  66. Cleaning Speaker Grills on Doors
  67. Thoughts on some wheels.
  68. 90 ls400 tps/sub tps/actuator check and adjust.
  69. Installed some 10in subs
  70. Ecu
  71. just bought an LS sight unseen!
  72. 93 Trac Control made CEL 13 appear and misfire. Distributor caps?
  73. 1993 LS 400 running on 4 cylinders
  74. I may have damaged the engine
  75. led h3c
  76. Need dire help in finding a light replacement
  77. Windshield washer nozzle
  78. Work Euroline fitment question
  79. Fuse keep blowing-Best alternative bulbs besides retrofit/hid
  80. Doing the LED conversion to my bulbs... so many choices - help me out guys
  81. UCF11 with 1uzfe VVTi ?
  82. 1992 ls400 suspension work
  83. Power Steering Problems
  84. UCF 10 Fender Rolling
  85. cv axle/half shaft question
  86. Check Engine Light 5 minutes a day
  87. Cold starting issue
  88. my ride
  89. I need a CAT!!!!!
  90. rear wheel alignment
  91. Dose Anyone know the specifications On the Springs on a 1994
  92. LS400's on 18's ??
  93. Battery or Alternator or?
  94. 98 - Panel Below Lower Glove Box
  95. Any truth to something I heard about the LS400.
  96. transmission fluid 95 ls400
  97. LS400 CD Changer Issues
  98. Buying a 94 LS 150k miles.
  99. Catalytic converters
  100. 1996 LS400 rough idle and misfire problem
  101. Noise from rear passenger suspension
  102. windshield wiper fluid.
  103. 1997 LS 400 air suspension?
  104. Finally! coilovers installed
  105. '97 LS 400 thoughts?
  106. 98-00 foglight bracket?
  107. Somewhat rough idle after warm up and died a couple of times. 98 Ls400
  108. 90 ls400 issues
  109. And The Restoration Begins Again
  110. Woodgrain Steering Wheel Installed
  111. '97 LS 400 Splash Shield
  112. air suspension setup UCF20
  113. $20 Borescope from eBay -- any good?
  114. HOW MANY 94 5th ANNIVERSARY EDITIONS MADE?
  115. ls400 donuts with open diff
  116. Mb w140
  117. Transmission leak.. '95 LS400.
  118. Aftermarket radiator 1990 ls400
  119. 94 LS400 Cluster Capacitor ?
  120. Dialled in big rear camber, now lost drive?
  121. 95 LS400 Nakamichi Aux in
  122. EGR Pipe replacement put to rest
  123. Just got a 98 ls... :d
  124. Brake Pad & Rotors for a UCF20
  125. Won't turn over
  126. Groaning noise in brake pedal
  127. what is this for?
  128. Cleaned MAF Sensor on my 98 and ..
  129. 93 LS400 Won't Start
  130. tune ups
  131. Aftermarket Headunit
  132. Car Completely Dead
  133. Capital Sport UHP tires
  134. replacing driver side door?
  135. Battery Strategy
  136. how is this quote from the dealer?
  137. 91 LS400 clear corners - where to buy now?
  138. Battery good but won't turn the engine
  139. Whose got the cleanest 93 LS400...
  140. 1991 ls400
  141. 1998 lexus ls400 bad motor what to do with it?
  142. How often do you change your differential oil?
  143. Wood steering wheel crack repair -- 98 LS400
  144. Cleaning TB on 98 -- Drive by Wire question
  145. My LS resurection project NEED HELP!
  146. Need new battery
  147. Problem starting from cold
  148. Xm Antenna wire
  149. asking $900 can lowball for close to half?
  150. Model changes for 1990, 91, 92 cars
  151. 94 LS400 for $1100 w/ slipping transmission
  152. Steam shooting out of the front grill. Fed up!
  153. I wanna change my 99LS400 tail lights to Red or white to replace the ugly yellow
  154. Wont start
  155. A hello to everyone from a Lexus newbie!
  156. O2 Sensors
  157. 95 ECU throttle jerk problem and the Dash pot
  158. LS400 will be a Collectable Classic (I believe)
  159. Power steering stiffness .... Help!!
  160. Calif New Member
  161. What is this leak?
  162. Can't Read Code
  163. After Market Stereo
  164. Opinions
  165. Introducing myself and my LS
  166. BG Power Steering Flush Kit & 98 LS400 Question
  167. changed battery now headlights won't come on
  168. Cluncking noise gone, Do this before replacing parts!!
  169. Lost power steering while driving
  170. size difference between 93 and 95 front brakes?
  171. Fuel Tank Pressure
  172. How can I upgrade my stock 99LS 400 Navi w/o buying one from the dealer?
  173. New guy! data system issue. AS165X
  174. Idle RPM increases when turning steering wheel
  175. Brake Pedal Low (1998 LS400)
  176. SC430 Wheels finally on my 96 LS400
  177. What do you think of this 2000 LS400?
  178. 96 LS400 - Low Idle
  179. need help identifying this for ls400
  180. 1998 LS400 -- CLICK CLICK CLICK Behind Glove Box ..
  181. so long lexus club
  182. Help! LS Navi screen white
  183. Separation of Upper and Lower Intake Manifold
  184. 1990 LS400 plug wires
  185. 1990 ls 400 Window problem
  186. 1990 ucf10 ls400
  187. 1992 ls400 power steering leak
  188. cam sprocket 1999 LS 400
  189. Shredded the insulation off of the wiring harness in the driver side wheel well
  190. ucf20 coilovers
  191. Daytime Running Lights for 1998 LS400?
  192. Extreme Dimensions Front Bumper Foglamps
  193. Which Brand of DOT 3 Brake Fluid Do You Use?
  194. Bilstein HD on '97 LS400
  195. I want to upgrade my 99 LS 400 wheels/rims, any suggestions?
  196. Seatbelt Question - 90-92 in a 93-94?
  197. noob here, don't understand most of the terminology yet so bare with me
  198. Need front Shocks 00 LS
  199. R12 A/C problems
  200. 1992 LS 400 Shifts from 1st to 3rd
  201. 93 LS400 - Aftermarket Wheel / Tire ???
  202. LS 400 2000, Electrical and Starting Problems
  203. 1998 LS400 Transmission Mount Replacement
  204. Wheel Lug Nuts Under Torqued - Dangerous?
  205. noise drivers side by cams
  206. Help! [Electrical Problems]
  207. 98 LS400 floor mats
  208. How to adjust headlight on 94 LS400
  209. Greetings - my first post and a question or two
  210. 98 LS400 Navigation/Climate and Stereo control module location
  211. Seat covers
  212. front brakes/90 Lexus ls400
  213. 1994 LS400 starting issue
  214. Exhaust pipe
  215. 97 LS400 emblem removal
  216. Where are you guys getting your K&N kit from
  217. Wire Hanging from Dash on my 1998 LS400
  218. Rear end sinks on my '97 w/ 215k miles
  219. 98LS multiple front end noises
  220. 1998 LS400 Thermostat Jiggle Valve
  221. 1992 LS 400 unusual engine blips
  222. LS400 vs. Toyota Springs
  223. Replacing suspension parts when lowering a 98 LS400?Stretch tire install Bay Area CA?
  224. in search for the low,
  225. Is this '92 LS400 a good buy?
  226. '91 LS400 RPM hunts up and down at 1000
  227. Power steering pump pulley removal help please
  228. Stuck Nuts on Megan Coilovers (Can't Adjust Height)
  229. Help on a Rim Decision
  230. 96 timing belt mark help
  231. 91 LS400 Brake repair upgrade on rotors
  232. Waterless cooling
  233. Engine Mounts Cracked/Split - Cost? OEM Mounts?
  234. New(ish) Member Intro
  235. Question about removing carpet.
  236. In a conundrum repair or part out a '97
  237. Need help...
  238. [Where to buy LS400 parts?]
  239. '92 ls400 front strut rod bushings and rear carrier bushings replacement?
  240. speedo needle went out...
  241. Help on audio equipment
  242. Is this LS400 worth picking up??
  243. rear toe link question
  244. No start, has fuel and spark
  245. LS400 brake upgrade questions
  246. Help 1992 ls400
  247. 215 or 225 tires
  248. Been awhile... Need some help?
  249. Trailer brake controller
  250. Power windows
