PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. car stalling
  2. Junkyard find.. 90 Ls 400 with rare color interior
  3. Climate control cheapo LCD replacement?
  4. Partial keyless entry fix
  5. Help with 93 transmission
  6. LS400 not running right like a flick of a switch
  7. New member here, longtime Ls 400 driver
  8. 1st gen series I and II compatibilities
  9. NooB to airbags *questions*
  10. Installation of front struts 1994 LS400
  11. Rear strut bar?
  12. Megan EZ Streets adjustments?
  13. 4 years old new starter, not starting car!
  14. New member needing advice '91 or '01?
  15. AC not blowing ice cold
  16. Noise
  17. loweredd my car...
  18. And I bid the trusty old LS400 goodby
  19. Adding heated seats?
  20. Ac question??
  21. 1st gen strut rod bushing replacement help
  22. Side Mirrors Not Moving - Fuse Or Motor?
  23. Is there a Timing belt break in procedure?
  24. Idle Port Cleaning 98LS
  25. Speedo issue
  26. Brake wear indicator flashing
  27. Power steering question
  28. Seat wiring question
  29. question about steering wheel radio controls
  30. 1995 LS 400 Front end Wanders
  31. Awd
  32. Does Over Tightening Engine Bolts Matter
  33. LS400 Headroom for taller people?
  34. help - p1305 code
  35. Which one to choose?
  36. LS 400 questions, need some help!
  37. current project
  38. Ls400 sub question.. Anything would help
  39. Is it my alternator?
  40. Getaway LS400
  41. What is the recommended maintenance & the maint intervals for the (95-00) LS400?
  42. Installing a GPS
  43. Many thanks to all...CL ROCKS!
  44. Click and no start issue continues..new developments
  45. Christine has invaded sound system of 1992 LS400
  46. Woohoo cars puking oil xD
  47. All black thread (no two-tone) 95-97 LS400 body styles
  48. 2013 avalon wheels
  49. 1993 LS400 - Trying to wire my double din.
  50. transmission
  51. 1995 LS400 weird idling problems.
  52. 93 ls400 turbo or s/charge
  53. Help me ........ Please !!!!!!!!
  54. 96 ls400 wiring diagram for nakamichi ... ive been looking for an accurate diagram
  55. What is this part called which broke?
  56. UCF11 JDM corners Vs. Usdm corners
  57. cats or no cats 94 ls400
  58. 94 LS400 with codes 41 & 55.
  59. I should've known better..
  60. Heading to the grave
  61. radio has power but no sound?
  62. Dash Panal Lights, other questions
  63. Intake manifold swap?
  64. New '91 LS 400, a couple quick inquiries
  65. First Lexus Ever!
  66. 1990 ls400 clock spring question.
  67. tell me why this will not work in my 94
  68. Black Jade Pearl Touch up paint?
  69. Bilstein question for 97 LS400
  70. Is the Nakamichi Sound & Navigation Package combinable on the LS400?
  71. new 94 ls400 lots of ?s
  72. 2000 LS400 issues Help!
  73. 96 with 98 front end?
  74. 99LS ... I need to change my bank 2 Cat, what OEM Brand/Supplier Can I trust?
  75. 1992 LS400 ABS issues (or not!)
  76. LS400 with fault code 31 and erratic idle. AlreadyTested MAF (good) ECU (good)
  77. Climate Control Wiring Diagram
  78. Failed Wheel Bearings....
  79. ucf10/11 transmission compatibility.
  80. LS400 with Lamborghini doors sound familiar?
  81. DIY: No Horn? QR Set Up for Horn Relocation
  82. Performance Air Filter replacement on LS 400 1992
  83. fog light out
  84. new member - intro
  85. anyone on saleen reps?
  86. 92 Sticker Pin Stripe Removal
  87. Please Help - dash lights out
  88. Quick Release Horn Button
  89. BWD Coolant Temperature Sensor
  90. 20 years of carbon build up
  91. Serpentine belt tension
  92. 94 ls400 still doesnt run
  93. Thoughts on buying a 98+ LS??
  94. LS400 coolant resevoir tank crack question
  95. the light next to the headlight
  96. heater control valve open or close?
  97. Radiator bushing problem
  98. Blower Motor/Integrated Phone Issue
  99. 1999 LS400 Problem with code po125
  100. LS400 Lack of power during acceleration?
  101. Unknown button??
  102. Factory Air Suspension Cheater on 98 LS400
  103. Cannot get serpantine belt tensioner pulley to come off
  104. new to 95 LS400
  105. Ls400 with the vcs plague!! Halp!!!
  106. TRAC issue?
  107. Straighten Steering Wheel?
  108. pinging problem
  109. How much would you pay for this LS400 ?
  110. Aftermarket steering wheel thread!
  111. car stalled after slamming on the brakes
  112. heater/ac fans not blowing.....???
  113. Engine block heater in my '93
  114. oil light on but oil pressure ok and oil pressure sensor replaced
  115. Strut Rod Replacement (1998)
  116. Max spacer on factory studs?
  117. Driver Seat dashboard button
  118. Door Chime Every Time I Hit a Bump
  119. Seatbelt Issue
  120. want to upgrade my wheels suddgestions anyone?
  121. cold air intake hmmmm
  122. Issue w/ key rolling up and down windows
  123. 96 front wheel spacing help???!!!
  124. HELP!!! ls400 speedometer needle
  125. BC Coilover install this weekend
  126. Engine vibration factors?
  127. Brake pad warning light on??
  128. Vibration
  129. Locked radio
  130. New Lexus Owner!
  131. OEM vs aftermarket
  132. New "JDM" style tail lights installed, lights not working properly
  133. Ls400 ride like floating
  134. my first lexus
  135. Fans come on so as I turn the key.
  136. new to cl
  137. new to cl
  138. Ls400 DHP WHEELS
  139. Transmission mount replaced! Motor mounts next
  140. Car Won't Start!! - Weird Feeling in Brake Pedal
  141. New '96 LS400, with some problems
  142. 1992 ls400 engine computer in a 1993 ls400
  143. 90 ls 400 over heating Help
  144. New; From Vancouver!
  145. Before you replace your 1st Gen brake lines..
  146. 99' lexus ls400 auxiliary input, how to?
  147. No Leaking or Sick Caps in my ECU
  148. Rear sway bar bushing kit??
  149. 92 steering wheel need some help
  150. Loose Door Panel/Seals, Part #'s
  151. I think i might have found my LS
  152. new tires, need opinions
  153. 1994 LS400 - Replaced Battery, Won't Start
  154. New owner of a 1993, new to CL, questions.
  155. Strut Mounts Cushion
  156. Need help replacing brake light on 1997 LS400
  157. UCF10 Sputtering/surging & low power
  158. Question on My Lexus Service History
  159. Replacing Parking Brake Shoes
  160. 1991 LS400 Throttle Issue
  161. Vibration At Cold Start Up Smoothes Out When Warm
  162. My New LS!
  163. UCF21 Headlight Removal
  164. My 99 LS turned over 230000 today
  165. Just bought your LS check your in cabin filter!!
  166. low uneven idle and stalling problem
  167. 92 MAF Sensor Cleaning???
  168. why wont my lexus rev over 2000 rpm
  169. 98 Ls400 Won't turn over Help Please ASAP Anyone!!
  170. Doors Unlock by themselves.
  171. Need Rim Advice For My LS400!!
  172. Radio intermittent
  173. Transmission hose leak?
  174. UCF 20 SS Brake lines
  175. how to get to shift lock solenoid ????
  176. loss of power and sputters around 2200 rpm
  177. BC Racing BR Coilovers
  178. Engine issues - newbie help required
  179. Idling issue
  180. 1997 LS400 won't start, possible immobilizer issue?
  181. Someone please help me find this part
  182. Where to buy ac vent *blades*
  183. Swapped my tranny mount - Got rid of a lot, no just have high speed shake at like 70+
  184. Steering reach
  185. Trunk emblems off and shaved!
  186. Need help!!! Doesn't start after throttle body cleaning
  187. After timing belt job, 91 LS400 is not starting
  188. Anyone drive with the PWR/ECT on all time?
  189. Just picked up ls400, help me mod this thing.
  190. Possible rack and pinion problems
  191. need some suggestions
  192. replaced alternator, no sound from radio
  193. Help identifying a hose 92 LS400
  194. 300.00 good for a timing belt kit
  195. 92 LS Distributor Cap/Rotor Change and Clean TB???
  196. Dash Lights Stay On
  197. Resurface rotors or not?
  198. Looking for LS front strut bumpers
  199. 99LS ... Whats the best way to clean the gas tank?
  200. 1uz in my 4runner, need help with a wiring question
  201. 98 LS400 Will Turnover, Won't Start no CEL
  202. 99LS ... What's the going price for Tune-Up and Timing belt at a local Mechanic ?
  203. 99LS ... How can I check if my timing belt needs to be changed?
  204. How badly did I mess up my car?
  205. 1992 ls 400 losing brake fluid
  206. lsx turbon swapped ls400
  207. Megan Coilovers on a UCF10
  208. Tail-lights not turning off
  209. clear tails?
  210. ECU removal/replacement procedure
  211. Key rolls down all windows
  212. 1998 LS400 snow-worthy?
  213. Is this a red flag on buying this '99 LS400?
  214. I cleaned my headlights with toothpaste.
  215. Code 13: Help!
  216. move along.
  217. Does this sound like a bad starter?
  218. The center bolt for the rotors
  219. Content removed
  220. this isn't the classifieds.
  221. A/C repair costs
  222. Coolant Leak? What is this tube?
  223. 00 LS400 -premium audio - upgrade time - beatsonic vs full upgrade???
  224. 1995 LS400 Starting Issue
  225. Benefit to Air Box Mod???
  226. High-level advice on water pump, timing components
  227. 1990 LS400 Exhaust = HP???
  228. new lexus owner with question about suspension
  229. What is this?
  230. Another Tranny Mount Question
  231. I just bought me another 1999 LS400
  232. whos ad is this?
  233. double din question
  234. New Member
  235. Fuel consumption, sputtering and hard shifting on a 98 LS
  236. Anyone put a Mushroom Intake?
  237. Transmission mount issue
  238. ls400 Speedometer issue - PLEASE HELP!
  239. 98 Ls400, engine runs fine, but no power to the wheels
  240. Looking to buy 95-97 UCF20
  241. just bought a 91 ls 400
  242. 98+ window switch question
  243. Any vender selling complete interior LED and license plate conversion kit.
  244. Repeat Power Steering Failure - 98LS
  245. Ls400 wont run help please
  246. Changing Power Steering Pump on 92 LS 400 Need some Info
  247. 92 ls400 failed CA smog test
  248. 1996 LS400 recent purchase
  249. ignition wont turn
  250. Timing belt change, cracked camshaft-sensor.
