PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Guess who got a Lexus car phone today? This guy.
  2. Driver side front speaker bad? Anyone know?
  3. 1993 Lexus LS400 jerking problem
  4. Should I go through with 97 LS400 purchase?
  5. 93 ls 400
  6. Did I get a good deal?
  7. Help 2 Denmark
  8. 92 1Ls tail lights not working
  9. 1uz good tune in sydney?
  10. 1991 ls400 disable factory alarm
  11. joining lexus fam
  12. Are these CUSCO Coils for 1996 LS400?
  13. VIN number
  14. Harmonic balancer / crankshaft pulley 1UZ-FE and 2UZ-FE... interchangeable?
  15. 99LS Warning light
  16. 90' LS400 crank angle sensor bad??
  17. One heck of a day!
  18. Having some car problem. HELP
  19. Need Help with EGR pipe fix - Los Angeles area
  20. 2 minute fix for some idling & shifting issues
  21. 1UZ Engine Shutting off when temperature rises to half
  22. Story of my first Lexus
  23. UCF20 LS400 Antennas (95-97)
  24. Translation Help Please.
  25. Price opinion on a 98 with 240,000 miles
  26. Humming noise on 99 LS400
  27. need shift knob for 2000 ls 400
  28. 2003 LS430 with 77k miles for 7900$
  29. 1995 LS 400 transmission issues
  30. Looking to join the LS400 club!
  31. Clunking sound and vibrating from rear wheel on UCF1....
  32. MAF sensor replaced but still having issues.
  33. rear bass speaker ls400
  34. 99 LS 400: p1351, p1354, & VSC
  35. Where is the Main oxygen sensor signal on right bank?
  36. Joining the Lexus family.
  37. DIY: All red tails using vinyl, cheap & easy
  38. Insane asking price on a 94 LS
  39. 1994 LS400 running issues
  40. where to find 91 Ls400 front lip.
  41. Eractic idle upon start up?
  42. Gauge Cluster went blackout
  43. Brake question...
  44. Remote key and paint color, LS400 1994
  45. LS400 Oil pump protrusion?
  46. Rust on ls 400
  47. New to ls400, have a question
  48. studio camber roll center adjusters (RCA)
  49. Question on tire size.
  50. Dashboard
  51. Stearing wheel
  52. Front seats
  53. Thermostat Housing Stud/Bolt
  54. '98 LS400, knocking noise in front end while braking & hitting bumps.
  55. gas cap tether for 97 ls400
  56. I need to find vss wire for double din Navigation?
  57. LS400 - generation ZERO!
  58. Transmission stuck in forward
  59. Who's owned their LS400 the longest?
  60. Homemade strut tower braces
  61. Something that I have Noticed: Stock vs Mod
  62. 1993 LS400 Factory Alarm
  63. In the club!
  64. 98 LS400 bass speaker vibration problem
  65. Oh CL...LONG day ahead...93 LS400 Water Pump
  66. LS400 Navigation Cold for Disk ?
  67. Upgraded to the LS430
  68. Possible electrical issue?
  69. New to the boards with a 93 LS400
  70. Bizarre dashboard light problem 1990 LS400
  71. Misfiring
  72. Coolant Temperature Switch (NOT temperature sensor!) - info and a question
  73. Ls400 randomdly wouldnt start and defrost light flashed
  74. Emergency brake light always on
  75. Just bought mine
  76. Replaced Strut Rods and Tranny Mount - Still have highway shake from 65-80mph
  77. Oxygen sensor problem?
  78. ls400 gps problems?
  79. HELP! body work guys! LS400 MAJOR quarter panel damage
  80. redrilled style 95's
  81. 99LS Cabin factory spec sound level in db
  82. 20 bucks thru paypal to whoever answers my alternator question
  83. 1995 LS400 Alternator Pigtail
  84. Have you done the ECU capacitor fix?
  85. P/S leak clarification
  86. ? about a/c
  87. where to get a jdm steering wheel
  88. 95-97 and 98-00 has same exhaust lay out?
  89. Newbie here- '93 and possible ECU and cluster problems.
  90. new bag light problem - code 15 and 41
  91. Bad starter symptoms?
  92. Noticed on my way to work tonight
  93. 1995 Ls400 needs new rear upper control arms..
  94. Ladies and gentlemen, we have a decision!
  95. Rats!
  96. Value of a Ls 400?
  97. Stock Suspension Rebuild - 97 LS
  98. Please HELP, car wont turn on.
  99. 1998 with 104k bizzare intermittent bogging when downshifting
  100. LS400 took a crap on me tonight
  101. code 47 on LS '92 400
  102. 1992 LS400 - Strangely good gas mileage for the state of the vehicle.
  103. ECU and other electrical issues
  104. LS400 Not Starting Please Help!
  105. Considering 60K mileage 2000 LS - Book Value Range is Huge!
  106. A/C noise + installing armrest
  107. Check engine code 25, 28 transmission code 63 trac 51
  108. CRAZY Transmission Problems Help please.....
  109. Oil filter magnets
  110. transmission fluid check, help
  111. Air Suspension switch and sport mode switch not working
  112. Connecting radio antenna to phone
  113. Best year for the LS400?
  114. Cracked windshield 99LS
  115. '94 running rough - Help please!
  116. polyurethane parts
  117. Couple of questions...
  118. 1993 LS400 No spark/no start...Why I'm so confused...
  119. 2013 Chrysler 300 vs 1999 LS400
  120. Please Help ! 1996 Lexus LS400 won't reverse !
  121. changing stock air shocks
  122. 1993 Lexus LS400 acceleration problems please Help!!
  123. Big Ty's LS at Club Lexus meet
  124. r-12 system with r-134a in it
  125. Air Suspension Replaced with coilovers - Normal Light Blinking
  126. aftermarket radio for a 1999 ls400
  127. No A/C in Florida
  128. Wire Wheels
  129. 1UZ from 91 LS400 - Gasket / TB Kit OEM Parts
  130. Buying a '98 some issues
  131. need light blub source
  132. Remote lock & power mirrors broken... Coincidence?
  133. 92 ls 400 idle surging.help please
  134. Opinion on some RonJon 19's
  135. '92 LS400 air bag lite
  136. 99 LS400 won't start, nothing
  137. Older Lexuses: Head unit desirability flips over time?
  138. How much would you pay for a Lexus Ls400 1998-00 ?
  139. LS400 vs GS400 Oil Pan - Same?
  140. Long Time Lurker Finally Became Owner
  141. Lexus issues
  142. UCF10 help
  143. Power Steering Fluid Leak From 1 of the 2 Power Steering Pressure Lines
  144. LS400 Bad inner tie rods question
  145. New to me 98' LS400
  146. factory ls400 window tint
  147. Overheating at idle with a/c on?
  148. Window motor/regulator
  149. Headlights won't work.
  150. KYB Sb104 rear boot is not the correct part
  151. Rear Brake Pad Replacement
  152. HELP - Confusing timing marks!
  153. The all-thumbs, no experience, 1998 LS400 head unit swap
  154. 2nd gen LS400 or 2nd gen GS300 project build?
  155. considering buying a '98 LS 400
  156. Factory Pioneer cutting out
  157. 99 LS400 random misfire/poor performance
  158. Oil question on High Mileage LS
  159. How to properly add coolant 90' LS400
  160. 1st gen vs 2nd gen upper control arms
  161. major coolant leak
  162. non-sunroof 98..?
  163. A/C fans not coming on?
  164. New LS400 owner
  165. Goodmornin clublexus
  166. Introduction - New to the Lexus Community
  167. Flashing panel and motor failing and disconnecting
  168. what size torque wrench is commonly used?
  169. Drivers door lock problem, 1994 LS400
  170. No more SC hello LS...
  171. Gold Pkg On Antennae Factory Only?
  172. RPM drops down and jumps up
  173. LS 400 Static in AM Radio
  174. 2-IS wheels- Would these fit?
  175. 1999 LS400 control arm
  176. set the timing on my 92 LS400 and now it hesitates to start
  177. 91 ls400 no longer starting.. PLEASE READ!
  178. 20x10.5 All Around?
  179. No brainer,right?
  180. 99LS ... Problems with Outside Temp Reading...
  181. A/C out - compressor pulley noisy
  182. CoilOver Question
  183. Replacing Lexus Emblems
  184. ROCA Bushes
  185. 1999 LS400 Radio Install Questions
  186. Bought Friday - KEYED Last Night!!
  187. Looking for easy 12 volt + wire to tap
  188. Just bought a lexus, need help to find this part.
  189. Passenger side mirror broken?
  190. Rear tire wear 1999 LS400
  191. New to Lexus/vip scene
  192. 98 LS400 Cluster removal
  193. 1990 LS400 vs. 2000 LS400 ride quality
  194. what size offset would clear?
  195. Strut mount?
  196. LS400 Radio Problems and Other Electrical Problems after Bag Installation
  197. Ignition Cylinder Problem
  198. steering wheel vibration
  199. license plate lights
  200. Best/easiest way to update tech in 98 LS400?
  201. Raybestos ball joints
  202. Stagg SHS Struts
  203. Low speed stall - hard to restart - my problem solved.
  204. New LS400 parts
  205. Saturday Brain Tease... Odd No Start
  206. New LS400 What Maintenence?
  207. Looking for advice/experiences
  208. Wow.. don't see this very often, Pristine 90 with Low miles...
  209. Hello from Maryland
  210. Thinking about picking up an ls400
  211. 94 LS 400 Car Fire
  212. Whats Good!
  213. Dealer said....replace tranny filter?
  214. getting there :)
  215. Converting to shocks on a LS400
  216. New TB, won't start
  217. my first lexus
  218. Replace Radiator or Reservoir Tank or Both?
  219. Little update on the car
  220. A/C conversion from r12 - r134a
  221. ECU failing HELP!! 95 ls400
  222. Do you guys check your state laws?
  223. Just call me Robert.
  224. Cambered out
  225. Tail light brake light dead
  226. Parasitic electrical draw & active short testing
  227. Will it fit? 2011 IS-F rim (19's)
  228. Low Oil
  229. Joining the LS club again....
  230. Can I upgrade my Headunit with a simple wiring harness?
  231. **1990 LS400 a/c electric problem(HELP)
  232. RPM Gauge - Works/Doesn't Work
  233. My heater smells like gas.
  234. Looking For Parts For my 94' Ls400
  235. Electrical problems with 1994 LS400
  236. Silver to Black
  237. LS400 Dies when give gas
  238. Window motor maintenance
  239. Supra TT Springs Vs LS400
  240. Repair Partially Lit Instrument Cluster Needles
  241. Does anybody have a sort of "plug and play" Supercharger Kit/Turbo Kit ?
  242. EBAY Power steering hoses
  243. Help - rear suspension broken!
  244. wont start
  245. P0420 ...p0430
  246. 1996 LS400: How to Remove The Infamous EGR Pipe
  247. 1992 LS400 won't shift out of park
  248. All dash lights suddenly ON
  249. Pinched my coil wire doing tune-up :(
  250. WTH happened to my car?
