PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Lost 2nd gear??
  2. 91' Lexus LS400 A/C work but it won't automatically on/off (Automatically Control)
  3. Help Me Decide if I should Buy this Lexus...
  4. 92 Lexus ls400 back firing no power
  5. Rear Upper Control Arm Bushings 1995 ADUS 578x2
  6. aftermarket NON-OEM window visors for 1990 ls400?
  7. Brake light off & on
  8. Question about a body panel part on a 90/97 LS
  9. Strange interior light issue
  10. how can I remove the rear deck trim?
  11. Power steering pump
  12. 2nd gen LS400 cup holder functions sporadically.
  13. 96 LS400 A/C ribbon wiring burst. Help
  14. stock subwoofer questions
  15. Audio system info requested
  16. Timing belt water pump. Car backfiring?
  17. Valve Cover Gaskets Leaking
  18. Bushings
  19. Can I replace stock subwoofer with aftermarket?
  20. 97 facelift!!
  21. Catching up on Maintenance
  22. 95+ brakes onto a 93.
  23. what are these mysterious wires?? audio?
  24. Vexed by VIP...
  25. Poly bushings...How bad?
  26. brake issues
  27. Any 2nd gen pics of aftermarket 16" rims
  28. Telescopic feature/Tilt feature
  29. Painting valve covers - 1995 LS400
  30. Put back the OEM mufflers and now car handles/runs better? WTFBBQ
  31. Picture Request(LS400 with newer OEM Wheels)
  32. R-A-P-I-D deceleration from 60mph, otherwise flawless.
  33. 1996 LS400: Engine Fan spinning too freely ?
  34. LS400 shift knob options (unorthodox choices)
  35. Codes 27 and 29?
  36. how to switch from park to neatral when car died
  37. LS400 shift kit.... installed
  38. will 2006 sc430 rims (18x8) fit my 1991 LS400
  39. Two questions: DRL's and steering motor
  40. My new 1995 LS400 125K miles-$3900.00
  41. ls400 has a knock!!!!?!!
  42. Starter repair Running Issue after !!!
  43. Backup Camera Install
  44. 97 vs 98-2000 reliability, etc.
  45. 93 ECU pinout?
  46. Key with integrated fob/buttons
  47. New LS400 Owner(new to the Lexus Brand)
  48. Starter or funky electrical issue?
  49. 1996 LS400 fan blower problem
  50. 97 reset immobilizer?
  51. 1991 lexus ls400 key fob
  52. Disabling steering wheel tilt motor?
  53. Looking for performance suggestions, seems like a rare thing to do.
  54. Wideband O2 sensor placement?
  55. Crankshaft front seal leak?
  56. Starter trouble in 93 LS400
  57. 1991 ls400
  58. LS400 lacks a sporting character?
  59. Shooting the LS400 with satin black paint?
  60. Acceleration and RPM Performance Question
  61. MPG - interesting change to my car...
  62. Looking into buying a 1996 LS400
  63. Running 98 LS400 wheels without centercaps/lug cover discs detrimental? (pic inside)
  64. Looking into getting my 2000 LS 400 vip/customed price questions?
  65. starting issues
  66. Going to do a retrofit on my 00 LS - I have factory hid's - self leveling concerns
  67. 1993 LS400 Lower Seat Rails
  68. Please Help!!! - Blown Head Gasket - Confused - White steam from exhaust
  69. Starter went out without warning?
  70. Question about "thunking" noise and struts for a '96 LS400
  71. coilovers aint coilovers
  72. hi new here!, wanting to semi upgrade all audio things!
  73. Ecu
  74. LS400: myth or legend?
  75. New LS400 owner here saying hello.
  76. Need battery code for LS400
  77. Speedometer not working
  78. 5spd clutch pedal setup
  79. Updating The Stereo System
  80. ANOTHER set of tyres destroyed
  81. Problems Caused From Cigarette Lighter
  82. Uses for an old belt - How to tighten crank pulley bolt for FREE
  83. 1991 LS400 Dash light turned on
  84. is this the car for me
  85. What side skirt is this?
  86. Rear rotor help !!
  87. A Last Hope For The Cell Phone?
  88. Wanting To Switch Antennas
  89. Just picked up a 91 LS400, question..
  90. Low voltage after new battery and new alternator?
  91. Newbie Here Just wanted to say whats up..
  92. please*HELP* ucf10 Power steering problem
  93. 9/14/13 - #ItsYourMove 1st Ever Lexus Car Show
  94. Intermitten hesitation on acceleration
  95. which serpentine belt are you guys buying.
  96. Manual swap 90 ls400
  97. Black out ghost start- #$@* electrical gremlin ?
  98. LS400 vs LS430
  99. White smoke on start-up (video)
  100. Running rough-white smoke
  101. How to tune??
  102. Intermittent vibration when braking...?
  103. does a 92ls400 have a cabin filter?
  104. Rim question
  105. The Modification You Are About to See is Real...
  106. temperature gauge rises
  107. Finally some non iphone photos of my LS -
  108. Batt terminal replacement: Pos and Negative terms?
  109. 92 ls400 steering wheel adapter?? For my custom wheel
  110. Need help with my Timing Belt shopping list...
  111. My wife's 400 turned 200,000 miles earlier this month!
  112. Mystery button under dash
  113. Alternator measured voltage question - in AC and DC mode...
  114. Calling all hotrodders for the 1UZ
  115. 1991 LS400 problems
  116. Front Brakes, Shims and Hardware Kit Question
  117. Transmission possible problems
  118. Where is the Parking Wire on 95-97 LS400?
  119. Tyre Placard and Service/Tune Up Stickers
  120. AT fluids - best test I have seen so far:
  121. 1UZ engine swap
  122. LS400 gauge clusters
  123. 92 LS400 acceleration issues and terrible gas mileage
  124. lock issue, need help
  125. of my LS400 tranny is acting VERY weird! (UCF20/21)
  126. LS430 brakes on a 1996 LS400???
  127. Should I buy a LS400?
  128. black smoke from exhaust when car starts
  129. LS400 Ebony Teal Pearl - New Member
  130. UCF10 axles interchangability!?
  131. Ucf20l..... Ucf20r
  132. Steal or no deal?
  133. 92 LS400 noob here
  134. 98LS problems with my new brakes and rotors ...
  135. About to pull the trigger on a 98....quick question.
  136. New addition to my Lexus Family
  137. Looking for a certain part
  138. new 93
  139. Going Crazy! Please help!
  140. My problem has me completely stumped
  141. LS400 AC recharging problem, pressures won't go hi/lo.
  142. Who sells red/clear tail lights for 95-97 LS400?
  143. 1993 LS400 damage
  144. 97 ls400 how to remove carpet?
  145. How To Set The Steering Wheel Tilt To Fixed Position?
  146. Your thoughts please.............
  147. Mudguards for LS400 1st generation 1993
  148. wedge headlights go on when i step on brake
  149. Cigarette lighter
  150. failed emission help
  151. Suggestions for looking at a Lexus for my son
  152. LS400 Hoonage on TV
  153. Excessive wind noise normal at higher speeds?
  154. Leaking trans fluid/temp gauge going crazy?
  155. Why Does My Ls400 Vibrate After Lowering 1 Inch?
  156. Questions, just changed air filter
  157. Any front lips for UCF20 (95-97 LS)?
  158. A testament to these cars
  159. New Owner '95 ls400
  160. 1997 LS400 - Radio says HELP on the screen?
  161. 99 LS400 Dexron III?
  162. need help! 96 ls400 with stock air ride...
  163. This is exactly why I hate british top gear
  164. '93 LS- dead slow=tried everything. HELP
  165. Guess who got a Lexus car phone today? This guy.
  166. Driver side front speaker bad? Anyone know?
  167. 1993 Lexus LS400 jerking problem
  168. Should I go through with 97 LS400 purchase?
  169. 93 ls 400
  170. Did I get a good deal?
  171. Help 2 Denmark
  172. 92 1Ls tail lights not working
  173. 1uz good tune in sydney?
  174. 1991 ls400 disable factory alarm
  175. joining lexus fam
  176. Are these CUSCO Coils for 1996 LS400?
  177. VIN number
  178. Harmonic balancer / crankshaft pulley 1UZ-FE and 2UZ-FE... interchangeable?
  179. 99LS Warning light
  180. 90' LS400 crank angle sensor bad??
  181. One heck of a day!
  182. Having some car problem. HELP
  183. Need Help with EGR pipe fix - Los Angeles area
  184. 2 minute fix for some idling & shifting issues
  185. 1UZ Engine Shutting off when temperature rises to half
  186. Story of my first Lexus
  187. UCF20 LS400 Antennas (95-97)
  188. Translation Help Please.
  189. Price opinion on a 98 with 240,000 miles
  190. Humming noise on 99 LS400
  191. need shift knob for 2000 ls 400
  192. 2003 LS430 with 77k miles for 7900$
  193. 1995 LS 400 transmission issues
  194. Looking to join the LS400 club!
  195. Clunking sound and vibrating from rear wheel on UCF1....
  196. MAF sensor replaced but still having issues.
  197. rear bass speaker ls400
  198. 99 LS 400: p1351, p1354, & VSC
  199. Where is the Main oxygen sensor signal on right bank?
  200. Joining the Lexus family.
  201. DIY: All red tails using vinyl, cheap & easy
  202. Insane asking price on a 94 LS
  203. 1994 LS400 running issues
  204. where to find 91 Ls400 front lip.
  205. Eractic idle upon start up?
  206. Gauge Cluster went blackout
  207. Brake question...
  208. Remote key and paint color, LS400 1994
  209. LS400 Oil pump protrusion?
  210. Rust on ls 400
  211. New to ls400, have a question
  212. studio camber roll center adjusters (RCA)
  213. Question on tire size.
  214. Dashboard
  215. Stearing wheel
  216. Front seats
  217. Thermostat Housing Stud/Bolt
  218. '98 LS400, knocking noise in front end while braking & hitting bumps.
  219. gas cap tether for 97 ls400
  220. I need to find vss wire for double din Navigation?
  221. LS400 - generation ZERO!
  222. Transmission stuck in forward
  223. Who's owned their LS400 the longest?
  224. Homemade strut tower braces
  225. Something that I have Noticed: Stock vs Mod
  226. 1993 LS400 Factory Alarm
  227. In the club!
  228. 98 LS400 bass speaker vibration problem
  229. Oh CL...LONG day ahead...93 LS400 Water Pump
  230. LS400 Navigation Cold for Disk ?
  231. Upgraded to the LS430
  232. Possible electrical issue?
  233. New to the boards with a 93 LS400
  234. Bizarre dashboard light problem 1990 LS400
  235. Misfiring
  236. Coolant Temperature Switch (NOT temperature sensor!) - info and a question
  237. Ls400 randomdly wouldnt start and defrost light flashed
  238. Emergency brake light always on
  239. Just bought mine
  240. Replaced Strut Rods and Tranny Mount - Still have highway shake from 65-80mph
  241. Oxygen sensor problem?
  242. ls400 gps problems?
  243. HELP! body work guys! LS400 MAJOR quarter panel damage
  244. redrilled style 95's
  245. 99LS Cabin factory spec sound level in db
  246. 20 bucks thru paypal to whoever answers my alternator question
  247. 1995 LS400 Alternator Pigtail
  248. Have you done the ECU capacitor fix?
  249. P/S leak clarification
  250. ? about a/c
