PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. '99 LS400 Catalytic converter
  2. No more tape adaptor!
  3. Transmission Pan
  4. 1st Gen Key Remote
  5. Anyone seen Ls400 with ccw replica
  6. New member, Lots of issues.
  7. master window switch will roll down but not up passenger window help!
  8. white smoke on startup!
  9. 1991 antenna function?
  10. removing rear phone antenna? 94'
  11. Best aftermarket radiator for 97 LS 400
  12. '93 ride height query
  13. 1997 LS400, Annoying Noise form engine/transmission
  14. List of repairs that go well together:
  15. Front Upper Control Arm Bushing
  16. Help!
  17. Rattle Fight front fender
  18. Better alignment than Lexus suggests
  19. Power Window Programming
  20. Will Poly Sway Bar Bushing, Reduce Sway?
  21. 1st Gen Interior Lighting
  22. Adding oem drl relay
  23. Door Ajar Switches
  24. 1992 LS400 DUAL Climate LCD
  25. steering wheel movement 1994 ls400
  26. Please help me out Guys- car shuts off
  27. Hello!
  28. Thank you all!
  29. 1990 ls400 160+k
  30. New Ls400 Silver EyeBrows
  31. 430/400 seatbelts interchangeable
  32. 1997 LS400 170K miles, Coolant Leaks, alternator not charging, ...
  33. new here, whistling noise, HELP
  34. Code 13, and yes I have searched the forums. THIS MAKES NO SENSE!!!
  35. Am I looking at ECU related issue, fluke, or something else?
  36. Starting Issue Click and then dead
  37. 1998 LS400 rpm (engine speed) at 60 & 70 mph
  38. Fuga de agua ,
  39. i just bought a 1994 LexusLS400.....i need advice/input!
  40. Partial outage
  41. ls400 ac not blowing at all
  42. Blown 80A fuse now issues
  43. Ignition key does not turn
  44. Are Toyota Steering wheels interchangable?
  45. Timing Belt Done - Is my car knocking?
  46. Thinking about purchasing a '94 LS400
  47. DYNO my Stock 1994 LS400
  48. Rear spring & damper removal
  49. reset immobiliser
  50. new member from South Carolina... HELP
  51. Can this be fixed?
  52. Can someone confirm this site?
  53. New member from Canada
  54. 2000 LS400 problem with steering wheel adjust
  55. Anyone had a climate control go bad? NOT the typical LCD bleedout
  56. recommend me a replacement for PB Blaster
  57. 94-97 fit1st gen
  58. jdm vs american seatbelts
  59. contectores del sensor radiador
  60. RCR tail lights on a UCF10
  61. Recently acquired LS400 ~ some questions
  62. Sensor on radiator
  63. Replacing Cam Seals, please help?
  64. UCF20 - Rear Suspension Typical bushings etc???
  65. Idler pulley and Tensioner Pulley for 1996 LS400
  66. Audio Service Mode revisited
  67. Lexus / Toyota - shared parts
  68. another offset help thread
  69. 99 ls400 wiring harness
  70. l990 Ls400 throttle problems
  71. 96 vs 99 Timing belt change
  72. Buying a donor car for my LS400
  73. 94 LS400 Suroof Assembly Removal
  74. Fitting UCF20/2LS rear adjustable absorbers to UCF10/1LS
  75. Cooling fan bracket
  76. electrical problem
  77. A few problems- steering, memory and lights
  78. The Night before Christmas
  79. simple abs bypass?
  80. Ayuda ubicacion caja fusibles ls 400 1992 electroventiladores
  81. Rear seat removal
  82. Coil Conversion Process - Post Swap ABS & TRAC LIGHTS
  83. Water in car during heavy rain, 1995 LS400
  84. Check engine light and Trac light flashing
  85. 97 LS w/nakamichi - no sound - how do I troubleshoot amp?
  86. Loose steering
  87. Rear speakers not working after new head unit install
  88. 1997 LS400 256k miles and heat takes a long time to get working?
  89. How does your car idle?
  90. electro ventiladores
  91. 97 LS400: Under-dash fuel-door release broken
  92. Power Steering Replaced
  93. Can anyone identify this?
  94. Time to retire the LS?
  95. A few suspension (and brakes) questions (first gen ls400):
  96. What happened to OEM list left here by LScowboy?
  97. Megan parts
  98. Transmission cooling hoses
  99. 98 LS400 Niggles
  100. What would I be getting myself into...?
  101. '92 LS 400 Knock Sensor
  102. front wheel bearing replacement
  103. Fitment Help
  104. fixed smoking and powersteering leak.
  105. How to Remove Console PRNDL Bulb
  106. Valve cover gasket tips! (especially for DIY)
  107. Need help.. Hessitation under hard acceleration
  108. OEM rain visors
  109. Need a part # and advice
  110. I thought this was an interesting find....
  111. Introduction
  112. PLEASE HELP 90 LS400 stalling
  113. 1993 LS400 Problems. Please HELP!
  114. Weir Oil leak Hoping to Find source Pics attached
  115. Life of a Fan Clutch
  116. Help! Locked out of trunk
  117. tilt steering noise fixed
  118. 1995 ls400 trac off light is blinking slowly
  119. Stripped fan clutch nut
  120. 95 ls400 with 3rd gear light on in drive
  121. Planning 1000 mile trip. Advice needed
  122. New Noise after Timing Belt Change - Ideas?
  123. 98-00 ls400 ocv filter change
  124. TRAC Code 43
  125. Driver Seat Sensor Switch
  126. TRAC Light Code Look up
  127. Leather re-upholstery question
  128. Need part #s and links.
  129. Help with speedo and trans issues
  130. Neutral saftey switch bypass?
  131. Possible upgrade.
  132. 1st Lexus
  133. 99 LS Throttle Body question...?
  134. EXample of what clean looks like - 95 with 112k
  135. 98-00 mirrors on a 95-97...
  136. Audio slightly upgraded - happy ending
  137. 90-94 Aftermarket Suspension Arms
  138. close to crackin the case! RE: Driver's side door Lock + window issue!
  139. 92' LS400 intermittent problem
  140. 1999 LS 400 steering column rattle
  141. Transmission interchangeability help!
  142. My nightmare continues... crank pulley leaking coolant?
  143. I have a starter replacement question for the group
  144. Help! Door Actuator issues for LS400
  145. Timing, Tensioners and now Radiators?... oh my! HELP! Pics inside
  146. tires question
  147. overheating ls400 1998
  148. Just bought a 1998 ls400 Previous owner was using regular unleaded fuel for awhile
  149. Auto UP/DOWN for all 4 windows on 1LS?
  150. You know what grinds my gears?
  151. 94 LS with 90 Motor Swap - no power. ECU?
  152. Oil leaking from timing cover onto pan gasket?
  153. Debating on mounting sparco fixed seats
  154. Another issue: Radio dies and lights dim when I press the brake
  155. Dash trim kit labels
  156. Aftermath of Spark Plug Install
  157. changed some fluids, now runs rough?!
  158. Jumping Idle
  159. Heater blows cold at idle - fixed
  160. Engine and transmission mounts?
  161. front brakes come on on thier own
  162. Dash Repair Advice - Pictures Included
  163. 1994 Lexus LS400
  164. 92 LS400 S14 Zenki Foglight Mod
  165. Raybestos LBJ update
  166. beck/arnley oem ball joint?
  167. headlights out of alignment
  168. replace stock radio up-to-date
  169. First winter ride
  170. ucf20 temp/aircon control unit into ucf10
  171. RPMs rev and car jumps
  172. My 00 UCF21
  173. Pick 'n Roll (I need tire suggestions)
  174. type t-iv
  175. 91 LS400 Leaking Oil Bad. Crank seal?
  176. how to clean in window rail?
  177. aftermarklet keyless
  178. Little Quirky Issues(Warning lights, Auto Window)
  179. Front control arm
  180. 95 LS 400 - Transmission Problems?
  181. Fuel system flush.... Better results than expected!
  182. quick tranny fluid question
  183. Rear Wheel Issue
  184. Front Passenger Auto Up Window Issue
  185. Driver's side Window goes down when the Door is unlocked
  186. best way to mount height sensors for aftermarket air?
  187. LS 400 Misfires on 1 2 and 8 plus 300 random misfire tried a lot.
  188. winter oil and fluid maintenace
  189. removing trim-guide?
  190. major problems 1999 LS400
  191. LS400 forum vs GX470 forum - observations
  192. 96 LS400 adding heated seats?
  193. starter job.
  194. Wont go pass 1100 rpm in drive
  195. 93 LS 400 not starting
  196. 99 LS400 - Good Value?
  197. New here...with info
  198. How Does Lexus/Toyota Do It? - To any potential Lexus owners
  199. Audio ?
  200. Failed smog, high HC levels
  201. Cabin Air Filter Change 96 LS 400
  202. 97 LS No Start - Checked a bunch already - missing anything?
  203. dash lights acting wierd.
  204. steering wheel auto retract making noise
  205. Lexus 3d logo for andriod. COOL!
  206. cel code 13
  207. What Parts to Replace - Rear Suspension, First Gen
  208. 2000 ls400 heated seats not working
  209. just finished starter install
  210. 1991 LS400 timing belt kit advise, please
  211. TRAC-OFF light always on. Need quick help!
  212. Steering wheel not retracting?
  213. Did the Toyota dealership just rob me?
  214. Where to find orange light cover?
  215. Ucf10 headlamp washers
  216. $3 that every LS400 owner should spend
  217. 95 ls400 CEL p1600
  218. Ucf20 headlamps on ucf10
  219. LS Almost Stalls When Coming to a Stop?
  220. Brake Squeak Noise and Shim Kit
  221. Right rear camshaft plug seems to be leaking...
  222. Rotated Tires Today Found a Few Issues Need Some Advice
  223. Trans Fluid Type
  224. 93 ls400 dies after timing belt repairs...
  225. 1996 LS400 Wont start with key
  226. Speedo and tranny wacked out
  227. 1991 front suspension tightening torques?
  228. Transmission mount and fluid
  229. Floor mats.
  230. Mildred the 92 LS 400.
  231. Help! Sway Bar Bushing Replacement
  232. What would YOU pay?
  233. 1995 LS400 intermittent rough idle and stalling
  234. replacing fan clutch bracket ls400
  235. 1995 lexus ls 400 making noise
  236. Transmission has a unique problem, HELP!
  237. LS400 Power Steering Idle Up Valve
  238. 96 ride height
  239. Need To Replace Bank 1 Sensor 2 P0136 For Code
  240. possible inner tie rod???
  241. Cat converter questions
  242. 93 LS 400 Severe Lack of Power - Where to start?
  243. What do you love about YOUR LS400?
  244. Lucked into a $450 Steal... or a money pit?
  245. was going to be used as a beater....now what?
  246. Members from CT
  247. Buying a steering wheel
  248. My LS400 is making some rather unflattering sounds
  249. I will catch some flack for this but... Maaco. Yes. Amazing Price.
  250. Soooo finally test drove an LS460... Still love my 400 though. :)
