PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Lexus LS400 seats
  2. Does my '94 LS have a factory alarm?
  3. New member. Pictures of the LS400.
  4. 96 Celsior Oil leak - To change Timing Belt or Not to ?
  5. '00 service manual cost
  6. 98-00 wooden steering wheel in a 95-97
  7. 2000 LS400 Trailer hitch questions
  8. Headlights gone nuts
  9. 91 LS400 fuel pressure drops fast after shutting engine off
  10. 1999 Alpine Silver Metallic paint code WITH other paint code?!?
  11. Power steering groan gone after oil change?
  12. 1993 LS400 Needs Timing Belt/Starter
  13. ECT button
  14. New to Lexus. 97 Ls400 Coach. Any advice?
  15. I need a pro assistance with a part for my lexus ls400 ...
  16. Rearview mirror with compass?
  17. For those looking; posted yesterday
  18. Test drove a 78K mile '00 Platinum today
  19. ride height sensor how to test?
  20. which type of timing belt kit should i use
  21. Type of suspension
  22. 99 LS400 ... Need After market radio assistant ...
  23. need help repair shop mess something up with my 1992 ls 400
  24. 2000 LS new bushings in the rear, which ones?
  25. the truth about LS400
  26. Looking for aftermarket wheels
  27. Buying ls400 with possible...
  28. Doors lock and unlock at random!!! help
  29. Installed an S204 (06-07 sti) Lip on my 95-97 LS400 *PICS*
  30. Lexus LS400/Klutch SL5 9.5''
  31. Good cheap speaker replacement for 90 LS400??
  32. weird front tire wear
  33. Why ACV on PS Pump Fail
  34. PS Pump Rebuilding - Piceses Left Over
  35. Gearbox shifts, engine response and economy lights
  36. 94 ls400 temp gauge issue..
  37. Looking for a Valve Adjusting Tool Kit
  38. 1994 LS 400: how do i improve my gas mileage?
  39. Need help, mysterious electrical problem.
  40. Rear deck sub replacement recommendations for 99 LS400?
  41. Is $250.00 for a new 1999 LS400 key to get cut unreasonable?
  42. Ignition key, not coming out when engin turned off
  43. floor mat sizing question
  44. Does 98-00 interior come in grey and blueish grey
  45. Brake Pulls
  46. 98 ls400 smoking real bad after pcv replacement
  47. 1990 Lexus LS 400 Rack and pinion replacement
  48. Our real nice '94 was hit hard passenger side. Would like to repair it but...
  49. Original 90 owner / tranny replace
  50. Any way to run an external line input via the CD changer?
  51. Speaker for factory sub location?
  52. Time to get rid of codes
  53. Diy cheap $5 chrome grill mod
  54. ...green ain't mean compared to red.
  55. just got a 95 ls400
  56. 97 LS400 fan temp switch sensor ..Bottom Radiator..
  57. Car theft anti-deterrent or ???
  58. Water in spare tire well?? Help
  59. Just bought a "new to me" LS400
  60. O/D off light is on, pushing O/D button does nothing.
  61. 1990 LS400 tail light failure box with pictures
  62. Back to life!
  63. Headlight leveling..? What the heck?
  64. Both my 95 and 98 ls400's have standing water in trunk??
  65. 1993 ls400 nakamichi radio aux jack?
  66. help stereo and a/c are not working
  67. Hack a valet key to make a master?
  68. Real quick question - 95 Can you turn off the auto-dim mirrors always??
  69. hood & bumper bra for 95-97 VS 98-00
  70. Replacement key fob on 99 LS
  71. Aftermarket pump for headlamp washer pump and motor?
  72. RCA's Max size with stock wheels?
  73. 1990 ls400
  74. 96 LS 400 Blower fan wont turn on
  75. Fixed my damn power steering!
  76. Greetings from the caribbean!
  77. Searched and searched. Having Alt/electrical issues. Help.
  78. 1999 LS 400 stays in 4th gear
  79. problem removing the high pressure hose from PS pump
  80. New to the Forums
  81. Current value, 98 ls400
  82. Pls help! 93 ls400 fuel issues!
  83. LSpho's: exhaust mod possibilities -thoughts?
  84. Soon to be new-to-me LS owner
  85. Burning smell at higher RPM.
  86. Strange issue -found- leaking differential seal
  87. LS400 shift knob
  88. gearbox changeability
  89. shifter for 1993 ls400
  90. my favorite cabin air filter
  91. 1990 Lexus LS 400 Drive shaft Leak?? Flexible Couplings
  92. How much does a resonator delete cost 90 ls400?
  93. 1994 LS400: i need instructions on how to change the front turn signal bulb....
  94. My LS400 On Cut Springs!!! Rides Same As Factory!!! Check It Out!
  95. OEM wheel choices for LS400
  96. 1997 ls400 front end clunk
  97. Car is sluggish, faster with MAF unpluged?
  98. Hello CL members
  99. strange issue ebrake and trac light on
  100. Bleeding brakes help
  101. What would you pay for a 2000 w/79K?
  102. Will these rims fit my 97 LS?
  103. Adjsuting front caster
  104. LS400 92 When giving gas hear valves clanging
  105. Power Hick up?
  106. High wind noise
  107. 95 LS…are they expensive to own?
  108. Possible opportunity on a 1997 400
  109. 90 coolant temp sensors - need clarification
  110. 98 corner light?
  111. Australia - Wollongong - ECU problem
  112. Major problem with new taillights
  113. New Build Threads area for LS400 owners
  114. Question just bought a ls400
  115. 2JZ VVTI SWAP first ls400
  116. Non interference 1UZ question.
  117. Top speed endurance question
  118. Quarter wave length resonators
  119. Speedometer way, way off.
  120. Part number of power steering solenoid gaskets
  121. ignition
  122. LED sockets?
  123. Exhaust smell in the cabin ('90 LS400, 160k)
  124. The future of our cars. The Ls400 in 2020
  125. UCF10 headers
  126. HID headlights flickering
  127. Manually ajust tilt 90 ls4??
  128. 93 LS 400 Severe Lack of Power - Input Please
  129. 90 ls400 tilt stopped working help???
  130. Parking brake- Please to god !!!! Help......!
  131. pic request: 98-00 stock body dropped on 20"
  132. Questions about P1346, MOA, and OCV.
  133. Ssr Vienna/Euroline Help
  134. Suspension besides coils?
  135. Ride height sensors, self leveling HID, while being lowered
  136. Speed sensor not working?
  137. Charging system problem
  138. Fan shroud necessary?
  139. Lexus gave me a new( To me ) ECU
  140. Diamond white pearl paint question..!
  141. HELP! Which is the better buy? 99 LS400 or 00 LS400?
  142. Telltale signs of a Headgasket?
  143. 94 LS400 ABS Code
  144. need help with factory CD player
  145. 98-00 LS400 powered driver seat motor/driver out!
  146. Hi, new here and looking to go from a 6MT 05 Acura TL to a 98-00 LS400
  147. pulled out some hair
  148. 5 speed trans shifting Q
  149. Camshaft & Crankshaft Sensor Location 1992
  150. Air Suspension Conversion Update
  151. Excessive RPM at Idle
  152. Suspension and wheel fitment
  153. Is this true? once the ECU is fixed it can never be fixed again?!
  154. Ect. Power/snow/Econ
  155. No electrical power whatsoever
  156. Question just bought a ls400
  157. Has a water pump leak
  158. New to the LS side
  159. ECU compatibility help
  160. rapid beeping from dash?
  161. ls400 differential question
  162. Tips? Rotor won't go on
  163. Catalytic Converters...Help PLEASE :)
  164. Ls400 seat help?
  165. What do you guys think? Should I get it?
  166. 98 Ls400 Headlight bulbs
  167. Remote Start on 98-00 LS400
  168. SERIOUSLY considering purchasing an 98-00 LS400! GIVE ME THE RUNDOWN guys!
  169. Double-Din radio/nav in a 98-00 LS400? Is it difficult?
  170. Correct way to install spark plug tube gaskets
  171. UCF21 ignition coil resitance
  172. Need seats!!!!
  173. 1UCF10/11 headlights 2014
  174. LS400 Towing discussion thread!
  175. Relocating: How should I prep my LS?
  176. LED DRL's for '98 LS400
  177. Poly/Plastic Fender Vents
  178. Ol Ford for a LS400
  179. Upper Control Arm is needed!
  180. how much fuel is left in the tank when the "low fuel" light comes on?
  181. so who has the earliest one?
  182. VSC off
  183. Interchangability of FLCA ball joints?
  184. Engine stumble continued
  185. Solar Sensors - A/C
  186. Uneven Pad wear- Odd
  187. 1994 Lexus LS400 MAINTENANCE
  188. Removing Dashboard (UCF10/11)
  189. Rotor size - '97ls
  190. CD changer removal from upper glove box UCF20 RHD Celsior
  191. 1996 LS400 no heater fan and phone/radio issue?
  192. Cam Phaser
  193. New LS400 for $1800
  194. 18x8 6" +40 offset will they fit 90 ls400
  195. Please Help - Parking (drum) Brake Replacement
  196. sad day.
  197. Auto climate control issues
  198. 1993 LS 400 Not Passing Smog
  199. How to change battery wires
  200. Australian LS400/Celsior Rollcall!
  201. 95' maf safe to clean?
  202. brakes!
  203. Power steering hose blown
  204. New Lexus owner LS400 1990 Problems please helpp
  205. airbag not working?
  206. No sales-here
  207. ls400 complete bulb code list?
  208. Hood struts- Need help
  209. Toyota Emblem on a UCF11
  210. BAD brake drag 2000 ls400
  211. 90 ls400
  212. Extended studs/Spacers
  213. 95 Ls400 funny smell...
  214. 1995 ls.Looking for a car cover that really hugs the whole car tight
  215. Rear autoshade retrofit
  216. Exhaust System
  217. removing rear parcel/sub shelf
  218. My 2000 LS audio upgrades
  219. Treating air suspension bladders for longevity?
  220. spark plugs and issue
  221. Bumper repair- Looking for Suggestions
  222. Radiator Hose
  223. 91/95+ rear caliper difference?
  224. Battle Version products or Megan?
  225. changing out the green
  226. 1996 ls400 Steering wheel no in and out?
  227. First gen front strut rod adjustment setting
  228. misfire slow pick up
  229. Tranny fluid dipstick measurement help
  230. Feedback on ls400s I am looking at (merged threads)
  231. in trunk air vents
  232. Strange brake pedal
  233. Bleeding brakes on 2000 ls...fronts or rears first??
  234. stupid question needs stupid awnser.
  235. LS400 with SC400 Motor Help
  236. speedometer/vsc light/check engine light
  237. Ignition LED Bulb Replacement Question
  238. Wire Harness in Trunk
  239. Help!! Lol Sheered off idler pulley bolt
  240. cowboy's favorite LS400 tools series
  241. Newbie with a question!! Steering column noise
  242. tire wear question
  243. Time for New Struts and Springs?
  244. 1UZ and 3UZ oil pans the same?
  245. 97 ls400
  246. I want to tow a pop up camper???
  247. Megan Coilovers on 95' LS
  248. Trunk Won't Close. Help!
  249. 1997 LS400 Camshaft Position Sensor Problem
  250. Viper 5101 remote starter with smart start on 97
