PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. Gabriel shocks/struts - your experience pls
  2. 1998 LS400 Instrument Cluster circuit diagram urgently needed
  3. 1998 UCF21 HID Headlight Flicker *Please Help*
  4. 96 LS400 Speed sensor location
  5. 91 ucf10 air line bypass
  6. driveshaft coupler ?
  7. Will this transmission work on my car?
  8. Parts in australia
  9. Just noticed something cool..
  10. love this car!
  11. ACV valve vacuum lines - I lost one.
  12. Quick Question. 1uz broken motor mount
  13. 1st Gen LS400 Steering Damper - you want to read this!
  14. Rear Axles dislocating/breaking
  15. No advertising
  16. The Ls400 registry
  17. The Search Continues - Am I being too picky?
  18. So just how many are still out there??
  19. Was this an LS factory option of aftermarket?
  20. problems fixed,now upgrades?
  21. My fuel consumption - normal?
  22. Is Possible to get to get the Master Code list for Ls400
  23. Any ideas why my transmission fluid needs is dirty... AGAIN???!
  24. weird issue with multi display..
  25. LS Cloth interior
  26. IS250 wheels on LS400
  27. New LS400 owner here, new to the forum
  28. Alternator questions
  29. differential/transmission
  30. Question for Yamae or someone who knows - 1990 ls400 speedo and tach low by 10-20%
  31. Will a Celsior pass smog in California?
  32. Code 1120
  33. Camber issues, front LCA bushing?
  34. What is this small emblem?
  35. LS Starter problems? PLEASES READ!!!
  36. Moonroof
  37. Is there a Lexus guide how to inspect struts for wear?
  38. 94 vs 95 ECU
  39. Intermittent grinding.
  40. Stumbles - Weird occurence, thoughts??
  41. 1uz-fe egr/agr
  42. Armrest Squeak Fix
  43. Alternator diodes test fail
  44. Helppppp steering wheel
  45. firmer shifts 2000 ls?
  46. Cost to Fix Exhaust Manifold Leak
  47. Potentially picking up a high mile 98
  48. Timing belt marks off.
  49. Definite guide to upgrading 1st gen LS400 front brakes to 2nd gen
  50. Need urgent help with ABS sensor on front wheels gen 1 to gen 2 upgrade
  51. Abnormal high idle 2k and above.
  52. auto headlight and highbeam not working
  53. Just picked up a 94 LS 400 for $400!
  54. A/c + Fuel Consumption LS400 95
  55. How long have you been with your LS400 so far?
  56. 93 ls400 rpm issues
  57. What Eprom chip does a 93/94 ls400 use?
  58. bouncy LS400 after converting from springs to air suspension
  59. '98 for sale. Not the best pics
  60. Sunroof electric motor location?
  61. low revs
  62. Saying Hi, New LS owner
  63. 2000 ls400 auto leveling lights going too high
  64. 97 LS400 vibration
  65. 92 ls400 no reverse drives in neutral
  66. 98 ls400 rear rattle + shake at 50 & 65 mph
  67. P0130 & P0133 Help/Advice appreicated :)
  68. Steering wheel motor issue....1994 LS400
  69. vibrating/rattling noise that goes away when AC on
  70. Help Please Coolant in Intake Manifold!
  71. new here with my 98 LS
  72. Steering wheel - Vibration
  73. Wheel fitment/Tire sizing
  74. Conventional Oil in HOT climate:5W30 or 10W40
  75. ECU from SC400 in '93 LS400 ?
  76. I Pulled the Trigger - 98 LS with 97k miles
  77. airbag light flashing..?
  78. tilt wheel stopped working 2000 ls400
  79. Freeing up some mpg, power, and sound
  80. 1996 LS400 RADIO LCD display needed?
  81. temp reading high on startup
  82. 1993 LS400 blower replacement
  83. oem upper control arm(ucf20)
  84. Coilover height adjustment question
  85. 91 ls400 HELLPPPPP!!!!
  86. LS400 differential rear end howling noise, bad wheel bearing?
  87. need help with fuel smell?
  88. Drainage Line Leaking In Trunk?
  89. 1992 ls400
  90. Battery or Alternator?
  91. Inner front tire gouged
  92. Help Lexus engine oil
  93. Nardi steering wheel
  94. hard to start in the morning.95 LS
  95. Sticky speedometer
  96. Any 95-97 owners have Depo clear headlights
  97. 96 LS400 headlight bulb questions
  98. Click noise from shifter
  99. Survivor for sale
  100. new motor
  101. OK I am confused - A 4 speed 98?
  102. CD Changer location?
  103. 1997 ECU Replacement - immobilizer concerns
  104. 94 ls400 overheating issues
  105. knock sensors 92 ls 400
  106. A/C problem - Compressor lock
  107. disable telescope but not auto tilt?
  108. The LS does drive pretty nice
  109. new to ls400 code 55 and 71
  110. new owner : couple questions
  111. 1993 Lexus LS400 Gas Gauge Problem
  112. I think we are a little obsessed
  113. Reliability on 98-00 LS
  114. Looking to do something with my exhaust
  115. new to the ls had a mk3 supra just meed some help
  116. 91 LS400 AC question
  117. "P" and "N" lights controlled by neutral switch?
  118. Immaculate 98 LS - What would you pay?
  119. Window Busted
  120. 98 coilovers on 94 ls400 work?
  121. engine light
  122. Blower Motor & Radio Problems Solved!!!
  123. Question about changing cam seals on 98 with VVT-i
  124. How do I replace the bulb in my front side marker light.
  125. How tough is it to remove the front grille? 97
  126. 1993 LS400 Problems after shop timing belt/starter change..
  127. How To Recharge A/C Ourselves?
  128. Help with ABS Wheel Speed Sensor
  129. 19x11/19x10 wheel fitment issues
  130. Egr tube woes
  131. Weird ignition problem
  132. blower motor control module How do you get to it?
  133. NEED HELP - title your post appropriately...
  134. Blower motor, radio and panic button all of the sudden do not work?
  135. O2 sensor wiring to ECU - pls need help
  136. 5 speed question 98+
  137. Water leak and interior lights don't work
  138. lower control arm??
  139. ls400 starts then dies. i dont know where to start
  140. 91 LS400 ECU. Is it better to rebuild or replace?
  141. Annoying intermittent hesitetation (mostly in cold)
  142. A/C lights blinks
  143. HUD for 1993 LS400
  144. Replace Fogs and Vibration on Start Up
  145. new here
  146. 94 LS400 Stalls when A/C is on?
  147. Suspension Maint.
  148. Console PRNDL lights work sometimes.
  149. New LS400 owner here
  150. Best $20.00 in a long time...
  151. 99LS400 P0161 code ... O2 Sensor , can I replace without new cat?
  152. Finally bought a 95 LS - Bad news needs rear differential - Where to find one
  153. Pumped Wrong Octane gas
  154. No climate, no clock, no outside temp, no lighter? WTF?
  155. Air conditioner issue? Ls400 '94.......
  156. using the car phone again.
  157. Lower Ball Joints 98 LS400
  158. Cannot separate UCA ball joint from steering knuckle
  159. Anyone have problems with valve clatter?
  160. seatbelts stuck in extended position
  161. Auto leveling VSC ABS warning lights
  162. Lights on warning buzzer location?
  163. Fuel Filter change '98-'00
  164. Ripple test questions...
  165. 1996 nakamichi stereo wiring diagram?
  166. Need brakes! 1999 ls400
  167. 1Gen 20 inch tire size dilemma
  168. EGR CEL on 1993
  169. my AC issue thread
  170. Looking at Buying a 97 in Canada
  171. 95 ls400 car alarm going off randomly
  172. To those running 95-97 clear depot headlights
  173. Accuair height sensors on a 95-00 LS400! Done!
  174. Oil pan interchangeable?
  175. 91 LS no start, no power to fuel pump relay!UPDATE TO MY 91 LS400 no start!
  176. New Set of Tires Recommendation Please
  177. LS Brothers! Help me decide!
  178. Will a 22 inch rim fit a 2000 LS?
  179. dash warrning light problem
  180. Help please - will it go to 250K miles?
  181. Looking For Advice On Parking Regularly In The Sun
  182. clock Spring/ spiral cable
  183. What is missing here?
  184. Strut Bars + Impact wrench
  185. 97 LS steering wheels shakes above 55mph,ONLY W/ A/C ON!!!!!????
  186. Deeza inner and outer tie rods
  187. anyone know if these godspeed coilovers will fit?
  188. Coming out of an Audi, looking at Lexus alternative... :)
  189. My new LS400!
  190. 92 Ls400, Clock Stereo problem.
  191. LS400 Immediate Stall after start-up
  192. 1999 LS400 leather seat
  193. 1997 front rotor help please!
  194. coilover question
  195. Engine Won't Start...'96 LS400
  196. ECU vs ECM
  197. Bodywork Q
  198. Help! Stuck with UCA and struts
  199. Started the car up and squeeling.
  200. UCF11 Megan LP Coilovers
  201. 1994 Lexus LS400 antenna
  202. 1990 LS400 Brakes upgrade to 2nd gen
  203. Require help identifying this outer grille trim
  204. 1997 Radiator, Spark Plugs, choose which maintenance parts?
  205. 1996 issues please help!
  206. 1990 Ls400 transmission problems
  207. Temp Gauge pegged hot after speedo & tach repair
  208. Wheel fitment
  209. 97' ls400 bad coolant leak
  210. '00 alarm help
  211. Key fob not working after dead battery... 98 LS400
  212. No spark on driver side plugs
  213. New to forum
  214. rear bumper removal, searched
  215. Widest front tires on UCF20?
  216. Goodbye 2000 LS400, Hello 2014 Sienna
  217. Leaking onto my exhaust...
  218. Cam Specs for '90-94? (they're in the Shop Manual)
  219. 253k miles on original timing belt! Beat That!
  220. To Chrome, or stay home?
  221. tuning software
  222. 98 keyless entry programming: options?
  223. Reverse Lights dont turn on...
  224. Advice Needed on 2000 LS 400
  225. Japan yahoo auctions HELP!
  226. Was the UCF10 LS400's platform used for the GS, SC, and MKIV Supra?
  227. Seat belt comparability
  228. Wheel Set Question
  229. 91 LS400 Cluster Issue
  230. lamp failure sensor black box keeps blowing
  231. Lost 91 Keys
  232. 2000 LS400 Platinum
  233. Aftermarket steering wheel and cruise/airbag
  234. Start/Off concerns
  235. 1996 ls400 totally dead in driveway
  236. Need AC service
  237. Is this a rear alignment issue or just normal for the LS
  238. 1997 LS400 Won't start
  239. how to remove mirrors?
  240. Service History (Canada)
  241. Got 16" wheels for a 1990 LS400 - what to do about speedo?
  242. Power Steering "Cooler Line" leak
  243. Aftermarket stereo question???
  244. Howdy Everyone - o2 Sensor Question Here
  245. IACV Valve
  246. Mystery steering shake on highway
  247. 94 LS400 Dies while driving. ECU caps? fuel?...
  248. My new 20 percent tint job!
  249. Lets play the what would you pay game!
  250. How to unlock trunk with spare?
