PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Need new catalytic converters
  2. Tail Lamp Failure Warning
  3. 1995 LS400 Aftermarket Stereo retaining Nakamichi AMP
  4. If you were one of the LS400 engineers?
  5. 90 LS400 Gas Fumes in Cabin
  6. Engine seal kit
  7. ECU service information
  8. Help !!!! - clicking when trying to start
  9. Where do you lift using Floor Jack
  10. 95 Ls400 Knock Sensor Wire Location in ECU
  11. Rear Wheel Going out of Alignment??
  12. 1990 ls400 value
  13. Where to find exact fit carpet kit for 91 ls400?
  14. Has anyone tried this ATF??????
  15. Problem with locking driver's door
  16. New seat belts?
  17. REAR Stabilizer Bar Link - OEM or Other
  18. Brake Calipers - How Urgent?
  19. Winter Tires/Wheels
  20. 1996 LS 400 Mirrors VS 1998-2000 models
  21. Alternator Replacement Info provided
  22. Engine oil light comes on when door(s) is open
  23. How would you feel about buying a 1998 LS400 with 244k?
  24. please help! doors flying open!
  25. HELP!! Ucf10 cv axle popping out
  26. Best 1/4 mile time so far....
  27. ls400 alternator or fuse issue?
  28. Engine mounts on 96
  29. Rear Bumper question
  30. car accident
  31. New LS400 owner!!!
  32. Thinking of selling - Should I or nah? how much?
  33. Trouble Selling High Milage LS400
  34. Full Throttle Behavior
  35. Engine cable / Line got cut while driving
  36. Abs
  37. Widest Tire on 1LS
  38. automatic choke
  39. Rebuilt power steering pump, now vibration
  40. 92ls400 Big problem! grinding noise, low idle..
  41. P0171 & rough idle after changing starter 98' LS
  42. Another Dash Light Bug
  43. the LS400 disease.
  44. mk4 sc300/400 subframe in ucf10?
  45. 93 LS400 Drift - Easiest way to lower gearing?
  46. Is wheel track the same
  47. Soon solved my bad lightning issues!
  48. Brake pad wear light questions
  49. Head rest question
  50. Speedometer reads slow after repairing needle illumination
  51. rpm drops during acceleration
  52. Looking for alinement specs
  53. Help with these symptoms- code 25, 26 low idle
  54. Where did you get replacment ac compressor?
  55. Who sayis there are no great 2000 LS400's left? Right here!
  56. How do i take this off -fan bracket sub assembly
  57. Air shock front 98 fit on 96?
  58. Odometer question 92 LS400
  59. Ecu doesn't ground Fuel Pump Relay
  60. Just replaced the starter in my 1995 LS400, brutal
  61. From start(er) to finish
  62. Code question
  63. Car randomly gets warm
  64. Blower motor / A/C clutch
  65. Sway Bar Links brand ( does it matter ) ?
  66. 95 ls400 cd changer not working not playing
  67. In trunk cd changer
  68. what do you guys think of this? Tons of dealer maint. city driven ok?
  69. Could crappy gas be my issue?!
  70. Naming your threads.
  71. ECU Swap...when is "reprogramming" necessary? (Any other ECU replacement advice)
  72. Help! Thump when letting off gas
  73. Throttle Position Sensor Faulty
  74. 1993 LS400 Electrical Problems
  75. 1992 LS400 questions
  76. Glove box question 90-94
  77. consistant driver foglight dies
  78. Please help me! Erratic-won't run after ECU change
  79. LS400 Automatic Transmission Fluid help
  80. Driver low beam headlight not working
  81. rebuild 97 LS400
  82. just did timing belt engine sounds kinda like a diesel please help
  83. 1993 LS 400 Seat power
  84. Interchangeable parts- 98 to 91 interior??
  85. What else should I replace?
  86. Need a louder car! [exhaust]
  87. 1995 Ls.Is it that hard to chnage the T -belt?
  88. Eletrical system issues
  89. Need help this afternoon 9/18 - Air Intake hose ripped
  90. need help identifying component
  91. 1991 won't start due to theft control starter kill?
  92. Thinking of buying an LS400
  93. If you were needing a transmission..where to buy?
  94. engine misses
  95. Engine Code 25 - O2 sensors? capacitors? EGR pipe?
  96. Headliner removal forward of sunroof?
  97. No Heat or AC....HELP! 91 Ls400
  98. Hit and Run
  99. Wiring diagram needed, amp drain found 00 LS400
  100. LS400 wont drive?
  101. Double glazing
  102. Front BBK to the extreme?
  103. dumb question. ..but 15-40 oil?
  104. Car won't go into park or reverse without pushing in safety switch near shifter?help!
  105. Heater/AC problem
  106. Repair Manual
  107. key help please
  108. Accessories on when the ignition is on?
  109. Question about No. 1 idler pulley
  110. Wiring up New Amplifier to Stock Pioneer Amp Harness? (1994 LS400)
  111. Any tips for power wire through firewall?
  112. 1994 LS400: New Brembo Rotors.....which brakes to use now?
  113. LS400 overheating and possible knocking?
  114. Front Passenger Window
  115. Gearshift getting stuck on neutral after tranny oil change
  116. 1994 LS catalytic converter Replacement
  117. 1998 LS400 rear seat armrest panel
  118. 94 LS400 223000 miles Egg smell?
  119. 1995 ls400 differential noise with video
  120. Ucf 10 gated shifter+ucf 20 style center console(pisc)
  121. Need some help on finding out who makes these wheels.
  122. My First Lexus: 1993 LS400
  123. No start / Electric Gremlin SOLVED! DTC Codes 14 & 15
  124. My ebay chrome grill 95 ls 400
  125. Are all the LS's in bad shape?
  126. LS400 Bucking and Won't Pass 50% Throttle
  127. Leaking Antifreeze?
  128. Leaping 98 LS 400 with 368K miles on it.
  129. nakamichi cd player help
  130. LS400 Front Swaybar modification - Your thoughts needed.
  131. must share - small fuel filter makes big difference
  132. non wood package 98 convert to wood?
  133. What is this leak?
  134. My car will not start...
  135. 3UZ Timing belt/Water Pump/Tensioner fit 1UZ?
  136. Headlight leveling on dashboard
  137. 1998 LS400 HVAC unit buttons not backlit after installing new radio
  138. Failing engine, maximum speed of 3000 rpm and red exhaust, what can be?
  139. Added PS Stop Leak - Reservoir Now Empty
  140. 99 LS400 overheating
  141. Anyone ever chnage their drive shaft bushings?
  142. Tranny wont shift while headlights are on...
  143. BMW Style 95 fitment question
  144. interior lights not working (dome light, foot well)
  145. Brake warning light on, now off, need help
  146. Seatbelts? where to buy
  147. Ls 400 coolant leak
  148. Improving the look of a worn steering wheel
  149. Tuning & Throttle Body Gasket
  150. Key Will NOT go all the way in to START CAR
  151. Coverking seat covers
  152. Introduction into the Lexus world
  153. Ls 400 (1994)power steering pump & alternator replacement
  154. Quick question regarding key less entry
  155. Steering Wheel Mod
  156. Lexus LS 400 1994 Unusual Idle when at traffic light?
  157. "Mooing" noise at idle
  158. Alternator Wiring
  159. Radio and Keyless entry doesn't work - 98 LS400
  160. got my first Lexus ever, need some help
  161. TRUNK LEAK - and how i found & solved it
  162. 96 LS400 Oil Leak
  163. Will 1993 brakes rotors pads fit a 1995?
  164. aftermarket stereo and factory sub
  165. Rear Strut Rod Bushing Repacement - GEN1
  166. UPPER CONTOL ARMS - Useful info
  167. Toyota ATF T-IV vs T-II
  168. Help - AC questions
  169. 94 vs 95 transmissions.
  170. Airfilter drenched in coolant?! Help?
  171. LS400 Cabin Air Filter and No more smoke smell!!!
  172. Can I put a 99 GS400 engine into 97 LS400?
  173. just found this article
  174. LS400 dont go sometimes.
  175. Replacement keys for 2000 LS400 - ebay ok?
  176. vsc lights on after I use OBD scanner
  177. Repairing Gauge Cluster
  178. 1991 lexus ls400 starting issues
  179. Time to replace the head gaskets
  180. 1994 LS 400 wiper blades
  181. Parts interchange-95 GS to '93 LS?
  182. ABS and VSC issues on a 1998 LS400
  183. will a 96 r/f door window fit a 99 ls400
  184. My New Toy Car! Did I get a good Deal?
  185. What years interchange with a 92
  186. Poor running and check engine light after cleaning maf
  187. looking for a maintenance manual..
  188. 1995 ls400 grill on ebay.What do you think
  189. Coolant leak - cancer can not be cured?
  190. Winter tires stretch?
  191. New to me 1995 LS400 172k
  192. '98 windshield onto a '95
  193. '99 400: Noise when brake pedal depressed, car stationary.
  194. Failed smog! Air injection failed
  195. runs rich, cuts off erratically above 2500RPM
  196. ls400(ucf10) seems sluggish
  197. Powering electric seat with no power to car
  198. 97 ls400
  199. JDM Upper intake man. has fuel line ?!!?!?!?!?!? PLZ VIEW PICTURES
  200. ucf20 badge less grille
  201. Bad light from aftermarket headlights
  202. 94 LS400 runnin rich HELP
  203. Broke battery tray bolts... Suggestions
  204. Antenna hole diameter?
  205. Lexus Throttle Body Extended Warranty
  206. Kik down
  207. No spark, ecu related?
  208. Trany noise
  209. Swapping interior of a tan 1995 LS to a black 1997 LS
  210. Can i use a 91' transmission in my 93' car?
  211. Hesitation at low RPM & Shaking at Idle
  212. Center arm rest storage lid won't stay closed...
  213. Coolant Level Dash Light
  214. need a measurement of 2nd gen wheel hub:
  215. How I fixed my Soft Brake Pedal (99 LS400)
  216. LS400 Track car styling
  217. 98 LS loud bang on speedbump in front after lowering!
  218. Maintenance cost- Help!2000LS
  219. Paint removal, Front bumper flaking/chipping
  220. i need to know if gs300-gs400 steering wheels fit
  221. 1992 UCF10 Radio dead, fuses ok.
  222. '96 LS400 A/C restricted air flow? Freezing up?
  223. 1uz eating belts
  224. 96 alternator wiring harness plug
  225. ring and pinion install kits for LS400?( Supra MKIV differential installation)
  226. My Dumb Low-Speed Bumper Collision--Any Cheap Fixes?
  227. 91 LS400 How hard should turning be?
  228. 1994 LS400......transmission fluid needs replaced
  229. Water Leaking from passenger door is this a common issue?
  230. Another Fuel Gauge broke.
  231. 91 LS400 Power Steering Dead at Idle
  232. 93 ls400 help please - overheated
  233. OBD2 Scanner
  234. Post-crash Air bag R&R question
  235. 96LS Instrument Cluster Needles Tears out!!
  236. Thinking of selling, pls help me value car(s)
  237. Cleaning LS400 front/rear windows, seriously
  238. 1991 LS400 no start issues "Heeellp"
  239. please help--worth it?
  240. Keep it or Sell it
  241. 1996 LS400 tranny issue? Hope not
  242. Question about lowering springs on my '99 LS400
  243. HELP me fix a high idle issue 1300RPM+?
  244. Just got my first 1990 Lexus ls400
  245. Better rear lift point than diff?
  246. 1uz twin turbo manifolds
  247. Can the infamous EGR leak cause a/f lean mixture code 25?
  248. heavy black caked gunk intake manifold and ports on head
  249. New Club Lexus Member, Long-Time Lexus Owner
  250. Missing bolts?
