PDA
View Full Version : LS - 1st and 2nd Gen (1990-2000)
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
  1. That New Car Smell On A 95 LS400!?
  2. PLEASE HELP--fog lights and driver seat--
  3. Help Check VSC
  4. 235/55-17 tires
  5. Across the country in a 900k-mile LS 400...
  6. Shortened spindles
  7. 2000 LS400 foglight removal
  8. Saw her on the corner and decided to pick her up...
  9. Am I seeing this correctly?
  10. rims without rolling fenders
  11. Officially A Proud New Lexus LS400 Owner!!!
  12. oil leaks 93 LS400
  13. UCF10 beeping
  14. '98 LS400: question on coolant filler plug
  15. LS400 MY 1995 AC Bypass Belt to use PN KO60630 6K630
  16. Trailer hitch with extra attachment points
  17. 96LS400 Cam sensor #2
  18. Another LS Radio Problem
  19. Thank you guyz!
  20. How to Play iPod, iPhone in my '98 LS400
  21. noise from the vent and sunroof while driving...
  22. Gas tank location 93 Ls400?
  23. Moisture / water in lights
  24. Coilovers vs springs/shocks ride comparison
  25. Need help asap transmission gasket leaking.
  26. Front Bumper cover
  27. Looking for ideas...
  28. Suspension questions
  29. Puzzled
  30. Minor Fender Rolling on 98-00
  31. Molding Paint Color: Black Onyx & ?
  32. 1994 Lexus ls400 Nightmare!!!!
  33. Sooo this happened today. 90 LS 400
  34. 98 LS400 electrical problem
  35. afm mod 92 ls
  36. 98 LS400 Keyless
  37. Ideas
  38. 95 LS400 help
  39. Some questions about struts and lowering springs
  40. UCF20 Complete DIY Rack N Pinion Tutorial
  41. 1991 LS400 Project - Question...
  42. 1st Gen vent visors 4 piece
  43. Bad gas from Kroger, anyone?
  44. Check your engine & transmission mounts
  45. Transmission Solenoids Gone Bad?
  46. LS400 Passenger Foglight (Well side to foglight)
  47. Picked up another blk/blk ucf20 last night
  48. Reliability?
  49. Major Electrical PROBLEM
  50. 91 Ls400 died while driving
  51. HELP 1995 LS400: Did i bend valve/s?
  52. New Power Steering Pump on 99 LS - No Steering at Idle - Air in lines??
  53. Random Wierdness: temporary stalling
  54. GS400 engine in LS400?
  55. front air shocks interchangeable from 94 - 99?
  56. 1991 LS400 for daughter
  57. Crashed LS--Dilemma
  58. Help with front strut bar bushings (48674-40051)
  59. Transmission fluid in coolant
  60. Rpm reading low
  61. Blitz Access ECU
  62. Need Help
  63. Fuel Tank Capacity
  64. Wheel fitment Question
  65. 98 ls driver side mirror replacement help!
  66. 1998 ucf20 ls400 single exhaust system
  67. Air bag ?
  68. First drive and couple brakes squeal
  69. Air Suspension from a 93 LS400 in to a 91
  70. New to Club Lexus. Strange noise above 3k RPMs.
  71. Please post side profile H&R + Bilstein
  72. Proud LS400 Owner :D
  73. advice on rear brake discs
  74. Cylinder locations, miss fire
  75. 90 ls 400 idle problems
  76. Easy way to check timing belt on a '99?
  77. Best online dealer for OEM parts?
  78. Hello from new owner - 2000 LS400
  79. Weird '98? No heated mirrors, only wood shift lever
  80. power antenna replacement
  81. Garmin in an LS400
  82. questions on driving habits
  83. Best setup for ride/comfort
  84. Correct Center Caps for 2000 LS400?
  85. Observations from 2000 mi. road trip
  86. Nakamichi Amp? 1999 LS 400
  87. Passenger heated mirror
  88. LS400 differences in years
  89. 96 LS400 wiring for horn with nardi
  90. 96 LS400 - Conversion from Air Sus to Spring
  91. 1991 LS400 Randomly won't start, just cranks and cranks?!?!
  92. Engine mounts - how subtle can the symptoms be?
  93. used car quality index
  94. 98 Ls400 opening door with broken spring tutorial.
  95. A650E gearbox mods
  96. Transmission oil temperature
  97. Power steering pump whining
  98. Caster arm rubbing on inner wheel
  99. Water spewing out open near gas filler
  100. check engine light
  101. Shift lever problem
  102. Right rear door does not unlock by remote or unlock switch
  103. Carfax vs Autocheck problems on LS400
  104. trunk release switch not working
  105. Fuel Gauge Problems 1997 ls400
  106. New to Club Lexus and finally a LS400 owner
  107. Groan/whine at idle. Not PS.
  108. took throttle body apart, cant figure how to put it back together
  109. P0340 after timing belt install
  110. exhaust leak question
  111. 96 Celsior- Shock leaking
  112. QUICK Q about an Idle Air Control Valve 91' ls400
  113. Reverse Lights
  114. Goodbye to my LS400
  115. replacing headlamp/turn signal on 1994 ls400
  116. Help!! 1996 LS400 Slow Accel, White Smoke, Replaced ECU and Deleted ACV
  117. 92 ls400 interior gas smell
  118. What to EXPECT for a new Buyer. (Your REVIEWS)
  119. how to remove front bumper
  120. Found on Craigslist: An Off-Road-Ready Lexus LS400
  121. Advice for potential 98 LS400 buyer?
  122. Remove these suspension braces?
  123. 91 ls400 diff question
  124. No classifieds access yet.
  125. '99 LS with codes and intermittent rough idle...
  126. UCF20/21 Charging issue
  127. Replacing Pioneer head unit with aftermarket HU (Sub working)
  128. Bimetallic Vacuum Switching Valve Thread pitch and size??
  129. 95-97 corner light
  130. NAK factory upgrade how much and is it worth it?
  131. 1990 ls400 Atf
  132. 1998 LS400, faint burning oil smell
  133. Needed Instrument Cluster
  134. what years front seats the same?
  135. looking for 1995 LS400 exhaust headers
  136. Lexus sc400 1992
  137. No, starter! 98 ls400
  138. Transmission Drama
  139. Battery Woes!
  140. Led conversion kit issue
  141. HELP! :( IACV? TPS? ECM? Dies cold, High idle warm.
  142. Unicorn hunting. in search of early build date 1990
  143. Major discovery on my 92 LS400
  144. HELP ucf10 vs ucf21
  145. UCF20 Blown Head[gasket]
  146. A/C runs in winter with heat on.
  147. HELP-car cutting off while driving
  148. Non OEM power steering pump for my 2000?
  149. key stuck at acc
  150. Broke Radiator. Can it be repaired
  151. Aftermarket wheels...will they fit?
  152. My first Lexus a 1991 LS400
  153. 1996 LS400 EGR questions?
  154. Spark plug wire question (too many?)
  155. LS400 ac not working
  156. Need help for 1996 LS 400 mass air flow sensor
  157. In the market for an LS400 Need Advice...
  158. Corner Running Lights?
  159. Tire Tuck
  160. Center Air Vent Question
  161. replacing rusted part of brake line
  162. NEED HELP: Moonroof Stuck.
  163. need help please - traction control.
  164. Steering End
  165. Modern seats for LS400 ???
  166. DIY negative camber setup w/ adjustable megan arms
  167. How do I replace hood latch on 90 LS400?
  168. Another Vibration thread... Replace the drive shaft???
  169. '93 LS400 removing the phone
  170. Removed Stereo, Strange Issue Popped Up
  171. mashup bumpers
  172. Which Replacement Power Steering Pump to Buy?
  173. cheapest way for better sounding exhaust
  174. Clicking noise from front of vehicle
  175. Hood lift struts 1st gen
  176. The moment you realize... (Feeling the turn signal relay in dead pedal)
  177. 2000 LS400 Nakamichi HELP!
  178. 1Uz Oil Pump, Wrong O-Ring?
  179. How to run new speaker wire to doors
  180. '98 Lexus LS400 issues - sputtering
  181. 93 ls400 ignition coils
  182. HUGE electrical heart attack!!!
  183. Is this the sunroof drain tube in trunk?
  184. 1997 ls400, starts and runs for about 10 seconds then dies
  185. 02 pre-cat sensor/s test procedure - Yamae
  186. P.S. Fluid LEAK help!
  187. New LS400 owner with questions
  188. Old School - Lexion 201's
  189. Heated seats ?
  190. Started checking #2 1990
  191. how can i test my 94 ls400 fuel pressure!!??? PLEASE HELP!!
  192. Ucf20 ride height
  193. 1 Gen steel wheels ?
  194. Front end metal scraping sound
  195. 99 LS not starting until multiple attempts! Help! It Clicks!
  196. Intermittant Slow/weak starter?
  197. Dim Dashboard Brakelight
  198. 1991 Dash Gear Indicator Light Issue
  199. Proud new LS owner :)
  200. Tips on Cleaning Panels below shift knob
  201. timing mark confirmation
  202. Help identifying heater valve 87240-50050
  203. CEL code P1346 and P1351 Atlanta Mechanic Recommendation
  204. humming noise at idle + air cond
  205. New to club lexus and new lexus owner
  206. Parts car, anyone?
  207. new to club lexus and new lexus owner
  208. 1993 aussie LS400 electrical manual
  209. Should I change the valve stem seals?
  210. 92 LS400 rough idle and bogging
  211. 1994 LS400.......front lower ball joints needed!
  212. Ss rca 1st gen question...
  213. 94 Celsior Fuel Pump ECU Location
  214. Built In FM Transmitter - Anyone Try?
  215. Turns Over, Wont Start - 94 JDM Celsior - HELP!
  216. Replacing O2 sensor on 98 LS400
  217. Changed an Oxygen Sensor - car running much better
  218. Starter engaging when R is selected
  219. NEED HELP - Lexus 98 LS400 starting problems (replaced battery and alternator)
  220. LS400 on the Track #quartermile
  221. 99 LS CD Changer (Pioneer) issue NEED HELP
  222. HELP: stock body panel removal
  223. Is this a good deal on a 00 LS400?
  224. Power steering pump noise
  225. clicking noise under engine load
  226. Ambient Floor Lighting!! #retrofit
  227. won't run in the morning
  228. Just wanted to Share with the LS crew
  229. Doors interchange?
  230. Anyone experience this 1st gear issue before
  231. Side mirror plug
  232. 1991 Ls400 Strange Noise
  233. 1uzfe Bad Serpentine Belt Tensioner?
  234. Front end lower ball joints?
  235. Are the Michelin Primacy MXV4 still the recommended all season tire here?
  236. No passing gear?
  237. Car dies when shifting out of P? Car has 897k miles!!!
  238. CD changer- Error 13 showing. HELP!!
  239. Replacing steering knuckle (with everything on it)
  240. 98+ Ignition Coil-test?
  241. A little confused on instrument cluster repair
  242. Need advice LS 400 - purchasing
  243. New to the Lexus world- need adivce - buying.
  244. Headlight leveling on dash board of a 98 ls 400
  245. I wanna lift my Lexus 2"
  246. Alarm and Transponder disabled
  247. Gasket covers with timing belt
  248. Replacing Lower Ball Joints w/ or w/o Control Arm (1996)
  249. suspension diagonosis/symptoms
  250. Power Steering leak comedy of errors
