- Driver Seat Power Adjustments
- Poor fuel consumption
- Cel p0505
- Cel light p0171
- P0755 tranny code.. high rev shift at 40mph
- Rx350 rims on Rx300
- Dash brake warning
- Door Lock Fixed
- 99 rx300 key tumbler stuck on ACC
- Transmission Clunking
- ABS Problem
- Honeycomb grill wanted as my next mod!
- Glove box?
- 2001 RX Transmission Failure?
- CEL/VSC lights and then cranks , no start
- 2002 Lexus RX300 AWD Questions
- Fading Information Screen
- Scan Gauge II
- Need to uncut the key..info anyone
- Rx300 won't idle
- rx tail light issue
- Passenger side door lock
- Which Servo ?
- Replacement Master Remote Key Question
- Strange Grinding sound from under the car.
- brake caliper bolt spins
- location of ECT sensor
- Which extended warranty company?
- a/c problem
- Side marker
- New Member, Introduction, Help?...P1130/P1135
- lighting headlamp/tail lights any help would be kool... thanks appreciate it
- fast idle problems
- Question about 99-03 RX300 Tail Light
- HELP!! What Offset for 22" wheels?
- rx300 problems
- Brake issue - chatter, grinding...
- very base RX
- Driver's Window Sticks
- stock front door speakers upgrade? Worth it?
- Headlight Trim
- Need help ASAP!!!
- Lubrication points?
- Part-NO BOFW02087 ?
- Antenna craziness
- New owner of 2001 Rx300 (with pics)
- Are transmission problems common?
- Was your lexus Rx300 the most reliable car you have ever purchased?
- Transmission service
- P1135 Code: Replace sensors in pairs??
- Winter tire pressure?
- What trim or package do I have? 2002 Rx300 black on black with Aluminum Trim
- New Underdrive Pulley for 1MZFE motor
- Glove box hard to close
- My 02 Rx300 has a P0136 CEL
- Which 16" toyota rims fit an 01
- key in my hand, car is off and locked, info screen is still lit
- HID lights to hot?
- DIY: Door Window Removal and Window Rail Window Motor Removal
- REbuilding Air Mix Servo
- '01 RX300 Airbag Light is on
- Knock Sensor Question
- got bored n took some pics.
- Product recommendation for those who live in ethanol or E10 states
- Car jerks when put in reverse
- Emergency Brake Question
- Timing belt change tools and tips
- Aftermarket Stereo for '02 RX300
- Left rear marker light
- newbie heat help needed
- Electrical Issue
- Brighter Headlights
- how to run power to the trunk?
- Demount headlights?
- Drivers Door Lock/Window
- Low beams on headlights will not work. help!
- what is this?
- Fluid leaking into the inside of my rx300
- rx300 transmission
- removing valve cover
- CEL code confusion
- Door will not open from inside! Help
- Please Help!!! How to install double din head unit?
- any good power steering leak sealers?
- ABS problems
- exhaust leak between cat and mufler
- Starter?
- rear suspension noise when turning
- Transmission Lines
- Is this a rear main seal leak?
- deceleration shimmy
- HELP: Cleaned IACV and now car barely stays on | High res pic inside
- Come to find out rear differentials was the cause of the Vibration...02 lex rx
- time is getting to me with my RX , maybe time to move on?
- Cylinder #2 misfire mystery
- Rear bumper "top" replacement
- OCI with synthetic oil in this engine???
- I've never seen this part on the rear seats
- RX00 in GTA San Andreas
- what type of oil leak is this?
- Stolen car part be on the look out!
- Cel p0171 and p0420
- Adding Off road lights? More lighting questions...
- Cel p0171,p042
- Just an observation
- DIY: Measuring air/fuel sensor resistance
- Passenger Side Engine Noise
- tint help
- navigation swap?
- Dropping RPMs and rumbling while stoped
- Numerous CEL codes - need advice
- 2000 RX300 AWD engine whine
- replacement ignition key
- My RX 300 Heating doesn't work
- slight VIbration From a dead stop
- Air Mix Servo
- Reset CEL by disconnecting battery
- CEL codes P0171,P0441,P0440
- transmission repaired
- Cruise Control Comes and Goes
- Need Tires. any suggestions?
- Any DIY Timing Belt Change Info?
- Hi From the UK
- Nav-owners: important question
- Key remote lock/unlock do not trigger front and back lights.
- Is my O2 sensor really bad? And cost to replace(No Engine light, low mpg)
- Are You Kidding ??
- 2005 RX I just bought
- Tein Lowering Spring
- How to Correct Camber on Front End?
- Looking to buy
- hardwiring V1
- Transmission finally went.......
- CEL Error codes on 99 rx300
- Can you add a heated seat to a 2001 RX 300?
- Front Lower Member Brace and Rear Anti-roll Bar / Rear Sway Bar ???
- Antenna mast and motor
- Change wheel bearing or hub as well?
- Trans Cooler?
- '99 RX300 misfire blues (wanna give it a try?)
- Taking fuse out to reset CEL
- Toyota - Lexus parts interchangeability - need advice
- RX300 2003 Radio code
- Parking brake light does not go off.
- Please help - transmission failed
- Timing Belt?
- Conventional oil
- rx 300 emblems
- Engine Rough..Cat Turning Red..Codes P0300, P0303, P0304
- Transmission Filters Which is best ?
- Timing belt and whatelse needed 107k mileages?
- Transmission Failure?
- Minor issue with my 2001 RX 300
- radio wont turn ON
- Timing belt and water pump
- Whats the difference between the 01 and 03
- Transmission fluid change?
- Rx300
- DIY: Replacing air/fuel sensor
- 2009 Navigation update
- Steering Wheel Upgrades?
- Stubby Antenna Upgrade?
- Alarm System Problem
- Sparkplug Life
- '99 RX300 - Gauge fuse blows frequently
- Sway bar end links removal - need help
- Alternator Removal
- Sludge Claims
- Doing a Trans rebuild I got a great deal!
- Any auto parts store the stock A/F Sensor?
- Ignition Coils
- Changing rear brake rotors
- Engine job done, so far so good, fuel pump?
- 2002 rx rear suspension noise
- I have about 5 questions about my rx from suspension to A/C system to my DTRL - Help?
- oxygen sensors and exhaust leak
- Hey Guys, Front Map Light Issue!
- 2003 RX300 hard to start & stalls when low on fuel
- 235/65-16
- potential rx300 owner
- New guy question about door lock . .
- brake lights out
- "Coach Option"
- Need some brake job info RX300 2001
- Oil filter change
- Code P1354 Help Please
- Oops! Snapped off a rear caliper bolt!
- Our model is getting old. Replacment parts
- Tear in the rear suspension boot
- Anyone have seen this problem on a RX 300 ?
- stripped rear differential fill allen bolt
- Auto-RX which oil to use
- Noob with some questions
- Air Conditioning Fan speed stuck on full blast
- Rebuilt engine/sensor questions
- Oil strainer and filter
- Rear Wheel Hub Assembly
- 2002 RX 300 PCV Valve
- Noise from back tire when turning
- Center isle Heater / AC Issues
- Easy fix for groaning antenna
- Question on Power Steering Fluid and Steering Noise.
- Knock Sensor questions
- US RX is showing celsius sometimes
- Shift Quadrant Indicator Lighting
- '01 RX300 - broken rear seat latch - help?
- Transmission Question
- Shifting Question?
- Fault code on my 1999 Lexus RX300
- Front Strut Replacement - Misc Comments
- Hello from So-Cal!
- Kumho or Yokohama tires ?
- Adding a Towing setup to an RX300 AWD
- 2002 RX300 2WD trans problem
- When do coil packs fail?
- Brake pad changing question!
- 2002 rx300 auto light system
- T-Stat and A/F Sensor Replace?
- Is starter or ignition swhitch?
- Fluids - How old is too old??
- Old rear differential leak????
- Where to get genuine lexus parts
- Squeaky steering wheel
- cabin air filter
- help. problems with remote central locking
- Question: Just Did The Brakes Pad DIY.
- Rx300 2001 Exhaust Flexpipe Help!
- More engine issues....damn it's electrical too!!
- P 1130 Please Help
- Switching to mobil1 synthetic 0w-30
- Ques on MAF sensor,O2 sensors and Fuel Injection Service.
- Time for timing belt(s) on a 2002 RX300...Help
- Question for Lexmex on Castrol Syntec
- DIY roof rack
- Difference between 99 and 2000 RX Snow/Power and Snow Button
- gear stays in low gear. HELP
- $2596 later, transmission rebuilt with 116K miles
- Alignment Adjustment
- Question on Oil Filter
- RX300 with new engine still using oil
- DIY Oil Change
- KYB Quality Issues
- cruise control blinking
- RX300 AWD Transmission symptoms
- Newbie question
- Driver window issue
- Amp Wire Diagram
- Ceramic brake pads
- RX300 Engine/Trans problems: Widespread or not?
- Help! Did I strip the oil filter screw on the engine????
