- More 'dark' videos with faster times
- Clublexus sticker on my RX300
- Hello from Florida
- Brembo Blank rotors for RX300
- RX 300 Crash!!! Pics Included
- Class Action Suit re: Oil Gelling
- General Questions about Brake Job (Pads and Rotors)
- Rear wiper - no wash fluid out nozzle
- what rims and combo for rx?
- What are my headlight options??
- Question regarding parts for struts and mounts repair!
- Low coolant reservoir
- Yokohama ADVAN S.T. 235/55/18
- broken attenna motor
- What do you do for a living?
- This car is getting to me..
- Transmission Diagnostic
- stupid kids vs. rx300
- License Plate Lights
- car is dying out
- Does anyone have any recommendations for when I change the struts and mounts
- 00 RX300 w/ 48K miles $16.5K ?
- Kumho Slolus Tires for RX 300???
- 2008 RX350 something to wait for!
- Engine oil leak after trani overhaul- coincidence?
- Auxillary setup for RX300, need my Ipod
- Km vs. Miles ;o)
- Heater / AC Blower Fan not working...
- 01 RX300 HID headlight replacement?
- New owner help. P1133, rims/tires, light clunks.
- Do you guys follow the Lexus-recommended 30psi for your tires?
- Probably been covered but a little help would be appreciated!
- Are these LED tail light brighter or dimmer than stock tail lights?
- Brake Pedal Clicks
- 2006 navigation DVD
- PLEASE HELP ASAP!!! (emergency brake question)
- 30 More Horses !!!!!!
- Getting nippy and have some remote start questions
- Discount OEM Parts Source
- Exhaust noise at idle
- Small vehicle speed record.
- third brake light
- Towing Capacity Question
- brake problem?
- Best Tires
- What do you use to make the RX300 look its absolute best?
- Tough Question, maybe someone can help.
- I'm on a roll tonight, haha
- That Magical Button that says Power and Snow
- Oh if only...
- who car is this?
- Check Engine code PO440 PO446
- check engine code PO 440 PO 446
- Starter went bad -Installing new one tonight - Need Hints/Tips
- rx 300 cd changer problem
- Do I Keep the RX300 or Get Out??
- RX 300 won't shift from 2nd to third when cold
- OBDII code P1153
- Angel Eyes, a little confused
- Looking at a 2000 RX300 - Have Questions...
- I Have NO HEAT - HELP
- Rear Pads and Rotors - RX300 AWD Brakes replaced
- JUST bought a 2001 RX 300 on Friday
- few issues with my new used rx
- Nav problem please help !
- 112 mph fuel cut off
- My new bunghole and resonator
- Transmission, af sensors
- RX300 replacement battery?
- CD Cartridge
- New Here, need advise
- Are window switch console clips replaceable (broken)?
- Speaker Wiring Diagram Needed
- a/c problem
- Oil Filter Location?
- Resonator?
- Somewhat poor gas mileage
- RX300 can't stay started
- Parking lights not flashing
- Videos from the track
- Removing the mudflaps...
- Downpipe modifications
- Thinking of Michelin LTX M/S tires- input
- Pics of the Brembos...
- Trying to decide on a car....
- Removing the gray at the sides of the 300?
- Brembos and Akebonos installed today...
- Out of warranty goodwill trani repair from Lexus
- RX400H rims possible?!?
- bank1 o2 sensors?
- Transmission Preservation Driving Techniques
- Help Cel Light Help
- Remote key locks/unlocks all doors except drivers
- How to remove rear rotor on 2002 RX300
- Oh my, look what UPS just left...
- Won't Start after Timing Belt/Spark Plug Replacement
- Oil Problem
- want to buy new chrome 17" wheels
- transmission failure RX300
- Air Flow Ratio Sensor - 2001 RX 300
- Storage compartment rubber inserts...
- Got Charged for Warranty Repair
- Should I take the plunge?
- Purchase Fuel Injector?
- New to forum looking for advice
- Considering a switch from GS400 to RX300
- Cost of timing belt?
- would you guys get this?
- getting ready for major maintenance
- Almost a new record
- put on my kyb and teins springs...
- 255/55-18's on 35mm offset rim do fit
- 1999 RX300 need help/advices... too many codes
- Hazy Headlight Lense
- Nav Display Garbled
- lexus dismantlers?
- RX Harrier emblem!?
- Phase 1 of My RX Transformation... BIG PICS
- Dropped my pan today...
- Washing the RX300's private parts
- Rear Alignment
- best oil filter for rx 300 replacement
- RX 300 navagation system
- Out of warranty trani failure update from Lexus
- antenna stuck in up position
- Air/Fuel Ratio Sensors
- Ignition Switch Locked
- RX Roof Racks
- Need help with paint....
- More Tranny Info
- Wheel Fit Question
- p1725 code ???
- Attention all Transmission Pan Droppers
- Engine Check Light is ON. #2,3 Misfire
- Aftermarket Alarm???
- Any recent buyers can share price info?
- # of pistons on brake caliper
- RX300 door trim / weatherstipping
- Possible O2 Sensor cheaper fix. Oxygen Sensor.
- WANTED A/C Compressor 99RX
- anybody with kyb gr-2?
- In need of owners manual
- Finally got pics (20 inch rims + intrax drop kit)
- 17x8 rim fit issue and tire size
- Tailgate Rubber Mat
- 02 rx 300 replacement carpet
- New Owner rx300
- Replacing FOG Light Bulb in RX300
- Catalytic converter Warranty??
- help needed for aftermarket stereo install
- Quick Pos/Neg question HELP!
- Brake lights completely out
- Transmission failure 1999 Rx300 AWD poll
- alarm sound
- 2003 rx300 remote/alarm
- Coolant Replacement Question
- 2001 rx300 dtc p0120
- RX300 Husky vs Weathertech Cargo Liners
- Brakes, pads and rotors? Help Please.
- Indicator Lights
- Moonroof grinding
- intro - shopping for a 300
- Factory Nav Install
- 01 RX300 Check Eng Light???
- GS Out, RX In
- 2001LexusRX300 check engine light on
- Idle air control valve
- Overfilled transmission
- Yellow "light out" indicator bulb is on, but why?
- New RX300 Owner Here
- trani clunking when shifting from D to R
- Dice IPOD Integration kit 2000 Rx 300
- Secret Weapon Intake
- 99 RX300 Rear Wheel Area Noise/Knocking
- Change Thermostat?
- Should I buy an 02/03 RX300?
- Lights & bulb help on RX300
- pass. seat front bolts
- p 1135 and p1130
- amp
- IPOD Integration kit 2000 Rx 300
- Anyone dealt with Luxorymods.com?
- Aftermarket Nav
- XenonDepot HID Conversion Kit : 6000k XenonDepot HID Conversion Kit
- wheel stud
- Got my teins
- 02 sensors
- Synthetic transmission fluid?
- aftermarket grill
- Stock Visor
- New to the Lexus family...
- Rear Main Seal
- Interior Rear Hatch Release?
- For Sale: Black Colgan Bra
- floormats?
- Need some RX advice (noobie)
- Headlight removal
- Power seat override??
- Oil Leak: Rear Main
- navigation swap??
- Tire and wheel size??
- Rotors: to replace or not to replace
- Fusebox Location
- Code P0446 ???
- Best Looking Hitch
- rx300 bodykit?
- Air/Fuel Sensor Replacement Tips
- Creaking Dash?
- rx300 a/c blower inop.
- weatherstripping
- Help - 2000 RX300 PCV Part No.
- ac not working???
- Windshield Cracked
- Outputs from trailer wiring connector?
- Starting problem
- Car shaking bad. Even after alignment.
- Oil Change
- Bulb Fitment Numbers
- Remote oil filter
- Pungent Odor from AC Use?
- Stripped Bung
- Catalytic Converters Replacement
- Feedback on Power Steering Fluid Flush
- Transmission Fluid level adjustment
- Lexus RX300 conversion from Miles to Kilometers
- cluster question?
- Navigation update for 2001 RX300?
- Front Windows Operation
- 2000 RX300 Antenna Motor
- Looking at RX 300's and NEED HELP
- Replacement bulb help
- Parts for 100K maintanance
- RX300 Pulley
- Service: Independant vs. Toyota vs. Lexus
- High-output alternator
- CEL confusion - more codes (0125, 1135, 1133)
- vsc/trac off warning lights
- I want to upgrade my display
- So Long RX300 Members
- 1999 rx300 stereo install question
- RX300 trans won't shift into OD
- Fog light replacement! HELP!!!
- XenonDepot 6000k HID light conversion complete...
- Very helpful and cheap
- RX 300 tool bag?
- Not the smoothest ride
- Driver's Door Panel Removal
- any rx300 members have indash dvd player?
- Yet another O2 Sensor question
- Replacing spark plugs
