- Recommended ATF change interval
- Topping off Air Conditioner
- RX300 door locks intermittent
- shaking in steering wheel when stopping
- RX300 driver door won't unlock/lock with master key or keyless entry
- pinging noise
- RX300: DIY door lock actuator fix write-up
- How do I put back together air servo mixer?
- Poor gas mileage in 99 RX300 AWD
- P0446 EVAP code
- 2001 RX300 - DIY rear main seal replacement
- Hard shift from 1st to 2nd??
- A/F sensor (P1155)
- 2001 rx300?
- Antenna very noisy when closing
- Sheared bolt tranny pan
- Lube gas pedal and shifter cable
- Pass window erratic
- Her RX300 sucks.... (need advice on a couple codes)
- Help! Torque wrench question
- RX 300 problem shift slow between 3 and 4
- Tick Behind the Glove Box please HELP
- Want to buy RX300 with 171k Miles Need opinion
- Quick question on the transmission fluid exchange
- What ABS Scan tool works for RX300 ?
- Reengineered rear valve cover??
- 2 quarts in 2 weeks ??? I should just purchase my own oil field !!!
- auxillary transmission filter??
- 2002 300RX window woes
- should I tow?
- Code P0446/0440 - Did I do it??
- Wheels/rims help!
- Transmission filter change help needed
- Replacing Valve Cover Gasket
- Oh please not another one.....tranny????
- Slow oil leak from the bell-housing
- Need help! Urgent! Ignition stuck
- Stalled during Breaking and Won't Start
- 1999 RX300 with CODE P1155
- Transmission Failed!!!
- HID Headlight Assembly nightmare...
- 28 MPG at 60 MPH????
- Pulstar be-1 pulse plug
- Spark Knock and P0171
- best pda phone mount options. permanent
- Smell of raw gasoline
- Timing Belt Time!
- Replaced Dome bulbs with SMD LED
- clicking noise in rx
- P0135 code check engine and VSC light on
- Filling A/C Freon
- Smell from A/C Vent.
- Just added Auto RX whats the white smoke??
- Poll: Do you always use the fog lights?
- I warn you ! These pictures are graphic !!
- 2001 rx 300 issue.. Need help !
- Cable part #?
- front passenger door can't be locked or unlocked...
- OK to change ATF brands during drain-and-fill?
- Sos help
- Where did you have your transmission rebuilt?
- Car leaking water on passenger side...
- Any honest mechanics in the Ft. Lauderdale, FL area ?? Please advise..
- ISSUES WITH MY 01 RX300.. Can i get anyones expert advise ?
- Just installed my HID (pics)
- Lack of tether anchor for RX300 1999
- Help with my 1999 RX 300...
- Advice on buying brother-in-law's 2000 RX300
- Some noise from my engine RX300
- Irritating cabin noises antenna and Hatch door
- Impending Failure?
- Why RX300 owners doesn't act together
- 1750 miles into the marriage
- Help Locating PCV Valve & MAF Sensor
- Trailer/Towing Wiring Issue
- Trouble sound!!
- Need help asap. Rx300 making weird sound
- Rear brake options
- couple questions: Hazards
- New tires: 225 or 235 size?
- Replacment Headlight Assembly
- servo problem under dashboard making noise
- RX 300 Drivers Seat Needs Help
- Speedometer Stopped
- HID kit 6000 or 8000 what do you guys prefer
- Changing interior SMD bulbs
- Where are side airbags?
- 99 RX300 180K miles, should I buy?
- running not to well, i have codes (need help)
- 2nd code ever: 1155 Bank 2 Sensor 1
- 01 RX300 - problems starting if left on an incline
- Right Headlight is now pinkish/purple
- Question about compatible nudge and nerf bars
- I have a leak. I have pictures. Help?
- Cladding Touchup Paint
- Code 441 - why?
- Battery Light and Electrical Issues
- Engine coolant sensor?
- Taillight Bulb Replacement
- Transmission fluid change is sooo easy
- Cost to change brake pads?
- Lexus RX300, easy to rollover?
- How much will it cost to replace one rear brake caliper on Lexus RX300?
- RX300 transmission problem
- Using the LATCH system for baby seat
- P1133 Code
- Rattling Noise in my Engine
- New guy here with a 2001
- 99 Rx300 console drawers
- hood squeaks
- Engine light CODE P0446
- Timing Belt / Time or Mileage?
- HALO Headlight, Clear side marker and LED rear reflector light installed
- engine knocking when accelerating 2000 rx 300 v6
- Roof rack bar installation
- RX300 100,000 miles (no real services done yet)
- Winding/whining noise?
- How to change the Timing Belt on a '99 RX300
- Transmission - delay in getting to third gear
- 2001 RX with fog lights?
- Product that gets my recommendation
- catalytic converter replacement - rx300
- knock sensors trouble code 0330
- Hitch on your Rx 300?
- rX300 miss firing
- ECU Reset
- Fluttering and hovering smells like gas
- RX330/350 wheels: Weight? Price? MPG?
- Maintenance suggestions at 200,000 miles
- Any Air-con re-charge DIY ?
- New DVD headrest!
- Child seats that fit well in RX300
- License Plate Light Screws Rusted
- Antenna assembly (new) for $69.95
- Where is this leak coming from?
- fuel injector ticking noise???
- How good are KYB GR-2 struts?
- Replacing a sunroof.
- air fuel sensor testing?
- Just wanted to brag about my 2001 RX
- Great forum for information!
- Type IV ATF
- DIY Collection
- I was under my RX and I noticed these
- Where is the transmission cooler on a 2001 model?
- Year 2000 RX300 fuel injector ticking noise
- Minimum wear on rotor?
- Sensor Repair turning into NIGHTMARE!!
- Are some cars just good cars?
- Going to buy a 2001 RX but saw this on the service history
- Keep or not to keep
- Driver's Side Window Update was :( and now :)
- RX300 Exhaust Disconnection?
- Rear View Mirror
- Timing Belt replace
- What oil are you using right now?
- Installed full led tail lights lamps clear
- Diy transmission tube assy oil cooler part2
- DIY Transmission Tube -Assy,Oil Cooler.
- Driver side seat belt
- Resistance of knock sensors and harness?
- Lexus RX 300 tag light bulb recommendation
- Bumpers colour recommendations
- Sold my SC400 for an RX300 need some advice
- question about exhaust
- 2002 Knocking under light load
- Figured I'd introduce myself
- Need some hose location help
- Buzzing noise under glovebox when air is on?
- Evap canister and CELs
- Changing display screen from MPH to MPG question
- Have you ever been off road?
- VSC and Check Engine Light
- Driver Auto Windows up/down & door lock problem
- Right hand drive front seat for rx300 2002
- Sun visor removal?
- Replacement rear motor 99 AWD
- DIY Exhaust System Replacement, Please!
- Can I save my transmission?
- Denso a/f sensor on header in front of rad
- key problem
- 99 RX300 rear window install
- Help me Remove RUST!
- 1999 RX 300 Needs Tires....help
- A sad day..
- painted the lower half of my rx
- Rear Struts
- '99 RX 300 Limited Slip Diff? How do I tell?
- Help Burning oil
- bajabill
- Mileage readout in console stuck
- Led turn signal mirror cover
- 2002 RX300 Keeps Shutting Off at start up and Draining Battery!! Please HELP!
- Roof rack part needed!
- 3MZ-FE swap in a RX300 - How Practical?
- RX300 2001 inside driver mirror directions not working
- Led upgrades to interior blue light and lighted door sills
- Smoke from glovebox of my 99 RX300?
- Lexmex...
- Dome Light and Middle Console Out! HELP!
- A/F Sensor - Is this right??
- WTF 15 codes???
- My Transmission Problem, help!
- gas leak from top of tank/fill neck
- Looking for a 2000 RX 300 Key Deal (Master Remote x2)
- 2003 RX 300 Exhaust Leak
- 2003 RX 300 Fuel Smell
- Just bought a 99 rx300
- A exhaust or warm oil smell when standing still
- A real head-scratcher: P0170, P0300, P0301, P0303, P0305
- 99 RX300 Issues
- Sunroof Hail Damage
- What does "O/D OFF" light mean
- Brake Light Comes on at idle
- debating whether to replace OEM brake rotors
- ticking noise
- CEL P0500 and ABS codes!
- DVD Headrest Wiring HELP
- My RX300 won't arm
- Tachometer Jumping & Check Engine light on!!
- @#^&*@ bulbs
- rx300 died while stopped-but restarted immediately
- Can you fit, A Baby, two Adults and three Dogs on a RX300..??
- how many total years of warranty for the Engine?
- 2003 "sport" model?
- After Market Knock Sensor Reviews
- No light in headlight, turn signal and cruse control switches
- P0305... not a normal coil pack...
- fuel injection!
- Help?
- Fredrico55
- Duplicate or Laser Cut Key
- Is it all downhill from here?
- drivers side low beam off when fog lights off
- Ignition Coil
- High Idle (Help)
- hard shifting with delay and hesitation
- What did you do to your RX300 today?
- "liquid" in the throttle body
- Not driving for long periods of time?
- Transfer case drain plug
- Is any AC maintenance needed?
- Philip HIR 9012 bulb
- Jerk, when transmission shift from gear 2 to gear 3
- sensitive driver side window switch
- Electrical issues
- diy rear valve cover gasket
- Change engine oil or not. 6 months passed, but only 2500 miles on synthetic oil
- MPH and RPM question
- yaw rate sensor
