- Bulb out indicator
- AT Temperature light on
- Headlight Control Sensor
- 2000 RX 300 DRL voltage issue
- Substitute to T-IV Transmission Fluid
- Change Speakers?
- Engine failure due to pre-cat.
- 2000 RX300 Replace Rear Differential Seals
- Looking for some help with brake questions.
- RX300 - Endless CEL's even with many replaced parts
- RX300 Transmission Hesitant to Downshift
- Help: Need to Exhaust System for RX 300 in Ontario Canada
- 1999 RX300 Trailor Hitch Bolt sizes
- Adding Auxiliary plug
- RX300 rear end noise at high speed
- 1999 Climate control help
- No heat
- License Plate Lamp Replacement
- Wife's car no brights
- hit a curb
- Transmission.....Drain or Flush
- what did I do??
- New Member: What to look for? About to buy a 2002 RX300
- '02 RX300 Transmission - at a crossroads, looking for advice
- quick question on power antenna mast orientation
- Air conditioning trouble
- Need help finding 2001 rx300 dash part
- Headlamp assembly replacement then problems
- RX300 Radiator Fan WON'T turn off
- RX300 Front Lens
- Any experience with 'lexuspartsonline.net'?
- RX300 not shifting into overdrive.
- My CEL flashed, stopped and mechanic can't identify issue. What's going on?
- 2000 Rx300 touch up paint
- NEED help locating a piece I'm missing in my trunk/cargo compartment
- Brake Fluid Change Interval
- P0755, what is it?
- 1999 Rx300 Stalling Electrical issue
- Power Steering flush question
- run time problem
- Diagnosis help: door actuator or electrical?
- 2002 RX300 tranny question...
- what should I do now? Dealer failed to replace knock sensor
- Adjust cargo roof rack bars 99 RX300
- B1S2 02 Sensor Fuel Trim is Reading 99.06
- New member from NH
- ATF IV using as Power steering fluid?
- New Owner
- burning oil
- RX300 Transmission Help ASAP
- Make it Faster
- Rear Hatch Door Replace - How?
- Battery and Radio Console
- How do you read trouble codes off display
- Quick acceleration bogs the engine down. Ideas?
- O2 sensor question for RX300 Lex-heads
- Toyota vs. Lexus service
- Noob: Looking for confirmation
- Sounds like a hamster is behind my console
- Very Noisy Alternator Belt
- Antenna replacement fail..lost a part on the road
- 2002 RX 300 Transmission Slipping
- P1155 & vsc
- need second key; can I find my "key code" somewhere?
- a/c light blinking occasionally
- Dipping my toe in the Lexus pool
- Seat cover source?
- After transmission flush problems arise
- Shifter Light
- 2002 RX300 idler pulley broke today
- 99 died suddenly, won't start
- Rear Differential or Transmission Problem???
- Brake pedal stiff & dropping
- A/C doesn't blow cold air
- Newbie rx300 owner
- Our oil consumption problem solved!
- gurgling noise ?
- RX300 (99) door lock actuator
- Aftermarket stereos for 99RX300?
- 99 RX300 Radio + climate control back lighting?
- 1999 lexus engine de-rated issues and codes
- Replace Oxygen Sensor together with Knock Sensor?
- All detailed up!!!
- Towing
- always premium gas feed, still got p0330, why?
- Fuel Pump, ECU, Relay, Fuse, or God Just Hates Me
- VSC beeping occasionally on turning
- Diy valve cover gasket
- PLEASE HELP!! 01' RX300 code 0765 issue
- Rear Hatch Lock/Actuator??
- VSC light and Check Engine
- Possible tranny destruction???
- 1999 RX300 Single Door Keyless Entry Problem
- Under hood courtesy light? 99Rx300
- Power steering squeal at startup 99Rx300
- Key Fob Question...
- Seat belt problem
- 2000 RX300 using oil - New Valve Cover Fix
- A/C Efficiency/Load Question
- thanks la4mead
- Buying an RX300
- CEL mystery on my 2000 rx
- Strange transmission problem occurs, please see if you can help
- Ventilation servo motor noise?
- New tires now a wobble gripping feel.
- RX300 CEL: P0446 and P0171?
- 2003 RX300 won't start after replacing with a new battery
- 2001 RX 300 A/C gets warm at idle
- Power Window - Passenger - '01 RX300
- Pinging sound
- Just Bought RX300 (yr 2000) Maintenance?
- Driveshaft repair
- Exhaust system movement when shifting to R / D
- Can it be OCV?
- Strange Transmission issues
- Marmot made nest in my RX300....ate hood heat shield. Need Replacement!
- Computer Information
- OBDII Pin #16 malfunction? so couldn't get emission test done.
- Urgent!! P0174 code on a long trip
- Noisy front suspension
- Ground problems?
- RX300 A/C Compressor Not turning
- DIY Axle out put seal driver side.
- Cruise Control Module
- RX300 to Highlander Cross Reference
- Brakes and Rotors All Around
- Strange clicking noise from AC/Heater fan when engaged
- Is this the original cladding color?
- Upholstery problem
- Gas mileage plummeted after tune-up / Any ideas what's wrong?
- Dropped PCV valve grommet into engine!
- 2000 RX 300 rear ended and now won't start
- audio update
- Question on new valve cover design
- rx300 slow off the line?
- Newb: 2000 RX with 200K and a Bad Trans, Questions
- Yet another servo question
- My RX sounds like Lexus, exhaust fixed WU cat DIY
- please help
- 2001 rx engine miss from dead stop
- ROUGH Idle (Cracked Manifold?) Dies sometimes
- Knocking sound during startup after letting car sit
- Denso Part# A/F Sensor for 2001 RX
- A/C blower problems
- RX300 FWD Tires for Rain & Snow
- Oil burn on Cold Startup
- Lexus Newbie
- How can I figure out whether Nakamichi or Pioneer speakers are installed?
- P1155 after new Toyota A/Fsensor install
- P1354 code problem
- Can Nakamichi be swapped for regular radio?
- Tail Light Failure Sensor
- 1999 RX300 window tinting
- what brand name
- 2002 RX300 saved my life!
- iPod adapter for Nakamichi?
- Marker lights fail to flash when locking or unlocking doors
- How do I remove transmission pump?
- Daytime Running Lights and Hi Beam Failure
- 2000 RX300 P0171, P1130, P1135, P1150 and P1155
- What type of transmission fluid do you use?
- Advice on code P1354
- Trouble sorting this one out
- Interesting on tranny pan
- Trans Swap 04 into 01 ?
- Leather Repairs - DIY
- RX300 starting problem
- Transmission dead? please help!!!
- Seatbelt retractor
- RX Shuts down after car wash on engine
- Remanufactured Engine
- Windshield wiper arm adjustment? wipers slamming into cowl.
- Lexus in for alignment (pics)
- 2001 RX300 blower motors stops
- RX300 Owners - I'm in the market for a used sedan. What Lexus is similar?
- Transmission Failure Survey
- RX 300 error codes
- 99 rx300
- Battery keeps draining after sitting for two days.
- Spacers for rx300
- 1999 - Replaced 'D'bulb killed tach & speedo
- Crusty, slow-filling oil cap is scary as hell for first timers!
- 01 rx rf window frame arm reassembly
- 18" wheels - rear strut concerns
- Why does my tranny dipstick say...
- U140E Transmission Woes
- rear sway bars
- LEXUS RX300 2002 Brake Lights out in back
- reverse wire
- 2002 lexus RX300 VSC
- HOT TIP of the day/week
- Axle shaft inner cv boot leaks
- 2000 RX300-running horrible, throwing a ton of codes
- 1999 RX300 Engine Light Codes and how to fix?
- Air Conditioning not working
- Just bought 2K RX300, have a few questions
- Looking for my first Lexus today - tips? (leaks,rust,etc)
- Stuck Sunroof
- Advice needed on jacking engine for RX300 timing belt change
- Thank you club lexus and sewell
- Calling the experts
- AGHWWW Heat in Florida?
- Vibration / buzzing at 2000RPM
- Trip A
- Metal sports pedals installed
- Telephone Transceiver / Speaker Relay Location
- Rattle from steering column or lower dash
- Seat Angle Mod
- Need help please
- Body Parts
- 02 Transmission Whine
- My poor girl might have just died...
- Bad wheel bearing after Tx replacement
- 2002 rx ignition
- died on freeway
- Pay it Forward
- 2000 RX300 AWD transmission shutter on deceleration
- P0330 Knock Sensor, 15 min. Hack Repair...
- Ipod adapter
- Buzzing noise after replacing 20amp EFI fuse...
- 2002 Rx300 transmission problem
- I just sold my 99 rx 300 - oh happy day !
- Tires and rims
- Water in Spare Tire well
- Possible transmission failure?
- Does anyone have 3GS 18's on their rx?
- New tires for 02 RX300 FWD
- help 2001 rx300 not starting
- Right Front Wheel Locked up?
- 90K price breakdown?
- RX 300 Coolant Leak Driver Side Rear
- Check engine light
- Scary steering problem
- How to choose right tires?
- Door locks?
- Another dead transmission reporting in
- Sold my 1999 RX300
- dash lights ?
- Odd A/C problem
- Between Triangle and Maxxis tyres, which is better?
- is my transmission toast
- '99 Lexus RX300-Codes p1133,p1155,p1154
- Interesting valve cover issue/leak
- Poor Gas Mileage on my RX 300
- Center Display Buttons
- RX300 Remote opens all doors but closes none!
- cats ?
- ignition cylinder $600?
- Panasonic Battery
- Liftgate Latch won't release
