View Full Version : RX - First Generation
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. My RX 300 Heating doesn't work
  2. slight VIbration From a dead stop
  3. Air Mix Servo
  4. Reset CEL by disconnecting battery
  5. CEL codes P0171,P0441,P0440
  6. transmission repaired
  7. Cruise Control Comes and Goes
  8. Need Tires. any suggestions?
  9. Any DIY Timing Belt Change Info?
  10. Hi From the UK
  11. Nav-owners: important question
  12. Key remote lock/unlock do not trigger front and back lights.
  13. Is my O2 sensor really bad? And cost to replace(No Engine light, low mpg)
  14. Are You Kidding ??
  15. 2005 RX I just bought
  16. Tein Lowering Spring
  17. How to Correct Camber on Front End?
  18. Looking to buy
  19. hardwiring V1
  20. Transmission finally went.......
  21. CEL Error codes on 99 rx300
  22. Can you add a heated seat to a 2001 RX 300?
  23. Front Lower Member Brace and Rear Anti-roll Bar / Rear Sway Bar ???
  24. Antenna mast and motor
  25. Change wheel bearing or hub as well?
  26. Trans Cooler?
  27. '99 RX300 misfire blues (wanna give it a try?)
  28. Taking fuse out to reset CEL
  29. Toyota - Lexus parts interchangeability - need advice
  30. RX300 2003 Radio code
  31. Parking brake light does not go off.
  32. Please help - transmission failed
  33. Timing Belt?
  34. Conventional oil
  35. Engine Rough..Cat Turning Red..Codes P0300, P0303, P0304
  36. Transmission Filters Which is best ?
  37. Timing belt and whatelse needed 107k mileages?
  38. Transmission Failure?
  39. Minor issue with my 2001 RX 300
  40. radio wont turn ON
  41. Timing belt and water pump
  42. Whats the difference between the 01 and 03
  43. Transmission fluid change?
  44. Rx300
  45. DIY: Replacing air/fuel sensor
  46. 2009 Navigation update
  47. Steering Wheel Upgrades?
  48. Stubby Antenna Upgrade?
  49. Alarm System Problem
  50. Sparkplug Life
  51. '99 RX300 - Gauge fuse blows frequently
  52. Sway bar end links removal - need help
  53. Alternator Removal
  54. Sludge Claims
  55. Doing a Trans rebuild I got a great deal!
  56. Any auto parts store the stock A/F Sensor?
  57. Ignition Coils
  58. Changing rear brake rotors
  59. Engine job done, so far so good, fuel pump?
  60. 2002 rx rear suspension noise
  61. I have about 5 questions about my rx from suspension to A/C system to my DTRL - Help?
  62. oxygen sensors and exhaust leak
  63. Hey Guys, Front Map Light Issue!
  64. 2003 RX300 hard to start & stalls when low on fuel
  65. 235/65-16
  66. potential rx300 owner
  67. New guy question about door lock . .
  68. brake lights out
  69. "Coach Option"
  70. Need some brake job info RX300 2001
  71. Oil filter change
  72. Code P1354 Help Please
  73. Oops! Snapped off a rear caliper bolt!
  74. Our model is getting old. Replacment parts
  75. Tear in the rear suspension boot
  76. Anyone have seen this problem on a RX 300 ?
  77. stripped rear differential fill allen bolt
  78. Auto-RX which oil to use
  79. Noob with some questions
  80. Air Conditioning Fan speed stuck on full blast
  81. Rebuilt engine/sensor questions
  82. Oil strainer and filter
  83. Rear Wheel Hub Assembly
  84. 2002 RX 300 PCV Valve
  85. Noise from back tire when turning
  86. Center isle Heater / AC Issues
  87. Easy fix for groaning antenna
  88. Question on Power Steering Fluid and Steering Noise.
  89. Knock Sensor questions
  90. US RX is showing celsius sometimes
  91. Shift Quadrant Indicator Lighting
  92. '01 RX300 - broken rear seat latch - help?
  93. Transmission Question
  94. Shifting Question?
  95. Fault code on my 1999 Lexus RX300
  96. Front Strut Replacement - Misc Comments
  97. Hello from So-Cal!
  98. Kumho or Yokohama tires ?
  99. Adding a Towing setup to an RX300 AWD
  100. 2002 RX300 2WD trans problem
  101. When do coil packs fail?
  102. Brake pad changing question!
  103. 2002 rx300 auto light system
  104. T-Stat and A/F Sensor Replace?
  105. Is starter or ignition switch?
  106. Fluids - How old is too old??
  107. Old rear differential leak????
  108. Where to get genuine lexus parts
  109. Squeaky steering wheel
  110. cabin air filter
  111. help. problems with remote central locking
  112. Question: Just Did The Brakes Pad DIY.
  113. Rx300 2001 Exhaust Flexpipe Help!
  114. More engine issues....damn it's electrical too!!
  115. P 1130 Please Help
  116. Switching to mobil1 synthetic 0w-30
  117. Ques on MAF sensor,O2 sensors and Fuel Injection Service.
  118. Time for timing belt(s) on a 2002 RX300...Help
  119. Question for Lexmex on Castrol Syntec
  120. DIY roof rack
  121. Difference between 99 and 2000 RX Snow/Power and Snow Button
  122. gear stays in low gear. HELP
  123. $2596 later, transmission rebuilt with 116K miles
  124. Alignment Adjustment
  125. Question on Oil Filter
  126. RX300 with new engine still using oil
  127. DIY Oil Change
  128. KYB Quality Issues
  129. cruise control blinking
  130. RX300 AWD Transmission symptoms
  131. Newbie question
  132. Driver window issue
  133. Amp Wire Diagram
  134. Ceramic brake pads
  135. RX300 Engine/Trans problems: Widespread or not?
  136. Help! Did I strip the oil filter screw on the engine????
  137. 2001 rx300 antenna
  138. rear hatch lift shocks supplier
  139. PCV/CCV problems...
  140. Good Code Reader?
  141. Door Lock & Driver Door Mirror Fault
  142. LOC install help
  143. Just bought a 2001 RX300, i have a question about the transmission
  144. Need New Struts?
  145. Need advice/info (Not using car for approx 45 days.)
  146. Installing Powered Subwoofer
  147. Transmission is Dead! I'm in a bit of a Pickle
  148. About to renovate my suspension - questions
  149. 2000 RX300 w/ding-ding sound and brake light on dash flashing
  150. Kool-vue side mirror ?
  151. Odd headlight question, stock HID install?
  152. Lexus RX 300 won't start (see video )
  153. Buyer Beware
  154. Intermittent Check Engine Light
  155. Maximum RX 300 AWd speed without the speed limter?
  156. rx300 with erratic shifting between gears. please help
  157. Z-max
  158. I cleaned my headlights with ATF - Automatic Transmission Fluid - It works!!!
  159. Clear on oil stick
  160. Good place to buy replacement Nav DVD unit?
  161. Brake Caliper Rubber Boot Replacement?
  162. Heat shield suggestions?
  163. passenger windshield wiper stoped working
  164. Brake Pads
  165. 5w-20??
  166. How to replace HID headlight bulb?
  167. Owners Manual
  168. Removing Parking Brake Cable
  169. if you have a second, please read here.
  170. First Post: Engine Cranks; Won't Fire.
  171. switching to synthetic ATF
  172. Valvoline Full Synthetic Racing oil VR
  173. ****EMERGENCY**** key internals
  174. Gas mileage computer information vs actual mileage
  175. E-3 Plugs
  176. pcv valve
  177. Cost of replacing Door Locks and Keys of 02 RX 300
  178. Cheap OBDII reader @ Costco
  179. What do you keep YOUR tire pressure at?
  180. Joined the RX300 World Today
  181. Power lock motor
  182. 1999 RX 300 ignition key is stuck
  183. Motor louder than usual!
  184. Cracked exhaust manifold.
  185. 99 Lexus RX300 maintenance suggestion need
  186. 02 Rx300 Rear Brakes Binding! Please Help!
  187. Need a new front and back bumper, Need help on Body parts
  188. DIY 1999 RX300 Exhaust without Lift?
  189. Code P0171 at 120K miles?
  190. DIY Catalytic Converter P1305-P1325
  191. What size tires on 18x8 and 18x8.5 5x.114
  192. Delayed shifts when cold.
  193. RX300 Silversport
  194. Interchanging rims with other lexus models
  195. What would be a good price to pay for a RX300?
  196. Will frequent oil changes prevent sludge/gelling?
  197. Caliper Maintainance
  198. USA SPEC PA15TOY (For my 03 rx)
  199. Multiple P1305 -P1315
  200. Any Preventive Maintenance For Air Conditioner?
  201. Lots of clues. Advice needed about rear end noise...
  202. muffler question
  203. low rpm when starts.
  204. 01 RX300 Door Removal
  205. Got light-brown coating on top of your headlight lenses?
  206. 2001 RX300, 18MPH, qualifies for "Cash For Clunkers" $4500 credit...
  207. Transmission Fluid(Sorry)
  208. TB Life - When all else fails, read the directions!
  209. Broken Wheel Lock
  210. CEL light is on
  211. Stalling w/ the AC on
  212. Rough start
  213. Steering Wheel Shimmy
  214. O2 sensor causing rough idle?
  215. Obvious oil sludge issue, claim denied
  216. Instrument panel, Hole cover
  217. Sub install PLZ help
  218. Auto-Rx
  219. Engine torque specs
  220. check this out!!
  221. Dead driver door power window fixed
  222. are there LED bulbs that's as bright as stock brake light bulbs?
  223. Duramax Gold Ceramic brake pads
  224. EDVANB in SC
  225. Start Up Squeak
  226. DIY: Engine removal and install????
  227. Need a double din dash kit--2000
  228. doesn't idle
  229. buying a 99 rx300 - some issues
  230. Does ES300 engine fit RX???
  231. Alternator Problem?? Please Help
  232. LED lights for high beam/daytime running
  233. HVAC Temprature control not working
  234. 2001 AWD trans on e-bay
  235. Honey like fluid in the intake
  236. Car doesn't move and then jerks when I press on the gas after braking
  237. clunking sound while driving in straight line
  238. Rims question.
  239. P1725 code- what is it?
  240. Dirty Headlight Housing...how to clean or fix
  241. Autotrans blues RX300 1999
  242. Alignment needed after strut replacement?
  243. 01 rx300 died driving help
  244. from bob is the oil guy.
  245. in 110+ degree weather, should I use a heavier oil than the usual Mobil 1 10W-30?
  246. Error Message 2
  247. driverside window wont roll up.
  248. Replacing Front Brakes
  249. Antenna replcement under CPO?
  250. 2001 RX300 Window Sticks
Content Relevant URLs by vBSEO 3.5.2
