- Charlotte NC meets????
- OEM replacement exterior door handle?
- First Lexus is a Sportcross
- crank position sensor location?
- anyone know what this is?
- New to Forum
- HELPPP!! Starting issue
- Does this look right to you.
- exhaust
- Headlight Issue
- Key FOB programming
- What do I need to know?
- A track video we Did locally
- IACV with code P1125
- i need answer about lexus is200 headlights
- My RB bbk
- New Member IS300 turbo
- Replace blower motor resistor. And DIY or How To's?
- All FS & WTB go in classifieds section only
- 1jz swap
- JDM headlights
- Just needing some opinions and advice ladies and gents.
- i need help:(
- Used IS300 - How Many Miles Should I Look For?
- looking to buy an IS300
- Please help!!! No power to car!!!
- ALL FS ISO WTB go in Classfieds Section Only
- first car. 01 IS300
- IS300 vacuum lines (HELP PLEASE)
- Throwing P0430 code....
- Soon to be is300 owner.
- Hi Im New & Need Help
- 01 Lexus is300 code P1127 troubleshooting
- 2003 is300 stolen & recovered, what to look for?
- IS300 Sitting for 3 years
- 01 is won't start. New to the Is300 HELP!!
- Reverse beeps
- New here
- Watch a 2JZ-GTE Lexus IS Smoke Its Tires
- VVT on 01 IS 300
- Steering wheel rewrap lexus is300
- My Lexus IS 200 1JZ GTE VVTi
- TRD Carbon Fiber Hood Need Hood pins
- IS300 - Fully Converted to RHD - BEAMS Motor - Driving Issues HELP!!!!!!!
- New 2005 Lexus IS300 owner and have a question
- Please with prep for turbo
- IS 300 Build.. Rec me some parts?
- IS300 on 18x10.5 wheels ??
- Problem with dbw throttle body on vvti swapped car
- Manual Lexus IS 250 or Manual Lexus IS 300?
- New Guy From Colorado
- hey yall, new is300 owner here
- Is300 misfire?
- Rear bumper applique ?
- idle jumping when a/c is on
- Stuck shifter, break lights out and break got stiff
- New to the Forum and to Lexus...
- "Tall" IS300 owners?
- lexus is300 o2 sensor help plz !!!!!
- IS300 rogh idle and stall when cold
- selling 93 sc 300
- IS300 Bluetooth push button start questions!!
- Oil leak at manifold! Help!
- Strut bar
- Potential sportcross high hp build?
- Traction control light flashing
- New IS300 Sportcross owner
- New member here
- cigarette lighter fuse
- new member, blah blah blah.
- My sportx
- srt intake with race ecu
- New member, problem car
- IS300 Aristo Swap Questions
- Varrstoen es220 17X9 +30 fitment?
- need to replace valve cover gaskets
- Rebuild? Replace engine? Sell??
- 2JZGTE swapped black 2003, anyone on here?
- Odometer rising
- Need help
- 01 is300 throtel issues
- 21.984 gallons
- What is this???
- This is not the classifieds
- ChicagoLand Meetup?
- A/C needs Freon - any cheap places?
- Need Help! Potential Immobilizer issue?!
- Just bought my first Lexus!
- *** Track Mega Meeting! ***
- Need Modified IS300 for Commercial
- Z edition black chrome grille
- Mileage on your 1S300
- juicij36's last revamp coming soon
- IS300 bogging
- Faulty OCV testing / loss of power right at 3500-4500 rpm.
- Manzo exhaust any good?
- fuel return/ fuel pump
- Fix or not to Fix
- All for sale threads belong in classifieds only, not here
- Trunk will not open!
- Crush washers for oil, trans fluid, and diff fluid
- Will 18x8 wheels work with no mods?
- Interior dash
- Manual transmission clunking when shifting
- New Seat "Covers"?
- Should I buy this is300
- Funky shift at 4K at 60% throttle
- 17x8 +35 or +38 Offset Fitment?
- My navi housing with retrofitted screen
- 2jz is300 into 65 mustang trouble
- New Lexus owner
- Ideal alignment settings for tire wear?
- o2 sensor bank 2 sensor 1 issues
- Car almost killed me!!!
- Tune up
- tranny swap? AT to MT?
- Any Year "Better" Than Others?
- 2001 IS300 purchase
- Need some quick advice guys/girls.
- Sportcross Glass Replacement
- fuel issue
- Powerseat won't move forward.
- 01 is300 light bulbs
- supercharged? ?
- Self Tanner on Leather Seats
- How to change hid fogs back to oem
- 2005 with 80K - High milage?
- Is this a good deal on this is300
- valve cover leaking oil need to change
- Trade Injen CAI for OEM Air Box Assembly
- Quebec Police Kick Hellaflush IS 300 Out of the Province
- LED V2 Taillights, please help me find
- Looking for fixed up Lexus is300
- Seat material
- new to this forum, been on others though
- Where do you shop?!?
- "new" IS300
- nitrous question
- New Member (
- led bulb fell inside headlight assembly
- Vibration in brake pedal after startup normal?
- hid self-levelling
- 2007 Lexus IS250 headlight question
- Catalyic Converter repair question
- Driver's side door not opening from inside
- '02 IS-300 5-spd/LSD/MSM
- Thinking of Trading the 530i for IS300
- New member, waiting for my perfect IS standard
- New Member
- My tail lights are not working what do I do.
- Nickel Motorsports Lexus IS 300 In-Car Video
- New with lexus is300 need some help
- new pics of my new look
- Front Strut Mount Bolt Pattern
- Roof rack options
- New here and need some advice
- 5peed is300
- Trouble starting
- How to know if blown head gasket?
- tach/mpg not working, and low coolant/beck up light indecator on
- Wierd speedometer
- VaderIS250's Progress Thread
- Transmission Leak?!?
- Did I Over Pay?!?!?
- Buying a high mileage is300.
- Popping noise from front
- CV Axel help
- Resetting ECU-Which fuse exactly?
- Super Crappy body work
- redoing interior dash
- is300 sportcross warning lights
- Problem with my is200 any help appreciated
- buying a 2001 lexus is300
- steel rims
- keep car or buy new one
- Stock intake please
- Cam Gears
- HID question: Harness or bad bulb?
- Car starts then dies immediately
- Greddy EVO exhaust starting to rust
- Gymkhana on Ice Starring Lexus IS
- OEM amp went out..
- Replacing suspension
- Lexus IS300 OCV
- New tire / wheel setup - Supra wheels, NT05R, RE71R
- Oem hid bulbs
- Question about transmission
- Looking for IS300
- Window switch both driver and passenger front very wobbly/flimsy
- Car takes 7-8 secs to turn over then pours smoke and gas smell out exhaust?
- My first sub and amp mod plus 6x9 rear install
- Need help! 18x9.5 and 18x9.5 tires
- is300 starts and dies immediatley
- Odometer
- Way To Much Body Roll IS 300
- Washington state is owners
- HELP PLZ, 2001 lexus is300 P0430
- Best wax?
- 2002 Aftermarket Head Unit
- 2002 IS300 Steering Noise
- anyone know this car?
- front diff oil change question
- Which car comes with 2JZ?
- Brake bracket fit issue
- Selling 01 Lexus is300
- New gauge cluster lights
- IS300 Oil changes messy?
- Them IS300 Keys...
- 2004 IS300 oil change question (new lexus owner)
- New Member saying hello
- 2005 Lexus Is300 (Auto) INJEN INTAKE problems!!
- Rattling noise
- Sportcross lowering with 2001 sedan springs?
- Seats not working
- having issues with codes p1300 p1349
- Fitment please look
- IS300 Motor Mounts Replacement
- IS200 help
- plz help my heater is killing me
- new is300 owner needs to know
- 2004 is300 cel HELP!!
- Which is300 swap to do? 1jzgte 2jzgte ls1
- How do I install an HID Relay Harness?
- DD Boost Application NA-T IS300/W55
- help with parts
- Hello everyone in need some help!!
- Farewell my IS
- Hello Club Lexus
- Does anyone have unlimited autocheck or carfax
- ***help!!***
- Buying IS300
- Help Code P0710
- Pricing a 2003 Lexus IS300
- IS300 Won't Start, please help!
- Windshield Replaced, now my hazards automatically turn on
- 1990 ls400- fuel gauge.mileage.cigarette lighter and attend not working
- Newbie to Lexus
- Bluetooth Systems for '01 IS300
- Buying a 2002 Sportcross
- Looking for some help with 09 is250 headlight purchase.
- yellow fogs
- help! oil in coolant??
- Buying a IS300 (5-speed)
- shop in the inland empire
- 2jz gte build
- New Member From Asheville NC Help Please
- Where do I get headers?
- UGO Roof Spoiler Fabrication
- Tein advanced street coilovers
- New rims and tires!
