- Roof Crossbars
- 2004 RX330 check engine light on code: p0018 someone help lol
- Timing Belt question
- Time For New Tires on RX340
- Bought a RX 330, anything I need to check?
- All 5 windows rolled down automatically???!!
- help needed on reverse lights wiring
- AC not blowing cold...HELP! I live in HOT Texas!
- Airbag off and seat belt light on
- A question on ML system
- I found the trunk rattle that has been driving me crazy
- Leather color faded
- Where is the Magentic Clutch Relay RX330, 2005?
- Improved Update with Nav Update?
- Cabin Air Filter Removal RX350 2007
- $850.00 to change the spark plugs?
- How to adjust auto-leveling projectors? Also, question about fog lights
- MAF wiring diagram
- Need paint job shop in South Florida!
- Green illuminated dot on gear shift panel
- RX400h 2006 Headlight replacement
- How to install Vaistech XM
- need help deciding between rx350 or 400h (07 or 08)
- Tire pressure indicator light
- Want to buy a lexus...
- door, dome light fuse?
- Playing iPOD/iPhone in 2006 Lexus RX330
- Error Code PO 420 Efficency Below Threshold ???
- Purchase off-lease 2008 Lexus RX350
- Neat Diagnostics Tool and Data Logger
- Rear carrier bushings??
- 2004 RX330 Flint Mica/Ebony Pictures
- Loss of gas mileage after ignition coil replacement
- TSB transmission re-flash
- RX 330 Help - too many problems ?
- Steering column squeaks while tilting down
- Any ideas how to fix intermitent Bluetooth connection?
- After Market Radio Install - No sound
- Rear Hatch Problem
- warning lights
- Looking for the following part
- Applied Latest Transmission Firmware, WoW, What a difference!!
- Gatorade in the carpet!
- really need some opinions on this potential purchase (2006 rx400h)
- Need engine air filter part number-2006 330
- Tire Balance
- RX330 Floor Console
- Interested in buying my first Lexus RX350
- Clunking Noise In Reverse
- '04 RX330 reliability, persuade or stay away?
- Where to order strut mounts online that ships to Canada?
- New 2008 RX350 Owner
- What do you guys suggest for a bug deflector and window visors?
- Brake Pad and Disc Change
- Modify RX330 to play DVDs on front screen while driving?
- Wheel bearing shot @16.5K?
- 2004 RX330 front Door Speaker size?
- Rusty Chips
- TSB ECU upgrade for transmission
- Need center console "open" button
- How to switch from headphones to speakers on RES
- Oil filter wrench in San Francisco area to borrow
- Wheels offsets, Spacer Hubs? 5mm, 10mm
- Turning on auto door lock
- Left rear bumper lens broken
- Help with my Water
- VSC light and Engine light
- mechanic recommendation in Ottawa
- Extending steering wheel squeaking
- Ipod controls on NAV Screen?
- OEM Cabin Filter vs Aftermarket
- How capable is the RX?
- H or Y Cant figure it out
- Remove front door panels
- Canadian All Weather Floor mats
- door lock fixed but handle doesnt work...
- Black Headlights Picture Request
- Check Engine Light - "P0356" - Ignition Coil 6
- 04 RX 330 Interior Door Handle Chrome peeling
- RX Interior Dog Protection
- Dipping rear wiper arm
- 2005 RX330 wheel/rim ?
- My clean RX
- 2007 RX350 Tire Question
- A/F and Oxygen sensors
- Is it possible (I'm guessing not)
- Headlight washers not working
- NAV Software Update
- Parking mode,engine stalls
- gas tank cover
- Running Boards / Bars ?
- 08 Rx 350 without roof bars
- 08 Rx 350 roof rack easy fix less than $20
- Urgent! Battery Is Down!
- Multi-Box Holder
- Annoying " THUMP " noise coming from the passenger side of the dashboard!!!
- What Trim do I have?
- Bit the Bullet; had 60K & 90K service done
- RX330-Screen cracked by GPS Suction Cup?
- Liftgate
- Rear End Creaking
- Resurface Rotors
- Why do mechanics do this - Idling
- Passenger Seat
- Toner-cover and bar noise
- Screen Configuration
- Question on personalized settings
- Remote "guts"
- Brake pads
- dog and the console
- Bypass NAV lockout in 08 RX400h????
- Dashboard
- 2005 RX 330 or 2006 RX 400H
- upgrade to RX 350 ?
- A/F sensors
- Who makes Lexus' trailer hitches?
- Replace Exterior Mirror Motors
- Rack and Pinion Unit Leaking Oil
- get audio from rear dvd on speakers
- RX330 Engine Noise Volume
- Can some one take a photo of their car for me?
- Roughly how much engine oil for the RX330?
- So, I still have the roof rattle
- PRNDL back lighting
- HELP!! Trying to buy an RX, but my wife hates the wood
- Husky Liner for RX - photo
- Best oil filter????
- HELP....sun roof won't close
- Volume and Tune Knobs Not Working
- Stupid thing happened to me last night
- Looking at buying an RX350
- RX 350 paint
- Dice Ipod and 2004 RX
- Where can I find this bit
- Darn Door lock!
- Looking for a RX for my family
- Ignition lock-out, key won't turn
- RX330 2005 rear hatch auomatic door closer
- Phone charger flashing RX330
- HID alignment
- Recirculating Air LED not working
- RF Headlight Breached
- Front end vibration on RX-350
- reverse light: bulb covering removal
- Venza wheels on RX350
- 08 RX350 - Oil Filter Cover "welded" shut?
- RX330 Rear Engine Coolant Drain Plug
- recalls
- RX330 Spark Plug DIY, Will this work?
- DIY Coolant Flush (partial) pics RX330
- RX330 cost to re-flash the transmission software?
- Rear Bumper Lense
- Cabin Air Filter Access Question/Help
- RX330 AWD acceleration wobble??
- RX350 Front Rotor bolts
- help with RX-350 frontend vibration
- help with power mirror
- RX330 Grinding noise when RELEASING brake pedal
- How can an '09 Lexus NOT have an mp3 jack?
- Poor ventilation design - and a fix!
- 08 RX350 - Good deals?
- Odd Problem - Check Engine Light Won't Come On
- Mityvac Transmission Fluid
- Brake pads and rotors
- Help me choose a tire. Sorry for repost
- Wheel Fitments for RX330
- Good Place to install aftermarket stereo in NYC
- New Tires - Michelin Lattitute Tours
- New Recalls
- Transmission Fluid Change - diy and pics
- Timing Belt Replacement (pics)
- Another 05 RX radiator failure !
- What Dash Switches are available for ~2007 RX's?
- Tire Info:
- Automatic Door Lock
- Weapon-R intake review :)
- Covered holes in front bumper?
- Rx350 engine noise (valve train?) during cold start
- How much does a 50000 mile service cost?
- Car Will Not Unlock - Help!! Also Continual Battery Problems.
- Removing left hand cup holder
- Boneheaded move of the decade
- 2004 RX330 Transmission needs to be replaced at 50,000 miles!!!!
- iPhone 4 bluetooth connection issues?
- Deactivate beep when locking/unlocking doors
- Vais VLM and install in New Jersey/Toronto
- IPOD and Functions within RX330
- spare tire help needed
- *53,000 miles on the RX350-To keep or To Sell?*
- Upgrade to Nav 9.1
- RX350 Antenna
- sorry, i've been away, pricing help needed...
- hi lexus, I'm back, but now I need help - bluetooth
- Power Driver Window won't stay up
- 2007 Lexus RX350 Questions
- Photos of dual exhaust system- Finally
- Oxygen sensor
- Looking for carseat suggestions for RX400h
- Looking for OEM quality chrome side-steps and maybe bumper guard?
- Is Delphi an OEM RX330 battery?
- Shock absorber question
- Bleeding procedure on 2006 Rx400h
- Increase Horsepower.....
- Nav Screen Dead....fuse?
- RX350 Tranny and Diff Fluid Change
- How to install NAv update DVD
- Need a new wheel for my '08 350 - $780??
- silver coated amber turn signals for front...light output bad...get led's instead??
- Power liftgate problems
- Is it possible to drive with just the fog lights on?
- NAV system turn guide display goes blank
- rear view mirror problems, driver side mirror drops too low in reverse
- Repairing door trim.
- DIY parking sensor
- Lexus RX 350 with 24" Hipnotic Diva Wheels
- Kudos to Lexus!!
- where to get this eyelid
- Accessories for Rx350 2007
- Rust on body chipped by rocks
- Timing Belt at 60K for an '04 RX 330?
- Nav. lockpick installation question
- Warning lights come on for no reason!
- Need Help- looking for lexus cargo liner
- 2004 RX330 w/20" rims
- Which Toyota oil filter to request?
- Brake Upgrades
- DYI - Timing Belt???
- Bad luck on the interstate...
- Mom's on the roof and she wants in
- DARN clicking noise!!!!
- Are ballast afs specific?
- 3m protection film cost?
- Relay clicking under drivers dash?
- Possbile Catalytic Converter Issue re: Bad Odor
- New Guy with a Question
- Black Forest Pearl RX330?
- how to fix a rip in the leather
- Toyota hitch for RX350
- Lexsus rx 330 differential frame carrier
- Is a Front Differential Leak a Drive tran/ engine issue?
- Fuel Injector Cleaners
- Hard start in the mornings
- Best way to add iPod connectivity to a RX?
- Just picked up an 05 RX330, now we have two RX's in family!
- I need help choosing a paint number (Different codes)
- RX330 or RX350
- Needs opinion
- Do I really need an oil change
- How do you adjust headlights?
- Kevin Tran's Bagged RX330 as featured by maydaygarage
