- Laser Fit Mats or OEM All weather floor mats
- Lowering question.
- Do I need new struts/shocks for my 2004 Lexus RX330?
- Vais products
- Tips on purchasing OEM parts for RX 350
- My Rx350 Thread
- A/C condenser fan issues
- 09 Rx350..different Btw Canada Make And Japan Make?
- Horrible Steering vibration! Help!
- tire question
- 2 questions, Brakes and Sunshades...help
- Did Dealer Install 10W-30 and is it OK?
- Update on A/C noise issue
- Reset the key to default
- How to reset check engine light with loose gas cap
- Where's the navigation DVD reader?
- Spark plugs, iridium; but NGK OR DENSO?
- Key problem
- Panic - Dropped nuts
- IPod Connection - 2007 RX350, can't figure out how to use it
- A fluid leak
- Can software be updated on 2006 RX400H with Gen 5 look?
- Sunroof noise
- Road trip
- 2005 RX Brake Light Replacement.
- HELP!! problem w/ 2009 RX 350
- cornering lamp bulb replacement rx 330
- Road Noise Reduction
- HELP! - won't start
- Problem finding replacement tail light bulbs
- Help: Radio controls stopped working - steering wheel and touch screen works
- LFA "style" wheels
- On vacation having issues
- 2009 RX 350 - Driver Seat
- RX-350 Bluetooth Cell Phone Interface
- 2005 RX330 Timing Belt question
- Reconditioned Engine - RX330
- Got Rear Ended Today
- Its been 3 weeks since looking for an RX 350 w/ low mileage! Need advice/insight! TX
- Is There a way to Slow Down the Blower Fan
- problem with the heat/ac in the rx
- Switch Blade Durable
- Isimple ISTY571
- Stereo faceplate (lens) removable?
- Can an RX400h head-unit be installed in 2004 RX330
- Pass. Mirror leaked
- Grille - Considering 2 options
- My Experience with RX Timing Kit Replacement
- A/C Making Noise
- RX400h power door lock- actuator or cable?
- Rx8 rims
- Small dent and paint chip
- Looking for a Vaistech SL2i-UP
- Bluetooth pandora to car speakers
- RX 350 tailgate closes by itself
- Coolant Leak
- Timing belt kit (2006 RX330)
- Trade in ???
- Rear Caliper pin
- Brighter rear view camera?
- Got a 2008 RX 350 lexus inspected.
- sirius radio
- 2004 RX330 Nav DVD
- cargo retractable cover
- Need pricing advice ASAP!!!
- rear seat dvd
- Luggage door opening: width x height
- PLEASE HELP!! My passenger side mirror won't move up or down
- Rx400h "Check Hybrid System" with P3221
- 05 rx330. Hitch lights not working
- battery won't hold the charge please help
- Is this a door lock actuator issue?
- 2006 RX 330 Brakes ?
- First Lexus...was a gift!
- 2005 awd rx330 fluids change
- navigation dvds
- tow prep package
- Confused about correct ATF level
- 330 to 350
- 2004 RX330 fluids change questions - long history
- Saris bones bike rack
- 07 RX 350 Tow package or not?
- I found a President audio for my Luxury rx400h
- 2009 vs 2010 ride comfort
- Any simple way to fix a door ding?
- Looking to purchase used 330 with 95k miles-good idea?
- My first DIY oil change
- Non AFS model RX330 warning light
- Condensation
- Tyres need replacing
- brake light switch issue
- Issues with audio/bluetooth unit
- RX330 Front passenger seat problem (with photos)
- 04 RX330 Diff fluid question
- peeling/cracking side mirrors
- sl2i-up issues
- RX330 key fob not working properly
- Delphi batteries
- Annoying rattle above 45 mph? FIXED!!!!
- Need Programming instructions for 2008 RX400h
- AFS Off Light question?
- Emergency Creditcard Key Chip
- Yak's Double Din / amp / Sub box install
- 09 RX350 hidden tow hitch
- my navigation system
- Fuel Stabilizer
- RX 330 A/C problem
- Looking for Vinyl Door Handle Protection Strips
- Lexus Ideas
- Crankshaft Pulley Recall
- Need roof rack mount cover
- Our Lexus RX vs The Competition
- Maintenance Help
- 2004 Front and Rear Struts---DIY
- How to set up a double din!(06 RX400h)
- Trailer Hitches for 2006 400h
- Pioneer X940BT
- Saying good bye to an old friend.
- Yet Another Lexus RX Fluid Question
- New to Me 07 RX350
- 04 RX330 AWD New Owner
- Lower Control Arm - bushings went bad....cautionary tale
- how to find parts # for 2006 front & read differential plugs ?
- Bumped a curb this morning.
- Updating GPS in 2008RX350 worth it?
- Torque Master spark plugs for 2005 RX330
- Just ordered Red Line 0w-20 for daughter's RX
- Proud new Owner of an 05 RX330
- New member need help!
- replace cv joint?
- Anyone know what this dash light indicator is???
- Key case question
- 04 rx330 and 05 highlander timing belt question
- Has Anyone Tried Euro Oils in Their Lexus?
- Cross Border Warranty Questions (US-CAN)
- Transmission Pan Removal RX330
- 2008 Lexus RX 350 tailgate doesn't open
- new front brakes 08 fwd
- Crankshaft Pulley
- Touch up light gray leather?
- 2006 RX 330 headlights
- Lexus gremlins : volume knob and roof rubber strip
- 2004 RX330 suspension question
- Disable Seat Belt Alarm (2008)?
- source for EWD and Repair Manuals
- Passenger mirror tint?
- RX330, AWD/FWD & suspension component confusion...
- Power Window - one touch down stopped working!
- Tire pressure monitor sensor
- Noise Proofing
- Anyone Using Amsoil in Their RX's?
- Torn Armrest
- Best extended warranty that covers cars over 100k miles
- 07 Rx350 - Aux/iPhone Kit
- Clearcoat missing around roof rack mounts
- XM Radio
- Clock question
- Door doesn't unlock with electronic key?$700+
- Steering Headlights Issue
- Anyone know how to tell if your alternator is 100 Amp or 130 Amp?
- Who do you use to get parts?
- things if adjusted then cool for rx owners!!!!
- My Oil Analysis Sample Results
- Trans cooler air duct bracket - help!
- windshield Washer reservoir filter ??
- Dribbling Front Tires
- Engine cranks up but does not start
- 2007 RX 350 Interference Engine?
- Parents intrested in used RX350
- I'm glad I bought extended warranty
- Looking for RX330 r RX350 rims
- rear shock replacement Q
- 330 - p0300 random misfire
- Disable Steering Lock
- ABS and BRAKE Warning light on???
- RX330 shopping
- Front Lip Only decision
- Interior colors question
- About to Buy an 07 350 - Thoughts?
- Lexus Technology Specialists
- navigation and bluetooth
- Aftermarket Headlights Query
- rx350 door unlocking
- Recommendations on brake rotors and pads please
- Rx 400H Center Storage Console 'Open' Button Missing
- Lexus RX Dash Cupholder
- Jumped 2009 rx350 with jumpers on backwards!
- Key question?
- 2005 rx330-awd fuse boxes diagram request
- Oil change question
- 2009 RX350 Serpentine Belt Replacement
- Hi, new to the forums.
- new owner
- 2004 RX330 Speedometer Stuck
- I've had it!
- 2005 Rear Axle Assembly
- Changing battery
- Side mirror swap
- Hello All
- differences between 2004 and 2007 thru 09
- 2008 RX350 Side Mirror Paint Problem. What action to take
- DIY with Pictures RX330 License Plate LED Bulbs
- Mud Guards for RX350
- Towing package - Do I have it or not?
- Tips on buying a 04' rx330 over 80,000
- Part # for interior door handle? New here
- price to pay
- 2006 RX400h Aftermarket Stereo Installation
- Blown Fuse
- Levinson CD Player doesnt work
- 30k maintenance required ?
- Help please w/RX replacement parts
- Hybrid map disk
- Strange problem with power locks
- transmission drain and flush? 2008 RX
- headlight bulb replacement--is it easy?
- 4th Gen RX
- Bought 2009 RX 350... shipping experience included
- 2004 RX330 - Heater never worked
- Brake bolt stuck
- Need help with crankshaft pulley recall........
- Radiator Warranty Run Around
- Lexus has turned into a big disappointment
- Dead battery/locked out/need car seat!!!
- should i get a warranty?
- Wheel Bearing?
- Great news! My pulley failed!
- Braking issue
- Almost done
- How to handle the "maintenance push"
- DIY for 2004+ RX330 Dash Removal
- RX330 Transmission Thump
- fender bender.... RX400h front bumper on RX330??
- Rear Rubber Cargo Mat for 2008 RX
- RX330 vs. Hawk = need a replacement grille
- Really bad creaky door seals
- replacement headlights
- LED Sills for 2006 Lexus RX400h
- Front differential service interval?
- Considering buyin 2009 Rx 350
- Navigation problem
- High Flow/ Aftermarket Catalytic Converter
- Auxiliary cable in RX 350?
- Splitting Dashboard
- Loud A/C after Lexus service (pulley) - Help!
- Help needed identifying part no.
- Front Bumper Fasteners
- brake replacement from dealer
- Engine "Braking" Sensation
- Odometer cover
