- RX 330 2005 wheel swap
- Intermittent wipers not working after battery replacement
- water pump replacement 2009-RX-350
- Hood Insulation Pad, 07 RX
- 08 RX350 Shifter Bezel
- Constantly changing bulbs
- RX 400H All Check System Lights Illuminated -P0351 -P0356
- Best Treadlife Tires for RX330: Goodyear vs. Bridgestone vs. Michelin
- RX-330 Engine Noise
- Strange rattle. Cold Start. Changes with acceleration
- Goodbye to our RX
- 2008 RX350 A Pillar Water Leak
- Liqui moly MOS2 - moly additive. Does it help to reduce friction?
- My 05 lexus rx330 with 18% suntek carbon line window tint
- Right Side Vent/Cup Holder from Toyota Harrier?
- Trailer Hitches - Is there a nicer looking one for 2007 RX350? Factory one is Ugly
- A-pillar panel removal guide (my first one)
- Battery Recommendation
- Computer Multiplex network door
- 2005 passenger side cup holder
- RX Snow Drifting
- RX-350 Thermostat Replacement Help Plz!
- Need advice (dropping car) bigger rims
- Pricing: Used Car Dealer Has a 2006 RX 330 AWD 143K miles...
- Sewell Online Parts Closing March 1st, 2015
- 2008 Lexus rx350 headlight housing ?s
- 08 RX350 engine oil cooler pipe rupture.
- AWD vs 4WD - which is better?
- spark plugs
- Dog in back
- Quality OEM Parts Supplier
- Power steering issue
- Helpful tips regarding valve cover gaskets
- Automatic Folding Mirrors (using po-40 module)
- Water in Tail Light
- Bought 09 RX 350. Found scary service record. Please help decode.
- Strange random red car warning light on cluster?
- 2008 Rx350 with 80K miles
- Power Rear Door Opening Malfunction
- P0037 check engine and VSC light on
- 12 volt receptacle not working 2005 Lexus RX330
- Two EFI fuses on 09 RX350, which to reset transmission?
- Check Airconditioning message RX350
- Power Steering Fluid Cover Fastener DIY
- 2005 RX 330 Tow Harness
- RX 330 Remote Programming
- Wheel slippage when applying brake in snow
- squeal on cold starts
- 2008 RX350 iPhone 6 Integration
- Problem with my OBD
- Temporarily disable all horns
- Ideas for a Rain Sensor mod?
- HD Radio
- 2008 RX350 Bluetooth Hack Redux
- What is this part?? Pic- Rear Right Suspension
- RX400 Air Vents Won't Click Down
- Driving Lights
- Need Advice: 180k service plus extra
- Confussed
- '05/'06 RX 350 key
- Just Bought This
- 2007 RX 350 - Confirming Location of B1S1
- 2007 RX 350 AWD - Torque Converter Issues?
- Radiator Cap Assembly broken
- Boiling power steering fluid
- RX330 Rear Suspension Noise
- Maintenance stickers?
- Question on how to modify fog lights to stay on with high beams
- Michelin Latitude Tour or Goodyear Assurance TripleTread?
- Power Steering
- Power steering pump
- RX330 Wet Rear Carpet
- No alternators available in Canada for 2007 RX350
- How look tires 235/65/17 or 225/65/17 on RX2?
- New 04 RX330 to me
- ignition coil replacement
- Power steering fluid = ATF???
- Not so enjoyable trip with the RX
- Lexus Virgin buy 2008 400h what to look for?
- Need Help Buying a second-gen RX 350
- 08 RX 350 Misfire on Cylinders 4,5,6
- Need new rear struts, KYB?
- Oil leak peace of mind
- RX450h 40K Service - New Timing Belt and Water Pump?!
- AC/Heater makes "dust" smell
- 2004 RX330 Choppy/Harsh Ride
- Bluetooth and Phone Models
- Yellow Side View mirrors
- 2006 RX 400h thermostat replacement
- Anyone explain ECT SNOW button/functionality?
- 16" rim and tire Winter set up?
- 05 rx330 sunroof open and closed button weird..
- Engine Light, VSC and Traction Lights
- Throttle body cleaning
- Used 2004 Lexus RX 330 a few questions
- Chirping noise....
- Clearing P0420 or P0430 Codes using Lacquer Thinner
- Lets Talk Coolant
- Slight Power Steering Sqeek
- Considering purchasing a 2006 rx330 with 100K miles on it
- Steering gear replacement help
- Rim positive offset
- rx 330 rear hatch won't open
- Power Steering Leak
- mud guard for unpaved road?
- Center Console Doors not work
- 2008 RX350 power tailgate issue
- I am looking for help with my anti theft system..
- Tailgate opens then closes
- pinout ecu 1mzfe 204 hp
- Impossible to align the wheels?
- Sun Visor problem 2004 Rx330
- Anyone Put H9 bulbs in their halogen low beams?
- Am I being taken? What should brake and rotor replacement cost?
- Catalytic Convertor
- Front Liner partially destroyed
- Aftermarket forward collision warning (Mobileye)
- 05 rx330 afs light
- off idle system too lean. LTFT AT 29 OFF IDLE
- Raining Sensing Button on inside of Windshield ?
- Possible Overheating issue
- Blown fuse
- Battery Size?
- Need rear brake pads P/N
- How to remove the stereo from a 2009 RX350 sports luxury
- 2009 RX350 Brake light on dash randomly comes on
- RX350 steering wheel vibrates after steering work
- Timing belt question
- Struts? Lexus or Aftermarket?
- pulsation while braking, sometimes.
- Compass Mirror Acting Weird
- Snow tires for RX
- Part number for '06 RX400h 3-button remote key
- Melting dash or door panels on your RX?? No problem Lexus is replacing it!!
- No Power at all
- RX400h transmission/engine vibration
- RX330 Weird rear caliper issue
- Help please!! Lexus rx330 power steering hose!
- Tow package
- Power mirror question
- Airbag lights comes on intermittently
- I need a trickle charger for the car...
- Ever heard of lifetime oil filters
- Coin Holder (where to get one)
- Steering/Vehicle vibration @75mph
- Just Purchased '04 RX330 - Goals: Subtly Unique and Reliable!
- '04 RX white spots on steering wheel
- Need replacement luggage cover
- Best place to get toyota emblems for front and back?
- RX350 AWD 2007 Traction control engaging when not needed
- Phoenix area services prices!!!
- dipstick reading ??
- RX 330 Power Issue After Replacing Junction Block
- Rear End Clunk
- 08 RX350 coolant change?
- Car ad slamming the RX?
- Headlight leveling warning light
- differences between 04-06 &07-09 wheels
- Rear Liftgate opening at different speeds
- 2010 rims on a 2004
- RX330 Suspension Mystery
- Question after tire install - tire sensor.
- Power Windows Question
- Struts- Replace 2 or 4
- My 2008 RX 350 - Definitely having concerns
- RX330 power steering rack bushings. Help.
- `09 RX350 Suddenly lots of fishy work needed
- Oil Cooler Pipe Repair and Reimbursement from Lexus
- 2004 RX330 stereo upgrade
- Michelin tires - which one?
- Passenger Heated seat not working
- 2005 RX330 P0420 Catalytic Converter?
- Port Plug Installation Location?
- '06 RX330 rear wiper blade not gripping well
- 2006 RX330 traction control does nothing but beep
- Who has had a water pump or timing belt go bad?
- Lift gate shock/strut repair
- 2004 RX 330 Loud humming sound
- Help! My cigarette lighter outlet keeps pulling out every time I use it.
- DIY door sill LED upgrade (Lots of Pics)
- Brake Rotors
- Sunroof randomly opening
- RX350 Headlight Poor Output
- Which one do I trust?
- Any issues with 0W-20?
- tow hitch for RX400h
- Looking to buy a used rx
- 3.3L Broken timing belt teachable moment
- The same old tire questions 2008 RX
- Stereo System Problem - Radio Frequency Changes by itself
- 2008 RX 350 Extended Warranty Expiring
- Remote Start for 2007 RX350
- Moving on up...
- interior lights dont turn off
- 2007 RX 350 Misfiring and Wind Noise Coming from Engine
- RX350 Phone Contacts Setup
- Rx330 hwy ride quality
- Loud Rear Wheel
- Spare Tire Carrier Repair Corrosion
- How to remove front seat rear panel???
- Hanging from bottom of car (2004 RX 330)
- 90k service: would you change the water pump?
- Coolant leaking! Don't know where its coming from
- 2009RX-350 AWD,90K..radio antenna
- 2004 RX with 68K miles or 2009 RX with 93K miles?
- Nav Screen Dark
- 2007 RX350 Driver Side noise rattle over 50 mph
- Radio/CD sound not working
- Replacement headlight bulb for RX330 above DRLs?
- What's the fastest you ever gone in your RX?
- RX incompatible with Chamberlain Garage
- Another brake light switch dash lights question
- Rear Lip - Who makes this
- Cargo Door
- ?? DVD Navigation purchase & update DIY
- Vibration at freeway speed…..pull over to the shoulder, place car in park, then back
- My engine survived 15-20k mile oil change intervals w pics
- How Long Have Your Tire Pressure Sensors Lasted?
- Curb Check
- My RX 2006 model approached its 8th year
- 2005 RX330 height sensors problem
- Need help to resolve Cold Start Problem
- Input on GY Tripletred and Conti PureContact
- Disassemble 2004 RX330/Damage
- Intermittent Cruise Control
- RX330 Passive Alarm Issue Q?
- 15 L/100 km / 15.68 MPG
- Will 3rd Gen RX 2010+ Cargo Cover fit 2nd Gen 2004-09?
- somewhat urgent question about tires 2008 RX350
- How many belts are in a 2004 RX330?
- Noise when braking (Squishy too)
- Will 3rd Gen floor mat fit in 2nd Gen?
- Rx350 2007 navigation screen dead
- Help me decide
- Engine block heater
- 4G Bluetooth compatibility with 2006 RX 400H
- RX330 Aftermarket Radio TYTO-01
- Replace your rear knuckle bushings with NEW OEM Bushings/Spherical Bearings
- Keyless Entry Remote Buying Options?
- Will Lexus fix this or will I have to pay for one??
- My console lid is stuck half way!
- Question about rearview mirror and rain-sensing...
- transmission flush
- Best way to adjust HID low beams separately from high beams on RX
- Lexus Logo on Carpets Falling Off
- clean fuel injection system service
- Crack developing in dash
- Just got remote start installed. Quick issue
- Dud Key?
