- Need help buying RX330
- 2008 Lexus RX350 Spoiler Leak
- AC charge/pressures question for you guys
- Removal of driver side kick panel
- Fog Lights
- 07 rx350 codes B0100 & B1180
- 04 rx330 cracked dash - free repair? Anyone confirmed?
- Warning lights glitch?
- Oxygen Heater Control Circuit Bank 1, Sensor 2
- Rattle from front underside when taking off
- Ignition Cranks but not starting
- Fit over mirror replacements - pics included
- 2004 RX 330 Rear Wheel Bearing Type Noise
- 04 RX at 88,888 miles
- Vibrating steering wheel while braking at high speed
- RX350 Spark Plug Replacement Guide
- Electric problem following botched radar wire tap
- GF's 2005 RX Broken Into - Some quick questions
- When are cooling fans supposed to work?
- 2009 RX low pressure port location
- 2007 RX Timing Belt Casing Oil Leak
- Low oil light on RX, easy to repair?
- lexuspartsnow.com
- Engine running worse after spark plug change
- Old member - Need help with a link to OEM Front Rotors at a good price :)
- O2 Sensor questions
- Big brake kits?
- Foam in the in-cabin air filter
- RX330 Tail light socket melted
- Annoying gas door problem
- Timing Belt Question
- air suspension issues AGAIN!!!!!
- Dangerous info?
- My steering rack replacement story
- Easist way to improve handling? RX400h
- Aftermarket Rim Width And Offset Question
- Strange Intermittent Noise (2008 RX350)
- Checking Front Differential Fluid Level
- Third Party Financing for an 11 yr old RX?
- Ac issue
- Which Gear Oil for Transfer Case and Rear Diff Oil Change?
- Used RXs with 76,000 miles
- Sprained Metal Spring Clips That Hold D2S Bulb in Place
- Outside Mirror Tilt Adjustment '06 RX330
- help needed to identify rear door weatherstripping
- After Market Stereo
- Cargo Cover Issue 2008 RX350 - Won't Stay Closed
- 2006 RX330 Bad O2 Sensor
- Throwing money at my problems...
- I've never had this much trouble buying tires
- K&N 33-2260 air filter install problem
- Failed transmission
- Led bulb fell inside headlight housing
- Clunk noise from the rear during slow speed
- Pcv change glad i did again!
- RX 330 has clicking sound in driver's dashboard
- Security light problem
- RX330 - What type of Rotor (Cyro, Slotted, and/or Drilled)
- RX350 control arm bushes
- RX330 Loud Growling Noise on Quick Acceleration - Any Ideas?
- FS goes in classifieds only
- Lexus rx330 making a thump from rear on left turn from stop
- Intersection guidance screen
- 04 RX330 AC working only at LO setting
- A/C Charge Port Caps
- Rx330 AC working only on LO..
- Install after market amplifier power wire?
- '06 330 Sunroof switch works but note one-touch feature
- '06 330 - Can get Galaxy S5 to connect to bluetooth
- '06 330 Just bought Service Recs say failed alignment/ Shakes when braking at 60 MPH
- 2006 RX330 OCV(VVT) Solenoid and Strainer preventive maintenance
- 2006 RX330 AWD Rear Spark Plug Replacement
- 2006 RX330 Transfer Case & Rear Differential Oil Change
- RX330 RX350 Trailer Wiring
- 2004 RX 330 Transmission Problems?
- 08 RX400h wheel replacement, color problems!!!
- Replacing the shift indicator plate cover?
- Centric premium rotors vs "oem"?
- Drivers Side Outside Mirror Repair Question
- 2008 RX350 problems! Need help
- Check engine + VSC and now tranny slip
- The death rattle
- RX350 Tow Package question
- isf brakes on a rx400h?
- 2004 RX 330 rear door won't latch
- How can I tell if my '06 RX330 has Adaptive Cruise? I need bumper covers (front/rear)
- Good Price?
- RX330 Manifold Coolant Leak
- Auto mode for HVAC system
- Rear brake rotor won't come off
- 2004 RX330 fuel door wont open
- tech notes or illustrated diagram on rebuilding rack and pinion 06' rx330
- 2008 RX350 final went
- Repair ripped dashboard leather
- Install Eagle Eye After Market Tail Lights
- 2006 RX330 Water in Floor
- Looking at a one owner clean car fax 2004 RX330
- 2007 RX350 Serpentine Replacement - Anyone Tried it?
- Low pressure AC location for 134a
- Radiator replacement question
- Changing from beep to horn when locking
- 08 low mileage or 10 rx350?
- New Tire Suggestions
- What are these spaces for in other trim levels
- Serious dilemma about my RX. Need some advice.
- Trailer wiring
- Current drain of 850ma at battery -remove #26(ECU-B0 & #68(Power) goes to 0
- extended warranty past 125k
- 04 RX330 - passenger mirror replacement options?
- Question about differences in door mirrors
- RX350 or 330......or MDX
- Suspension strut mystery
- Timing belt/water pump disaster
- 2008 RX350 having engine movement
- 2004 RX330 key cracked..
- Rx330 elextrical problem
- Buying an RX400h
- Best place to tap in for adding LED lights
- Saying goodbye, but I'll be on 3rd generation forum
- rx330 turns over but wont start
- Tail Light relay
- Headlight, AFS Off & Bearing Noise
- Code P0430 & O2 sensor help
- rx330 power window and power lock stop working
- RX330 - Lost original key and remote
- Window Side-view Mirror Trim(?) WRINKLE
- Servo AC mix location
- Daytime driving lights
- 2005 rx 330 headlight flickering then turn off after 5-10 seconds
- DVD to Navigation Screen Hack
- Radiator DIY?
- Rolled over, no airbag deployed
- 2006 400H -- Should rear door open automatically after pressing rear manual button?
- Static/draft heard at higher speeds
- Steering/suspension questions
- 07 RX 350 doesn't turn over
- Service 140000km (~87000 miles)
- New iPhone Aux installed now no power to rear hatch
- RX330 Rear Passenger side Glass Replacement
- Brake problem, after oil change and spark plug maintenance
- What adhesive for rain detector?
- Rattling noise from rear power door mechanism
- shock conversion
- Door is permanently LOCKED!
- Expanded comments on service at Lexus Drivers
- RX 330 air suspension
- 2008 Buying Considerations
- E85 Conversion?
- Misfire help
- Fog Light issue, fuse is fine, wiring issue?
- Aftermarket windshield wipers
- Chime when installing/removing key
- HID headlight assemly
- lexus tow package questions!
- intermittent front shimmy
- Question about console "adapter" or "organizer"
- RX400h Rattling when going up hill
- 2008 RX350 Actuator Motor - Which one to buy?
- Spark Plug Recommendations?
- Noob post, sat radio with ml
- rx400h rear problem
- NEW 2005 RX 2nd gen 330 350 400h Tail lights LED acrylic Tube
- Falken tires
- Just bought 08 rx350
- Costco battery?
- Gobi style
- 2009 RX350 oil cooler recall - did they change my oil?
- Lexus Rx 2008 chrome body side molding
- Dead Bug in Headlight housing of 05 RX330
- Service manual to replace steering rack assembly.
- Air Filter Message at Start up question ??
- Rear wheel hub bearing removal TIPS RX330 fwd
- Anyone using dash pod speakers in their RX?
- RX 350 oil filter demolished
- DIY Engine Air Filter Replacement
- Think about Trade in my 05 RX330
- 2007-2009 - RX 350 Gas Milage Highway Poll
- Just bought radio upgrade
- Transmission Fluid Level
- How Remove 2008 RX350 front right door panel on
- RX330 Power Steering Reservoir hose replacement
- 2008 Rx400H radiator bottom mounting ?
- Bluetooth for Iphone 6+
- lexus roof top antenna is broken
- 2008 RX 350 overheats, burns engine, no alarm other than Engine Check
- RX 330 Engine seems to stall
- 2007 RX 350 - TRAC & VSC, ABS, BRAKE light fix
- Looking to buy an RX, what are the costs?
- 2006 RX330 - Window not working correctly
- Lower front power outlet not working
- OEM radio wiring help needed
- Cabin temperature... Help please
- Low/High beam headlights?
- 2004 Lexus RX 330 AWD TSC Beeping. HELP!
- RX330 Cabin Air Filter DIY?
- What does Certified Preowned PDI mean?
- Intermitent A/C
- Squeaky Steering Wheel
- Outside Temp Reading "Sluggish"
- Back-up Camera Video is Bad!
- Cooper CS3 Touring
- Items covered in Warranty Enhancement Program
- 2007 RX 350 code P0051 Sensor Locations
- Brake Pads?
- AFS light driving me crazy
- Rear wiper
- OEM carpet cargo mat- standard or accessory?
- RX 350 limited slipdiff??
- How reliable are higher mile RX's?
- Sunroof issues
- Rx330 rear door issue. Sometimes it works, sometimes it doesn't
- Side view mirror with or without memory
- 06 Radio problem
- How do I determine if I have HID or Halogen headlights
- Newbie needs new tires. Check my choices please.
- 10mm screws for undertray
- No heat on driver side - Can't adjust temp on driver side
- Brake issue
- Strange problem after alarm autostart install. Extremely weird..
- RX330 V-Bank Cover Bolts
- 2007 RX 350 - TRAC & VSC, ABS, BRAKE LIGHT come on intermediately
- Fault code P2197
- 07 RX350 cd stucks in cd player
- Water pump or...?
- Looking To Purchase RX 350 AWD - Need Advice!
- AFS flashing with both horizontal/vertical movement at init
- Lexus RX330 2005 Technology not working
- Remote Access Key Not Working
- Oily bolt on end of transmission case
- New Headlights Have No Distance
- Click in steering wheel
- When do you need to replace rotors ...?
- Dash Rattle
- Lethargic L - R Outside Mirrors!!!
- Radiator leak 2004 RX
- My Rx 330 with Venza wheels
- Driver Side Mirror memory and auto dip problem
- Another tire question
- Please Can Someone Explaine Me These Error Codes?
- RX350 2007 133k miles,
- Long shift from 1st to 2nd
- RX330 or 300? Advice needed
- How much for prepurchase inspection by Lexus dealer
- RX330 - Bamboo Pearl paint cracking and falling off!
- 2005 lexus rx 330 left center roof molding help!!
- Door panel removal and side mirror replacement
- 2005 RX330 ignition programming problem
- Side Rearview Mirrors Not Keeping There Preset Memory
- Fried ECM-Damsel in distress!
