- 2005 RX330 p0158
- RX350 (2008) part name/number/description
- Fastener list for RX350 (2008)
- RX350 underseat sub (2008)
- Warning light for alternator??
- Replaced My Rear Wheel Bearing Today...
- window switch problem
- 2007 RX350 Nav Screen flickering problem and more
- Grinding noise that changes when the vehicle is shut off
- Pics of new subs, amps, and speakers
- Smog check
- Proper Amperage on Alternator for 2007 Lexus Rx 350
- Lexus rx 330 2004
- OEM rear struts, japan parts dif?
- Question for AWD...slide much?
- Failed smog test.
- Type 168 LED Bulbs?
- Which tires ride the smoothest and quietest?
- Lexus ES 330, year 2005
- Mystery drivetrain vibration
- Damaged Transmission
- Screw Housing fell under roof - Roof Rack Removed
- lexus rx 350 heater
- HD Radio
- Multiple codes but no symptoms? (P0031, P0351, P2195, P0172, P0175)
- Bodykit for RX 400h
- 2009 RX350 vibration & rumble
- 2006 400h bluetooth not pairing
- 2006 RX330: Experiencing Peculiar Overheating
- Replaced engine, won't start
- Rear Diff Leak
- Video of Aftermarket Stereo Install, USB Ports Added and Wired Mic into Light Dome
- Installed Aftermarket Stereo, Added USB Ports, Wired Mic to Light Dome-INSTALL VIDEO
- Tailgate Glass shattered
- where to buy reasonable oem brake pads and rotors for RX 350 ?
- //rx330 to rx400h look//
- I changed all fluid today, lesson and tips
- 10-11 MPG City?
- Valve Cover Gasket and What Else?
- Catalytic Converters
- '04 Transmission Issues
- Which RX 330 is the better bet?
- Life of TPMS sensor - fwiw
- A warning to those recently purchasing a 2nd gen RX
- A/C Amplifier change?
- 2005 RX330 Oxygen sensor went after oil change? Mechanic failure or actual failure
- Fluid Leak
- AC Evaporator Replacement cost 2004 RX330
- Blown fuse every time i replace interior lights with LED
- Undercarriage
- Wheeling bearing replacement question
- No DIY for thermostats replacement?
- Dealer installed new plugs now idling seems high
- Rattling noise sounds like it's coming from the dash
- Outer Tail Lights - Melted
- RPM question
- RX400H Taillights
- jayhawkgal
- 2005 LEXUS RX330 SRS light stays on
- differential fluid change
- MAF sensor
- 2009 Lexus RX350 - how difficult is it to replace Bank 2 O2 Sensors
- Transmission Fluid
- 2007 RX350 Coil Replacement bracket question
- antenn
- My paint is peeling badly on my 05 GX470, what should I do?
- How to Remove Oil Control valve
- Navigation Screen won't zoom out
- Power rear door attack!
- Switching out Nav unit
- RX330 codes P033 and C1223, CEL and VSC on
- OEM JDM Side Markers RX350
- playing music
- Navigation Screen/Buttons Fuse Problem
- 2ND Gen RX350 with aftermarket Camry mods
- Lost hose...safe?
- Fuse for power outlets
- Valve Cover Spark Plugs PCV Coil pack replacement Experience Buying Guide References
- Another DIY for Rear Brake Pad/Rotor Replacement
- Rear Brake Troubles
- Lexus Assembly Plant in Canada Video
- To much junk in the trunk!
- HELP. Valve cover Job question
- Steering gear RX-350
- Start 2007 RX350 From "Valet Key" - Possible?
- Power Steering flush
- Front drive shafts: OEM vs aftermarket
- leak fixed, now need drain hole cover replacement
- P0304 Code
- Manual operation of rear door
- Won't display POI icons
- struts for 2009 RX-350 AWD
- 2008 Lexus RX350 VSC ESC lights on ??
- Need help ! Climate control!
- fuel injector cleaner
- Video on remove dome light on RX 330
- spark plug replacement
- Silicon wiper blades
- What else to replace besides spark plugs
- Beeping sound when Auto is pushed (RX400H)
- Replacing Brake Pads and Calipers with Video
- Could spark plugs replacement lead to Valve Cover Gasket Replacement.
- RX330 Timing Belt
- exterior cleaning/waxing
- 2009 Rx-350 AWD interior cleaner
- Steering wheel vibrates on braking at low speed
- Tires - Need Suggestions Please
- gas mileage
- Best deals on TPMS sensors?
- Upgrade front sound interface in Lexus 2005 RX330
- question - AUX inside RX330 2005
- RX330 Remove Wiper Cowl
- Click noise driver seat
- Suspect transmission noise when early morning start up
- Spyder LED Tail lights on 2004 RX330
- Where on the engine is the engine code?
- cabin air filter replacement 2009 RX-350
- engine air filter RX-350 AWD
- Brakes and rotors
- Looking for that Needle in a Haystack
- Potential Buyer
- finally added an interface
- brake flush or drain and fill
- Running wire down the A pillars (07, RX350)
- Used 2005 RX330
- Did you reseal your half moon pieces during valve cover gasket replacement?
- Where to lubricate driver seat rails?
- '07 RX350 throwing codes, please help
- transmission oil leaking
- VSC + ABS + VSC Off lights after brake change
- Wichita, Ks Dealer Alternative
- RX350 Oil Pan
- Wires spliced into driver kickpanel harnes??
- No panic alarm or or lock chirp - new to me 2009 RX 350
- oil change synthetic blend
- Differential fluid change AWD
- New Owner - 2005 RX330
- Odd hatch indication
- 2008 Lexus RX350 front bumber cover.
- Need some help with a dash vent
- Transmission fluid
- RX330 Dash Speaker Removal
- spark plug tips
- 2004 RX330 front electric passenger seat
- Lexus & the Chicago Blackhawks Team Up
- 07 RX350 VSC Light and Check Engine Light
- High-powered LEDs for low beams?
- Recorded MP3 Files to play on older RX330 Cd Players
- Cup Holder Vent replacement (pics)
- Door Lock stuck after removal (video)
- Repainting window control Plastic (pics)
- Kensun HID conversion kit for high beams
- Stumped by hybrid
- 2004 RX 330 Rear DVD Remote Alternative
- RX350's- different in gas mileage btw '07 vs '08,-09??
- Crusing range
- RX 350 Tail Light Dismantling Help!
- Diesel guy looking at my first lexus
- LED Lighting Upgrades to the Exterior
- Reliability of "new" VVTi oil line hose
- Bad Smell - Find Source? 2005 RX 330
- Backup Camera
- Antislip Indicator and Wheel Shudder
- Should I Buy A RX??
- RX330 Network Door Multiplex
- 2007 RX 400h - Finding good places for service
- Replacing Inner Quarter Panels With Pics
- Spoiler Removal with pics
- 2008 Rx400h ML Center Dash Speaker Disconnect?
- New Radio in '05 RX330 with Mark Levinson & Nav
- How to open trunk lid with no battery?
- Radio/Nav Display works, no sound - which fuse?
- OEM Ignition Coil
- How to use iPod 30Pin Adapter BT dongle
- P0306 and VSC light fixed
- Bought another RX330!
- Have you cleaned behind your backseat ever?
- How old was your car when you started seeing oil seepage
- RX330 windows does not defog
- Noise after new brake install?
- O2 Sensor Help
- Need Help with removing VVT (OCV) on RX350
- Spark Plugs: when to replace on 3.3 engine
- Help instaling subs and amp
- Thermostat Housing Bolt Torque
- Looking for parts ID
- What tires are best for RX350
- New user asking for help!
- New member seeking a bit of guidance...
- Nav Question - Want Aftermarket Replacement
- Cassette Deck
- Rear Main Engine Seal
- 2008 Rx 350 Water Pump/A/C Compressor
- Disabling onboard computer's warning light after air suspention swap out
- Spongy Mushey Brake Pedal and finally a Resolution
- AFS Light Flashing?
- Broken Key FOB Shell- Repair Solution
- Water pump when to change 2008rx350
- RX330 gets carplay
- RX350 trany oil pan
- RX400h rear DVD stuck/won't eject
- Oil change blues
- Unusual rollover accident
- Do it yourself AC Condenser
- 2007 RX350 Heated Seats Wiring Loom
- When to replace struts
- New Owner - Some Questions....
- Interior Lighting
- Add Bluetooth on the cheap
- Check engine; VSC off indicator
- 2008 RX 350 rear door interior panels
- RX350 Rack and Pinion
- Wiper Cowl Pan Removal (Help)
- Air Suspension
- Any way to upgrade to Mark Levinson
- PLEASE HELP !!!! Error code P0051 (P/N needed)
- ML CD player frozen, radio does not pick up stations, tape deck works fine
- 2005 RX330 Radiator Hose Replacement
- Aftermarket back up camera
- In love with my new Lexus RX 330 is this normal?
- Heater/AC problems
- No audio sound
- Newbie looking to make a few upgrades, any recommendations? (Car Starter/Speaker/etc)
- 05 RX330 wheel shake and possible handling issue
- New to the forum
- Is this a good buy?
- How do I know if my car has air suspension and how can I make it corner better?
- Coverlay Dashboard Replacement
- Seat track 'end-caps' for front seats
- 1st GEN RX 300 Versus RX 330/350 - Former owner re shopping
- sticky driver seat
- No Heat at idle in winter and no AC in summer
- Stressed about possible 2008 Rx purchase
- DRL question
- Lexus rx300 2005 year remote not working
- Happy Holidays- Post your garage pics here
- Should I: Transmission, Differential Drain and Fill - 99k RX330
- What do you like and dislike about your RX?
- Which coolant to use?
- How do you mute the music/radio?
- New 400h owner questions- leather repair, gold plating, battery tender
- Washer Reservoir Replacement
- Interior Rear Quarter Panel Removal?
- Gearbox stuck
- Where do you place your smartphone GPS?
- 2009 w/90K miles - CV boot cracked
- E brake problem
- Opinion questions
- Bolt stuck in frame...how to get it out?
- New Bell Sound When Opening the Drivers Door
